Home » Language IDEs » Java Development Tools (JDT) » NO CODE TIPS IN ECLIPSE ?
NO CODE TIPS IN ECLIPSE ? [message #136379] Thu, 22 January 2004 07:07 Go to next message
Originally posted by: herberto.graca.hotpop.com
hi,
i used eclipse for the first time, one and half years ago, and i remember
that when i wrote somethig like:
someObject.
it came out a box telling me what methods are available for that object,
than when i cicle the methods, a description of the method used to pop up in
another box.
Well, now the description doesnt appear.
Any idea on how to get those descriptions to appear again?
tkx
Herberto Gra
Re: NO CODE TIPS IN ECLIPSE ? [message #136391 is a reply to message #136379] Thu, 22 January 2004 09:17 Go to previous messageGo to next message
Boneripper wrote:
> hi,
> someObject.
> another box.
This should work - you should probably file a bug report against
platform-text.
-tom
Re: NO CODE TIPS IN ECLIPSE ? [message #136414 is a reply to message #136379] Thu, 22 January 2004 09:27 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
The description appears only if you have sources attached to the jar which
defines the class. If you got no description for the core java classes you
probably use a jre not a jdk. Go to Preferences-->Java-->Installed JREs.
Edit the one you use and see whether there is source attached to the rt.jar.
If not, you have to attach src.zip to it.
HTH,
Csaba
"Boneripper" <herberto.graca@hotpop.com> wrote in message
news:buoeae$k6k$1@eclipse.org...
> hi,
> someObject.
in
> another box.
> tkx
> Herberto Gra
Re: NO CODE TIPS IN ECLIPSE ? [message #136459 is a reply to message #136379] Thu, 22 January 2004 10:49 Go to previous messageGo to next message
Originally posted by: eclipse-user.jibeinc.com
Boneripper wrote:
> hi,
> someObject.
> another box.
The feature is called Code Assist.
Check your Preferences under Java > Editor > Code Assist and make sure
the Enable Auto Activation box is checked. If it is not, you'll have to
use Ctrl-Space to bring up the help box in code.
Note: this is for Eclipse 2.1 - the preferences location might have
changed for 3.0
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: NO CODE TIPS IN ECLIPSE ? [message #136575 is a reply to message #136379] Thu, 22 January 2004 15:36 Go to previous message
Mr Horv
Previous Topic:Java files structure and resolving classes
Next Topic:Incorrect JRE system libraries list
Current Time: Sat Nov 08 23:35:52 EST 2025
Powered by FUDForum. Page generated in 0.03275 seconds
