Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Comparing models without resources
[EMF Compare] Comparing models without resources [message #136716] Sat, 23 May 2009 23:27 Go to next message
I wonder if it is at all possible to compare just two in-memory models with EMF Compare?
Regarding the API, it should be, since MatchService.doMatch takes EObjects and not Resources.
However, the match engine uses the resources (which are not set in the example below) to perform the comparison.
My use case is a comparison of partial models, i.e. the compared EObjects are contained in another, larger model.
For example, two sub-packages in a UML model.
Any suggestions and comments are appreciated.
Patrick
// this creates two simple EObjects for comparison, but a NullPointer is raised because the resources are not set
MatchService.doMatch(createDynamicObject("a"), createDynamicObject("b"), Collections.<String, Object> emptyMap());
/** Just to create a simple EObject just having a name. */
private EObject createDynamicObject(String name) {
// create the wrapper containment reference
final EAttribute attr = EcoreFactory.eINSTANCE.createEAttribute();
attr.setName("name");
attr.setEType(EcorePackage.Literals.ESTRING);
// create the wrapper class
final EClass namedClass = EcoreFactory.eINSTANCE.createEClass();
namedClass.setName("DynamicNamedElement");
namedClass.getEStructuralFeatures().add(attr);
// create a package for our wrapper class
final EPackage simplePackage = EcoreFactory.eINSTANCE.createEPackage();
simplePackage.setName("dynamic");
simplePackage.setNsPrefix("dynamic");
simplePackage.setNsURI("http://www.example.org/dynamic");
simplePackage.getEClassifiers().add(namedClass);
// validate what we just created
if (Diagnostician.INSTANCE.validate(simplePackage).getCode() == Diagnostic.OK) {
// instantiate our class, fill the children and return it
final EObject namedClassInstance = simplePackage.getEFactoryInstance().create(namedClass);
namedClassInstance.eSet(attr, name);
return namedClassInstance;
} else {
return null; // TODO: better error handling required here
Re: [EMF Compare] Comparing models without resources [message #136955 is a reply to message #136716] Thu, 04 June 2009 11:10 Go to previous messageGo to next message
--------------000704040904090303020207
Hi Patrick,
I'll simply quote the javadoc :
MatchService.doMatch : "Matches two models and returns the corresponding
matching model."
=> what is meant here is : regardless of the EObjects passed as
arguments, we'll compare their containing resources.
MatchService.doContentMatch : "Matches two objects along with their
content, then return the corresponding match model."
=> this is what you seek to do.
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Comparing models without resources [message #136991 is a reply to message #136955] Tue, 09 June 2009 04:20 Go to previous messageGo to next message
Thanks Laurent and forgive my blindness ;-)
On 04-06-2009 17:10, laurent Goubet wrote:
> Hi Patrick,
> matching model."
> Laurent Goubet
> Obeo
> Patrick Könemann a écrit :
>> Cheers,
>> with EMF Compare?
>> Patrick
>> Diagnostic.OK) {
>> } else {
Re: [EMF Compare] Comparing models without resources [message #137052 is a reply to message #136991] Tue, 09 June 2009 12:17 Go to previous message
--------------060905010900090007010000
Patrick,
Or the javadoc needs to be rewrote with a little less copy/pasting so
that people know it does contain interesting things to read :D.
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Comparing models without resources [message #620995 is a reply to message #136716] Thu, 04 June 2009 11:10 Go to previous message
Hi Patrick,
matching model."
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Comparing models without resources [message #620998 is a reply to message #136955] Tue, 09 June 2009 04:20 Go to previous message
> Hi Patrick,
> matching model."
> Laurent Goubet
> Obeo
>> Cheers,
>> with EMF Compare?
>> Patrick
>> Diagnostic.OK) {
>> } else {
Re: [EMF Compare] Comparing models without resources [message #621003 is a reply to message #136991] Tue, 09 June 2009 12:17 Go to previous message
Patrick,
Laurent Goubet
Obeo
Patrick K
Previous Topic:[Announce] EMFT MWE 0.7.0RC4 is available
Next Topic:Teneo 1.0.1 does not support Lazy-Loading of Many-to-One and One-to-One
Current Time: Wed Jul 09 22:52:17 EDT 2025
Powered by FUDForum. Page generated in 0.05596 seconds
