Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP-4.5.1 profiling fails with CBE and log4j
TPTP-4.5.1 profiling fails with CBE and log4j [message #137812] Fri, 31 October 2008 11:09
Originally posted by: wrobinson.gsu.edu
I tried to profile a very simple program with CBE & log4j:
1. Select Instrument Collector, Common Base Event Analysis
2. Select 'output Common Base Event to Log Facility'
The error seems to occur when the Log4jLoggingOutputter is passed an CBE
event.
Exception in thread "main" java.lang.VerifyError: (class:
org/eclipse/tptp/monitoring/instrumentation/internal/cbe/mod el/Log4jLoggingOutputter,
method: output signature:
(Ljava/lang/String;Ljava/lang/String;Lorg/eclipse/hyades/log ging/events/cbe/CommonBaseEvent;)V)
Incompatible argument to function
org.eclipse.tptp.monitoring.instrumentation.internal.cbe.mod el.CbeUtility.getCbeOutputter(CbeUtility.java:59)
org.eclipse.tptp.monitoring.instrumentation.internal.cbe.mod el.CbeInstrument.init(CbeInstrument.java:63)
org.eclipse.tptp.monitoring.instrumentation.internal.cbe.mod el.CbeInstrument. <init>(CbeInstrument.java:54)
org.eclipse.tptp.monitoring.instrumentation.internal.cbe.mod el.CbeInstrument.getInstance(CbeInstrument.java:45)
at CbeProbe_probe$Probe_0._entry(CbeProbe_probe.java:29)
at org.reqmon.samples.tptp.simple.Main.main(Main.java)
Bug or user error?
Previous Topic:problem with installing the agent controlller
Next Topic:Problem with navigation from Object References view to source code for anonymous inner classes
Current Time: Mon Jul 14 02:56:38 EDT 2025
Powered by FUDForum. Page generated in 0.13929 seconds
