| Re: // Comments cause remainder of EGL document to be ignored [message #13505 is a reply to message #12793] |
Tue, 17 February 2009 10:20  |
Hi Steffen,
Still no luck with the SVN (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265156) but I noticed your
comment on the syntax for comments in EOL and EGL :)
In EOL, the syntax is -- for single line comments and -* *- for
multi-line comments. In EGL on the other hand, you can still comment out
individual EOL statements using the EOL comments but you can also
comment out entire EGL parts including both dynamic and static text
using [* *]. I'll add this to the book shortly.
Dimitris
Dimitris Kolovos wrote:
> Hi Steffen,
> Thanks for filing the bug report. This has now been fixed but I can't
> seem to be able to commit to the SVN at the moment. I'll let you know
> once I do.
> Cheers,
> Dimtiris
> Steffen Zschaler wrote:
>> Bug report filed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=265127
>> Steffen
>>> Hi,
>>> It seems that using // for line comments in EOL causes the remainder
>>> of an EGL file to be ignored from that position. This is an easy
>>> mistake to make, as the actual comment format is not document for EOL
>>> (or have I overlooked something?)
>>> Steffen
| Re: // Comments cause remainder of EGL document to be ignored [message #565379 is a reply to message #12662] |
Mon, 16 February 2009 11:28  |
Hi Steffen,
This should be indicated with an error marker in the editor... Could you
please file a bug report for this?
Dimitris
> It seems that using // for line comments in EOL causes the remainder of
> an EGL file to be ignored from that position. This is an easy mistake to
> make, as the actual comment format is not document for EOL (or have I
> Steffen
| Re: // Comments cause remainder of EGL document to be ignored [message #565493 is a reply to message #12706] |
Tue, 17 February 2009 07:00  |
Hi Steffen,
once I do.
Dimtiris
> Steffen
>> Steffen
| Re: // Comments cause remainder of EGL document to be ignored [message #565675 is a reply to message #12793] |
Hi Steffen,
Dimitris
> Hi Steffen,
> once I do.
> Cheers,
> Dimtiris
>> Steffen
>>> Hi,
>>> Steffen
FUDForum. Page generated in 0.04388 seconds
