Home » Archived » Visual Editor (VE) » No SWT Controls on palette
No SWT Controls on palette [message #136350] Fri, 09 March 2007 19:42 Go to next message
Originally posted by: scott.softwareassist.net
I recently installed VE and SWT in my Eclipse environment but the VE
palette only shows Swing and AWT controls. Does anyone have an idea where
I need to "tweak" the configuration so they will show up?
Thanks in advance for any help.
Re: No SWT Controls on palette [message #136386 is a reply to message #136350] Tue, 13 March 2007 15:40 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Go to New->Visual Class and select an SWT style and SWT class from the
Tree. This will make sure the classpath is setup correctly for SWT.
> where I need to "tweak" the configuration so they will show up?
Rich Kulp
Re: No SWT Controls on palette [message #136504 is a reply to message #136386] Thu, 15 March 2007 13:26 Go to previous messageGo to next message
I must have some incorrect setting(s). When I do a "New", I don't see
Visual Class as an option.
Re: No SWT Controls on palette [message #136514 is a reply to message #136504] Thu, 15 March 2007 17:37 Go to previous messageGo to next message
Then you have a configuration problem.
The best way to install is using the update manager.
1) Get an Eclipse 3.2.2 SDK zip.
2) Unzip it.
3) Open Eclipse up, and use Help->Manage Configurations->Find and
Install new features.
4) Select the "Callisto" site, and hit next.
5) Expand and Select VE Runtime (or SDK), and then hit the "Add Required
...." button.
6) Hit install and install everything.
Rich Kulp
Re: No SWT Controls on palette [message #136726 is a reply to message #136514] Wed, 21 March 2007 17:56 Go to previous messageGo to next message
Thank you for the advice. I installed a brand new version of Eclipse 3.2.2
and installed VE using the steps you suggested. VE is working fine but I
still do not see any SWT Widgets on the VE palette. All I see are tabs for
Swing and AWT Widgets.
I have SWT installed in the plugins folder and am able to write and run
SWT applications where I build the UI "by hand".
Is there anything special I need to do th get VE to offer SWT Widgets in
its palette? What mechanism makes VE aware of the SWT Widgets so that it
will add them to its palette?
Scott
Re: No SWT Controls on palette [message #136738 is a reply to message #136726] Wed, 21 March 2007 20:12 Go to previous messageGo to next message
Try using the New Visual Class wizard and select an SWT style and
control from the style tree. This will make sure your project is setup
correctly. Just having a project doesn't make it able to have SWT. You
have to tell it that the project has SWT available to it, until then no
SWT palette will show up. The New Visual Class wizard makes sure it is
set up correctly.
> 3.2.2 and installed VE using the steps you suggested. VE is working fine
> but I still do not see any SWT Widgets on the VE palette. All I see are
> tabs for Swing and AWT Widgets.
> Scott
Rich Kulp
Re: No SWT Controls on palette [message #136874 is a reply to message #136738] Mon, 26 March 2007 13:20 Go to previous messageGo to next message
The style tree has only 2 entries under SWT (Composite and Shell). Is that
how it is supposed to be?
The Style box has nodes RCP, SWT, Swing, AWT and Other. Swing and AWT each
have a number of objects underneath them but SWT only has Composite and
Shell. I tried creating a form using Shell and there are no SWT components
in the pallette. Same when I tried Composite.
Re: No SWT Controls on palette [message #136885 is a reply to message #136874] Mon, 26 March 2007 13:29 Go to previous messageGo to next message
Yes, under SWT there is only Composite and Shell. Use one of those in
the New Visual Class Wizard to create an SWT class.
> that how it is supposed to be?
> each have a number of objects underneath them but SWT only has Composite
> and Shell. I tried creating a form using Shell and there are no SWT
> components in the pallette. Same when I tried Composite.
Rich Kulp
Re: No SWT Controls on palette [message #136897 is a reply to message #136885] Mon, 26 March 2007 13:54 Go to previous messageGo to next message
First, let me take a minute to thank you for the help you've given me with
this issue Rich. It is greatly appreciated. I would really like to use VE
to develop the GUI for my applicaiton because doing it "by hand".
although very instructive, is very slow.
It appears that the new visual class gets set up properly. The code that
is generated is shown below:
package ftprrtm;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
* @author HP_Administrator
public class Setup {
private Shell sShell = null;
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
sShell.setLayout(new GridLayout());
The palette still does not have any SWT controls on it. It has the
following categories:
Swing Components
Swing Containers
Swing Menus
AWT Controls
Where does the code that sets up the palette get the list of controls to
display?
Re: No SWT Controls on palette [message #136908 is a reply to message #136897] Mon, 26 March 2007 15:12 Go to previous messageGo to next message
I don't know what is going on. If you open the new Setup class itself
and there are no SWT stuff in the palette then there is something wrong.
I have no idea what.
The palette is a per-project entity. Only the project that the new Setup
class is in will show SWT controls. the other projects will not.
Look at the classpath for the project that Setup class was created in.
Is there a SWT Library (not the jar, but a specific JDT library called
SWT) in it? That is what is keyed off of. I
Rich Kulp
Re: No SWT Controls on palette [message #136919 is a reply to message #136908] Mon, 26 March 2007 20:52 Go to previous messageGo to next message
<Look at the classpath for the project that Setup class was created in. Is
there a SWT Library (not the jar, but a specific JDT library called SWT)
in it?>
I am not exactly sure what file this is supposed to be but I'll bet it is
the source of my problem. I am running on WIndows XP. Do you know what
file that would be? What file extension would it have (DLL, Zip)?
Scott
Re: No SWT Controls on palette [message #136945 is a reply to message #136919] Tue, 27 March 2007 09:21 Go to previous messageGo to next message
--------------080707010607010307000006
I've attached a picture of what it should look like.
> SWT) in it?>
> is the source of my problem. I am running on WIndows XP. Do you know
> what file that would be? What file extension would it have (DLL, Zip)?
> Scott
Rich Kulp
Content-Type: image/jpeg;
name="Snap2.jpg"
Content-Disposition: inline;
filename="Snap2.jpg"
/9j/4AAQSkZJRgABAAEAYABgAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5j LiBWMS4wMQD/
2wCEAAgGBgcGBQgHBwcKCQgKDRYODQwMDRsTFBAWIBwiIR8cHx4jKDMrIyYw Jh4fLD0tMDU2
OTo5Iis/Qz44QzM4OTcBCQoKDQsNGg4OGjckHyQ3Nzc3Nzc3Nzc3Nzc3Nzc3 Nzc3Nzc3Nzc3
Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//EAaIAAAEFAQEBAQEBAAAAAAAA AAABAgMEBQYH
CAkKCwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUE BAAAAX0BAgMA
BBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygp KjQ1Njc4OTpD
REVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaX mJmaoqOkpaan
qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T1 9vf4+foRAAIB
AgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1Lw FWJy0QoWJDTh
JfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2 d3h5eoKDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uLj5OXm
5+jp6vLz9PX29/j5+v/AABEIAlECfwMBEQACEQEDEQH/2gAMAwEAAhEDEQA/ APUNBTf4Y0Ie
T5uILc437QuFHzHkZA6471pi/wDeqn+J/mZ0P4UfRfkbFcZuUbPStPvb7UJb ixt5pVmUb3iD
H/Vp3NdFCpOMWr9f0RhVhGUlp0/zJNZ0rT/7Pmma0jLQwN0GPlHzAHHUblHB 9/euHG041pLS
7X5f8OdGHbpryJp4VuLeSFy4SRSpKOUYAjHDKQQfcHIrYRjeGPDj+HLSeKbW dR1WWaQt5t9c
NIVXJ2qATgYB5I6nnpgBt3EbMjbJYD6Of/QTVQ3Eyr9qlt4gFnAhj+UMVXjH HTdn9K2sSWIg
FmKA5CRIo/DNZVCkUNVxJcRW7SOqvDIyhZGQbgUxnHUcnjpWtCN0/l+pnUdm ilLAZLl7gLAs
jBxn5ONwI6+Xu7+tde6sZdbmnpjKftccbu0UUoRN8jOQNinqxJPJPWuKurNe n6s2pu6ZclGY
nG0tlT8oOCfxrBGoRLsgiTyxFtRRs3btvA4z3x603uIx/FUUzeH7x4ZsMsLq IGQMk7EYVD0b
JPC7SDkjr0pxdncmavFnG6leWEmnNaz20b6wMR3CSJmWabggFTy6MdpAxwNu AMDa7TjUSivd
+9Jfpb+tDgcuX/F+f+aZ3+krPHYJFcWzQSIcbWuWuM55yHb5j1xyByDjjBMs 9BaIzLTwsbXx
Zc62da1SWGVf3dhJdu0ETnO5gpPIIxhTwvOP4dpfSwzoaQzgfAl42hXOsyax MsaWyBW9dwYj
A9Saik1Bts8zDy5L83Qi0G6fVfG4urW0S1tQWk8tSeF2suT7ksOBxx7VlTUU 3yrQVGXPWXKt
DrfEeivr2izWMOpXmmzn5orq0laN42HQnBG5fVT19jgjpTsemW9MsF0vTbey S4ubgQrt866m
MsrnuWY9ST+A6AAYFIDE1vTriLxNp2vQxyzx2y7ZIYuWONxBA7/eqXpJSOWt GSmprVGFBql5
ceLhqWpbYZ1D7bdgyhAAAAcKW6PnOPyyucub3nJnVhMDWr/v56LotPNd0drp OqW+safFd254
ZRuXqUJAOM9+o5HFbJprQ2rUZUZ8sjMtPCxtfFlzrZ1rVJYZV/d2El27QROc 7mCk8gjGFPC8
4/h21fSxidDSGFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQBFbpsWX9 z5W6VjkvuL8D
5uvA7Y9qp7CK18F+26dvd/LaVkdAxCsNjNyB15UfrUtpQk3/AFqkVG7kkjFg hW9v7zUb23ur
9LqLyEUpFGqxhiR/y0yxz0bj1HrXbXoyq0VSSVvO/wDkctOUadRzk9TS0MhE uYDBJHIspd2f
YdxYk8lT97ABI7Z44xXI8OsPFRX9eZ0e09o7kevm5Emm+RcRQA3BBLxludjE HOR6H8x0xzhV
+E3o7v0OdVrqGLVZri8t5I4ZxKFWLDBlRSGU54I/Hv2OK55RjJcrR02u1Y7W ztksrOG2jVFW
NQMIMD3PU/zNdcYqC5Y7HC227swvE032TVNCu5wPsMVwROSMhc4wT+v+TT7X OPEOzi3sZGrX
uqxveXV1q9pcWguFktYY2Du/J2lOuwjI7c9OairBVE1JmSrVKUnNSX+Z2GmQ fZdLtYfKWIpE
oZF6Bsc/rmqjFQXLFaHenKSvLcybTwsbXxZc62da1SWGVf3dhJdu0ETnO5gp PIIxhTwvOP4d
t30sB0NIZEE/0wv5PSLHml+B8w+ULnr3zjtVLYRV1hgmn/MMo00SMD0ZTIoI PsQcVzYh2pP+
uptRV5/f+Rz2r6Pb67ePfwQ7XeMp5xuNnmcYDY2NkYPByM49MGsoZlOFN07X XmXPCqUWm7XK
3hvw7eWniCOe4uhKlsrFvLdmXeRgKcj0Ynj2z1GTDzc3e2hw/UvYyUue/lb/ AILO1mkMcZKr
vkPCJnG5uwroqVFTjzM6Ix5nY5jV5dQ0u5SSYN9vxuiCsWjcnjao/EDGM9PU EjpwnC81aVi4
ya0Wx0VtbGImWVt87/ebsPYe1ZUKHs9XrJ/1ZDq1efRbFmukxIrdNiy/ufK3 Sscl9xfgfN14
HbHtVPYRDfTfZ/s8pO1Fk+Zj0A2sOfxx+dcmJbVO6N6KTlZjftk11uFpcIpW PerZBDEkgAnB
4G05xyc9RiuWFTlinJbmsoq4+2c/arlHQLKxWVgr71wRtGDgf3K66ElJOxjU TVjI1/wsdd1L
T7tda1SwS3b99DZ3bxJcJyQpCkYOcfMOcZHoV6U7GJ0NIZFMm9oR5Pm4lU43 7QuD948jIHXH
eqjuID/yEtN/67t/6Kerp9SZdDYnnS3j3ufYAdWPoKitWjRhzS/4cqMXJ2Rx HiS3vrq9img/
e3Eo8pIVIynU4HqPU9uvTp5NHH+2q+yfxeX5f8E3dLljdbGxaxSW88UMy7ZY 7C3VxnOCC4Ne
xJWhFf10OZfEzFZ4RLYPc2bzQGHJK2rSgHEHXEZ6qHGeehG4fw91OLULJ/j6 +ZzzklLVfh6F
ZZbZrpYYbN/tAkgYAWTKUBlXLE+Qm0bVfktjg/hUrqLu+j6+XqyVJNqy7dPP 0NvxL/yKusf9
eU3/AKAa58B/vdL/ABR/NG9f+FL0f5HG/BT/AJFLUf8AsJSf+i469DPf96+X 6sywn8JHYeHo
kk8MaLvXcEtoHAyRyEGOn8q87GO2Jqf4n+ZrQ/hR9F+RrVyGxFHbxxXMlxGZ EkkOWxIwUnAG
ducdAO1K3QCO5sYbveJnnKuMMq3Eiqw75AIFJRUdh3bLNUIKAI5YhIF+YqVO QR9Mf1pp2EQN
p6OmxpZCuScZHfOe3uarnYWJ44fLZm3sxIA+bHb6fWk5NhaxT1bRrTWIo0uQ wMZyjpjIz16g
itKVaVJ3iROCnuZP/CD6b/z8XP8A5D/+Irf67U7L+vmZ+wibWm6bb6VaC2tl ITJYk9WPqa5q
lSVSXNI1jFQVkW2UOhU9CMHnFZlgiLHGkaLtRFCqMk4AGO9Nu4haQyra2EFp NcToN01xIZJJ
GxknAAHHYBVH4c5OSXcSVi1SGFABQBnX+g6ZqUolurUNL/fRmRj9SpBP40mk zGdGnN3kiex0
2z0yIxWdusSnqRyW+pPJ/GhJLYqFONNWii1TNAoAKAOa1fwPpOtajJe3RmEs gXcF2kHAwOqn
