Home » Archived » BIRT » change language
change language [message #136893] Tue, 28 February 2006 05:40 Go to next message
Can the language of the report designer gui be changed? In my case it is
german by default. It is often difficult to discuss about BIRT
features without knowing the english naming.
Paul
Re: change language [message #137028 is a reply to message #136893] Tue, 28 February 2006 11:04 Go to previous messageGo to next message
Paul,
If you're using windows XP, go to the control panel and then into "Regional
and Language Options" (or whatever that would be in German). From there,
you should be able to choose English (United States). This doesn't seem to
work perfectly, but it enables a little icon on the right of your toolbar
that you can use to switch between English and German. Just make sure it is
set to English before you open BIRT.
I think that should work. I think I remember that Windows 2000 has a very
similar function, too.
--floor
"Paul Ziemann" <p.ziemann@interwall.net> wrote in message
news:va91ud.m08.ln@igate28.intern.neusta.de...
> german by default. It is often difficult to discuss about BIRT features
> Paul
Re: change language [message #137586 is a reply to message #137028] Wed, 01 March 2006 10:34 Go to previous messageGo to next message
I already tried that but BIRTs language isn't affected by this (under
Windows 2000).
Paul
floor schrieb:
> Paul,
> --floor
>>Paul
Re: change language [message #138919 is a reply to message #137586] Fri, 03 March 2006 10:38 Go to previous messageGo to next message
hi...yes u can:
i'm using myeclips which is pretty the same as eclipse.
so, from eclipse: windows->preferences->BIRT->Preview->Choose your locale
cheers,
Cristian
Re: change language [message #139447 is a reply to message #138919] Mon, 06 March 2006 02:58 Go to previous messageGo to next message
Does not work :-(
Re: change language [message #141343 is a reply to message #138919] Wed, 08 March 2006 04:41 Go to previous message
can someone from BIRT team please help for this case?
Thanks a lot!
Previous Topic:Birt integration with Struts
Next Topic:DHTML Support
Current Time: Fri Nov 07 22:13:58 EST 2025
Powered by FUDForum. Page generated in 0.04373 seconds
