Home » Archived » BIRT » bottom border in table header
bottom border in table header [message #136879] Tue, 28 February 2006 05:17 Go to next message
I put a border at the bottom of all the cells in a table header row to
have an underlined header. For some reason, this border is only
displayed on the first pdf page unless I add a second header row under
the original.
Paul
Re: bottom border in table header [message #137040 is a reply to message #136879] Tue, 28 February 2006 11:09 Go to previous messageGo to next message
That seems pretty strange. What if you put the underline at the baseline of
the text/data boxes instead of the cells themselves?
--floor
"Paul Ziemann" <p.ziemann@interwall.net> wrote in message
news:lv71ud.pk7.ln@igate28.intern.neusta.de...
>I put a border at the bottom of all the cells in a table header row to have
>an underlined header. For some reason, this border is only displayed on the
>first pdf page unless I add a second header row under the original.
> Paul
Re: bottom border in table header [message #137053 is a reply to message #136879] Tue, 28 February 2006 12:46 Go to previous messageGo to next message
Originally posted by: service.altekweb.com
Hello Paul,
Had the same problem. Select header row, insert new row below, adj that
row to hight you want example 10pix. Then the line in the above header
row will show on all pages. Plus having another header row below the
spacing between the header and the data can be achieved.
Hope this helps.
Bo
> the original.
> Paul
Re: bottom border in table header [message #137609 is a reply to message #137040] Wed, 01 March 2006 10:43 Go to previous messageGo to next message
When I do this, the underline is displayed on every page. Anyway, the
issue is not so critical because a second (possibly empty) header row
seems to fix it.
Paul
> --floor
>>Paul
Re: bottom border in table header [message #1798651 is a reply to message #137053] Thu, 22 November 2018 00:33 Go to previous message
Thanks for that. Even I got the same problem. But now issue is fixed
Previous Topic:"dataSetRow" is not defined
Next Topic:BIRT build fails
Current Time: Sat Jul 05 00:31:16 EDT 2025
Powered by FUDForum. Page generated in 0.02876 seconds