tWbppu53UsdUpQUElZf13NTRdEtdBsWtLMuY2cyEuQSScegHpVRioqyMK9eV eXNI0aowCgAo
AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAGRxJEHCLjexdjknJOPX6dK dxFbUtOh1O2E
MzOm1tyshwQcEd8gggkEEEYNXTqOm7pCkrqxV/sNv+gre/8AkL/4iun65L+V fj/mZewiaUEE
dtCsMK7UXoM5+pJ7n371ySk5O7NkklZCXFtBdxeVcwRzR5ztkUMM/Q1DSe5S bjsUo/D+jwyP
ImmWoZmDk+UDg4A49Og4HfnqTRyrsV7Sfc0qZBHNBFcwvDPGskTjDIwyCPpQ JpNWZnWnhvSL
G4W4gslEq8qzMz7T6jJODStYyjRpxd0jVpmwUAFADBEgm87bmTbsByeBnPTp 26076WEMurWC
9tZLa5iWWGQYZW7/AP1/eplFSVmVGTi7op/2DY+t1/4GTf8AxVYfVaP8pr7e p3/IvQQR20Kw
wrtRegzn8Se59+9bxioqyMm23dkqkqwYdV6UWTafYRFNBFPdxXUqB54gyxsf 4c4zj8qlQSk5
dWO7tYkqxBQAyOJIg4Rcb2Lsck5Jx6/TpTuIfSGQT2cNw4ZwwYDGUdkJHvgj NZzpwn8SuVGc
o7MWC1itt3lqct1LMWJ/E84/xpwhGCtFWCUnLcmqyQoAY8SSFN67gjBwMkcj p0/lTTsIbKHW
a3nRd5gkL7M43ZVl/wDZqqDSepMk3sLJeRy536ZfHnP+tTg+37zj8KxnhMPU d5tv5y/DXT5e
hSqTWy/Ibb3EFrK0sWkXYkYYLM6McemS/FOhhcPh7ukkr+v6hKpOe/6ChnuL 2W6eJog0aRhG
IJ+UscnGR/F69q3nJNJImKd7sz/7CgMSxtM7ooAAeKJuwHdPQAfgKv6xJC9m izY6bDYM7RMT
uVUxtVQACxwAoA6sfzrOdRz3KjFR2K/iX/kVdY/68pv/AEA10YD/AHul/ij+ aM6/8KXo/wAj
jfgp/wAinqP/AGEpP/Rcdehnv+9fL9WZYP8AhI63Q3EfhfQsziINBbr93cWy o+Ue56ZrzsX/
AL1U/wAT/M1ofwo+i/I2a5DYx7u7ikOqNHcEtZWwdPLlICSfPncAcH7q8Nn9 TXBWqq8rPZaW
fXX/AIGjOmnB2jdbv8NDS+0KYvOieOaFiArxtuBywXrjH4Z7V6NouHPF3Ry6 p2aHTzxW1vJc
TypFDEpd5HYKqKBkkk9AB3qRlTTdb0nWPN/svU7O+8rHmfZp1k2ZzjO0nGcH 8qLWEW522Rhy
wVVdWYk4AUMC2T6YzSbS1Y12RW02S7itXS8vEuJ1YsWktRCVQgbfl3d8Hn3w cEEV0xnSqv3F
by/X+vzuZ8s4fE7liKQyTTnPAZcY6D5FPH51hJWky1sUtQ8Q6JpNwtvqWsWN lMy7xHcXKRsV
yRnBI4yDz7UWYGlSGZ+n6i+oXMkCxCNl5BY9u59//rj1rTksTctRzZiVpEkQ 4BbMbAD9KnlY
7k1SMqXU9x5NwLGMSSwoXbIJAIGQuByWPHHYHJ7A4Vakkmobr+rer/4Pa+kI Jtc2wq38LOql
Z48nAMlvIi5PQZIA9qarQbtr9zX6CdOSX/BQ+8vbTTrR7u+uobW2jxvlmcIi 5OBkngckD8a2
MyPT9U0/VrdrjTb+2vYVbYZLeVZFDYBxlSecEce9GwFpmC4zk56ADJP4U0rg NXzZJQscT4Cl
juQrnpwCeM8n8qpR7hccrBhkVGwDTLGG2F1DemeaAH0DIZHC3VuhnCb937vb kyYUnr2x1/Cm
hE1IZnyahJDdvHLFiMdMfeI9fer5boLXHW17LcXRQRDygOueV9M/X0pNWQNW L1SBHI7iNpEG
UQgMcE55wcY9PX/6+KUdBXI97maNgzLGx2hSuN3BJPr6U7WQEk7FY8h9nzKC 2OgJAqY7gNVp
S8cG0ib+IspxwDznpgkdfeq5dQuSq2c8EEHBB6g1LVgI7qcWtpNcMpIiRnIH fAzWc5ckHLsV
GPM0iq97dR3a2bW8P2hyu3ExKYIc8nbkf6s9u4rF1pqXI0r+unXy8uxp7OLX NfT09PPzLNrO
biHeyBGDsjAHIyrFTg+mRWtOfPG78/wdiJR5XYcv/Hy/+4v8zWhJX1d3i0W+ kjYo628hVlOC
CFPIprcRIrS20yW10dxf/VTYwJRjOD6MB1HfqO4VLYCxQMpXEccuqWqvcSIy xu6wozKHwU+Y
4ODjOMHruqXG7TBO2hIbGErMN8+Jjlv9IfjnPy8/L+GKORa/5sdw04MNLtA8 yzuIU3Sq24Oc
D5ge+euaIpqKTE3d3QahcLbWMrm5itnKlUkmYBQ2OM5pVHaL1sxM5fRNYvbP UJINSS4SzaMG
N5syMz9cKRndxkkrleAflziuCjWdJfvXp/W3l/Xq9L6HXxyJLGskbq8bgMrK cgg9CDXpJ32A
z9P8Q6Jq1w1vpusWN7Mq7zHb3KSMFyBnCk8ZI596dmhF6X/WQ/7/AP7KaQxL gyCEiIgSEhVJ
6ckCqirsTKZe5juhbS3UIlJAwH7noM7MZ9q05YbE3ZcjWeKZ45mBIVWGDnrn 2HpUTSWw0V9W
N0NOcWUgjuWdERjjAy4HcH19DRCUIyXOrr/MU1JxfLuc3baleSOVHinSpWCl iEvos4AJJ/1X
QAEn2Fem6FNfYf4/5nBGtN/bX4G5o9xNO0rPexXcJRWjkhlWRTy4OGVVHVcf hXBX5Iz5IqzR
2UXKUeZu6H6h4h0TSbhbfUtYsbKZl3iO4uUjYrkjOCRxkHn2rGzNTSpDCgAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgDL8S/8irrH/XlN/6Aa7MB/vdL /FH80Y1/4UvR
/kcZ8Ff+RT1H/sJSf+i469DPf96+X6sywn8JHX6DL5XhjQj9o8ndBbrnbktl R8o9z0zXn4v/
AHqp/if5mlD+FH0X5GxXGbmFeXVvaagltHdNbG5m8sr5TOAxCksuAQCd4zu4 yd3Yhsnl3tnz
xdl1/wCB5/8AD+tLEqHuyV+39f1/lckEcNuiRx7FDxjBB7yr3Iycnkknkk13 eyjCnyxWiMed
yldmjXMaFDSdF03QrR7XSrKGzgeRpWSJdoLMck/0HoAAMAAUXuITW1YaVPcR yvFJbK06lQCC
yqSMgggjPP1ANc+Ijem3fbX7jai7TS76EfmTXOtOTJJi3hUqibRkvvByeuPl XgEcgHtWOBl7
So5ze363LrrlhZLf/gFy2SRJLhnBG9wVyeo2KPX1Br0qjTd0csbpakF/oum6 nd2N1fWUNxPY
SebbO65MTYxkfofqAeoBGd7DL9AyGRXjJePODyyj+Y/z/wDXpPoIjWO4lgUS ygb1+YBCDyOe
9PmsBaqBmZdyXelWtxJZxNPGQ7pGqlmSQ5PQclSx+oJ9Pu8FenOHvU9fL+v6 /TopyjJpSJGt
r+42JdXkLwh1crHAUYlWDDkue4HbpWiw8rrmlp6f8En2kUtEW54Irm3kt54k lhlUo8bqGVlI
wQQeoI7V1mJBpmmWWjabb6dp1sltaW67Y406Af1JPJJ5JJJo3EWHRm2lG2sp yDjPbH9aadgI
2lu0kVd4cMD0UjB46nP1quYCVFK5LNuZjlj6mpbuAGNDIHKjcBgGkA6gZE8u y6gT7R5e/cPL
25MmFJxntjr+FUhEtSMxryK+vb4xiPy4487Wbp9f/rVaskUmkP01by2unt5I sw8nf2B9vXND
s1cTaepqkZBB7+hxUCK0kkluFQAHkKhzgHnH5/5+lp3EPjhkMolmYFgMKo6L +PrSbAlkjWWN
kbowxUrQCszz2+wSMrqTt3AkHp6fhVp3AmjRtxkfhiMY9B/n/PrLYEOqxvLp F7HEpaRoHVVH
UkqcCsaycqckuzNKbSmm+5lTTNJq8d4kdybdCgLG2kBHyzD7uMn769B3rgcJ N31+5/3v8zpT
SVv19DT0oMLIllZd00rgOpU4MjEHB5HBFdtBOMLPz/NnPVd5aeX5Flf+Pl/9 xf5mtzMr6ujy
aLfRxqXdreQKqjJJ2ngU1uIo6peXtzby290PskK4nXymDOYVwHySCFZCVfIz 2CnIzSWlhGwi
lI1UuXIABZsZPuccUFFC7ujbazYo1szxyxyL5yQM5Rt0eFLKDtB5Jzx8o54r WMOaDd9vP1M5
S5ZJW/rQqa3r72GjaldWVlcTz2cbkh4SiKQrHcS5XcoK87CTyMdacaV2k3v5 /wCW3zBz0dls
aWmgJptvGtpLZrGgRYJWVmQDgAlWYHgeprKW5S0RheKGuLSZbss6W3lbfOjG TA4JOTz91hwR
0O0cg4Nefi6c21JbGkWluZOh2EviCxulZzBChBhlj+aNmbJk299pwjcYIbng 5qadH2sNdLbe
QSfvXR1+j6cNJ0m3sfPecxA7pHGCxJJJx25J4rupw5IqJAlhoum6Xd311Y2U NvPfyebcvGuD
I2MZP6n6knqSTdwLcv8ArIf9/wD9lNAwmIVVZiABIhJPb5hVR3E9jA1zTZZb tns57eeKVskG
ZQVzyQcnlc88cjP52466Em7EfmRDcLO6QRq8inO5hnJpT6DRDqkghsxISqhZ oiSxwB+8Xqew
rJ9PVfmV0Zz1nJIbEpcS2au0hJz4kuAcAsFwRuIGD2PPBIGAB3fWFe919yOb 2GltfvZoeHZp
ZYwJzH5628YkEd0bgBt0hwXYk556ZOPWuSpJTqOS7L9TeEeSCiXr/RdN1O7s bq+sobiewk82
2d1yYmxjI/Q/UA9QCJvYZfoGFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAU
AFAGX4l/5FXWP+vKb/0A12YD/e6X+KP5oxr/AMKXo/yOL+C3/Ip6j/2EpP8A 0XHXoZ7/AL18
v1Zlg/4SO48MgDwvpBEoU/Y4fXj5B7V52M0xNTX7T/M0ofwo+i/I09i/89V/ X/CuWxsNEMal
iroCxySAeTjHp7CqTa0TFZA0MbjDOhGQcEHqOR2o5n3Cy7Dti/8APVf1/wAK mww2L/z1X9f8
KLAQTXNnbsFmvreJvR3wf1qlBvYTkluVrefRbOMx215YQITkrGwUE+uBSjQ5 FaKt8gdVS1bL
Ed5YyuEi1C2dz0VZMk03TktwUk9mWNi/89V/X/CpsMNi/wDPVf1/wosAbF/5 6r+v+FFgDYv/
AD1X9f8ACiwBsX/nqv6/4UWANi/89V/X/CiwBsX/AJ6r+v8AhRYA2L/z1X9f 8KLAGxf+eq/r
/hRYA2L/AM9V/X/CiwBsX/nqv6/4UWANi/8APVf1/wAKLAGxf+eq/r/hRYA2 L/z1X9f8KLAK
FAziVR27/wCFHzATYv8Az1X9f8KLAGxf+eq/r/hRYA2L/wA9V/X/AAosAbF/ 56r+v+FFgDYv
/PVf1/wosAbF/wCeq/r/AIUWANi/89V/X/CiwBsX/nqv6/4UWANi/wDPVf1/ wosAbF/56r+v
+FFgDYv/AD1X9f8ACiwBsX/nqv6/4UWAaIUDl/NXJAHftn296LAO2L/z1X9f 8KLARy2sE2zz
fKfYwddyk7WHQjjg0fMCTYv/AD1X9f8ACiwBsX/nqv6/4UWANi/89V/X/Ciw BsX/AJ6r+v8A
hRYA2L/z1X9f8KLAGxf+eq/r/hRYA2L/AM9V/X/CiwBsX/nqv6/4UWAa0KMV JlX5TkdfTHp7
0WAdsX/nqv6/4UWANi/89V/X/CiwBsX/AJ6r+v8AhRYA2L/z1X9f8KLAGxf+ eq/r/hRYA2L/
AM9V/X/CiwBsX/nqv6/4UWANi/8APVf1/wAKLAGxf+eq/r/hRYA2L/z1X9f8 KLAGxf8Anqv6
/wCFFgDYv/PVf1/wosAbF/56r+v+FFgDYv8Az1X9f8KLAGxf+eq/r/hRYA2L /wA9V/X/AAos
AbF/56r+v+FFgDYv/PVf1/wosAbF/wCeq/r/AIUWANi/89V/X/CiwBsX/nqv 6/4UWANi/wDP
Vf1/wosAbF/56r+v+FFgDYv/AD1X9f8ACiwBsX/nqv6/4UWANi/89V/X/Ciw BsX/AJ6r+v8A
hRYA2L/z1X9f8KLAGxf+eq/r/hRYA2L/AM9V/X/CiwGV4mRR4U1j94p/0Kb1 /uH2rswC/wBr
pf4o/mjGv/Cl6P8AI4j4LkDwpqP/AGEpP/Rcdd2e/wC9fL9WZ4P+EjtvDf8A yK+kf9ecP/oA
rzsZ/vNT/E/zNaH8KPovyMyx8cabfyIkUMwLjIzJCT0z90OWz7AZqp4OpTi5 NrT1/wAiI4mE
nZI1rTU1uJ1jITEql4/LkVyACRztJ9M56c46jnyaWI55W/r5/wBW6b79sqfK rlu5leCBpI7e
S4cYxHGVDNz23ED8zXUZPQ5a38V3TTT+bZSxI90ojMoVhBCCFkMmwnZykmCe 5HYHGnItr6mH
tlezOi0/VbHVI2aznDlMb0IKOmc43I2GXOOMjmoaaN009hkupT6VoH2q3tkl klvHid3bAjzI
yqx7sAdowPXtXXCHO1G9tDFy5Ytj9N1fVH1VbW5ht3t5M4dZ/wB5HgEnI2jO TtGByM557EoQ
hop3fpb9WUqjnrycpS1LUruTxJrOmtLm0h0s3Ece0fLJn72cZ/WrjFcil1uZ Sk+dx6WNmuA6
goAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAo
AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAK
ACgAoAKACgAoAKAMvxL/AMirrH/XlN/6Aa7MB/vdL/FH80Y1/wCFL0f5HC/B y3MvhbUGFhPP
/wATGQbo5tgH7uPjG8fyr1M6inifl+rMMK7Ulod34b/5FfSP+vOH/wBAFeTj P95qf4n+ZvQ/
hR9F+RFoovZ7bRdgt4gbAsrHMm4fu+o+XB5Hc1nBNRj5IGk2/Unt7drTXr6N jEWeGKU+WhQZ
LSZ4JPpn6knqSTg6ajUcl1NlJuKXYuXFtBdwNBcwRzQtjdHIoZTg55B96ewm r7nDRQ6xok7W
EdvNcnUXlu4wJfMkiwyjbIWOCArRj7x5B56GqqR9pFWdmjklGcXotzovDWm6 jp1ii3lz8rbm
+y7VIt8tlVVgB0BIOc9sEAcknc2pRlGKTJdS1a20nwsj3dslxFPeyRFHXcP9 a7Zx3wFJHvit
Z1HTSkvL8jOpUVON33Mey1O5aC48p/OsY4VZvLDN5TLglxx7E4BznGQDmso6 3tsFKTnO6eh0
KaZo0Hh/UdS0qND9rtXYzK5bcNpOBk8DPYYrqU3JpN6FumoJ2WperjNwoAKA CgAoAKACgAoA
KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKA
CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKAMv
xL/yKusf9eU3/oBrswH+90v8UfzRjX/hS9H+RwHwetLm68OagsN7cQqL9/ki fYM7E5Pr/wDW
r3M2UFXvJf1dnFQk1BJHoHhv/kV9I/684f8A0AV4OM/3mp/if5nbQ/hR9F+Q 7/hH9F/6BFj/
AOA6f4VympYtdPsrHf8AY7OC3343eVGE3Y6Zx9TQMsMyopZiFUDJJ4AoAqi6 08StKJ7cSMoV
m3rkgZwM+gyfzNAh/wBvs/8An7h/7+CgZRuJLObT5NPmWxu7R3Z8SXPlkEsW 6gHuTyCK15oy
VpGMqfMuVq6DSriz0S2a30+00+GNjub/AE9mZj7sykn86E6cdv6/EUKfs1aK JWv4n0+SwjTT
rS3kVlPlXAO0NnOF2gZOTVKcY6otqUtGWft9n/z9w/8AfwVgaB9vs/8An7h/ 7+CgA+32f/P3
D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w /wDfwUAH2+z/
AOfuH/v4KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32f/P3D/38FAB9vs/+ fuH/AL+CgA+3
2f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4KAD7 fZ/8/cP/AH8F
AB9vs/8An7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQ Afb7P/n7h/7+
CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4KAD7fZ/8/cP/AH8FADku7aRwkdxE 7HoFcEmgB8k0
UKhpZFjXOMscCgCL7fZ/8/cP/fwUAH2+z/5+4f8Av4KAD7fZ/wDP3D/38FAB 9vs/+fuH/v4K
AD7fZ/8AP3D/AN/BQAfb7P8A5+4f+/goAPt9n/z9w/8AfwUAH2+z/wCfuH/v 4KAD7fZ/8/cP
/fwUAH2+z/5+4f8Av4KAD7fZ/wDP3D/38FAB9vs/+fuH/v4KAD7fZ/8AP3D/ AN/BQBOrK6hl
IKkZBHQ0AQfb7P8A5+4f+/goAPt9n/z9w/8AfwUAH2+z/wCfuH/v4KAD7fZ/ 8/cP/fwUAH2+
z/5+4f8Av4KAD7fZ/wDP3D/38FAB9vs/+fuH/v4KAD7fZ/8AP3D/AN/BQAfb 7P8A5+4f+/go
APt9n/z9w/8AfwUAH2+z/wCfuH/v4KAD7fZ/8/cP/fwUAH2+z/5+4f8Av4KA HxXNvM22KeN2
AzhWBNACyzwwY82VI89NzAZoAj+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/ AD9w/wDfwUAH
2+z/AOfuH/v4KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32f/P3D/38FAB9 vs/+fuH/AL+C
gA+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4 KAD7fZ/8/cP/
AH8FAFPxL/yKusf9eU3/AKAa7MB/vdL/ABR/NGNf+FL0f5Hn/wAINL1S78Na jPp+ppaqNQdC
jw78nYhz1HqK9nOKjjiLeX6s5cPBSpps77w95n/CMaKI9g/0aDcXzwuwZxjv Xi4y31mpf+Z/
mdVD+FH0X5GiBc8cwjMvq3EfHPT73Xjp05rmsjUdH5mHMuz7x2hc/d4xn360 tAEOPtlmDypl
OQehwjEfqAfwpx3At3+qw6abU3DpHFNL5bSO4VU+Rmzk/wC7j8a2WpOxnWXj HTL/AFgabbsX
lJIVg6FWxv5GGzj5D27j1Fc0cRFz5LP/AIY3dCShz3N3fXRcwDfRcBk11DbI HnmSJCyoGdgo
LMQqjnuSQAO5IFFwH76LgG+i4BvouAb6LgG+i4DI7qGV5UimR3hbZIqsCUbA bB9DhlOPQg96
LgP30XAN9FwDfRcCjBrlhcWjXMczeWoVvmjZWIb7pCkZO48DA5PAyaLjLFpf Q3tuJ4GYxksv
zIVIIJBBBAIwQRRcRmW2BG6jhVlkVR6AOQB9MVi9yiakMKACgAoAKACgAoAK ACgCjqWof2el
uf3A86Xy91xN5SL8rNktg/3cdO9NK4imdd2PEPO0mXfKkey31DzH+ZguQuwZ xnPXtTcbBc0r
65+xafc3Wzf5ETSbc4zgZxn8KkZnf2rqH/QN/wDId1/8Yq+UVyybn7Z4fF3s 2GW3EwXOdpK7
hz7HvUDL9tNFBeXc07qkcUCsXc4CDLFjk9BwM/Sri7CtfQ563+IlvJqHlyvY JAUhP/H18yby
24kkYO0bcjjHqc8cscW21eOj8zreFSTs+/T/AIJ2u+u65xBvouAb6LgG+i4E dxdRWltLcTNs
iiQu7YzgAZJ4ouBX/ti0+z+dvkxv2eX5T+ZuxnHl43ZxzjHTnpzRcCeK4gvb NJUIkt54wy5H
DKR6H2NFxmVZMXsLdmJLGNSSep4rAoybfxB9otop/tGjReYgfZJqeGXIzgjZ wavlFc0tNvPt
9ktxiMZd0/dyb1O1iuQ2BkHGeneoegFObVrpb25ggsfMWBwm/EzZJVW/giYD 73rmqUbhcm07
UZru5ngntvIaJEcf6wZDFh0dEP8AD6YpNWAfxmdP4PtUale2CUyPocnP1NC3 AXX/ABbBod3F
amNHmdPMPmS7FC5wOcHJ4PbtTnU5NDmqVlB8pQv/AIiafZ21lKkYY3MZkxJJ tCgMVIyAcnIP
txXXQpOsuZbGsJKcVJHR6TqsOr6Xb38AIjmXIB7YOD+orOcXCXKyy5vqbiDf RcA30XAqy6ra
w3q2ckjCYhT/AKtto3EhctjaMkEAE8mi4BFqtrNetZxyMZgGP+rbadpAbDY2 nBIBAPBouBXv
iP7StyOC0T598Fcflk/mazmUjN1HU/sNzBButE81HffdXPkqNpUYB2nJO79D UpXAhh1nzL22
t/N02bz3Kf6Lfeay4VmyV2Dj5cde4puNgLmpXjWNk06Rea29ECZPJZgvYE9+ wJqUBm3GuX1t
bSzvpuViQufluRwBnqYAB+JAq+ULmrecRIw4IlTB9MsAf0JH41Awt+bi7J6i QKD7bFOPzJ/O
