Home » Archived » Test and Performance Tools Platform (TPTP) » integrating tptp with my product.
integrating tptp with my product. [message #136706] |
Thu, 02 October 2008 19:32  |
I would like to integrate the tptp plugins into our product and then run
some tests cases. Is this possible? We are able to run the tests cases from
ant by adding our plugins to the eclipse environment.
It looks like
<property name="tptp.automation.eclipse" value="c:/tot/HyperAsic/src/ins
dows/x86/ourdirectory" /> expects to launch eclipse.
Matt
Re: integrating tptp with my product. [message #136812 is a reply to message #136789] |
Mon, 06 October 2008 06:49   |
Hi Matt,
Yes, the current architecture requires that Eclipse (or an Eclipse
application) be invoked by the eclipse.exe (Windows) executable. The
current architecture requires the path to the 'Eclipse home' directory,
which ASF locates the Eclipse executable. This mechanism would need to be
extended to handle the absolute path to the Eclipse executable.
Unfortunately, the current resources in the Test Tools Project preclude
us from providing this function. Would you or your company be willing to
contribute a tested patch?
Paul
"matt murphy" <murphy@coherentlogix.com> wrote in message
news:gc60nn$5f4$1@build.eclipse.org...
> Hi Paul,
> The problem is that we do not invoke eclipse.exe to run our application.
> We invoke A.exe. tptp.automation.eclipse property always appears to look
> for eclipse.exe. I want to run A.exe and run our tests cases from within
> this environment , not eclipse.exe. Is this possible? Do I have to rename
> our product from A.exe to eclipse.exe?
> thanks,
> matt
> "Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
> news:gc4tab$pel$1@build.eclipse.org...
>> Hi Matt,
>> It really depends on your product's dependencies. If they are the
>> same (Eclipse/EMF/XSD) including version as TPTP, then 'yes'.
>> When using ASF, the tptp.automation.eclipse property points to the
>> <Eclipse home directory>. For example:
>> D:\TPTP\45M8\eclipse[Source:
>> http://dev.eclipse.org/viewcvs/index.cgi/test-results/test/o rg.eclipse.hyades.test.core.services.tests/resources/Ant/bui ld.xml?root=TPTP_Project&view=log]
>> Paul
>> news:gc3lm3$c4b$1@build.eclipse.org...
>>> Hi,
>>> from ant by adding our plugins to the eclipse environment.
>>> It looks like
>>> Matt
Re: integrating tptp with my product. [message #136846 is a reply to message #136812] |
Mon, 06 October 2008 13:33   |
Hi Paul,
Any idea on the effort to do this?
thanks,
matt
news:gccqgo$gjp$1@build.eclipse.org...
> Hi Matt,
> Paul
>> Hi Paul,
>> thanks,
>> matt
>>> Hi Matt,
>>> Paul
>>>> Hi,
>>>> run some tests cases. Is this possible? We are able to run the tests
>>>> cases from ant by adding our plugins to the eclipse environment.
>>>> It looks like
>>>> Matt
Re: integrating tptp with my product. [message #136858 is a reply to message #136846] |
Tue, 07 October 2008 06:57  |
Hi Matt,
I would estimate ~4 PH (including writing test cases) for a developer
experienced with the code. Possibly double that estimate for a developer
looking at the code for the first time.
Paul
news:gcdjvs$p1i$1@build.eclipse.org...
> Hi Paul,
> thanks,
> matt
>> Hi Matt,
>> be extended to handle the absolute path to the Eclipse executable.
>> preclude us from providing this function. Would you or your company be
>> willing to contribute a tested patch?
>> Paul
>>> Hi Paul,
>>> look for eclipse.exe. I want to run A.exe and run our tests cases from
>>> within this environment , not eclipse.exe. Is this possible? Do I have
>>> to rename our product from A.exe to eclipse.exe?
>>> thanks,
>>> matt
>>>> Hi Matt,
>>>> Paul
>>>>> Hi,
>>>>> It looks like
>>>>> Matt
Current Time: Mon Jul 21 23:58:28 EDT 2025
Powered by FUDForum. Page generated in 0.25008 seconds
