Home » Eclipse Projects » Plugin Development Environment (PDE) » CombinedWordRule and strange bugs in IPresentationReconciler
CombinedWordRule and strange bugs in IPresentationReconciler [message #12596] |
Tue, 15 July 2008 17:18  |
Originally posted by: richardepsilonhughes.gmail.com
As some of you probably remember, I'm working on a plugin for converting a
simple XML file describing features of a sourceViewerConfiguration such as
syntax coloration in to a complete editor plugin. I've gotten the first
bare bones of a plug-in working, and I've run in to a very strange bug
that I'm not sure how to fix.
I've set it up so that it reads an XML file, creates a formatting token
with a text attribute, and associates it with several keywords. Using a
CombinedWordRule and a RuleBasedScanner, it checks for those keywords and
highlights them with the text attribute defined in the formatting token.
HOWEVER. There is a problem.
I'm using a simple IWordDetector implementation that uses
Character.isLetter(c) for both isWordPart(char c) and isWordStart(char c).
Let's say one of the keywords is 'try', and I write the word 'country',
the word 'try', and the word 'tryouts'. In 'country' and 'try', the last
three letters (the 'try') will be highlighted. In 'tryouts', however, the
'try' will NOT be highlighted.
I don't know why this is. I suspect it's because the word is scanned from
each character in the word to the end of the word, so a word like country
appears as:
country
ountry
untry
ntry
try
while tryouts appears as
tryouts
ryouts
youts
However, I have no idea why it's happening NOW. I've created a text
editor, and I've given it a SourceViewerConfiguration, and it has a
RuleBasedPartitionScanner that does nothing and puts everyone in
IDocument.DEFAULT_CONTENT_TYPE, and a RuleBasedScanner with that single
CombinedWordRule. This is not a particularly complex arrangement, and it's
more or less, to the best of my knowledge, what goes on in the JDT, but
when I do it, it has this bug.
If you need to see the source code, I've uploaded it to a .zip for your
convenience. It's dependent on a xerces implementation, but you shouldn't
need to worry about that.
https://www.yousendit.com/download/TTdFZUNwYUlCSWV4dnc9PQ
Re: CombinedWordRule and strange bugs in IPresentationReconciler [message #13541 is a reply to message #12596] |
Mon, 21 July 2008 17:19  |
> appears as:
> country
> ountry
> untry
> ntry
> try
> tryouts
> ryouts
> youts
I've found a solution (though probably not THE solution) to my problem. I
altered the WordRule's evaluate(ICharacterScanner scanner) method so that
it checks to make sure that the character immediately prior in the
ICharacterScanner is not potentially part of a word via unread() and an
if-this-then-return.
Using WordRule does not fix it. [message #573383 is a reply to message #12596] |
Thu, 17 July 2008 16:55  |
I've rebuilt the code, and I'm getting the same results regardless of
whether I use CombinedWordRule or WordRule.
Let me narrow the question: Does anyone have experience with
RuleBasedScanners that include WordRule or CombinedWordRule? Has anyone
experienced a similar problem?
Alternately, can anyone suggest another possible place I can look for
advice?
Re: Does anyone have experience with this? [message #573665 is a reply to message #12798] |
Mon, 21 July 2008 09:06  |
> I truly need something - I don't need a solution, but I need some idea
> where to look for one.
Um, what? I only see the subject and the sentence above.
Please, always quote when replying to a message, so the rest of us see
the context of a thread.
Eric
Re: Does anyone have experience with this? [message #573697 is a reply to message #13498] |
Mon, 21 July 2008 12:13  |
> Eric
Sorry, Eric. I'm still trying to solve the problem described at the
beginning of the thread. :(
I'm trying to see if I can solve it by adding a WhitespaceRule and/or
using setDefaultReturnToken(Token token) to set a default return token for
the rulescanner.
Re: CombinedWordRule and strange bugs in IPresentationReconciler [message #573755 is a reply to message #12596] |
> appears as:
> country
> ountry
> untry
> ntry
> try
> tryouts
> ryouts
> youts
Current Time: Sat Jul 12 16:26:13 EDT 2025
Powered by FUDForum. Page generated in 0.07365 seconds