gCxQBEuoLpehT3jRmRllf5QQCx8wquSeg6DJ6Ae1E6ipU3Nk9R2heIrfW0nV F8u4t2Cyx5zt
znHJAPYjBAIIPFLD4hVo3tZg1bQ1t9dFxBvouBXvNRgsVjaYyfvH2IscTSMx wTgBQT0BP4UX
Ajl1myiaBTPu87ZsaNWdcMcKSVBABPAJwDz6UXGJqrA2an+JZY8HuMuAf0JH 41MtgRRvrn7F
p9zdbN/kRNJtzjOBnGfwrIozv7a/6fNC/wDBp/8Aa6vl8xXNGxuftun211s2 edEsm3OcZGcZ
qBmaNZvJHl8rT9yJK8YO2ds7WK5ysLDt2JqlEVy5pl9JfJcebB5Lwy+WV+bn 5VbOGVSPvdxS
asBR1njwZrI7LbXKgegAcAflXXgP97pf4o/mjKv/AApej/I5X4KXN1B4S1FY LeKRf7SkOXmK
HPlx9gpr1c6cVide36s58Lf2asdn4b/5FfSP+vOH/wBAFeRjP95qf4n+Z0UP 4UfRfkadcpsF
AETnF3ZH/pqf/QGprcQzV52iuNLdIXmYXRwiFQT+5k9SB+tarqSzltJv45fG vl/YxE5lfrMS
yn99nKiUj1/hx856ZBPmwa9tay3ffz8z0Jxfsb+S/Ty/XoX/AB1bfb5PDlt/ Z1nqO/Uz/o16
22F8Ws5+Y7H6YyPlPIHTrXopnAc74i1nU/Beiw20GoW1nNZwTXgimuUigmDO 7JbRBomaURgB
NqGI7WTGNw2iAsavq895bXavq6SarFqsCpozyRxrGiahEsUhAQyqGUI24lh+ 8yBgqAAV/Enj
bUNM0wPBqqW+oWEEk9zHfSRWqzy8t5CxmNy5XA+VHU7JIz5j7w9AEmqeLNVt b0taav5ur/ab
2P8AsHZE37uKG4aFtgXzvn8uFs7sHfxgECgDe8EatqGofblu9Ws9Ut4/LMc9 tcrcYY7tymRI
Yk4AU7QCwySThloYHK+AZdDsfCMFxa6v4eg1YafAd+n2Sfak+5lJlDs0pZ9i kAKxJwMMVwMD
TuPEs7ahpseq+Kf7AE8V091Fm3T7PMhgCwbpUbOFdm3fx53rhCoABQ0rX703 Vy+r6n/wjkd7
Ks93cbY4vLuBZWWIczBlXO+U7SN37vrw2QC5B4i8Uz+HtX1SadLe4ga0h+yt CIltTLDbPO7s
wYqE8yRgWBCfMWDgAKAT+HtZ17UtY0yzk1y2mtGW5laa22z/AGhI2ttoEvlx oTukkUsiY25X
743KAeg76VwOdsb+ym05ZoGULtZre5WNZF01XUAKSTx6lRwoODhQDVJgamj3 ME+mRvbKoj3O
vyvvDMGIZg38WSCdx5Ocnk1NwIrX/Vyf9dpP/Q2qGMnpDCgAoAKACgAoAKAC gAoAKACgCpqs
Elzo97BCu6WSB0Rc4ySpAoEWv7dl/wCgLff99Q//ABytedCsZkMElt4WjgmX bLFZhHXOcEJg
1kUaVq23Ubj/AK5R/wA3qoiOU1LRG0i8tHhl1C8ilMUYjV4lI8oOygtwfpjp huckVxVKKp2a
ud1Orz3ukv8Aglfw3f3iXFgDZXyJLeTq264BVstITlS/Y8k45wcZ4yqbamtX 9/qOok4vbZdP
QPEOiy67441OG3sLB5/7KtUjv7hyJrBmkuQJYQEJLA/N95OVXnuPRueedlJr unxfaN9xj7Nc
xWkvyN8ssmzYvTnPmx8jgbuehwgJ7fULe6muoYZN0lpKIZhgja5RXxz1+V1P HrRcAv7iGDTr
qa5j8yCOJmkTAO5QDkYPB4ouBj/arf8As/d9oj87Z5f9p7h5e3fu8nzvvYx8 vmY68/f4qrgb
FhcQz6dazW0flwSRK0aYA2qQMDA4HFTcCnYf8g62/wCuS/yFZlFigAoAp2d3 Pp11qAOm3M6T
TiRHiaPBHlov8Tg9VPatIySRLQRSTXWsXN29nLbRtBFGolKEkq0hP3WP94VM nca0GHh5/wDr
7i/9p0kBX8U6BpuqW76hdtNFJaxMxeAqGZVydp3Aj17d6r2aqSSOavRhNcz6 HE6WNK8S39jp
U1q1sscbLE8AwwHLEMWyGydxzgHJ969mph5YOlzRehw4PGRqS9kkekLouljR V0eSxhn09VCm
CdBIrYOeQ2c88/WvJlNyd2esYXgQ6Zo3gbwvDFDDayajbQ4EUW3zpjb72ZsD 7xWNiSeuOvSk
2Bvx67p8v2fZcZ+0XMtpF8jfNLHv3r04x5UnJ4O3jqMoC/vouBj3t5arrKwP tMnkfvIeGa7R
twWMKeDggkk/dHszENMAsry1bWWgTaJPI/dQ8K1oi7Q0ZUcDJIII+8PZVJGw LV02dRt/+uUn
80qJDQ6pGFAFPUkle1QwxNK8c8MmxSASFkVjjJA6A96a0Yg1XU7i+0e9tItH vRJPA8almhwC
VIGf3nvWnMhWJL3/AFC/9dY//QxWRRzfjKzt9R8PXljdx+ZbXOpWUUqZI3K0 8AIyORwe1NaM
RR0fTb+28e2N7q8vnajNpt1bmTaq7oopbdUOFOPnYyS46jzdvO0U3sB3Fkkc unSQyoskbvKr
IwyGBdsgjuKa2sBwr2P2PQb2aJ7cW82oTJ5CxsJJfLldAGkLEbVRCwBXb8vP fPHjqVKlR5Ya
bed9P6e5nDmbuzpfBU95JoLfbZkkZZ3RApOUUHABz05yQMnAIq8I26Sv/wAM aPcqQNpF18S0
vNL+xy3Mdjcw6hNbbWdZPMtwiSleQ2EcANz8rY6Guu+gja1u6hhtoBJPHbSS ShYbmRgqwPtY
78n2BGP4s7TwTSArXN9Yx3NsfI+yxyXAY20iCNrh3ZQswH8RB5KnBGQxAKrl tgaWpNm0A/6a
x/8Aoa1LegxKgYUAFAFPTb+4061e2fSruUieZw8bRbSGkZhjLg9CO1aKSSJs FmZZLrULmW3k
txPOHRJCpbAjRedpI6qe9TJ3Y0Z+s/8AIna1/wBe91/7PXVgP97pf4o/mjKv /Cl6P8jjfg3Z
21x4W1F5raKRhqMgBdATjy4/WvSzuUo4rR9P1ZhhYp0ldHb6FPDbeEdKmnlS KJbOHLuwUD5B
3NeZi4uWKqJfzP8ANm1FpUYt9kXF1Swe3lnS9geKIZdkkDBfTpXJU/cx5qmi NoNTdo6k0E6X
CMUPKMUdcjKMOoPvUQmpq6KaaGznFxZn/pqf/QGqxFltjsjMqkocqSPunBGR +BI/GncQ7fRc
A30XAN9FwDfRcA30XAof2VZnVv7TcTSXI+6JLiR44zt27kjLbEbGRlQDgtzy cu4F/fSuAb6L
gV3tbd9QhvmjzcwxPEj5PCOVLDHTkxr+X1ouBY30XAN9FwDfRcA30XAN9FwD fRcDOguFhV0d
Jg3mueIWI5ckcgUhkv22L+5N/wB+H/woAPtsX9yb/vw/+FAB9ti/uTf9+H/w oAPtsX9yb/vw
/wDhQAfbYv7k3/fh/wDCgA+2xf3Jv+/D/wCFAB9ti/uTf9+H/wAKAD7bF/cm /wC/D/4UAH22
L+5N/wB+H/woAPtsX9yb/vw/+FAB9ti/uTf9+H/woAPtsX9yb/vw/wDhQAfb Yv7k3/fh/wDC
gCC9u42sLhQs2TGw5hcDp9KALMTbdRn/AOuUf83piFvLS3v4ljuFYqjblKuy EHBGQVIPQn86
mUVJWZcZODuilYaBp+myJJCJmdHd0MkzNtLE5wCcdGIzjPqScmpjTjF3RUqs 5KzNbfWlzIN9
FwDfRcA30XAN9FwDfRcDNtLlIrKCN45gyxqCPIfggfSkMm+2xf3Jv+/D/wCF AB9ti/uTf9+H
/wAKAD7bF/cm/wC/D/4UAH22L+5N/wB+H/woAq+YJFndQwH2qL7ylT/yz7Gg DVLBlKsAQeCD
3p3FYzrHRNM024ae0tVjlYYzuJwPQZPH4VtOvUqLlk9DKFGnB3ijS31jc1Df RcA30XAN9FwD
fRcA30XAp3Mnl3sEjK5URuMqhbBJX0HsaAD7bF/cm/78P/hSGH22L+5N/wB+ H/woAPtsX9yb
/vw/+FAB9ti/uTf9+H/woAhubmOSNEVZQTLH96JlH3x3IoAWO4SK5u1ZZCfM B+WNmH3F9BQB
L9ti/uTf9+H/AMKAH2DEWvIZcyOQGBBwXJHBp3EUpvDujSyTTLp1vBczHc9x BGI5S2d2d4Gc
5APv3pVV7WHJPVCUUndEmi6RaaDYm0s95RnMjM5yST9MAYAAAAHAqKcFTjZD NLfWlwDfRcA3
0XArXzE2vAZsSISFBJwHBPAouAz7bF/cm/78P/hSGH22L+5N/wB+H/woAPts X9yb/vw/+FAB
9ti/uTf9+H/woAPtsX9yb/vw/wDhQBlauwbwZrLDODb3R5GD/HXZgP8Ae6X+ KP5oxr/wpej/
ACOV+C3/ACKeo/8AYSk/9Fx16Oef718v1ZjhP4SOq0u3iuvBmjwTqTFJBaqw DFSR8nccivOx
U5Qxc3Hfmf5mlKMZUIqW1l+RbbRbG3uLi2tRLCGiRg6zMXRsuMqxJI4/r6mu bEuVZ8s36eRr
RjGmrwRatLX7OrF5Glnc5eRieeScDJOFGTgdvzNc9Kmqa7vuaylzMLj/AF9p /wBdT/6A1akl
igAoAKACgAoAKACgAoAKACgAoAKACgBCQoJJwB1JoARGDrlc4yRyMUNWEOoG FADVkV8hT0OO
n+fQ07WEOpDGGTBIVd23r8wGPzIqlG4hEnhkICSKSegzz+VKzQCysY4XcdVU kUhj6AIPtcWS
AJDgkZWJiMjg8gVoqUmrpEOcVpcfHOkrMq7gygEhkK9fqPY1MoOO41JPYc7r GjO7BUUZJJwA
KhtJXZSV9EUv7UiiumiuzHajYskZlkCswJYcg9Pu9PcZweK51iIqTU9O136/ 5Gvsna8dS5FL
HPGJIZFkjPRkOQfxreMlJXi7ozaadmK7FI2ZUZyASFXGW9hniqEZ39ry/YPt v9lXn2f+9uhz
nONuN+d2eNuM54xmq5WK5Zu2L6VOzIyEwsSrYyvy9DjipGOT/kIzf9ck/m9A FigAoAKACgAo
AKACgAoAKACgAoApPfTC+a0i065mcJvBVowGHcjc4JweD6ZHqMtK+wh9netd tMDazQeU+wmQ
oQT3AKsc46H346g4GrAQyf8ALz/19Rf+06QzQoAKACgAoAKACgAoAKACgAoA KAIbqc21rJMI
JZygz5cQBY/QEjNAFSTVJo4IZjpV0Y5iojZZIW355GMSc8c/QE9BVcrQrlm9 /wBQv/XWP/0M
VIwt/wDX3f8A11H/AKAtAFigCC9ma3sLiZMbo42YZ9QM1UVeSRMnZNktzp9p AET/AEia5k+4
v2qRd2OpODhVHc49MZJANVKqhokr9F/XT+twjTvuyrYvoV7b2zfbdk0yqfJ/ tFywYj7v3uue
KzpYqlUindXfTT7i50JRb0dl6li7tI9PltTA0uJpDGyvKzj7jNn5icfdreST izFaNCPcRxyb
CHLYBwqM2B+A9jWcYSkrotyUdxFuY2dUxIpY4G6NlzxnqR7UOnKKu0JTi9ET VBZHJPHEcE5b
so5P+fek2kBzWoeLp7K8uoU0p5Y7cFmcM/QKrHohA4cdTx3xkZOaCScpJf8A B0X3iOppjKKX
88tzPBDpV1I0JAbDRDIPRhlwcHnn2I6g1Si3sIlsbz7dbeeIJIVJIXzCp3D+ 8NpIIPY9+vTF
TsBmaz/yJ2tf9e91/wCz12YD/e6X+KP5oyr/AMKXo/yOX+Cdgl14S1J2lkUj UpBhSMf6uP2r
087inivl+rMcI7UkdZocIn8JaQm9k/0WBgy4yCFUjr9K8rGaYmp/if5mtD+D H0X5GlDbtHK8
rzyTO6hcvt4AzjoB6muaUnJ3Zqko6ImpFFe4/wBfaf8AXU/+gNQBYoAKACgA oAKACgAoAKAC
gAoAKACgAoAYXEcytIMoMbfTd7/0/wD1VcbCZFvtWLEJNyxztMmM55/Wq0ET Rb/KTf8AfwN3
1rJjIyyLI4mjlbn5ShbGMD0981atYA8+F4Fjt42DqW2ZzkHPOc84z1//AFVT asImrIoz7u+e
xjnZBzu3HplV28sAevTGP59K1hqS9COG+Msz2iszojKQzMCwOVOPUjBzk+h/ CpaISNC4/wCP
aX/cP8qwLJKAMULH9ruHbSX1JgABHGIyygyS8/OyjHA6HPSvQh8K1sccnaT0 JEWI3No66DLp
jrNgNKsQLgxvkDy2b0HXHaoq6RetyqTvLZo05YkniaOQZU+hwR6EEdD7jpXB KKkrM603F3Ri
8vfTfbLm7miRVjja288ZILbi3lgLnkA4zyp6dB5y9nGclOTfa1/00Or3nFcq t936lnSHlhto
4ru38iab5wxct5hIBwSxLbgOMN/d4yBxthanuqMlZ/n+t15/LQzrR1undGpX aYEH2OD7V9o2
HzOv3jtzjG7b03Y43YzjjOKBCX//ACDrn/rk38jQME/5CM3/AFyT+b0AWKAC gAoAKACgAoAK
ACgAoAKACgCKe3juECybhtOVZHKMp6ZDAgjgkcdiR3o2EPjjSKNY40VEQBVV RgADoAKBlGT/
AJef+vqL/wBp0AaFABQAUAFABQAUAFABQAUAFABQAUAQRWcEM7TIhDtn+IkL k5O0dFyeTjGT
yc0CEvf9Qv8A11j/APQxQMLf/X3f/XUf+gLQBYoAqap/yCL3/rg//oJq6fxo ifws0NWgVIje
xyiGeIYyc7ZBnhCByeTxgEgnjOSDjiqcXFzvZrr+n+RtSk78u6Od8lBY2MUM V1e3nyi5W4ku
VikAQlvvYXkjABGOeRivPcqajFQV5db81ttd9NTp967b0XTY2r66ju1090yC Lkq6N95G8p+D
/nngjIIr14VI1Kbcf62OGcXGSTM2+RX1CFXtvtIyp8kBSXISUgDcQM/UgVvQ +Exq7kFysMll
dKfClxZ/uZCJ5Ft9qEKSD8shPX0FbWt9pGSbb2f9fM3K847TnbUXrxqwkbDI r8dST1P+rP8A
nuapwj/X/DkjE0e2v9z3CymeZnSQrM6gqDtOQCAeFUdOcDNYTpwc7uKurdF0 vb7ru3qyk2jp
a1AguLOC62+chbGRwxGQeqnHVTgZU8HAyKNhE9AzD1n/AJE7Wv8Ar3uv/Z67 MB/vdL/FH80Y
1/4UvR/kYXwJ/wCRN1P/ALCkn/ouOvVzr/efl+rMMJ/CR03hv/kV9I/684f/ AEAV5GM/3mp/
if5m9D+FH0X5GnXKbBQBXuP9faf9dT/6A1AFigAoAKACgAoAKACgAoAKACgA oAKACgBCAQQR
kHqDQAiIsaBVGAPfNAh1AwoAYkSRliq4LHJp3EPpDEIBBBGQeoNAFeGyjgl3 xu4/2c8VTk3u
K1iaZS8EiqMkqQPyqRj6AKwtDHcvcW1xJbPIoV/LVMNgk5OVPPJrRVGlYhxV 7jjBNJLE817N
MIm3KrKgGcEdlB6E0ObatYajYnrMoqTaXp9zK0s9hbSyN1d4lYn8SKzdKnJ3 cV9xSqTSsmR6
Zpn2C3iWSXz5YoxEr7doVQAMAZOM4BPqfYADOhQVFd2XUqOb8i/XQZBQBXv/ APkHXP8A1yb+
RoAE/wCQjN/1yT+b0AWKACgAoAKACgAoAKACgAoAKACgAoAKAM+T/l5/6+ov /adAGhQAUAFA
BQAUAFABQAUAFABQAUAFABQBXvf9Qv8A11j/APQxQAW/+vu/+uo/9AWgCxQB BewtPYXEKY3S
Rsoz6kYqou0kyZK6aLb6tYyxNFPDOVdSrxtauwIPUHCkGtnFNWdiVK2pj3dp orvbyWEH2CWG
TcZIdNfcVKspA+Uf3s85GQODXJVwdOaSjZeljaOIkr81395cd7aVbK3sYpUi t5DIxeNk/hYd
WGSSWyTz3JroUY04csTJyc5XYs9qs0sUqu0U0TZWRAu4cEY5B45NTGbjsNxT EmgubiCSGXUb
ho5FKsNsYyCMH+Cq9q10FylisizJj0m4iRUW6hwqhRm2B6fjV8wrFuyszaIQ 0gkYk8hdoGST
wPx/QVD1dwLdAwoAKAMPWf8AkTta/wCve6/9nrswH+90v8UfzRjX/hS9H+Rh fAn/AJE3U/8A
sKSf+i469XOv95+X6swwn8JF/T5bhNK8PJb6KuqH+zPMeN2CqFURZ2kggyHd 8qnaDhssMc+T
i1/tVT1f5m1D+FH0X5Fi713QL21tE0ObQUup7lbeU3ioGtWZXIV4SyOXLJs2 ZDAknB2kVjaN
r2NRfCWq2usWt/c2n2VQt15ciWkiyRK4ijzsdeGU9QR2PIByBlazGjZuP9fa f9dT/wCgNQM0
Liy0y1tpbiSwt9kSF2xCucAZPauhRTdiG7K5QkS0t/NuZtAKQqmWJSE7QMkn Af8AkM8d+MNQ
TejRPM10LWoQaZpthNeSaZFJHENzLHApbGeT9B1PsKSjd2RZVaKFcSjSbZlP PkiFN4H+9uxn
8Mds964vrC5ttP68/wBDb2ehWg/su+8TQw29tBtgguUnh8tco4kjCll7ZAYq T1BJFei6fLC7
Xb9TjU7zsvP9Cvqt9oml3pt5rRpJiN/l2thJcMi5IBYRo20HBxnGdpx0OOVr U3FjutEl+z7E
hP2i5ktIv3H3pY9+9enGPKfk8fLx1GUBRufEPhu1kije3lcyySQxmHTJpQzo zq6gohG4GN+O
uFz05oswOittPsmnUGzgI54MY9KcdwZf/svT/wDnwtv+/S/4VrZEh/Zen/8A Phbf9+l/wosg
D+y9P/58Lb/v0v8AhRZAH9l6f/z4W3/fpf8ACiyAP7L0/wD58Lb/AL9L/hRZ AH9l6f8A8+Ft
/wB+l/wosgD+y9P/AOfC2/79L/hRZAH9l6f/AM+Ft/36X/CiyAP7L0//AJ8L b/v0v+FFkAf2
Xp//AD4W3/fpf8KLIA/svT/+fC2/79L/AIUWQB/Zen/8+Ft/36X/AAosgD+y 9P8A+fC2/wC/
S/4UWQB/Zen/APPhbf8Afpf8KLIA/svT/wDnwtv+/S/4UWQB/Zen/wDPhbf9 +l/wosgD+y9P
/wCfC2/79L/hRZAH9l6f/wA+Ft/36X/CiyAP7L0//nwtv+/S/wCFFkBXvLCw hiLrY24wP+eS
+oHp71cIKUkhSbSMC4utPhvUsyLVbiRS6R+THkgd+n+cH0NdcaEH0MXOS6k7 +UNMmKwRI5il
G5I1UkAL6D3rlxNOMH7ppTk3uX7eKObVZY5Y1kQxJlWGQeX7VzR3NWLqyWWn RW5i0m0meaXy
grKqAfKzZztP92lWqeySaVy6UOdu72MIawI0v5ZfD+nmO2kwArgEDYp/uc8k 88dh7nmeJlFX
cV9//AN1h4tpKX4f8E6G/XSdPezjk06F5bycW8KJCuWbaWJ5wAAiOx56KQMk gHvsjjCRdJi1
m20ttOh8+4gluEYQrtCxtGrA985lXHHY/iWQEd62l2eo2VgmkLc3V1uYJFFG NkalQ8jFiBtU
umQMsd3AODgsgND+y9P/AOfC2/79L/hRZAZeo3egaVqVnY3llCj3alo3FuCu fNiiCnHOS86A
cY65IxRZAan9l6f/AM+Ft/36X/CiyAP7L0//AJ8Lb/v0v+FFkBT1NdJ0q1S4 n06FkeeG3ASF
Sd0sqxqee2XGfbPWiyAuf2Xp/wDz4W3/AH6X/CiyAP7L0/8A58Lb/v0v+FFk BT1FdJ0xLeS4
06Hypp47cusKkIzttQkdcFyq8A8sCcAEgsgM+T/l5/6+ov8A2nWBZZ1trDSd AuNTksLaR40B
+eMcsSAMn6kZrV2UbmNSfJFyONvLfSrJ4f7T1t4NQmhE42RgRLnoNo47eh96 xem7OVyt8U3c
6nwnNY67oouJbK0aaKQwyOkKhXIAOQO2QRWsGpK50UajnG7LGsxaVpdrPe3N tBFbW0LTSsIQ
dqqCScAZPA7UpLXQ3Rkyar4fjsLK9WETRX0Ymt1gsnlkdCAd3lopYL8y5JGA WAOCRU2An02f
S9Ua7EFiE+yyLE/m2+wktEkg+UjI+WRQQQCCCMUbASaidO0y2S4mso2R54oA EiUndJIsannt
lxn2zSANLOnatpFlqVvZRrDdwJOivEoYKyhgDjPODRsBv/2Xp/8Az4W3/fpf 8K3siQ/svT/+
fC2/79L/AIUWQB/Zen/8+Ft/36X/AAosgD+y9P8A+fC2/wC/S/4UWQB/Zen/ APPhbf8Afpf8
KLICjqlrb20Ef2eCOLdLHnYgXPzr6VE1YaG2FvDcXV4k8KSqJAQHUEZ2L60o bjZof2Xp/wDz
4W3/AH6X/CtLIkP7L0//AJ8Lb/v0v+FFkBg+IdMuHurODSIrOBmSR5N8ScgF QOqN6n0rWk6S
lyzX9f0zKqqlrwZSi0PW1/1psm+giH/tCtmqHRf195inW6s19PsIH0Xfc2ts 1wrujMIl7SEd
lHYegrjm4Su4LT/LQ64qSS5ipqD6Tpdus11bxgM2xEjtzI7tgnCooLMcAnAB wAT0BrEog0+9
0nU7yW2gsGR4oI5z59oYTtdpFA2uAwOYm6gcEEZzTtYCfVDp2k6Re6lPZRtD aQPO6pEpYqql
iBnHOBSAqPqOkR+H9Q1o2A+zWP2nzFES7z5DOr4GcclDjkds4p26AQDX/D+0 /wChStIsksbR
