Home » Archived » COSMOS » How or Where can I get an SML-IF file
How or Where can I get an SML-IF file [message #12632] Wed, 06 May 2009 07:13 Go to next message
I'm new to Eclipse COSMOS . Now I want to know well about SML . So I need to
import an SML file . The problem is that I'm not able to find one.
I'm very glad if somenoe could help.
Thank you!
Re: How or Where can I get an SML-IF file [message #12672 is a reply to message #12632] Thu, 07 May 2009 17:28 Go to previous messageGo to next message
> Thank you!
Hi Jennifer,
There are some available in the org.eclipse.cosmos.validation.tests
project found in the CVS repository. Also, you can create one by
selecting File -> New -> Other... -> SML-IF File from within Eclipse,
though that still requires you have SML files to build up the SML-IF
file. You can probably find examples on the SML workgroup's web site as
well.
Let me know if you are still stuck and I'll give you more specifics.
Hope that helps,
David
Re: How or Where can I get an SML-IF file [message #12716 is a reply to message #12672] Sun, 10 May 2009 22:32 Go to previous messageGo to next message
Hi David:
Thank you for your reply .
I've studied on SML Version 1.1 and SML-IF Version 1.1 as well as COSMOS UG
& IG carefully , however , it is pity that I am still stuck . Following what
you told me , I've found some,but still have error when importing . It says
"...is not an SML-IF file" .
I am so worried . Would you give me more specifics please? Thank you very
much.
Jennifer
"David Whiteman" <david_whiteman@us.ibm.com> ????
news:gtvjpj$4vv$1@build.eclipse.org...
>> to import an SML file . The problem is that I'm not able to find one.
>> Thank you!
> Hi Jennifer,
> though that still requires you have SML files to build up the SML-IF file.
> You can probably find examples on the SML workgroup's web site as well.
> Hope that helps,
> David
Re: How or Where can I get an SML-IF file [message #12736 is a reply to message #12716] Mon, 11 May 2009 17:05 Go to previous messageGo to next message
Jennifer wrote:
> Hi David:
> much.
> Jennifer
Hi Jennifer,
Please also check out the document
http://wiki.eclipse.org/COSMOS_SML_Test_Plan . This gives a nice web
based interface to the SML-IF files we use to test the SML validator.
Can you please also email me the specific SML-IF file you were trying to
import? Maybe I can spot a problem with the file you are using.
Thanks!
David
Re: How or Where can I get an SML-IF file [message #12776 is a reply to message #12736] Mon, 11 May 2009 22:47 Go to previous messageGo to next message
Hi David,
Thank you very much . I've found the file I need .
But there are still some problems when I validate an SML-IF document as the
COSMOS user's guide tells .
The error discribes like this
"An internal error occurred during: "Validating...".
org/apache/xerces/xs/XSTypeDefinition . I search on the web but no related
solutions.
Besides, I used the SML-IF files before are from
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.cosmos/ tests/resource-modeling/org.eclipse.cosmos.rm.smlif.tests/te st-resources/TestSMLSample/acyclic/InValidCycles/?root=Techn ology_Project.
news:gua3vl$44p$1@build.eclipse.org...
> Jennifer wrote:
>> Hi David:
>> UG & IG carefully , however , it is pity that I am still stuck .
>> Following what you told me , I've found some,but still have error when
>> importing . It says "...is not an SML-IF file" .
>> much.
>> Jennifer
> Hi Jennifer,
> Thanks!
> David
Re: How or Where can I get an SML-IF file [message #12796 is a reply to message #12776] Mon, 11 May 2009 23:23 Go to previous messageGo to next message
Jennifer wrote:
> Hi David,
> solutions.
Jennifer,
Can you provide the version # of the COSMOS build you downloaded, your
JRE, the OS, and the Eclipse version please?
David
Re: How or Where can I get an SML-IF file [message #12816 is a reply to message #12796] Tue, 12 May 2009 07:58 Go to previous messageGo to next message
David,
COSMOS V1.0 , Eclipse 3.4 , JRE 1.7 , OS is Windows server 2003.
Thank you.
Jennifer
??????:guaq42$nrm$1@build.eclipse.org...
> Jennifer wrote:
>> Hi David,
>> the COSMOS user's guide tells .
>> related solutions.
> Jennifer,
> David
Re: How or Where can I get an SML-IF file [message #12836 is a reply to message #12816] Tue, 12 May 2009 10:55 Go to previous messageGo to next message
Jennifer wrote:
> David,
> Thank you.
> Jennifer
Hi Jennifer...
Please try the following step 6.2 if you are using a Sun JRE:
http://wiki.eclipse.org/COSMOS_SDK_Installation#Download_COS MOS_Build_and_Prerequisites
I believe this info is found in the COSMOS installation guide, but I'm
linking an old draft copy of it here for your convenience.
David
Re: How or Where can I get an SML-IF file [message #13446 is a reply to message #12836] Wed, 13 May 2009 23:13 Go to previous message
David,
Thank you very much for your help. The problem has been solved .
By the way, I scaned the COSMOS installation guide again , no such
instructions appear, only with "minimum IBM SDK 5.0 or Sun JRE 1.5.0_13"
requirement.
Jennifer
news:guc2lm$4qf$1@build.eclipse.org...
> Jennifer wrote:
>> David,
>> Thank you.
>> Jennifer
> Hi Jennifer...
> David
Re: How or Where can I get an SML-IF file [message #572693 is a reply to message #12632] Thu, 07 May 2009 17:28 Go to previous message
> Thank you!
Hi Jennifer,
well.
Hope that helps,
David
Re: How or Where can I get an SML-IF file [message #572726 is a reply to message #12672] Sun, 10 May 2009 22:32 Go to previous message
Hi David:
much.
Jennifer
>> Thank you!
> Hi Jennifer,
> Hope that helps,
> David
Re: How or Where can I get an SML-IF file [message #572773 is a reply to message #12716] Mon, 11 May 2009 17:05 Go to previous message
Jennifer wrote:
> Hi David:
> much.
> Jennifer
Hi Jennifer,
Thanks!
David
Re: How or Where can I get an SML-IF file [message #572839 is a reply to message #12736] Mon, 11 May 2009 22:47 Go to previous message
Hi David,
solutions.
> Jennifer wrote:
>> Hi David:
>> much.
>> Jennifer
> Hi Jennifer,
> Thanks!
> David
Re: How or Where can I get an SML-IF file [message #572870 is a reply to message #12776] Mon, 11 May 2009 23:23 Go to previous message
Jennifer wrote:
> Hi David,
> solutions.
Jennifer,
David
Re: How or Where can I get an SML-IF file [message #572897 is a reply to message #12796] Tue, 12 May 2009 07:58 Go to previous message
David,
Thank you.
Jennifer
> Jennifer wrote:
>> Hi David,
>> related solutions.
> Jennifer,
> David
Re: How or Where can I get an SML-IF file [message #572933 is a reply to message #12816] Tue, 12 May 2009 10:55 Go to previous message
Jennifer wrote:
> David,
> Thank you.
> Jennifer
Hi Jennifer...
David
Re: How or Where can I get an SML-IF file [message #572960 is a reply to message #12836] Wed, 13 May 2009 23:13 Go to previous message
David,
requirement.
Jennifer
> Jennifer wrote:
>> David,
>> Thank you.
>> Jennifer
> Hi Jennifer...
> David
Previous Topic:COSMOS on macos
Next Topic:How to creating a Data Manager
Current Time: Tue Jul 15 16:17:29 EDT 2025
Powered by FUDForum. Page generated in 0.08533 seconds
