Home » Modeling » GMF (Graphical Modeling Framework) » org.eclipse.gmf.graphdef.editor
org.eclipse.gmf.graphdef.editor [message #136936] Mon, 18 June 2007 09:00 Go to next message
Originally posted by: prodanov.tk.informatik.tu-darmstadt.de
Hello everyone,
In the article "GMF Propsheet Customization" it's mensioned that the plug
in "org.eclipse.gmf.graphdef.editor" have to be used. I want to aks, where
ist the Metamodel - gmfui.genmodel(mensioned in the article)? and
which(and where) is the last version of the plug-in
"org.eclipse.gmf.graphdef.editor"? As you can see, I'm pretty confused:)
about this article but I really need to do my Property Sheet well. So if
someone has any idea with where can I find the gmfui.genmodel in the
"org.eclipse.gmf.graphdef.editor" plug-in, please tell me.
Thanks in advance!
Buy
Re: org.eclipse.gmf.graphdef.editor [message #136946 is a reply to message #136936] Mon, 18 June 2007 09:40 Go to previous messageGo to next message
Originally posted by: Halimatou.Pouye-Diaw.thomson.net
Hi, everybody
I have got the same problem. I would like to add some specific properties,
and I am confused with the article GMF Propsheet Customization. I use GMF
1.0.3, and I can't see the Property Sheet node under the generator model
Gen Editor Generator. Does it exist for the GMF 1.0.3?
Thanks for any hint.
Halimatou.
Re: org.eclipse.gmf.graphdef.editor [message #136969 is a reply to message #136946] Mon, 18 June 2007 09:52 Go to previous messageGo to next message
Hi Halimatou,
I think that this funcionality(in the .gmfgen)is not in 1.03 available
Martin
Re: org.eclipse.gmf.graphdef.editor [message #137017 is a reply to message #136969] Mon, 18 June 2007 10:09 Go to previous messageGo to next message
May be, you're right Martin. I still hoped because it isn't mentioned
nowhere. I should use the last stable release.
I think, if you have want to add some specific properties, you are not
obliged to use the genmodel, it is just if you want to retrieve the
tutorial example.
Halimatou.
Re: org.eclipse.gmf.graphdef.editor [message #137082 is a reply to message #136936] Mon, 18 June 2007 11:21 Go to previous message
gmfui model is part of contribution attached to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192711. Unfortunately, it
won't get into GMF 2.0, you can either stick to older propsheet.ecore model
or to use patch from bugzilla.
Artem
"Martin Prodanov" <prodanov@tk.informatik.tu-darmstadt.de> wrote in message
news:603d75241b14a2a756021719f4df4acb$1@www.eclipse.org...
> Hello everyone,
> Thanks in advance!
> Buy
Previous Topic:connecting lines in different levels of the semantic model
Next Topic:Compartment
Current Time: Wed Nov 26 13:48:02 EST 2025
Powered by FUDForum. Page generated in 0.03747 seconds