wWDzuvlyvGWYRK21S0bbScZwfQgFgNLTjp2p2z3ENlGqJPLAQ8Sg7o5GjY8d soce2KWwFTX9
R0jw5ZLdXlgHjbzMCKJSfkhklPUj+GJgPcj6hpXAXSNT0rVb+6trWx8uWzJL M8SgcTSxcEH+
9A5+hX3ALWAXWf8AkTta/wCve6/9nrrwH+90v8UfzRlX/hS9H+RhfAn/AJE3 U/8AsKSf+i46
9XOv95+X6swwn8JG/wCHLmOy0nQp5VlMf9nKmY4mkwSsZHCg+hrycW0sVUv3 f5m1D+FH0X5G
NZ+HrWPTW0y+1a6ns49Lm0q1EWlTRvHDKEBLsdwZgI0wQFHXjnjnUkupqa2g 2d0L291C+u/t
Ny6RWwdbRrZDHHuZSEdmbO6VwTnHAwBjJjyQzVuP9faf9dT/AOgNQM1dSge5 0u7giAMksLoo
PHJBArqi7NMzkrpo46fQ72e8uJI7TUBPKGJWTVpHjXeCM+UZSoHXA24GOOlK KtJO6/r5Cbum
rGz4xi2eF7tkaUFmjUgTMuQ0gBHXoQxHpjHoKzm2o3R34GMZV0pK618+jORn ZrfVo4o5NTu4
GhZiILmWYhgwB4j5AXlc9D17inhKFJ1bNK1utv1N8fKf1XmirPmWytpZ/nv5 bHTeHbG7nuY7
+R7+2toshIbieUtKcEfMjn5VHbIySM8ADd21/ZwXJC3y/r+vy8SlzvWbM3xZ Z3VxfSHTNMvh
qZiKwahBcrFDG+W2ecvmAyKrHdtKOMM2AckHzup0mdqXhvVRq99eWLuYbdhf 2dujhFknLRl4
hz8hIhkBfHP2yT0bcXA0k0G4soPCttE32n+zrkyXU5AUuTbTK0pBOSzSOCep yxJzyaVwOqtf
+PhPx/lTjuDNGtiQoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgChq xIsnIGcAH/x5
a1o/xERP4Tz+bwvaSw3Dy3U0l/LL5q3bH50I+6BjHAHYY/DAx6CRzM31Vl0p gzM+IZhuYDLc
JzxxXFi/8v1N6Jr2X/IZk/65J/N64Y7m7OW11Td67qyT3E+23ZGt4xd7FLeS DgL2PJbPsR3q
JpSbue3h7Ro02ktb30v1/pfj0OesLMXOj34jtdTnu5QuCqysu4xKeccc5B57 EdsVxz5mmkvw
M6to1nqkrvt3PQNRiXTfE+gXrlvsawTadvZixR5TE0Zdm7EwlMk5Lug53ceq tDxjhn8GarJF
bww6E9leQ6cbfUtQjNtu1N/PtmkIJYmQyLFN/rlAO/D4DNQBseHfBf2fWdLu LvSXNjardSQR
3wtma1lZrbYVjhURxnMUrDZnqWJDOQADLi8K+IP7Ye8/syaKRtl1fBBaRQXV xHd2837ny8O+
QkwRp+RuGSu5jQBJqHhfWNd1m/1C40F47SaczNaXUkLNKitpx2EK7KS4tZgA TjpuKg0Abni6
1tZLLwjbSeHPtdqL8AaT5cBwBZz4TazCP5cD+LHy8Z4oA5/XvCviC40GKCLT JmmgiuJNMFoL
QyWUjyu0aO83+rVE8hV8g5Uo+DgIaANS78M3k6XsC6M6atLqMc/9tx/ZyzQf bklVQzEuTHEF
G1k2/usDIC5AM/xN4Z1270sWdvozmewgkWwuLD7KWNy2WM7PcEyIGPltlG8w OJSWbCOwBT1X
Tzd+JTo9hbQr4qF1fStqsc0Rkjilt7jyN7KxnRVEsC5ZAoKqFJ+TIBoR6A+l eEtf06KzvbNt
biXT7S1ufsiEzOrqXEVqoQKFYMz5ZysTZAEYyAdTJ/y8/wDX1F/7TrnLNfUt Mi1jQ5tPmJVJ
4wu4dVPUH8CAa2teNjKpBTi4s43+yPE0UsEb6PYXdxbJ5MN8zDhOgyCc8A91 P41nyyOTkqrS
ydup1fhvRF0DR0s/MEkpYySuBgFj6e3AH4VpGPKrHRSp+zjYy/G1hqWpxafZ 6a8MWbyGWaaW
PzBEsRMqnbuUnMkcanB6MfqJlozZHMw6Pf2VpNa6npN5qciXs8tvd6VMtm+y UrK4JM6sFMju
Nu4g+WpI4BM3GR2nhXUkE+o3tpbTeIDqFi/2+MIHaNUtlnKtgFVO2cbeMgkY +bBLgZuleDdV
s44t1veG7SS0N3LLJbLHdOlzC7yr5ah5MBJCGmIcBuhLth3A7rwvZ3GneEtF sbuPy7m2soYp
UyDtZUAIyODyO1S9wOtrckKACgAoAKAMvW/9RD/11T/0NazmNDdK/wCP29/3 /wD2RKUNxs1q
1JIhbIuMNJxjrKx6Y9/9kfr6nIBl301tYavZGe4WKMwyjdNLxnMYxlj6D+Zq NIzTfZ/oDTat
/XUk/tnSv+gnaf8Af9f8av2ke5PI+wmnSJLoryRsHRp5irKcgjzW5FZL4H6v 8zR7nnul6DNY
2F0tx4bvJ42kjMUiNbwak7gPullmjlVW+9tDBg53uGByWZXAjm8J6leW2sXd 3p6T6mNLEelT
TMjz28gkuWjUSEkrIqvAC+eWGdzYzRcCpqPg3VZ5tekS3vJb65jvQs/mWyRT JIkgii37fOfA
eMbXIQFMg4RAXcDr9B0e+swZJ725gQXd3IbNREYpFe4ldGJ2lslXU4DDoMjr mWwIPE9ndXFw
TpmmXw1MwbYNQguVihjfJ2ecvmAyKrHdtKOMM2AckEQGNceD79bB5NKtYbDW bm91EzXsbLHI
YpRc+UXdfmK7mgOOSCFOMrw7gZN14K1JtEuYNN028hWTzQLe5e0iwxs7mPcE gAjGWljXcSWO
OQAgJdwPV6gZh6z/AMidrX/Xvdf+z12YD/e6X+KP5oxr/wAKXo/yML4E/wDI m6n/ANhST/0X
HXq51/vPy/VmGE/hI6PQJY4fCekySuqILOHLMcAfIK8fGtLEVG/5n+Z0YdN0 oJdl+Rqqyuiu
jBlYZBByCK5k77GtraC0AV7j/X2n/XU/+gNQBv10EEalvtLgk7QikemcnPb6 dz9B3AC4t4Lq
BoLiGOaJvvJIoZT35BpNX3KjOUHzRdmZQTSdNuHFjYJDcKVV2trM8DIJUsqH tg4+nTrTVO2q
KniKk1yzk397NO2uortGaIt8jbWDoUIOAeQQD0I/Om00ZJ3KGpXttYTwxtaT zyTBmAixwFxk
nLD+8K5qtSNNq6vc2p03NN3tYzbLxFa3SxGTS7qES3BgVtysud+0E/Nn0zxx nv1rNV4XScX+
H+Zo6DV7Nf18jdnWztbeW4uGSGCJS8kkj7VRQMkkk4AA711cqOe5C95YWllb 38heGGZokQyR
urbpWVEBUjKks6jBAxnnGDQopCuWL6+t9Os5Lq6k8uFMZIBYkk4CgDlmJIAU AkkgAEmqAkgm
W4t4p0DhJFDqJEZGAIzyrAFT7EAigCO8vrfT4FmupPLjaWOEHBPzyOEQcerM B+PNAEkE8N1b
xXFvKk0Eqh45I2DK6kZBBHBBHegCSgAoAr2F9b6np1tf2cnmWtzEs0T4I3Iw BBweRwR1oAsU
ARzzLbW8s7hykal2EaM7EAZ4VQST7AEmgAgnhureK4t5UmglUPHJGwZXUjII I4II70ASUAFA
BQAUAFABQAUAFABQBWu0EmxTkdeVYgj8RyKLtPQLXKy6fCest1/4FS//ABVU qkvL7kTyL+my
DVbaO30y4CbyTE+S7s56epJNZ1JOW5UUkFl/yGZP+uSfzes47lMTWbfSIGS5 u9HhvJ7iQRgi
BGdjtJ5LY7L60VZxpq7Vzoo1K1uWE2kvNlKHxZbww3K/2Tcw21mwjGwR4ChQ em7jqRgZ4A+g
x+tRitYv8P8AMboSk/iTb9f8jannlSZlVsAe1byk0zlSK8eomV5UjuEd4W2S KpBKNgNg+hww
OPQj1pczHYk+1Tf3/wBBRzMLFe41ZbWa1hmn2yXUhihG3O5gjPjgcfKjHn0o 5mFi9azSSSkM
2RjPSqi23qJlutBBQAUAFABQAUAcxJ/y8/8AX1F/7TrnLNjUNRi0jRZL6YFk hjB2j+InAA/E
kCtr2jcynJQi5M5iTUNaXy5bjX7KzuJY/OS0aNdgXsCxGf1H4VlzS7nNzT3c kvI6Hw7rI1zS
luigjmVjHKinIDj0Ppgg/jWsZcyub0p88bl2c2qywrO6LJM3lxBnwXbBbAHc 4Vjj0BPam0ma
DYVs7lC8DJKgZkLI+4BlYqw4PUEEEdiCKXKh3JPssP8Ac/U0cqC4fZYf7n6m jlQXD7LD/c/U
0cqC5NVCCgAoAKACgDL1v/UQ/wDXVP8A0NazmNDdK/4/b3/f/wDZEpQ3GzWr UkKACgAoARlV
1KsMik1cCL7LD/c/U0uVDuH2WH+5+po5UFw+yw/3P1NHKguH2WH+5+po5UFw +yw/3P1NHKgu
H2WH+5+po5UFw+yw/wBz9TRyoLjZLaJYnITBAJ6mk4pILnKaz/yJ2tf9e91/ 7PW+A/3ul/ij
+aM6/wDCl6P8jC+BP/Im6n/2FJP/AEXHXq51/vPy/VmGE/hI04XuLbwHpl/a yKktjYpcAOuQ
+ISNvUY69a8bG0fb4qdO9ryf5m9CqqVBSav7v6DoszW891DrMpg81pJbnT44 vLztXIIbeTjG
SR/eOenHFTqRwbdOau/NHRUh9YUZQdu1nub1rE0FusT3Mlw65zJJt3HnvtAH t0rondvmtYyh
ZK17jbj/AF9p/wBdT/6A1QWb9dBBEo/0uQ46oozj3bvj+p+g7gEtAHBeMNO1 O/kkt7KfULbF
9b3ObeBXSRUaFskmNvmXy22gYGcbsiqabSsSmk3c6Hw9DdfZJnuJLkO0oO6Z FV5MIg3MNowT
tPQAcnA6YT2SBbs4/VrjU5or++fULotYTTwxAQJjbvAzkAZHyjJ7Hb61xzjz avofR0KVFOFP
lXvJN6vt+fb5lDTWikis7eHXZXuHv1wimMkAzfeA2ntzzx7Y4rl5k5JLuvzO JxaTbXR/kd34
148K3Ej/APHrDLBLdg8g2yTI04I/iXyg+V53DIwc4r1Tyzm/EcFxc686XUWr S3A1awewWBbh
rYWyyQM5fy/3WQwnOZPmGAemygDDtdL8RX2nrBqd1qdzNLLZf2hCtrcwiOYX cBZkleUj5QJT
ut1VMAsSAI6ANzXDq9p4q09LE6hCltPaW8SLFeXK3NuXQSSPIH8lSFaRT5qs /wAm7cMoQAZ8
kus31v4X06S31aS4sILVdS822m2GdLyyJYuw2yEBJjvUsMBjnBzQBoWMMmhf BPUoITqFrqFh
pMiTGd5t0VwlvhvKZz9wEfKYzs4+WgCO4e8FnqEWlJrI0SX7Ovn3a3zzwSZl aRlQsty6nFuu
EYKN5PIEgIAeHJdRluNPPiJtZeFfksGihu4QzrczLmZVywUxC2P+kE5GTkne SAU9Ni1zTvAu
m6de2+oJNPZ2qm4hjuGW0hSMfL5MLLIJA+EYBgzeZuyURo4wDP1C81eLwZqN zrVxrqGDTrj+
zJraO8gIlSW4AeUIdyjyxbEGcnjJyTvJAOk0aHX/APhOZJby+vf+Pq4823+x z+T9my/k/vWk
8jp5J/dJ5meG/wCWhoA6DwVz4VtpE/49ZZZ5bQDgC2eZ2gAH8K+UUwvG0YGB jFAHQUAFABQA
UAFABQAUAFABQBBcfeT8aTGCdKSEUtc/5Bs3/XJ/5VMhoisv+QzJ/wBck/m9 THcbKPjPCQ6Z
NJfSWsK3WHZduBmN8Ekj2x1x8x9sZYrRRb7/AKM6MNduSS6fqjhZJ7b7JrAX XXkd3Plx7kPm
fIPbnnjj0/PinKLj8jsjGSktDsPE6avZNa3mlStdXMSm2aObJSQyBVWVlQDl ZAhYjAVDLgZx
XpvezPLOQ1C21eykuLRZ9Xv4oLkR29szXKNeAW1uoY3UX+q+fzCS3yMzNnBG 5UBfk1DWbWaz
s4bTUbrULfUr2d4ykixSwlLloUM5Hl7TuhAGTtOBgFcA0AzdCi1VvEunxNJf Xen293HMss9l
dQhGa3u1fm4Z3x/qh97aCwwASct7Aeq2X+uP+7RDcGXq1JCgAoAKACgAoA5i T/l5/wCvqL/2
nXOWaWtaUNb8OXGnbwhmjG1j0DDBGfbIFa2vGxjVhzxcTg7i0uZ7i2/tLwlc XWo2sQt1ZSTC
4AwpJxg9fUe+Kys+qOJptrmhqvuOz8I6G+gaEttNt8+RzLIE6KTgYH0AFawj yqx1Uafs4WZR
8cabqWpnw/FpjOkseomR3UsoCfZpwyl1GYw2dm8cqXBHIAqzY5/X01m4vbQa UdQ0eyjs0jsL
aHT5nMdwruroVikSJQuIgDNuiI5U7dxIB0GnJqUniy4sDevJp+mzyXRkErF3 aZcpA56EJvlb
ZxtX7KRnmgDrKACgAoAKACgAoAKAMvW/9RD/ANdU/wDQ1rOY0N0r/j9vf9// ANkSlDcbNatS
QoAKACgAoAKACgAoAKACgAoAKAGS/wCpf/dNJ7AcfrP/ACJ2tf8AXvdf+z1r gP8Ae6X+KP5o
iv8Awpej/IwvgT/yJup/9hST/wBFx16udf7z8v1ZhhP4SOm8N/8AIr6R/wBe cP8A6AK8jGf7
zU/xP8zeh/Cj6L8iS40ayupJZJUlzN/rAs7qrcAcgEDoAK4JUYSfM1qdUas4 qyZPb2NpaSzS
21rDDJO26V44wpkPPLEdTyevrW7lKSSb2MVGMXdILj/X2n/XU/8AoDVJRv10 EECD/TpTkf6t
OMDPVu/X8+PTvS6gT0wKN7qFlARFNdWySBlJSR1BAyOcEj65/n0p8reyFzJb stQXEFzH5lvN
HKmcbkYMPzFDTW4Jp7HOapovhm3uC19BMJLou5CPM27JBY4U8ckVzVHSg/e6 +p6NLFYpq0Ht
bovluW9P8SaPKqpbiSASTsiqbdlDOXIzkDHzNzzzzzg5oWIp3t+jOaVCotX+ aNyugwI4IIbW
3it7eJIYIlCRxxqFVFAwAAOAAO1AElAEc88Nrby3FxKkMESl5JJGCqigZJJP AAHegCSgCOeC
G6t5be4iSaCVSkkcihldSMEEHggjtQBJQAUAFAFO80nTdQuLW4vdPtbme0bf byTQq7QtkHKE
jKnIHI9BQBYnghureW3uIkmglUpJHIoZXUjBBB4II7UASUAFABQAUAFABQAU AFABQAUAZlpr
OjatHFLY6tZ3UbymFGguEcNIF3lAQTltoLY64GaVgLkzwWdtLcXEywwRIXkk kYKqKBkkk8AA
d6LAZcmteHtUvX0VNcsZL8l4jbRXUZmBAO4bM5yMHIxxg0nG4bF6GC0j1KQJ OGuVjQvFvBKq
SwUkdQCQ3PfafQ0KKQ7ktvf2d3LJFbXcM0kX31jkDFPmZeQOnzI6/VWHY1Qi VIo42kZI1VpG
3OVGCxwBk+pwAPoBQAyS1SRyxLAn0qXFMdxn2KP+8350uRBcPsUf95vzo5EF w+xR/wB5vzo5
EFySK3SJiyk5xjmmopBclqhBQAUAFABQAUAcxJ/y8/8AX1F/7TrnLNy5vYNN 0t7y4bbFDHub
HU+w9z0ra9o3M5SUU2znl1nxJMqXEVlYxxyL5iW0rnzWX65/p+dZ88uxz89V 6pI3dG1WHWdN
S7hVkJJV426ow6g1pGSkro2hNTjdF+qLCgCOOCGF5niiRHmbfIyqAXbaFyfU 4VRn0AHagCSg
AoAKACgAoAKACgDL1v8A1EP/AF1T/wBDWs5jQ3Sv+P29/wB//wBkSlDcbNat SQoAKACgAoAK
ACgAoAKACgAoAKAGS/6l/wDdNJ7AcfrP/Ina1/173X/s9a4D/e6X+KP5oiv/ AApej/IwvgT/
AMibqf8A2FJP/RcdernX+8/L9WYYT+EjpvDf/Ir6R/15w/8AoAryMZ/vNT/E /wAzeh/Cj6L8
jTrlNgoAr3H+vtP+up/9AagDfroIIlP+lyLnoinGfdu2f6D6nsAS0AcB4vvt Vt5Z4NJ1GCzm
N/byyCSIszIDCSQRImFAV9y87hlRjNU02lZEJpN3Z0Xhye4u7a4uHnikZ5hv dYiFchIwSo3H
A4bjJxxyccjvZX/rUcbXdjP8SfbRrWmhLyCIG2l5aI8sCm7+LocjA7YPJzxw Yle9H5/odtC3
I/Vfqc1YjURZWg/tC2LHUVCqYScEzcEjcMjPOOOOM96wfxK3dfmb6a+j/I9C 1v8AtEaPPJpP
zX0W2WOP5R521gxiy3C7wCm7+HdntXqHmnB3/iDU5JoNWh1DT7OC+s7qeymv ikSQW/nWaIfO
KEqXUtIAynDSIrK2wUAR3HjibT/Dmr3c+rzW27RjNpcmqC3SWe4D3AJTYPLl 4WAjbkFWQ/x5
IBn+N/FV60mu6el9CLW5tb61fTprmP7REEtZm8wQiIOqs0QIZpGBWQHaNw2g HsFABQAUAFAB
QAUAFABQAUAFABQAUAFABQAUAFAGZ4jhsrnwxq0GoyyRWMlnKlxJEMusZQhi owckDOOD9DSb
SV2VGMpyUYq7ZyUdzceIYNRmsZtM1e/0/wCzXVtqOmIIlndHdja7y77W2hlJ 38LdcrgncySO
K9vvENx9gaJzp+vTx6hA7y7lFjGVDrsP8Egjhypx/wAfrAqfLfIB0ln/AMlD 1n/sF2P/AKNu
qAM+fXdH0T4h6p/auq2Vh52l2fl/arhIt+JbrONxGcZH5igDj5PEV1Druv3x 8QfZtWitXSys
v3I/tBor2+SKHYyl2+6i4jIY7uuSDQBsX/iLUodF3Prf2OafVL5Vu7m4gtYI o4Z3iWDzGhkG
4gBgCpY7XO7C4IBHoni/V7mxg8QahduLA3lolzBBbh1iSWwRwEVVMjFrieMY yx6dBuyAd5oX
9o/8I9pn9r/8hP7LF9r+7/rdo3/d4+9npx6UAaFABQAUAFABQAUAFABQAUAc xJ/y8/8AX1F/
7TrnLL3iHTJdY8K3VjA2JpI1Kc4yykMBntkjFatXjYwrQc4OKPPb250u/urR 9Ui1KK/t4Bbv
ZIMeYwBAIIORnPoaxdnujhk4ya5r3XQ6TQpT4L8MWx1K3uGlv7s4ijAZo8oT zkjosZJAye2D
VcyowvI3pv2EFzdWR+KzZeLofDUenXygnVmMU4XJt50tZ3RmQ4OVcK2xsZxg jBrWMlJXR0xn
GavFmVZ/2joHiHWdeuv3Nw9rY6jq8PytiItdIybhkfuYwhygy/kdMuaooBpn iK78V3GpRzfZ
vEI0u2R/ljf7PFcT3W5OuxvJ/dNnq/2fHHmGgDHstR1Tw5aJo2iXdlplhZy3 Yso7q42/anF7
cL5QUxSPPtCRjZGUf94OSWXABuahrPiS10a41Cy1S6uru8vNTsre0+zxMsRh W6MRjCoGZ826
DDFgctxkjAB1GieJLbXPFWqwabqlrf6fbWdq6m2kSRUld5w+WXvhI+CePx5A OkoAKACgAoAy
9b/1EP8A11T/ANDWs5jQ3Sv+P29/3/8A2RKUNxs1q1JCgAoAKACgAoAKACgA oAKACgAoAZL/
AKl/900nsBx+s/8AIna1/wBe91/7PWuA/wB7pf4o/miK/wDCl6P8jC+BP/Im 6n/2FJP/AEXH
Xq51/vPy/VmGE/hI6bw3/wAivpH/AF5w/wDoAryMZ/vNT/E/zN6H8KPovyNO uU2CgCvcf6+0
/wCup/8AQGoA366CCJd32uTP3Ni469ctn29OnPr2oAloAjm4jHBPzr0JH8Q9 P/1evFAElAFa
70+yvwgvLOC5CfdE0Yfb9M1MoRl8SuVGco/C7Gfb6R4e0++igh0+zjuiTLH+ 5BYEknIbHHfA
zwBxwK574eFRU9OZ6o15qsouV3Y2a6jAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
oAqXt+tl5aLDJc3EmfLgh272A6n5iAAMjJJA5A6kAzKXL6m9Gg6t22oxW7d7 Ltsm7vsk3u9k
2q0WmSXUyXOr+RcSxsHhhRP3cB65GfvOOm/A4HAXLZlQbd5/8N/Xf8jWWIjT i4Ye6T3fV/ds
v7uvm5WVtStDjCgAoAKACgAoAp3ml2l/cWs10jyG2bfGnmsIy2QQWQHa5BAI LA7SMjB5oAuU
AFABQAUAFABQAUAFABQAUAcxJ/y8/wDX1F/7TrnLOge4itLE3E7iOKKPc7Ho ABzW60Rm2lqz
nx4p1CWP7VbeH7iSx+8JDIFcr67cf1/Ks/adUtDD2snqo6F9oNJ8W6Xazyxm e2V/NQFmQq4B
UggEdiwIPFU4xqLUu0K0U3salvbw2kCQW8KQwxjCRxqFVR6ADpVpW0RokkrI jvLG31CBYbqP
zI1ljmAyRh43DoePRlB/DmgZYoAKACgAoAKACgAoAKAMvW/9RD/11T/0Nazm NDdK/wCP29/3
/wD2RKUNxs1q1JCgAoAKACgAoAKACgAoAKACgAoAZL/qX/3TSewHH6z/AMid rX/Xvdf+z1rg
P97pf4o/miK/8KXo/wAjC+BP/Im6n/2FJP8A0XHXq51/vPy/VmGE/hI6bw3/ AMivpH/XnD/6
AK8jGf7zU/xP8zeh/Cj6L8jTrlNgoAr3H+vtP+up/wDQGoA366CCJR/pchx1 RRnHu3fH9T9B
3AJaAOA8X3V7ayztp2m2N3Ob+3R2uW+dYyYcgDy3+UgvuPG0ZYZNU5uKSuQo pt3R0XhyWSS2
uGS2t4h5w3RxOdkZ2R5C/KMjljnAz6DPA3dJ/wBbjirNo4XxrNq8fieUWGq6 tEhijMsVtLmO
OTHKrnHGNp+rHp0rN46NL3LLTujnrYTFVJc1JOz87fqiHStX1FBbveedJNZY KSzqfOmBcsdz
AkYB2qOn38V4eZ1lOpDExSvF9FbT/L/M9XLaOIjCVGurLpqn3v1f9I9XdYb+ xZRIxguI8b4p
ChKsOqspBBweCCCO1e7FqSutjlaadmeOreX8U2rpHPrMrWUUiWl3/aL+RZP9 vvI0luA0mZEU
JHuJWTCRncMDliOwsLK+1Hx7rU0vnPY2l/GiuNYuYvLxawuFFuo8t1LNk5Iz uOQccgFjxlb3
UHm6xM00+kWVqZZoINSnspIgm5pHXyv9czLgBXKgFOD87EAEkniLWhf3GmW2 lpc6haNcTSR8
xxywBSbcI5Pyu5eNdzDbmK4x9wUAZemaxreqeLdMtjqkKTQRXa31u2nSwhdr Wh8soZiC4Ehx
KGZcPwCDkgFO18c+KLrTra6fTrWzTVFtpLJ7hEIjWW4hj+6k5eYBZ87sRYKj I+fAAOg8P+It
SvdXjs74WrpOt4EMMbRlGtZ1gcnLNkOW3AcbANpL/eoArw6ncxeEjcvI80h8 QNb5eVwQh1Qx
gZBBwFOAM4wACCMggHP6L4i17w/4M8LWqjT7173TrRrRTG8AjXzbWEo7bn3E i4HzgDBTO1s4
AB0GpeJ9X0/WbaGKFL2zgntrHUJY7YRqk8rIMhmm3AYljbaI3HON+clQCOw8 XaxD4Z0XX9Ys
4ZLXULXzHh0+N3kSRoleJRuODvIkXHXfJEg3cswBY8QWH9pjwbZ+ILSyu5JL /wD0qER74GkF
ncE4V+q7hkZ54FAFe31nW5/FWqaFa3FlFcC6mlW5mgllQRJDakJ5fmjDf6QM srBfkJ2ZckAG
H8LNSmhgg0/akME62r+dKCfOYaba/uo8HAcD5zu/hU7Q3zmMA7DwldtD4bZt R1F53TUbu3+0
XTqGci7kjQE8DJ+VQAAOgAHAoAy7bVNef4nW9tfWN7b2MlreLFGJITAUSSHZ McPvZjnuo2+Y
qheHcgFzXFXWri2TR9UunvpYFltpLa6Zbe1Qk4uXCECUHjaj7g5TAAXzGABr f2k+q/utIbNu
3DagpVox6iPk727ZxtBzkkqUOXPz6Q+//L+rfkd31dYf3sRv/Jqn8+y+fM9L JJqS5qwk1aHw
1NcabaTX+o3GqXVtc3cQgFwIo7iZFf5yiMwVVRQeF3A7SF2m4wUdjCtiJ1rJ 7LZdF6L8+r3b
b1E8O6ldt4e8A3jq8d3qaxW95LMFeW4RbSeRSz5JILjeOc/Mc4JYVRgdtM7I V2nGc0mAqOxH
JoAq6rcS21jLJC+11jYg4B5AqZNoaI7W7nk1N4WfMYjUgYHU7v8AAUoybYNG nWggoAKACgAo
AKACgAoAKACgAoAKACgDmJP+Xn/r6i/9p1zllrxRZXOo+ELu2tATOY1ZAOp2 kNge5xitWrws
c9eLlBpHEXOpWuovZX//AAkM2nxwWoimgRGEgZQQdvGOT61i2nrc43NSs+a2 h1fgCzurTw4X
ug4a4maZQ4w20gAZ+uM/jWtNWidOGi1DXqS+Poi3gXWrhLi6t57OzmuIZLa5 khZXWNipJQgk
Z7HI9q0Ogx7y+1DSPFlt4e0aZIxOtugn1B57wqGW9kbhpQScwKM5zg4OQqgA Eb+NNYax1W5i
SyT+wrWW4vFaJ2+1+XNcRER/OPJz9lY5PmY8wDnblgDY0i0Gt3VzqOoXN6t7 aX80It4ryWGO
JI5D5QaJGAbcmyQ7wdwk/uFQADDfxlrw07SbhTp4fXYILm0Bt3ItFe4toyr/ ALz96cXQ5Hl8
p0+bgAsWuq69eePLXS2vrVHsFuo7tlt38q5UCykBWPzPkcCcqGLPjDHHzYAB c8PeKdR1TxCt
tPa50y/tZL3T7ryVi3xK0YHAlctlZlOWWMjH3eSFAOwoAKACgDL1v/UQ/wDX VP8A0NazmNDd
K/4/b3/f/wDZEpQ3GzWrUkKACgAoAKACgAoAKACgAoAKACgBkv8AqX/3TSew HH6z/wAidrX/
AF73X/s9a4D/AHul/ij+aIr/AMKXo/yML4E/8ibqf/YUk/8ARcdernX+8/L9 WYYT+EjpvDf/
ACK+kf8AXnD/AOgCvIxn+81P8T/M3ofwo+i/I065TYKAK9x/r7T/AK6n/wBA agDfroIMrUb2
S0uBHbohu7kxww7sEZJckkDBwqqzYJGduAQTWc5OOi3Z04elGo25/DFXf5Jf NtK9na92rIT+
ydQb5n8Q3queWEUUAQH/AGQ0bED0ySfc9aXJL+Z/h/ka/WaK0VGNvNyv87SS v6JLyRSu/DSy
N51zq11K5Krue3tCeSAOTF71SU1tN/h/kJ4ig96EP/J//kyxB4fntY/Lt9dv okznakNso/IR
UnGT3m/w/wAhrE0VtQj98/8A5My734e2moXkt3c61qrTy4LsskSZwABwEA6A VzzwcJy5pN3+
X+R0wzP2ceWNGFv+3v8A5Ihi+Hum20rxJrmpiSZNpVpoiSoYNxlPVV5HpWbw VHWm3v00KeaN
q/sY6f4v/kjTm8JLdaWNMutXu7mxCqnkTwW0iELjbkNEc4wOvpXTGk4RUYyd l6f5HNLGU5Nt
0I/fP/5MktvDLWW37LrN3BtiSEeXb2q4jTOxOIfuruOB0GTjrVckv5n+H+RP 1ql/z4j98/8A
5Mzx8O9JW8hvA4F1Bs8qYWFnvTYAEw3kZG0KAMdMDHSjkl/M/wAP8g+tUv8A nxH75/8AyZYu
vBVrfajBqF5fS3F9b7fKuJbO0eSPacrtYw5GCSRjvRyS/mf4f5B9apf8+I/f P/5MkbwmHe9e
XWr+U3yiO482O3cSIFwEIMRGzBb5emWY4yxJOSX8z/D/ACD61S/58R++f/yZ Gngq1js7Wzjv
pUtbSUTW8K2doEhkBJDovk4VsknI55NHJL+Z/h/kH1ql/wA+I/fP/wCTCHwV a28tzLDfSxSX
MqzTslnaAyyK25XYiH5mDfMCeQeaOSX8z/D/ACD61S/58R++f/yZYi8MtBKs sWs3cci+ZtZb
e1BHmMGfB8n+JgGPqRk0ckv5n+H+QfWqX/PiP3z/APkynH4D0+G9mvYrlku5 m3yTLZWYd23h
8lvJyTvVWz6gHqKOSX8z/D/IPrVL/nxH75//ACYWXgPT9NSRLC5a1SRkd1gs rNAzI25CcQ8l
TyD2PIo5JfzP8P8AIPrVL/nxH75//Jkl14Ktb7UYNQvL6W4vrfb5VxLZ2jyR 7TldrGHIwSSM
d6OSX8z/AA/yD61S/wCfEfvn/wDJkj+Ew9vaWx1q/W3s2R4YUjt1jQoPk+UR YIXggEYBCkcq
CDkl/M/w/wAg+tUv+fEfvn/8mSXHhqW7ntJp9f1J5LSUzQnbbjY5RkJ4i5+V 2HPr9KOSX8z/
AA/yD61S/wCfEfvn/wDJlO58CWd8Llb2/uLtLmcXMqXNvayqZRGsYYBoiAdi gcf1NHJL+Z/h
/kH1ql/z4j98/wD5MsReEY4Lf7PDqdxHBujfy0tbQLuQKEOPJxlQiYPbauOg o5JfzP8AD/IP
rVL/AJ8R++f/AMmR2fgq10+zNnZX0ttamVZjDDZ2iJ5gIIfaIcbgVUg9flHp RyS/mf4f5B9a
pf8APiP3z/8Aky4dAuGuEuG16/M8asiSGG23KrEFgD5WQCVXI/2R6Uckv5n+ H+QfWqX/AD4j
98//AJMxrz4cabqE0BvLjzo7aOKO2zY2m+EIxIUN5XCdMKAB16g4qXSk9HJ2 +X+RtTx1Kk1K
FCKkr63n8re9o1rrftazVzd/si+/6GPUv+/dt/8AGqrkl/M/w/yMfrVL/nxH 75//ACZT03wj
Ho1u1vpep3FjAzb2jtrW0jUtgDOFhAzgDn2o5JfzP8P8g+tUv+fEfvn/APJl CfQJ9K1jQruT
WLmbSLGVYorPyYI0hkZHhRsogJX94ECDAG4HOARR70Gru6/r+tikqWJjJQhy ySbVm7NLV73a
dru/NbS1ru51Vx95PxrRnACdKSEUtc/5Bs3/AFyf+VTIaIrL/kMyf9ck/m9T HcbNmtiQoAKA
CgAoAKACgAoAKACgAoAKACgDmJP+Xn/r6i/9p1zlnSRf6lP90VutiCs+k6bJ dfapNPtnuMg+
a0KlsjvnGaLInki3excplEc8EN1by29xEk0EqlJI5FDK6kYIIPBBHagDL1nw vo+vz2supWMN
x9nlEhWSJHWXakiqrhgdyjzXYDsefXIBYl0LR5vsPm6VZP8A2fj7Hut0P2bG MeXx8mNq9MdB
6UAF1oWj32owaheaVZXF9b7fKuJbdHkj2nK7WIyMEkjHegAh0LR7eW5lh0qy ikuZVmnZLdAZ
ZFbcrsQPmYN8wJ5B5oAkm0nTblw8+n2sridbkM8KsRMqhVk5H3wAAG6gACgC O10LR7DUZ9Qs
9Ksre+n3ebcRW6JJJuOTuYDJyQCc96ANCgAoAKAMvW/9RD/11T/0NazmNDdK /wCP29/3/wD2
RKUNxs1q1JCgAoAKACgAoAKACgAoAKACgAoAZL/qX/3TSewHH6z/AMidrX/X vdf+z1rgP97p
f4o/miK/8KXo/wAjC+BP/Im6n/2FJP8A0XHXq51/vPy/VmGE/hI6bw3/AMiv pH/XnD/6AK8j
Gf7zU/xP8zeh/Cj6L8jTrlNgoAr3H+vtP+up/wDQGoA366CDD1U/8T/RFz0u s4z/ANO9x2z/
AEH1PbKfxR9f0Z3YX+FX/wAK/wDS4G5WpwnD+LNcuNIaWWKxvL1jfW8A8m5E aRo7QqQQZU+Z
vMbaRkA43YFW5cqRCV2ze0K7knt528i4VfNGEllDtFlEJUtuOSCxPBI4OD0y m7pMcdLo4vxl
4j8Q6V4jeCw1hIbd4kkELWgkMJIwVLDOTxu5/vDtS+s0afuyim/WxyV44nm/ dp28lf8ARlfS
/FN1cy2t3fOJLqzwJZhmPzlLM2FQgYwoZSefvCvBzKrBV6eKpq1nZpO+n9X+ 89XLfbVKU6NW
LXm1a/4LbQ9G1o6gdGmOknN0du0rt3bdw37N3y79u7bu+Xdt3cZr3TnOT0rW tYPiXT9Lhnur
s7bk6hDqrQxS25U2pXBgjKMQk24AHB8zlgRgABN8RZFu5rWDSkneRk+wSiWZ IbhGuIod5keE
DH79GBj8wEZ5+6WANCPxXqVxfto9vpNqdaiaQTRvestuqosLErKIyzHFzFwU HO/ngbgDH0Lx
xJaaN4Vt7iF75LizsY7q7UzSSRzzKgAc+WYwSXRjvkVsNnByu4A1NN8X6pq+ naRLaaFDFeap
ateww3N9tVYVEW4l0RvmLSrtGOV5JU/IACPS9VvrfwL4K1KS5eRJVskvi/zy TCaMRrye/myR
sTkHCt16EAw/+E8vbvQHubaaZZreK91KU7Y0LWotxNDGpKsA6i7teSpGY3yW H3wDQ1zxfeW1
zp+qm18rQrS/vElaK5Jnn+z290HUxbQu3fESMufuoSAT8oBY1Dxzqej3kun6 hocP28+R9nS0
uZrhH8wTn5tsG8YFs/3UbqM4GSACxoPiPWNZ8TPGbD7PYCwhlmiuS8UsMhlu ELIrRhnVvKXG
/YQuDtySKALF8mpf8J9p1tFrt7FY3FrNcvarHAUzE8ChQTGX2t5jZ+bPoRQB Tj8dzfZbO4l0
pFTVYEuNMC3JYurywxqJvkHlHNxFnb5mBv64G4Aw/Efiq/XWLOOXzrKaxlEV 5BZyvMjn7Xpz
fLhQ0mYpyuNgPzOoBByQDQuvFusz69pMGmQQ7rvyJRBJdoYZIpIr1l/eJGxD YgjYlSy5ACnG
WYA6TVJ5pvEujaTHK8MTrNezMjEGRYTGoj4wQC8yMTnkRlSCGNAHLz6vruk2 t3Pql9qEN/bQ
fbZLd47VraWGGWNrn7OUUvjYSqCUhv3i55BZQCxF4tu73WbnS7WZ0nm1aKO1 Z412pAjSLMh6
nLGxu8HBP7yPkc7ACxpthrF/L4mspPFGoO9pOLa0kkjhHlN5EMyyERohYh3P yk7WXgg5NAHS
aFqf9t+HtM1XyfJ+3WsVx5e7ds3qGxnAzjPXFAEPiP8A5BkP/X9af+lEdZVf h+a/NHdgP4r/
AMM//SJF+4+8n41oziBOlJCKWuf8g2b/AK5P/KpkNEVl/wAhmT/rkn83qY7j Zs1sSFABQAUA
FABQAUAFABQAUAFABQAUAcxJ/wAvP/X1F/7TrnLOki/1Kf7ordbED6YBQAUA FABQAUAFABQA
UAFABQAUAZet/wCoh/66p/6GtZzGhulf8ft7/v8A/siUobjZrVqSFABQAUAF ABQAUAFABQAU
AFABQAyX/Uv/ALppPYDj9Z/5E7Wv+ve6/wDZ61wH+90v8UfzRFf+FL0f5GF8 Cf8AkTdT/wCw
pJ/6Ljr1c6/3n5fqzDCfwkdN4b/5FfSP+vOH/wBAFeRjP95qf4n+ZvQ/hR9F +Rp1ymwUAV7j
/X2n/XU/+gNQBv10EGHqpP8Ab+iDDY+1cEg4/wCPe46c4z+Hp14xlP4o+v6M 7sL/AAq/+Ff+
lwNytThMy+0WwupTPLExkdl3FXfnoOikduM9u/SncVi3Z2Ntp8Jito9iFtxy xYk/U89hQ3cE
rHP6z4c0uXUZb281i4s3uCDsEsaKcKF43KT0A71w1qFJy5pytfzO6liZxiox inb1/wAyGx8K
aPN5xt9YuLslAhIlibZ8ysDwvBynf3rP6nQqxcVK6fmipYuorXil9/8An5nQ PpVvJo6aW0lw
IEjSMNFO8MmFxj50KsOnOCM/Su6EFCKgumhxSk5Scn1KsPhfSbf7O0UMyzQS mUT/AGqUzOx2
5Dybt8inYgKsSCEQEYUYskrx+CtBjukuFtZi0W3yka7maOELIkirHGW2ooeK M7VAGFAxjigC
xd+F9JvJ5rh4ZoriaXzXmt7qWCQsURCN6MCFKxx5UHBKKSMjNAFdfBWgx/Yx FazRR2nk+XFH
dzJGTDt8tnQNtkZdiDcwJwqgngUAWJPC+kyadY2KwzQQ2EQhtmt7qWGSOMAD Z5iMHK/KuQTg
lVJyQKALH9iad/wj39gfZ/8AiWfZfsfk72/1W3Zt3Zz93jOc+9ABeaJp1/8A 2h9pt9/9oWos
7n52G+Ib8LweP9a/IweevAoApy+ENDnv/tk1o8h3SP5D3Eht9zqyufI3eXlg 75O3ksxPJJoA
y9J8BQ232uXVb6a+urjygssc9xG0Ij37SjvM8it+9kBKuAQcYGW3AG5beHdM sri2uLaB4Zbd
SgZJnHmAlifN5/enLu2X3Hc7N1JJALj2NvJqMN+0ebqCJ4Y3yeEcoWGOnJjT 8vc0AZcfhDQ4
klRbRyki7FVriRhAoYMBDlv3IBVCBHtwUQj7q4ABfCGhqYGNo8kkLb1lluJH kZvMikyzsxZz
ugi5YnAQL04oAJPCGhyXF3cfZHjnumV3khuJI2RlLnKFWBjJMsmSmN3mPnO4 5ALmoaZ9svLC
8im8i6spdyvtyHjYYeNuQSpGDjOAyIxB24IBHpvh/T9KuGuIPtUs5XYJLq8m uWRSQSFMjMVB
IGQMZ2rnOBgAks9E06w/s/7Nb+X/AGfamztvnY+XEdmV5PP+qTk5PHXk0AR3 ujLLZanDYzvY
z6kwae4jLFwdixlkOflfYgCkcAgHB5BANCCCG1t4re3iSGCJQkccahVRQMAA DgADtQBm+I/+
QZD/ANf1p/6UR1lV+H5r80d2A/iv/DP/ANIkX7j7yfjWjOIE6UkIpa5/yDZv +uT/AMqmQ0RW
X/IZk/65J/N6mO42bNbEhQAUAFABQAUAFABQAUAFABQAUAFAHMSf8vP/AF9R f+065yzpIv8A
Up/uit1sQPpgFABQAUAFABQAUAFABQAUAFABQBl63/qIf+uqf+hrWcxobpX/ AB+3v+//AOyJ
ShuNmtWpIUAFABQAUAFABQAUAFABQAUAFADJf9S/+6aT2A4/Wf8AkTta/wCv e6/9nrXAf73S
/wAUfzRFf+FL0f5GF8Cf+RN1P/sKSf8AouOvVzr/AHn5fqzDCfwkdN4b/wCR X0j/AK84f/QB
XkYz/ean+J/mb0P4UfRfkadcpsFAFe4/19p/11P/AKA1AG/XQQYetDyb2y1B hiCznSSZsdEK
Sx7s4xhTIGOTwoY8d8qmjUuz/wA1+p3YP3lUpLeUbL1TUrertZd20jZiljnh SaGRZIpFDI6H
IYHoQe4rRNNXRxyjKEnGSs0NuRmJRjPzoemf4h7H/PcdQyQFyhxhZOcdYmHX Ht/tD9fQ4AMr
U5mGoWjxM6M1tKQQpDD5ouxU/wAqmKvVXo/0G3aD/ruZzTTfbbe5YyrNG8cX mHcN6tKoKkGN
R0Y/kD2zSr0UpKqnrovlcKc3bkZ1dWI5PxR4ons9I8RLpdpdNPptnMz3qiLy reZYPNVSGbcx
wUPCsvzAE8NgAkv/AB9omla9c6Tfy/Z5LeJpWk82KTIWIyt+7RzKMIGOWQA4 4JyuQA/4TWEx
aeBpF613qW9rO1Wa1Lzxqqs0iN53llcMOA248kDAJABYsPFkF7qK2x069t4Z bqazgupfLMc8
sRcOqhXLj/VSEFlAwvXJAIBhx/Eq31KWxj0axe8ne8EFxaxT28smxoJnVldJ TEDuhPBfOAeO
VJANDw94onuJjaalaXSGbUby1trxhF5Uxjml2xgK24ERxnllAOw8kkZAOsoA KACgAoAKACgA
oAKACgAoAKACgAoAxtcljuZLPSopFa7kuYZzGDkpHHIJC7DqFPllQcY3Mo71 lUadoLfT8NT0
MHGUFOvJe6lJX7trlSXnrdrsmzSuPvJ+NaM4ATpSQilrn/INm/65P/KpkNEV l/yGZP8Arkn8
3qY7jZs1sSFABQAUAFABQAUAFABQAUAFABQAUAcxJ/y8/wDX1F/7TrnLOki/ 1Kf7ordbED6Y
BQAUAFABQAUAFABQAUAFABQAUAZet/6iH/rqn/oa1nMaG6V/x+3v+/8A+yJS huNmtWpIUAFA
BQAUAFABQAUAFABQAUAFADJf9S/+6aT2A4/Wf+RO1r/r3uv/AGetcB/vdL/F H80RX/hS9H+R
hfAn/kTdT/7Ckn/ouOvVzr/efl+rMMJ/CR03hv8A5FfSP+vOH/0AV5GM/wB5 qf4n+ZvQ/hR9
F+Rp1ymwUAV7j/X2n/XU/wDoDUAb9dBBAhX7dKARuEaE+uMtjt9e5+g7rqBS l8N6FPM802i6
fJLIxZ3e2QliepJxyah0qbd3Ffcdkcfi4RUY1ZJL+8/8yvc+GfD0cSt/Yemr 86Ln7JH3YDH3
T6//AFx1pexp/wAq+4r+0sb/AM/pf+BP/Mm/4Rbw9/0AdN/8BI/8KPY0/wCV fcH9pY3/AJ/S
/wDAn/mZWq+DbGS4t5NP0XSgqo6urxLHkkqQRhGBxtYcjvR7KmnflQPMca1b 20v/AAJ/5lRP
BYbykl0XRwgmR3cBS20MCVAESg5AI/GiVOEtORL+vQSzHGr/AJfT/wDAn/mb F/4L8PX2nXNn
/ZNpb+fE0fnQW8aSR7gRuVtvDDOQfWj2NP8AlX3D/tLG/wDP6X/gT/zM+/8A hxod7PctGptI
bmJo5IYIINoYoU3qzRl0YcEbWAyucZLZPY0/5V9wf2ljf+f0v/An/mRy/DTR Xv8A7RHJJBEG
kkS2SC3aNGdWXOWiLMAXLBWYqCFwMKAD2NP+VfcH9pY3/n9L/wACf+YH4aaK 1ukLSSHLM1ww
gt1a4BAG0kRDywAuB5Ww8k53HdR7Gn/KvuD+0sb/AM/pf+BP/Mr6b8MtMU3L aqFuUknuXjto
0jSOJJJH2YdUWTIjYDBYhTyv3VIPY0/5V9wf2ljf+f0v/An/AJkifDDRx5zy XVxLcPs8uU29
qvk7d/3UWERnIcg7lbop4KqQexp/yr7g/tLG/wDP6X/gT/zNCPwD4ej+zf6B E3kXUtz80UZ8
zf5n7tvl5RfM+Ve2xPSj2NP+VfcH9pY3/n9L/wACf+Zof8It4e/6AOm/+Akf +FHsaf8AKvuD
+0sb/wA/pf8AgT/zD/hFvD3/AEAdN/8AASP/AAo9jT/lX3B/aWN/5/S/8Cf+ Yf8ACLeHv+gD
pv8A4CR/4Uexp/yr7g/tLG/8/pf+BP8AzD/hFvD3/QB03/wEj/wo9jT/AJV9 wf2ljf8An9L/
AMCf+Yf8It4e/wCgDpv/AICR/wCFHsaf8q+4P7Sxv/P6X/gT/wAw/wCEW8Pf 9AHTf/ASP/Cj
2NP+VfcH9pY3/n9L/wACf+Yf8It4e/6AOm/+Akf+FHsaf8q+4P7Sxv8Az+l/ 4E/8w/4Rbw9/
0AdN/wDASP8Awo9jT/lX3B/aWN/5/S/8Cf8AmH/CLeHv+gDpv/gJH/hR7Gn/ ACr7g/tLG/8A
P6X/AIE/8w/4Rbw9/wBAHTf/AAEj/wAKPY0/5V9wf2ljf+f0v/An/mH/AAi3 h7/oA6b/AOAk
f+FHsaf8q+4P7Sxv/P6X/gT/AMw/4Rbw9/0AdN/8BI/8KPY0/wCVfcH9pY3/ AJ/S/wDAn/mH
/CLeHv8AoA6b/wCAkf8AhR7Gn/KvuD+0sb/z+l/4E/8AMvWen2WnQmGxtILW ItuKQxhAT0zg
d+B+VXGMYq0VY5qterXlzVZOT83f8xL2Tyot46genuBWkI80kmYydkYkurtH E8q3SiJN25vl
wMdcnHbBz9K7I0YPoYubEubyW40qYStuby5ecAcAL/jXLiYKD0NKcm9yxA2z Up3/ALsCnrjp
vrmpq8kjR6Iq6r4mi0nyvPcbpnCRoqszMSewBycZ/wAkgV3qhFmDqNF211KS aUo4GPlwVJHV
gPX3qatFQV0OM23qNbUpt3y7NvbO7/GrVCNuovaMT+0rj/pn/wCPf40/q8PM PaMT+07n/pn/
AOPf40fV4eYe0Yv9pXGCf3eACTndwB/wKl7CHmHtGDajcocExdcdT15/2v8A ZP5UKhB9w9ow
/tK4/wCmf/j3+NP6vHzD2jE/tO5z/wAs/wDx7/Gj6vDzD2jF/tK4/wCmf/j3 +NH1eHmHtGS2
t5NPeRRscBlfIBOPlKf/ABf6CsatNQWn9b/5FRk2ylqviNNJtBdT5EO5VJVH bbk4ycHp/nrg
VoqESXUZNb6w0w3BkeIxs4ZCeQFJBByc0ToRjG6GqjbK8n/Lz/19Rf8AtOvN Og6SL/Up/uit
1sQPpgFABQAUAFABQBycXi6+Ph/+35tGRNJkgjvI5ku9zJbkqWaVSoKusbF9 qb87GXOdu4A3
LzW9OsP7Q+03Hl/2fai8ufkY+XEd+G4HP+qfgZPHTkUAY8ev+IDrml6bNoNl B9ttTcyFtRYv
CE8oSqQIiGYNLgYbDbc5XNAG5qWrabo1utxqmoWtjAzbFkuZljUtgnALEDOA ePagAOraat+l
g2oWovHZkSAzL5jMqh2AXOSQrKxHYMD0NAGXe6zrH/CQz6TpOl2Vz9ntYbiS S6vng/1jSKAA
sT5x5R5yOooAsab4o0fU4tL8u+hhutTtUu7ezmlRZ2jZdwOzOTwDnGRwfSgC PRvFOm6rZaO0
t1a2uoapZx3cdi1wpl2sm7gcFgMNyB/CaAK+j+OtB1pFeC8SJDp0epFppEUL CzOrZwxwUKEP
2UkDNAG5Y39nqdnHeWF3Dd2smdk0EgdGwcHDDg8gj8KALFABQAUAFABQAUAF ABQAUAFABQBz
Pi//AJF3Wv8Aryl/9FmtsH/vlP8AxR/NGdf+DL0ZyvwJ/wCRN1P/ALCkn/ou OvTzr/efl+rM
cJ/CR03hv/kV9I/684f/AEAV5GM/3mp/if5m9D+FH0X5GnXKbBQBXuP9faf9 dT/6A1AG/XQQ
RKf9LkXPRFOM+7ds/wBB9T2AJaAIrk7YlOcfOg64/iHuP89j0IAC6t2xtnjO cYw45zjH/oS/
mPWi4GNrXkTXlmzpBMn2eV0Miq6/ei55IHQ+tZOnGpUipK6s/wBCuZxi7Gdb XEdtfRS2fkwv
ujjljiWMJIGkC52q5II3dfb3xSqYf2UlUp6LRWt5/IcanOuWR19bEGO3ijSU 1iTS2mmW4ilW
GRzayiFJGVWVDLt8sMQ6YG7JLAdSBQBXh8a6Dc6db31pdTXcFxnyfs1pNM0g AUswRFLFV3Kr
NjCsdpIbigAbxjpKXlxF5/mRxxQSRmCKWV5/NDsvlqqHzF2oTmMt918hdpJA LCeKNJlltYoJ
pp5LnGFhtZZDHliv70Kp8r5lZf3m3BRwfutgAPC/iCLxP4es9Vit5rfz4kdo 5YnTazKGIUsq
71+bhwMHtQBsUAFABQAUAFABQAUAFABQAUAFABQAUAFABQBQ1YkWTkDOAD/4 8ta0f4iIn8J5
3ceFoXvGWG6eHSpm82a0U4DOOmPQHuPYe230Ejmeh0aoselMqIEjWGYKAMAA BOlcWL/y/U3o
mgM/a7zAyfswwB/wOuSj/ERtL4WcpqmmznWbfWLApJcLiOSKZvlKHjKnnaRk 9Pf3Dexaxxs6
GwJMxwMgNHz/ANtUrOv8K/roOne5EZcYBBBAwc1okK4ebTsK4ecBSsFxGlzH IoHLIy8n1BFN
JXQNuw1pS8u7AA37uvvIf/Zx+VNJJf15f5Cu7/15/wCY/wA3FKw7h5w6UWC4 ebRYLmhpQLX0
DYONk384q5K+33fqa09/v/QwdWa9k0l4LKOJp5MRkTfdUHgkjHOPQ/r0PVbs ZiaJpqaVp5so
ZHlCQylmY9SUOcDsM9v681NTSP3Cje5ryf8ALz/19Rf+068Q7zpIv9Sn+6K3 WxA+mAUAFABQ
AUAFAHJ6Z4ZmXWbq6v8ATtJt4J4JYbpLJSV1JnZSZZkKgAgK+FJk/wBcw3dS wBTh8D3h+z/a
9Umud8phvfNnL+faJt8pDlfmY+Um8N8p8+5x98YAOkn02aXxVp+qKyCC3s7i 3ZSTuLSPCykc
YxiJs89x+ABX1iw1L+2bHV9Litbie2gmtmguZ2hUrI0Tbg6o5yDCBjbzuzkY wQDn9K8AzaTo
01lHLayTteabILjaUaSG1W2BDcEg5hkIXJA39eTQBsXnhDTdV8VXeqavpmn3 8D2cFvAtzAsr
RsjzM5G4EAESJ0POOegoAzPEHh7VdT8SW5W5ilh+1211EJNRmhMMUMkTOgt1 UpNypO9iCDIB
wFWldXsVyy5ea2n9f5MztE+Hl9pjafFcGG4jT7FLNINQuUSOSCKFMC3XCS8w Ah2II3DKnYAz
JLH/AAgd+uipYG4hby7CytQyzPEWNnOZIyGUZTzFY5I5jI48zqADpPC+jSaP ZXIniSKe6nMz
qt3NdEHYqDMsp3OcIOygDAxxuIBuUAFABQAUAFABQAUAFABQAUAFAHM+L/8A kXda/wCvKX/0
Wa2wf++U/wDFH80Z1/4MvRnK/An/AJE3U/8AsKSf+i469POv95+X6sxwn8JH TeG/+RX0j/rz
h/8AQBXkYz/ean+J/mb0P4UfRfkadcpsFAEFzHIxheIKWjfdhmwD8pHXB9aA Jftupf8APOH/
AL+n/wCIquZisNF3qIct5cWSAP8AXHH5bfejmYWHfbdS/wCecP8A39P/AMRR zMLB9t1L/nnD
/wB/T/8AEUczCwfbdS/55w/9/T/8RRzMLFef7XcSpLJBEXRWRWE7KQCQT0X/ AGR+VCk07hZW
sQ/Zp9wJhVsMrANdyMAVYMDgj1ApyqSkrMSilsXvtupf884f+/p/+IpczHYz 5LEy/ad9lCft
N1FeS/6Q3zSx+Xsb7vGPKj4HB28jk5OZhYLOxNh/Z/2ayhj/ALPtTZ23+kMf LiOzK8rz/qk5
OTx15NHMwsZ8nhTTJ4rSK40SyuIbSKGGKOeVpECRLIsYKspDYEsnXPXPUDBz MLGhp2nrpErv
pumWVnuiSEpA2xAis7ABQmB80rngc7uaOZhYsWAutM062sLO3hitbWJYYk85 jtRQABkrk8Ad
aOZhYsfbdS/55w/9/T/8RRzMLB9t1L/nnD/39P8A8RRzMLB9t1L/AJ5w/wDf 0/8AxFHMwsH2
3Uv+ecP/AH9P/wARRzMLB9t1L/nnD/39P/xFHMwsH23Uv+ecP/f0/wDxFHMw sH23Uv8AnnD/
AN/T/wDEUczCwfbdS/55w/8Af0//ABFHMwsH23Uv+ecP/f0//EUczCwfbdS/ 55w/9/T/APEU
czCwfbdS/wCecP8A39P/AMRRzMLB9t1L/nnD/wB/T/8AEUczCwfbdS/55w/9 /T/8RRzMLB9t
1L/nnD/39P8A8RRzMLB9t1L/AJ5w/wDf0/8AxFHMwsRyzX8ygPFFx0KzspH4 haanJCaTK3kX
X+3/AOB8v+FX7aXl9y/yFyL+mwkhu3tZYRHH+8Urue4dyMj1K5/ColNy3Gop bEskc63TyRJG
yuir80hUggk9gfWpTad0Nq5GYbsnOH/8D5f8K09tLy+5f5E8i/psdGt3EwYI GI6eZdyPj6ZB
xSdWTVv0QKCQrfbXYsV5PpeSAfoKFUkh8qE23nof/A2T/Cj2kv6SFyoNt56H /wADZP8ACj2k
v6SDlQbbz0P/AIGyf4Ue0l/SQcqDbeeh/wDA2T/Cj2kv6SDlQbbz0P8A4Gyf 4Ue0l/SQcqDb
eeh/8DZP8KPaS/pIOVBtvPQ/+Bsn+FHtJf0kHKh6NeRggRRnIwS9wzEj0yV6 UnOTHypETRXb
HJD/AIX8o/pVe2l5fchci/pipFdIwOzdjs95I4/Igih1ZNW/RAoJAbe4aKYl YxI8ySBQ5I+X
bxnH+z6VkWWheaiqgCKEAcD96f8A4mq5mhWF+26l/wA84f8Av6f/AIijmYWD 7bqX/POH/v6f
/iKOZhYPtupf884f+/p/+Io5mFg+26l/zzh/7+n/AOIo5mFg+26l/wA84f8A v6f/AIijmYWL
NjcXcs7LcJGE25G18nP/AHyKqLbYmaFaCCgAoAKACgAoAyda/wBHuNLvxwIL pY5Cv3mSUGML
7je0bEf7GeSBWVTRxl5/np+djuwnvxqUu8W12vH3r+vKpJettmzWrU4QoAKA CgAoAKACgAoA
KACgAoAKACgAoA5nxf8A8i7rX/XlL/6LNbYP/fKf+KP5ozr/AMGXozlfgT/y Jup/9hST/wBF
x16edf7z8v1ZjhP4SOm8N/8AIr6R/wBecP8A6AK8jGf7zU/xP8zeh/Cj6L8j TrlNgoA5nx7d
3Nn4TuHtZmikZlQsvXBPP0r0cspwq4uEZq61/BNnJjJyhQlKLs/+CeX6Jpvi HxBPLBp95O8k
a72DXBXjOO5r6XHVcFgnGM6N+a+0Y9Ld2u55OGhiMQm41LWtu319L9iTWtF8 TaAEN/c3Ch+6
XBYD64NZYTGZdiqvsVSUZbpNR19LX27f8EuvQxdCHO53Xk3p+Rj/AG7Uv+f+ 6/7/ADf416/1
PC/8+4/cjh+sVv5397D7dqX/AD/3X/f5v8aPqeF/59x+5B9Yrfzv72H27Uv+ f+6/7/N/jR9T
wv8Az7j9yD6xW/nf3sPt2pf8/wDdf9/m/wAaPqeF/wCfcfuQfWK387+9h9u1 L/n/ALr/AL/N
/jR9Twv/AD7j9yD6xW/nf3sPt2pf8/8Adf8Af5v8aPqeF/59x+5B9Yrfzv72 H27Uv+f+6/7/
ADf40fU8L/z7j9yD6xW/nf3sPt2pf8/91/3+b/Gj6nhf+fcfuQfWK387+9i/ bNT25+3XWPXz
W/xrN0MEpqDhG76WVylVxDjzKTt6sPtmphc/brrHr5rf40KhgnNwUI3XSyuD q4hR5uZ29Wd3
8M5Zr26v4b1/tKKisvnDeQc44J5r57PaFKk6bpxSvfbTa3+Z6mW1ZzUlJ3tY 9G+wWf8Az6Q/
9+xXzh6wfYLP/n0h/wC/YoAPsFn/AM+kP/fsUAH2Cz/59If+/YoAPsFn/wA+ kP8A37FAB9gs
/wDn0h/79igA+wWf/PpD/wB+xQAfYLP/AJ9If+/YoAPsFn/z6Q/9+xQAfYLP /n0h/wC/YoAP
sFn/AM+kP/fsUAH2Cz/59If+/YoAPsFn/wA+kP8A37FAB9gs/wDn0h/79igA +wWf/PpD/wB+
xQAfYLP/AJ9If+/YoAPsFn/z6Q/9+xQAfYLP/n0h/wC/YoAPsFn/AM+kP/fs UAH2Cz/59If+
/YoAPsFn/wA+kP8A37FAB9gs/wDn0h/79igA+wWf/PpD/wB+xQAfYLP/AJ9I f+/YoAPsFn/z
6Q/9+xQAfYLP/n0h/wC/YoAPsFn/AM+kP/fsUAH2Cz/59If+/YoAPsFn/wA+ kP8A37FAB9gs
xQBc062t4bhmigjjbbjKqAeoq4biZp1qSFABQAUAFABQBU1Sx/tHS7mzEnlP KhCS4yY3/hce
6nBHTkCpnHmi0b4at7CrGpa6T1XddV6NaPyDSr3+09Isr/y/L+0wJNsznbuU HGe/WiEuaKl3
DE0fYVp0r35W19zsW6owCgAoAKACgAoAKACgAoAKACgAoAKAOZ8X/wDIu61/ 15S/+izW2D/3
yn/ij+aM6/8ABl6M5X4E/wDIm6n/ANhST/0XHXp51/vPy/VmOE/hI6bw3/yK +kf9ecP/AKAK
8jGf7zU/xP8AM3ofwo+i/I065TYKAOX+IC7vCzr/ANNU/nXp5TpjIfP8mcWO /wB3l8vzRzPw
3mj0/V7+eZgkSWjMzHsAy5NernacqtJLtL/204ctkowm35fqaMgjl8Aa7cCM ETXsjwyFfvI0
gwQfQ815koJ4ik2tU4f+lI7ISaoT7NS/JnIeHtMFzqfmOkLR20bTsJ3VYyVH yK24gFS5RSPQ
9utfXYqryU7K927aXv52t1SuzwqEOad+2uv4fjY07mGz0vU5nlihj+2Rxzxy wwQ3UaZB8xFQ
naF35AOcgJjnJNc8HOtTSTfutpptxfk2972+Tv5G0uWnNt9bPRJ+qttv+RJq mkwyC1sLpGF/
Ba3LedCyrCPLlnYgR7RwdpAwRjI44wZo1pK9SHwtx0e+qit7+fZ+pVSCdoS3 Sfpo5dLEo0HT
tNu7pbS6aae2iubeYfMQT9nl55RQnKn5dzZyeflyZ+sVasY86sm4tbfzR83f fey9NR+yhCT5
Xqrr8H5K33v8CnNp63HxDlFxFIbefVJIwwAwT5n+0CpxuUkEHI471rGo44Jc r1UE/wAPJp/M
zcb4nXZyf5kUOgaaumia8lkS4gSOeeKOTcxiZ1AwCgUHa6nO9vQgZOKliavt LQWjuk/NJ+d9
1bZevdKlBRvJ6qzfo7eVtn3f+TV8OW1vcJFdzK4jDy3DxzYRYtwSMghGbJY5 +6cq6HjJIbxU
pRvBb2S01vu+qWi03WqaF7GMXaT9fTZdH+WzRn6vpcVhqTwQSebCUSRG5+66 BgOQM43YzgZ9
B0rooVXUp80lZ6r7nb+tX6syqwUJWW3+ep0fgOMoNUW++z/2CYR9uE347NuO d2c4x/PFeFnD
h7SHJf2nl26fO+1v8j1Mu5uSXN8H9fhbf/hw8dxlhpa2P2f+wRCfsIh/Dfuz zuzjOf55oydw
VSfPf2nn26/O+9/8wzDm5I8vwf1+Ftv+GJ/hpH5eo33vEv8AOoz939n8/wBB 5X9v5fqek18w
eyFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUA
FABQAUAFABQAUAFABQBZsv8AXH/dq4biZerUkKACgAoAKACgAoAydE/0d9R0 9vvwXUkgJ4Lp
KTKGx6Zdkz3MZ9wMqel4+f56/wDA+R3Yz31TrLZxS9HFctvWyUvJSXq9atTh CgAoAKACgAoA
KACgAoAKACgAoAKAOZ8X/wDIu61/15S/+izW2D/3yn/ij+aM6/8ABl6M5X4E /wDIm6n/ANhS
T/0XHXp51/vPy/VmOE/hI6bw3/yK+kf9ecP/AKAK8jGf7zU/xP8AM3ofwo+i /I065TYKAOc8
bru8PFf+mq/1r0sq0xcPn+TOLHf7vL5fmjz+wubvTJ2ms5vKkZChO0NkHBxg g+gr6jF4OGKc
XJtWvtbrbun2PDoYmVBNRSd+5au9b1e+tGtLm8LwNjKeWgzg5HQe1csMqpQm pc8nZp9Ojv2N
5Y+pKLjZa6df8zNWN0V1RmVXG1gDjcMg4PryAfwr1nZ7nAm1sWbe91CzXbbX 1zAuNuI5WXjJ
OOD6sT+J9aznSpT+KKfyLjVnH4W0Qjzl24lkGxCi4Y8Kc5A9juPHufWrtHsR zPuSPcXsiRI9
3OyxIUjDSEhFIwQPQEcY9KlU6abaitfIp1Juyb2HQXV1Ddx3JkaSWOQzKZGL YkP8fXk5APPX
AzkcUpU4Si4WsmrfLt6f0hxqSUub5/PuN+0Xv2L7F9rn+yf88fMOzrn7vTrz T9nT5+flV+9t
Re0ny8t9Ow2OS6huEuIriVJ0AVZFchlAG0AHr04+lNxhKPK0rCU5J8yeo2fz rqZpriWSaVvv
PIxZj25JpxUYLlirIUpOTvJ3ZF9n9qThByU2lddeo1OSjyp6B9n9qFCCk5pK /fqDnJx5b6HW
eBWitb+6aWRY1MYGWOB1r5/PXf2fz/Q9fK/t/L9Tuft9n/z9w/8AfwV82eyH 2+z/AOfuH/v4
KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+C gA+32f8Az9w/
9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4KAD7fZ/8/cP/ AH8FAB9vs/8A
n7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQAfb7P/n7 h/7+CgA+32f/
AD9w/wDfwUAH2+z/AOfuH/v4KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32 f/P3D/38FAB9
vs/+fuH/AL+CgA+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH 2+z/AOfuH/v4
n7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQBc065t5r hlinjdgucKwJ
6irhuJmnWpIUAFABQAUAFABQBkzf6H4ot5jxHfwG3Ynn95GWdAPTKtMSTx8o 6d8n7tRPvp93
9M7ofvMJKPWDv8pWTfyajb1e/TWrU4QoAKACgAoAKACgAoAKACgAoAKACgDm fF//ACLutf8A
XlL/AOizW2D/AN8p/wCKP5ozr/wZejOV+BP/ACJup/8AYUk/9Fx16edf7z8v 1ZjhP4SOm8N/
8ivpH/XnD/6AK8jGf7zU/wAT/M3ofwo+i/I065TYKAOf8Zf8gL/tqv8AWvRy v/e4fP8AJnFj
v93l8vzRs/8ACGeH/wDnw/8AIz//ABVbf2jiv5vwX+RP1Kh/L+LD/hDPD/8A z4f+Rn/+Ko/t
HFfzfgv8g+pUP5fxYf8ACGeH/wDnw/8AIz//ABVH9o4r+b8F/kH1Kh/L+LD/ AIQzw/8A8+H/
AJGf/wCKo/tHFfzfgv8AIPqVD+X8WH/CGeH/APnw/wDIz/8AxVH9o4r+b8F/ kH1Kh/L+LD/h
DPD/APz4f+Rn/wDiqP7RxX834L/IPqVD+X8WH/CGeH/+fD/yM/8A8VR/aOK/ m/Bf5B9Sofy/
iw/4Qzw//wA+H/kZ/wD4qj+0cV/N+C/yD6lQ/l/Fh/whnh//AJ8P/Iz/APxV H9o4r+b8F/kH
1Kh/L+LD/hDPD/8Az4f+Rn/+Ko/tHFfzfgv8g+pUP5fxYf8ACGeH/wDnw/8A Iz//ABVH9o4r
+b8F/kH1Kh/L+LD/AIQzw/8A8+H/AJGf/wCKo/tHFfzfgv8AIPqVD+X8WH/C GeH/APnw/wDI
z/8AxVH9o4r+b8F/kH1Kh/L+LD/hDPD/APz4f+Rn/wDiqP7RxX834L/IPqVD +X8WH/CGeH/+
fD/yM/8A8VR/aOK/m/Bf5B9Sofy/iw/4Qzw//wA+H/kZ/wD4qj+0cV/N+C/y D6lQ/l/Fh/wh
nh//AJ8P/Iz/APxVH9o4r+b8F/kH1Kh/L+LD/hDPD/8Az4f+Rn/+Ko/tHFfz fgv8g+pUP5fx
Yf8ACGeH/wDnw/8AIz//ABVH9o4r+b8F/kH1Kh/L+LD/AIQzw/8A8+H/AJGf /wCKo/tHFfzf
gv8AIPqVD+X8WH/CGeH/APnw/wDIz/8AxVH9o4r+b8F/kH1Kh/L+LD/hDPD/ APz4f+Rn/wDi
qP7RxX834L/IPqVD+X8WH/CGeH/+fD/yM/8A8VR/aOK/m/Bf5B9Sofy/iw/4 Qzw//wA+H/kZ
/wD4qj+0cV/N+C/yD6lQ/l/Fh/whnh//AJ8P/Iz/APxVH9o4r+b8F/kH1Kh/ L+LD/hDPD/8A
z4f+Rn/+Ko/tHFfzfgv8g+pUP5fxYf8ACGeH/wDnw/8AIz//ABVH9o4r+b8F /kH1Kh/L+LD/
AIQzw/8A8+H/AJGf/wCKo/tHFfzfgv8AIPqVD+X8WH/CGeH/APnw/wDIz/8A xVH9o4r+b8F/
kH1Kh/L+LD/hDPD/APz4f+Rn/wDiqP7RxX834L/IPqVD+X8WH/CGeH/+fD/y M/8A8VR/aOK/
m/Bf5B9Sofy/iw/4Qzw//wA+H/kZ/wD4qj+0cV/N+C/yD6lQ/l/Fh/whnh// AJ8P/Iz/APxV
H9o4r+b8F/kH1Kh/L+LD/hDPD/8Az4f+Rn/+Ko/tHFfzfgv8g+pUP5fxYf8A CGeH/wDnw/8A
Iz//ABVH9o4r+b8F/kH1Kh/L+LD/AIQzw/8A8+H/AJGf/wCKo/tHFfzfgv8A IPqVD+X8WH/C
GeH/APnw/wDIz/8AxVH9o4r+b8F/kH1Kh/L+LD/hDPD/APz4f+Rn/wDiqP7R xX834L/IPqV
Re: No SWT Controls on palette [message #136972 is a reply to message #136945] Tue, 27 March 2007 14:24 Go to previous message
Originally posted by: scott.softwareassist.net
Success! Thank you very much for your help.
The screen shot you took showed me what the problem was (a picture is
worth 1000 words). I did not have the SWT library loaded in my project.
You told me that earlier but the picture made the issue clear.
In case someone else has this problem and stumbles upon this thread,
here's what I did:
1. I right-clicked on the project in the Package Explorer and selected the
Properties menu.
2. I clicked the Java Build Path option on the left.
3. I clicked the Libraries tab.
4. I clicked Add Library.
5. I selected Standard Widget Toolkit from the list of choices.
The SWT Library included the SWT jar file that I already had in the list
so I removed the entry I had added for this jar file earlier.
Now when I open a Visual Class, VE is the editor and I have SWT controls
on the palette.
Thanks again for all of your help.
Scott
Re: No SWT Controls on palette [message #615119 is a reply to message #136350] Tue, 13 March 2007 15:40 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Go to New->Visual Class and select an SWT style and SWT class from the
Tree. This will make sure the classpath is setup correctly for SWT.
Scott wrote:
> I recently installed VE and SWT in my Eclipse environment but the VE
> palette only shows Swing and AWT controls. Does anyone have an idea
> where I need to "tweak" the configuration so they will show up?
> Thanks in advance for any help.
Rich Kulp
Re: No SWT Controls on palette [message #615129 is a reply to message #136386] Thu, 15 March 2007 13:26 Go to previous message
I must have some incorrect setting(s). When I do a "New", I don't see
Visual Class as an option.
Re: No SWT Controls on palette [message #615130 is a reply to message #136504] Thu, 15 March 2007 17:37 Go to previous message
Then you have a configuration problem.
The best way to install is using the update manager.
1) Get an Eclipse 3.2.2 SDK zip.
2) Unzip it.
3) Open Eclipse up, and use Help->Manage Configurations->Find and
Install new features.
4) Select the "Callisto" site, and hit next.
5) Expand and Select VE Runtime (or SDK), and then hit the "Add Required
...." button.
6) Hit install and install everything.
Rich Kulp
Re: No SWT Controls on palette [message #615148 is a reply to message #136514] Wed, 21 March 2007 17:56 Go to previous message
Thank you for the advice. I installed a brand new version of Eclipse 3.2.2
and installed VE using the steps you suggested. VE is working fine but I
still do not see any SWT Widgets on the VE palette. All I see are tabs for
Swing and AWT Widgets.
I have SWT installed in the plugins folder and am able to write and run
SWT applications where I build the UI "by hand".
Is there anything special I need to do th get VE to offer SWT Widgets in
its palette? What mechanism makes VE aware of the SWT Widgets so that it
will add them to its palette?
Scott
Re: No SWT Controls on palette [message #615149 is a reply to message #136726] Wed, 21 March 2007 20:12 Go to previous message
Try using the New Visual Class wizard and select an SWT style and
control from the style tree. This will make sure your project is setup
correctly. Just having a project doesn't make it able to have SWT. You
have to tell it that the project has SWT available to it, until then no
SWT palette will show up. The New Visual Class wizard makes sure it is
set up correctly.
> 3.2.2 and installed VE using the steps you suggested. VE is working fine
> but I still do not see any SWT Widgets on the VE palette. All I see are
> tabs for Swing and AWT Widgets.
> Scott
Rich Kulp
Re: No SWT Controls on palette [message #615160 is a reply to message #136738] Mon, 26 March 2007 13:20 Go to previous message
The style tree has only 2 entries under SWT (Composite and Shell). Is that
how it is supposed to be?
The Style box has nodes RCP, SWT, Swing, AWT and Other. Swing and AWT each
have a number of objects underneath them but SWT only has Composite and
Shell. I tried creating a form using Shell and there are no SWT components
in the pallette. Same when I tried Composite.
Re: No SWT Controls on palette [message #615161 is a reply to message #136874] Mon, 26 March 2007 13:29 Go to previous message
Yes, under SWT there is only Composite and Shell. Use one of those in
the New Visual Class Wizard to create an SWT class.
> that how it is supposed to be?
> each have a number of objects underneath them but SWT only has Composite
> and Shell. I tried creating a form using Shell and there are no SWT
> components in the pallette. Same when I tried Composite.
Rich Kulp
Re: No SWT Controls on palette [message #615162 is a reply to message #136885] Mon, 26 March 2007 13:54 Go to previous message
First, let me take a minute to thank you for the help you've given me with
this issue Rich. It is greatly appreciated. I would really like to use VE
to develop the GUI for my applicaiton because doing it "by hand".
although very instructive, is very slow.
It appears that the new visual class gets set up properly. The code that
is generated is shown below:
package ftprrtm;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
* @author HP_Administrator
public class Setup {
private Shell sShell = null;
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
sShell.setLayout(new GridLayout());
The palette still does not have any SWT controls on it. It has the
following categories:
Swing Components
Swing Containers
Swing Menus
AWT Controls
Where does the code that sets up the palette get the list of controls to
display?
Re: No SWT Controls on palette [message #615163 is a reply to message #136897] Mon, 26 March 2007 15:12 Go to previous message
I don't know what is going on. If you open the new Setup class itself
and there are no SWT stuff in the palette then there is something wrong.
I have no idea what.
The palette is a per-project entity. Only the project that the new Setup
class is in will show SWT controls. the other projects will not.
Look at the classpath for the project that Setup class was created in.
Is there a SWT Library (not the jar, but a specific JDT library called
SWT) in it? That is what is keyed off of. I
Rich Kulp
Re: No SWT Controls on palette [message #615164 is a reply to message #136908] Mon, 26 March 2007 20:52 Go to previous message
<Look at the classpath for the project that Setup class was created in. Is
there a SWT Library (not the jar, but a specific JDT library called SWT)
in it?>
I am not exactly sure what file this is supposed to be but I'll bet it is
the source of my problem. I am running on WIndows XP. Do you know what
file that would be? What file extension would it have (DLL, Zip)?
Scott
Re: No SWT Controls on palette [message #615166 is a reply to message #136919] Tue, 27 March 2007 09:21 Go to previous message
--------------080707010607010307000006
I've attached a picture of what it should look like.
> SWT) in it?>
> is the source of my problem. I am running on WIndows XP. Do you know
> what file that would be? What file extension would it have (DLL, Zip)?
> Scott
Rich Kulp
Content-Type: image/jpeg;
name="Snap2.jpg"
Content-Disposition: inline;
filename="Snap2.jpg"
/9j/4AAQSkZJRgABAAEAYABgAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5j LiBWMS4wMQD/
2wCEAAgGBgcGBQgHBwcKCQgKDRYODQwMDRsTFBAWIBwiIR8cHx4jKDMrIyYw Jh4fLD0tMDU2
OTo5Iis/Qz44QzM4OTcBCQoKDQsNGg4OGjckHyQ3Nzc3Nzc3Nzc3Nzc3Nzc3 Nzc3Nzc3Nzc3
Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//EAaIAAAEFAQEBAQEBAAAAAAAA AAABAgMEBQYH
CAkKCwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUE BAAAAX0BAgMA
BBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygp KjQ1Njc4OTpD
REVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaX mJmaoqOkpaan
qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T1 9vf4+foRAAIB
AgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1Lw FWJy0QoWJDTh
JfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2 d3h5eoKDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uLj5OXm
5+jp6vLz9PX29/j5+v/AABEIAlECfwMBEQACEQEDEQH/2gAMAwEAAhEDEQA/ APUNBTf4Y0Ie
T5uILc437QuFHzHkZA6471pi/wDeqn+J/mZ0P4UfRfkbFcZuUbPStPvb7UJb ixt5pVmUb3iD
H/Vp3NdFCpOMWr9f0RhVhGUlp0/zJNZ0rT/7Pmma0jLQwN0GPlHzAHHUblHB 9/euHG041pLS
7X5f8OdGHbpryJp4VuLeSFy4SRSpKOUYAjHDKQQfcHIrYRjeGPDj+HLSeKbW dR1WWaQt5t9c
NIVXJ2qATgYB5I6nnpgBt3EbMjbJYD6Of/QTVQ3Eyr9qlt4gFnAhj+UMVXjH HTdn9K2sSWIg
FmKA5CRIo/DNZVCkUNVxJcRW7SOqvDIyhZGQbgUxnHUcnjpWtCN0/l+pnUdm ilLAZLl7gLAs
jBxn5ONwI6+Xu7+tde6sZdbmnpjKftccbu0UUoRN8jOQNinqxJPJPWuKurNe n6s2pu6ZclGY
nG0tlT8oOCfxrBGoRLsgiTyxFtRRs3btvA4z3x603uIx/FUUzeH7x4ZsMsLq IGQMk7EYVD0b
JPC7SDkjr0pxdncmavFnG6leWEmnNaz20b6wMR3CSJmWabggFTy6MdpAxwNu AMDa7TjUSivd
+9Jfpb+tDgcuX/F+f+aZ3+krPHYJFcWzQSIcbWuWuM55yHb5j1xyByDjjBMs 9BaIzLTwsbXx
Zc62da1SWGVf3dhJdu0ETnO5gpPIIxhTwvOP4dpfSwzoaQzgfAl42hXOsyax MsaWyBW9dwYj
A9Saik1Bts8zDy5L83Qi0G6fVfG4urW0S1tQWk8tSeF2suT7ksOBxx7VlTUU 3yrQVGXPWXKt
DrfEeivr2izWMOpXmmzn5orq0laN42HQnBG5fVT19jgjpTsemW9MsF0vTbey S4ubgQrt866m
MsrnuWY9ST+A6AAYFIDE1vTriLxNp2vQxyzx2y7ZIYuWONxBA7/eqXpJSOWt GSmprVGFBql5
ceLhqWpbYZ1D7bdgyhAAAAcKW6PnOPyyucub3nJnVhMDWr/v56LotPNd0drp OqW+safFd254
ZRuXqUJAOM9+o5HFbJprQ2rUZUZ8sjMtPCxtfFlzrZ1rVJYZV/d2El27QROc 7mCk8gjGFPC8
4/h21fSxidDSGFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQBFbpsWX9 z5W6VjkvuL8D
5uvA7Y9qp7CK18F+26dvd/LaVkdAxCsNjNyB15UfrUtpQk3/AFqkVG7kkjFg hW9v7zUb23ur
9LqLyEUpFGqxhiR/y0yxz0bj1HrXbXoyq0VSSVvO/wDkctOUadRzk9TS0MhE uYDBJHIspd2f
YdxYk8lT97ABI7Z44xXI8OsPFRX9eZ0e09o7kevm5Emm+RcRQA3BBLxludjE HOR6H8x0xzhV
+E3o7v0OdVrqGLVZri8t5I4ZxKFWLDBlRSGU54I/Hv2OK55RjJcrR02u1Y7W ztksrOG2jVFW
NQMIMD3PU/zNdcYqC5Y7HC227swvE032TVNCu5wPsMVwROSMhc4wT+v+TT7X OPEOzi3sZGrX
uqxveXV1q9pcWguFktYY2Du/J2lOuwjI7c9OairBVE1JmSrVKUnNSX+Z2GmQ fZdLtYfKWIpE
oZF6Bsc/rmqjFQXLFaHenKSvLcybTwsbXxZc62da1SWGVf3dhJdu0ETnO5gp PIIxhTwvOP4d
t30sB0NIZEE/0wv5PSLHml+B8w+ULnr3zjtVLYRV1hgmn/MMo00SMD0ZTIoI PsQcVzYh2pP+
uptRV5/f+Rz2r6Pb67ePfwQ7XeMp5xuNnmcYDY2NkYPByM49MGsoZlOFN07X XmXPCqUWm7XK
3hvw7eWniCOe4uhKlsrFvLdmXeRgKcj0Ynj2z1GTDzc3e2hw/UvYyUue/lb/ AILO1mkMcZKr
vkPCJnG5uwroqVFTjzM6Ix5nY5jV5dQ0u5SSYN9vxuiCsWjcnjao/EDGM9PU EjpwnC81aVi4
ya0Wx0VtbGImWVt87/ebsPYe1ZUKHs9XrJ/1ZDq1efRbFmukxIrdNiy/ufK3 Sscl9xfgfN14
HbHtVPYRDfTfZ/s8pO1Fk+Zj0A2sOfxx+dcmJbVO6N6KTlZjftk11uFpcIpW PerZBDEkgAnB
4G05xyc9RiuWFTlinJbmsoq4+2c/arlHQLKxWVgr71wRtGDgf3K66ElJOxjU TVjI1/wsdd1L
T7tda1SwS3b99DZ3bxJcJyQpCkYOcfMOcZHoV6U7GJ0NIZFMm9oR5Pm4lU43 7QuD948jIHXH
eqjuID/yEtN/67t/6Kerp9SZdDYnnS3j3ufYAdWPoKitWjRhzS/4cqMXJ2Rx HiS3vrq9img/
e3Eo8pIVIynU4HqPU9uvTp5NHH+2q+yfxeX5f8E3dLljdbGxaxSW88UMy7ZY 7C3VxnOCC4Ne
xJWhFf10OZfEzFZ4RLYPc2bzQGHJK2rSgHEHXEZ6qHGeehG4fw91OLULJ/j6 +ZzzklLVfh6F
ZZbZrpYYbN/tAkgYAWTKUBlXLE+Qm0bVfktjg/hUrqLu+j6+XqyVJNqy7dPP 0NvxL/yKusf9
eU3/AKAa58B/vdL/ABR/NG9f+FL0f5HG/BT/AJFLUf8AsJSf+i469DPf96+X 6sywn8JHYeHo
kk8MaLvXcEtoHAyRyEGOn8q87GO2Jqf4n+ZrQ/hR9F+RrVyGxFHbxxXMlxGZ EkkOWxIwUnAG
ducdAO1K3QCO5sYbveJnnKuMMq3Eiqw75AIFJRUdh3bLNUIKAI5YhIF+YqVO QR9Mf1pp2EQN
p6OmxpZCuScZHfOe3uarnYWJ44fLZm3sxIA+bHb6fWk5NhaxT1bRrTWIo0uQ wMZyjpjIz16g
itKVaVJ3iROCnuZP/CD6b/z8XP8A5D/+Irf67U7L+vmZ+wibWm6bb6VaC2tl ITJYk9WPqa5q
lSVSXNI1jFQVkW2UOhU9CMHnFZlgiLHGkaLtRFCqMk4AGO9Nu4haQyra2EFp NcToN01xIZJJ
GxknAAHHYBVH4c5OSXcSVi1SGFABQBnX+g6ZqUolurUNL/fRmRj9SpBP40mk zGdGnN3kiex0
2z0yIxWdusSnqRyW+pPJ/GhJLYqFONNWii1TNAoAKAOa1fwPpOtajJe3RmEs gXcF2kHAwOqn
tWbppu53UsdUpQUElZf13NTRdEtdBsWtLMuY2cyEuQSScegHpVRioqyMK9eV eXNI0aowCgAo
AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAGRxJEHCLjexdjknJOPX6dK dxFbUtOh1O2E
MzOm1tyshwQcEd8gggkEEEYNXTqOm7pCkrqxV/sNv+gre/8AkL/4iun65L+V fj/mZewiaUEE
dtCsMK7UXoM5+pJ7n371ySk5O7NkklZCXFtBdxeVcwRzR5ztkUMM/Q1DSe5S bjsUo/D+jwyP
ImmWoZmDk+UDg4A49Og4HfnqTRyrsV7Sfc0qZBHNBFcwvDPGskTjDIwyCPpQ JpNWZnWnhvSL
G4W4gslEq8qzMz7T6jJODStYyjRpxd0jVpmwUAFADBEgm87bmTbsByeBnPTp 26076WEMurWC
9tZLa5iWWGQYZW7/AP1/eplFSVmVGTi7op/2DY+t1/4GTf8AxVYfVaP8pr7e p3/IvQQR20Kw
wrtRegzn8Se59+9bxioqyMm23dkqkqwYdV6UWTafYRFNBFPdxXUqB54gyxsf 4c4zj8qlQSk5
dWO7tYkqxBQAyOJIg4Rcb2Lsck5Jx6/TpTuIfSGQT2cNw4ZwwYDGUdkJHvgj NZzpwn8SuVGc
o7MWC1itt3lqct1LMWJ/E84/xpwhGCtFWCUnLcmqyQoAY8SSFN67gjBwMkcj p0/lTTsIbKHW
a3nRd5gkL7M43ZVl/wDZqqDSepMk3sLJeRy536ZfHnP+tTg+37zj8KxnhMPU d5tv5y/DXT5e
hSqTWy/Ibb3EFrK0sWkXYkYYLM6McemS/FOhhcPh7ukkr+v6hKpOe/6ChnuL 2W6eJog0aRhG
IJ+UscnGR/F69q3nJNJImKd7sz/7CgMSxtM7ooAAeKJuwHdPQAfgKv6xJC9m izY6bDYM7RMT
uVUxtVQACxwAoA6sfzrOdRz3KjFR2K/iX/kVdY/68pv/AEA10YD/AHul/ij+ aM6/8KXo/wAj
jfgp/wAinqP/AGEpP/Rcdehnv+9fL9WZYP8AhI63Q3EfhfQsziINBbr93cWy o+Ue56ZrzsX/
AL1U/wAT/M1ofwo+i/I2a5DYx7u7ikOqNHcEtZWwdPLlICSfPncAcH7q8Nn9 TXBWqq8rPZaW
fXX/AIGjOmnB2jdbv8NDS+0KYvOieOaFiArxtuBywXrjH4Z7V6NouHPF3Ry6 p2aHTzxW1vJc
TypFDEpd5HYKqKBkkk9AB3qRlTTdb0nWPN/svU7O+8rHmfZp1k2ZzjO0nGcH 8qLWEW522Rhy
wVVdWYk4AUMC2T6YzSbS1Y12RW02S7itXS8vEuJ1YsWktRCVQgbfl3d8Hn3w cEEV0xnSqv3F
by/X+vzuZ8s4fE7liKQyTTnPAZcY6D5FPH51hJWky1sUtQ8Q6JpNwtvqWsWN lMy7xHcXKRsV
yRnBI4yDz7UWYGlSGZ+n6i+oXMkCxCNl5BY9u59//rj1rTksTctRzZiVpEkQ 4BbMbAD9KnlY
7k1SMqXU9x5NwLGMSSwoXbIJAIGQuByWPHHYHJ7A4Vakkmobr+rer/4Pa+kI Jtc2wq38LOql
Z48nAMlvIi5PQZIA9qarQbtr9zX6CdOSX/BQ+8vbTTrR7u+uobW2jxvlmcIi 5OBkngckD8a2
MyPT9U0/VrdrjTb+2vYVbYZLeVZFDYBxlSecEce9GwFpmC4zk56ADJP4U0rg NXzZJQscT4Cl
juQrnpwCeM8n8qpR7hccrBhkVGwDTLGG2F1DemeaAH0DIZHC3VuhnCb937vb kyYUnr2x1/Cm
hE1IZnyahJDdvHLFiMdMfeI9fer5boLXHW17LcXRQRDygOueV9M/X0pNWQNW L1SBHI7iNpEG
UQgMcE55wcY9PX/6+KUdBXI97maNgzLGx2hSuN3BJPr6U7WQEk7FY8h9nzKC 2OgJAqY7gNVp
S8cG0ib+IspxwDznpgkdfeq5dQuSq2c8EEHBB6g1LVgI7qcWtpNcMpIiRnIH fAzWc5ckHLsV
GPM0iq97dR3a2bW8P2hyu3ExKYIc8nbkf6s9u4rF1pqXI0r+unXy8uxp7OLX NfT09PPzLNrO
biHeyBGDsjAHIyrFTg+mRWtOfPG78/wdiJR5XYcv/Hy/+4v8zWhJX1d3i0W+ kjYo628hVlOC
CFPIprcRIrS20yW10dxf/VTYwJRjOD6MB1HfqO4VLYCxQMpXEccuqWqvcSIy xu6wozKHwU+Y
4ODjOMHruqXG7TBO2hIbGErMN8+Jjlv9IfjnPy8/L+GKORa/5sdw04MNLtA8 yzuIU3Sq24Oc
D5ge+euaIpqKTE3d3QahcLbWMrm5itnKlUkmYBQ2OM5pVHaL1sxM5fRNYvbP UJINSS4SzaMG
N5syMz9cKRndxkkrleAflziuCjWdJfvXp/W3l/Xq9L6HXxyJLGskbq8bgMrK cgg9CDXpJ32A
z9P8Q6Jq1w1vpusWN7Mq7zHb3KSMFyBnCk8ZI596dmhF6X/WQ/7/AP7KaQxL gyCEiIgSEhVJ
6ckCqirsTKZe5juhbS3UIlJAwH7noM7MZ9q05YbE3ZcjWeKZ45mBIVWGDnrn 2HpUTSWw0V9W
N0NOcWUgjuWdERjjAy4HcH19DRCUIyXOrr/MU1JxfLuc3baleSOVHinSpWCl iEvos4AJJ/1X
QAEn2Fem6FNfYf4/5nBGtN/bX4G5o9xNO0rPexXcJRWjkhlWRTy4OGVVHVcf hXBX5Iz5IqzR
2UXKUeZu6H6h4h0TSbhbfUtYsbKZl3iO4uUjYrkjOCRxkHn2rGzNTSpDCgAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgDL8S/8irrH/XlN/6Aa7MB/vdL /FH80Y1/4UvR
/kcZ8Ff+RT1H/sJSf+i469DPf96+X6sywn8JHX6DL5XhjQj9o8ndBbrnbktl R8o9z0zXn4v/
AHqp/if5mlD+FH0X5GxXGbmFeXVvaagltHdNbG5m8sr5TOAxCksuAQCd4zu4 yd3Yhsnl3tnz
xdl1/wCB5/8AD+tLEqHuyV+39f1/lckEcNuiRx7FDxjBB7yr3Iycnkknkk13 eyjCnyxWiMed
yldmjXMaFDSdF03QrR7XSrKGzgeRpWSJdoLMck/0HoAAMAAUXuITW1YaVPcR yvFJbK06lQCC
yqSMgggjPP1ANc+Ijem3fbX7jai7TS76EfmTXOtOTJJi3hUqibRkvvByeuPl XgEcgHtWOBl7
So5ze363LrrlhZLf/gFy2SRJLhnBG9wVyeo2KPX1Br0qjTd0csbpakF/oum6 nd2N1fWUNxPY
SebbO65MTYxkfofqAeoBGd7DL9AyGRXjJePODyyj+Y/z/wDXpPoIjWO4lgUS ygb1+YBCDyOe
9PmsBaqBmZdyXelWtxJZxNPGQ7pGqlmSQ5PQclSx+oJ9Pu8FenOHvU9fL+v6 /TopyjJpSJGt
r+42JdXkLwh1crHAUYlWDDkue4HbpWiw8rrmlp6f8En2kUtEW54Irm3kt54k lhlUo8bqGVlI
wQQeoI7V1mJBpmmWWjabb6dp1sltaW67Y406Af1JPJJ5JJJo3EWHRm2lG2sp yDjPbH9aadgI
2lu0kVd4cMD0UjB46nP1quYCVFK5LNuZjlj6mpbuAGNDIHKjcBgGkA6gZE8u y6gT7R5e/cPL
25MmFJxntjr+FUhEtSMxryK+vb4xiPy4487Wbp9f/rVaskUmkP01by2unt5I sw8nf2B9vXND
s1cTaepqkZBB7+hxUCK0kkluFQAHkKhzgHnH5/5+lp3EPjhkMolmYFgMKo6L +PrSbAlkjWWN
kbowxUrQCszz2+wSMrqTt3AkHp6fhVp3AmjRtxkfhiMY9B/n/PrLYEOqxvLp F7HEpaRoHVVH
UkqcCsaycqckuzNKbSmm+5lTTNJq8d4kdybdCgLG2kBHyzD7uMn769B3rgcJ N31+5/3v8zpT
SVv19DT0oMLIllZd00rgOpU4MjEHB5HBFdtBOMLPz/NnPVd5aeX5Flf+Pl/9 xf5mtzMr6ujy
aLfRxqXdreQKqjJJ2ngU1uIo6peXtzby290PskK4nXymDOYVwHySCFZCVfIz 2CnIzSWlhGwi
lI1UuXIABZsZPuccUFFC7ujbazYo1szxyxyL5yQM5Rt0eFLKDtB5Jzx8o54r WMOaDd9vP1M5
S5ZJW/rQqa3r72GjaldWVlcTz2cbkh4SiKQrHcS5XcoK87CTyMdacaV2k3v5 /wCW3zBz0dls
aWmgJptvGtpLZrGgRYJWVmQDgAlWYHgeprKW5S0RheKGuLSZbss6W3lbfOjG TA4JOTz91hwR
0O0cg4Nefi6c21JbGkWluZOh2EviCxulZzBChBhlj+aNmbJk299pwjcYIbng 5qadH2sNdLbe
QSfvXR1+j6cNJ0m3sfPecxA7pHGCxJJJx25J4rupw5IqJAlhoum6Xd311Y2U NvPfyebcvGuD
I2MZP6n6knqSTdwLcv8ArIf9/wD9lNAwmIVVZiABIhJPb5hVR3E9jA1zTZZb tns57eeKVskG
ZQVzyQcnlc88cjP52466Em7EfmRDcLO6QRq8inO5hnJpT6DRDqkghsxISqhZ oiSxwB+8Xqew
rJ9PVfmV0Zz1nJIbEpcS2au0hJz4kuAcAsFwRuIGD2PPBIGAB3fWFe919yOb 2GltfvZoeHZp
ZYwJzH5628YkEd0bgBt0hwXYk556ZOPWuSpJTqOS7L9TeEeSCiXr/RdN1O7s bq+sobiewk82
2d1yYmxjI/Q/UA9QCJvYZfoGFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAU
AFAGX4l/5FXWP+vKb/0A12YD/e6X+KP5oxr/AMKXo/yOL+C3/Ip6j/2EpP8A 0XHXoZ7/AL18
v1Zlg/4SO48MgDwvpBEoU/Y4fXj5B7V52M0xNTX7T/M0ofwo+i/I09i/89V/ X/CuWxsNEMal
iroCxySAeTjHp7CqTa0TFZA0MbjDOhGQcEHqOR2o5n3Cy7Dti/8APVf1/wAK mww2L/z1X9f8
KLAQTXNnbsFmvreJvR3wf1qlBvYTkluVrefRbOMx215YQITkrGwUE+uBSjQ5 FaKt8gdVS1bL
Ed5YyuEi1C2dz0VZMk03TktwUk9mWNi/89V/X/CpsMNi/wDPVf1/wosAbF/5 6r+v+FFgDYv/
AD1X9f8ACiwBsX/nqv6/4UWANi/89V/X/CiwBsX/AJ6r+v8AhRYA2L/z1X9f 8KLAGxf+eq/r
/hRYA2L/AM9V/X/CiwBsX/nqv6/4UWANi/8APVf1/wAKLAGxf+eq/r/hRYA2 L/z1X9f8KLAK
FAziVR27/wCFHzATYv8Az1X9f8KLAGxf+eq/r/hRYA2L/wA9V/X/AAosAbF/ 56r+v+FFgDYv
/PVf1/wosAbF/wCeq/r/AIUWANi/89V/X/CiwBsX/nqv6/4UWANi/wDPVf1/ wosAbF/56r+v
+FFgDYv/AD1X9f8ACiwBsX/nqv6/4UWAaIUDl/NXJAHftn296LAO2L/z1X9f 8KLARy2sE2zz
fKfYwddyk7WHQjjg0fMCTYv/AD1X9f8ACiwBsX/nqv6/4UWANi/89V/X/Ciw BsX/AJ6r+v8A
hRYA2L/z1X9f8KLAGxf+eq/r/hRYA2L/AM9V/X/CiwBsX/nqv6/4UWAa0KMV JlX5TkdfTHp7
0WAdsX/nqv6/4UWANi/89V/X/CiwBsX/AJ6r+v8AhRYA2L/z1X9f8KLAGxf+ eq/r/hRYA2L/
AM9V/X/CiwBsX/nqv6/4UWANi/8APVf1/wAKLAGxf+eq/r/hRYA2L/z1X9f8 KLAGxf8Anqv6
/wCFFgDYv/PVf1/wosAbF/56r+v+FFgDYv8Az1X9f8KLAGxf+eq/r/hRYA2L /wA9V/X/AAos
AbF/56r+v+FFgDYv/PVf1/wosAbF/wCeq/r/AIUWANi/89V/X/CiwBsX/nqv 6/4UWANi/wDP
Vf1/wosAbF/56r+v+FFgDYv/AD1X9f8ACiwBsX/nqv6/4UWANi/89V/X/Ciw BsX/AJ6r+v8A
hRYA2L/z1X9f8KLAGxf+eq/r/hRYA2L/AM9V/X/CiwGV4mRR4U1j94p/0Kb1 /uH2rswC/wBr
pf4o/mjGv/Cl6P8AI4j4LkDwpqP/AGEpP/Rcdd2e/wC9fL9WZ4P+EjtvDf8A yK+kf9ecP/oA
rzsZ/vNT/E/zNaH8KPovyMyx8cabfyIkUMwLjIzJCT0z90OWz7AZqp4OpTi5 NrT1/wAiI4mE
nZI1rTU1uJ1jITEql4/LkVyACRztJ9M56c46jnyaWI55W/r5/wBW6b79sqfK rlu5leCBpI7e
S4cYxHGVDNz23ED8zXUZPQ5a38V3TTT+bZSxI90ojMoVhBCCFkMmwnZykmCe 5HYHGnItr6mH
tlezOi0/VbHVI2aznDlMb0IKOmc43I2GXOOMjmoaaN009hkupT6VoH2q3tkl klvHid3bAjzI
yqx7sAdowPXtXXCHO1G9tDFy5Ytj9N1fVH1VbW5ht3t5M4dZ/wB5HgEnI2jO TtGByM557EoQ
hop3fpb9WUqjnrycpS1LUruTxJrOmtLm0h0s3Ece0fLJn72cZ/WrjFcil1uZ Sk+dx6WNmuA6
goAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAo
AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAK
ACgAoAKACgAoAKAMvxL/AMirrH/XlN/6Aa7MB/vdL/FH80Y1/wCFL0f5HC/B y3MvhbUGFhPP
/wATGQbo5tgH7uPjG8fyr1M6inifl+rMMK7Ulod34b/5FfSP+vOH/wBAFeTj P95qf4n+ZvQ/
hR9F+RFoovZ7bRdgt4gbAsrHMm4fu+o+XB5Hc1nBNRj5IGk2/Unt7drTXr6N jEWeGKU+WhQZ
LSZ4JPpn6knqSTg6ajUcl1NlJuKXYuXFtBdwNBcwRzQtjdHIoZTg55B96ewm r7nDRQ6xok7W
EdvNcnUXlu4wJfMkiwyjbIWOCArRj7x5B56GqqR9pFWdmjklGcXotzovDWm6 jp1ii3lz8rbm
+y7VIt8tlVVgB0BIOc9sEAcknc2pRlGKTJdS1a20nwsj3dslxFPeyRFHXcP9 a7Zx3wFJHvit
Z1HTSkvL8jOpUVON33Mey1O5aC48p/OsY4VZvLDN5TLglxx7E4BznGQDmso6 3tsFKTnO6eh0
KaZo0Hh/UdS0qND9rtXYzK5bcNpOBk8DPYYrqU3JpN6FumoJ2WperjNwoAKA CgAoAKACgAoA
KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKA
CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKAMv
xL/yKusf9eU3/oBrswH+90v8UfzRjX/hS9H+RwHwetLm68OagsN7cQqL9/ki fYM7E5Pr/wDW
r3M2UFXvJf1dnFQk1BJHoHhv/kV9I/684f8A0AV4OM/3mp/if5nbQ/hR9F+Q 7/hH9F/6BFj/
AOA6f4VympYtdPsrHf8AY7OC3343eVGE3Y6Zx9TQMsMyopZiFUDJJ4AoAqi6 08StKJ7cSMoV
m3rkgZwM+gyfzNAh/wBvs/8An7h/7+CgZRuJLObT5NPmWxu7R3Z8SXPlkEsW 6gHuTyCK15oy
VpGMqfMuVq6DSriz0S2a30+00+GNjub/AE9mZj7sykn86E6cdv6/EUKfs1aK JWv4n0+SwjTT
rS3kVlPlXAO0NnOF2gZOTVKcY6otqUtGWft9n/z9w/8AfwVgaB9vs/8An7h/ 7+CgA+32f/P3
D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w /wDfwUAH2+z/
AOfuH/v4KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32f/P3D/38FAB9vs/+ fuH/AL+CgA+3
2f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4KAD7 fZ/8/cP/AH8F
AB9vs/8An7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQ Afb7P/n7h/7+
CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4KAD7fZ/8/cP/AH8FADku7aRwkdxE 7HoFcEmgB8k0
UKhpZFjXOMscCgCL7fZ/8/cP/fwUAH2+z/5+4f8Av4KAD7fZ/wDP3D/38FAB 9vs/+fuH/v4K
AD7fZ/8AP3D/AN/BQAfb7P8A5+4f+/goAPt9n/z9w/8AfwUAH2+z/wCfuH/v 4KAD7fZ/8/cP
/fwUAH2+z/5+4f8Av4KAD7fZ/wDP3D/38FAB9vs/+fuH/v4KAD7fZ/8AP3D/ AN/BQBOrK6hl
IKkZBHQ0AQfb7P8A5+4f+/goAPt9n/z9w/8AfwUAH2+z/wCfuH/v4KAD7fZ/ 8/cP/fwUAH2+
z/5+4f8Av4KAD7fZ/wDP3D/38FAB9vs/+fuH/v4KAD7fZ/8AP3D/AN/BQAfb 7P8A5+4f+/go
APt9n/z9w/8AfwUAH2+z/wCfuH/v4KAD7fZ/8/cP/fwUAH2+z/5+4f8Av4KA HxXNvM22KeN2
AzhWBNACyzwwY82VI89NzAZoAj+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/ AD9w/wDfwUAH
2+z/AOfuH/v4KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32f/P3D/38FAB9 vs/+fuH/AL+C
gA+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4 KAD7fZ/8/cP/
AH8FAFPxL/yKusf9eU3/AKAa7MB/vdL/ABR/NGNf+FL0f5Hn/wAINL1S78Na jPp+ppaqNQdC
jw78nYhz1HqK9nOKjjiLeX6s5cPBSpps77w95n/CMaKI9g/0aDcXzwuwZxjv Xi4y31mpf+Z/
mdVD+FH0X5GiBc8cwjMvq3EfHPT73Xjp05rmsjUdH5mHMuz7x2hc/d4xn360 tAEOPtlmDypl
OQehwjEfqAfwpx3At3+qw6abU3DpHFNL5bSO4VU+Rmzk/wC7j8a2WpOxnWXj HTL/AFgabbsX
lJIVg6FWxv5GGzj5D27j1Fc0cRFz5LP/AIY3dCShz3N3fXRcwDfRcBk11DbI HnmSJCyoGdgo
LMQqjnuSQAO5IFFwH76LgG+i4BvouAb6LgG+i4DI7qGV5UimR3hbZIqsCUbA bB9DhlOPQg96
LgP30XAN9FwDfRcCjBrlhcWjXMczeWoVvmjZWIb7pCkZO48DA5PAyaLjLFpf Q3tuJ4GYxksv
zIVIIJBBBAIwQRRcRmW2BG6jhVlkVR6AOQB9MVi9yiakMKACgAoAKACgAoAK ACgCjqWof2el
uf3A86Xy91xN5SL8rNktg/3cdO9NK4imdd2PEPO0mXfKkey31DzH+ZguQuwZ xnPXtTcbBc0r
65+xafc3Wzf5ETSbc4zgZxn8KkZnf2rqH/QN/wDId1/8Yq+UVyybn7Z4fF3s 2GW3EwXOdpK7
hz7HvUDL9tNFBeXc07qkcUCsXc4CDLFjk9BwM/Sri7CtfQ563+IlvJqHlyvY JAUhP/H18yby
24kkYO0bcjjHqc8cscW21eOj8zreFSTs+/T/AIJ2u+u65xBvouAb6LgG+i4E dxdRWltLcTNs
iiQu7YzgAZJ4ouBX/ti0+z+dvkxv2eX5T+ZuxnHl43ZxzjHTnpzRcCeK4gvb NJUIkt54wy5H
DKR6H2NFxmVZMXsLdmJLGNSSep4rAoybfxB9otop/tGjReYgfZJqeGXIzgjZ wavlFc0tNvPt
9ktxiMZd0/dyb1O1iuQ2BkHGeneoegFObVrpb25ggsfMWBwm/EzZJVW/giYD 73rmqUbhcm07
UZru5ngntvIaJEcf6wZDFh0dEP8AD6YpNWAfxmdP4PtUale2CUyPocnP1NC3 AXX/ABbBod3F
amNHmdPMPmS7FC5wOcHJ4PbtTnU5NDmqVlB8pQv/AIiafZ21lKkYY3MZkxJJ tCgMVIyAcnIP
txXXQpOsuZbGsJKcVJHR6TqsOr6Xb38AIjmXIB7YOD+orOcXCXKyy5vqbiDf RcA30XAqy6ra
w3q2ckjCYhT/AKtto3EhctjaMkEAE8mi4BFqtrNetZxyMZgGP+rbadpAbDY2 nBIBAPBouBXv
iP7StyOC0T598Fcflk/mazmUjN1HU/sNzBButE81HffdXPkqNpUYB2nJO79D UpXAhh1nzL22
t/N02bz3Kf6Lfeay4VmyV2Dj5cde4puNgLmpXjWNk06Rea29ECZPJZgvYE9+ wJqUBm3GuX1t
bSzvpuViQufluRwBnqYAB+JAq+ULmrecRIw4IlTB9MsAf0JH41Awt+bi7J6i QKD7bFOPzJ/O
gCxQBEuoLpehT3jRmRllf5QQCx8wquSeg6DJ6Ae1E6ipU3Nk9R2heIrfW0nV F8u4t2Cyx5zt
znHJAPYjBAIIPFLD4hVo3tZg1bQ1t9dFxBvouBXvNRgsVjaYyfvH2IscTSMx wTgBQT0BP4UX
Ajl1myiaBTPu87ZsaNWdcMcKSVBABPAJwDz6UXGJqrA2an+JZY8HuMuAf0JH 41MtgRRvrn7F
p9zdbN/kRNJtzjOBnGfwrIozv7a/6fNC/wDBp/8Aa6vl8xXNGxuftun211s2 edEsm3OcZGcZ
qBmaNZvJHl8rT9yJK8YO2ds7WK5ysLDt2JqlEVy5pl9JfJcebB5Lwy+WV+bn 5VbOGVSPvdxS
asBR1njwZrI7LbXKgegAcAflXXgP97pf4o/mjKv/AApej/I5X4KXN1B4S1FY LeKRf7SkOXmK
HPlx9gpr1c6cVide36s58Lf2asdn4b/5FfSP+vOH/wBAFeRjP95qf4n+Z0UP 4UfRfkadcpsF
AETnF3ZH/pqf/QGprcQzV52iuNLdIXmYXRwiFQT+5k9SB+tarqSzltJv45fG vl/YxE5lfrMS
yn99nKiUj1/hx856ZBPmwa9tay3ffz8z0Jxfsb+S/Ty/XoX/AB1bfb5PDlt/ Z1nqO/Uz/o16
22F8Ws5+Y7H6YyPlPIHTrXopnAc74i1nU/Beiw20GoW1nNZwTXgimuUigmDO 7JbRBomaURgB
NqGI7WTGNw2iAsavq895bXavq6SarFqsCpozyRxrGiahEsUhAQyqGUI24lh+ 8yBgqAAV/Enj
bUNM0wPBqqW+oWEEk9zHfSRWqzy8t5CxmNy5XA+VHU7JIz5j7w9AEmqeLNVt b0taav5ur/ab
2P8AsHZE37uKG4aFtgXzvn8uFs7sHfxgECgDe8EatqGofblu9Ws9Ut4/LMc9 tcrcYY7tymRI
Yk4AU7QCwySThloYHK+AZdDsfCMFxa6v4eg1YafAd+n2Sfak+5lJlDs0pZ9i kAKxJwMMVwMD
TuPEs7ahpseq+Kf7AE8V091Fm3T7PMhgCwbpUbOFdm3fx53rhCoABQ0rX703 Vy+r6n/wjkd7
Ks93cbY4vLuBZWWIczBlXO+U7SN37vrw2QC5B4i8Uz+HtX1SadLe4ga0h+yt CIltTLDbPO7s
wYqE8yRgWBCfMWDgAKAT+HtZ17UtY0yzk1y2mtGW5laa22z/AGhI2ttoEvlx oTukkUsiY25X
743KAeg76VwOdsb+ym05ZoGULtZre5WNZF01XUAKSTx6lRwoODhQDVJgamj3 ME+mRvbKoj3O
vyvvDMGIZg38WSCdx5Ocnk1NwIrX/Vyf9dpP/Q2qGMnpDCgAoAKACgAoAKAC gAoAKACgCpqs
Elzo97BCu6WSB0Rc4ySpAoEWv7dl/wCgLff99Q//ABytedCsZkMElt4WjgmX bLFZhHXOcEJg
1kUaVq23Ubj/AK5R/wA3qoiOU1LRG0i8tHhl1C8ilMUYjV4lI8oOygtwfpjp huckVxVKKp2a
ud1Orz3ukv8Aglfw3f3iXFgDZXyJLeTq264BVstITlS/Y8k45wcZ4yqbamtX 9/qOok4vbZdP
QPEOiy67441OG3sLB5/7KtUjv7hyJrBmkuQJYQEJLA/N95OVXnuPRueedlJr unxfaN9xj7Nc
xWkvyN8ssmzYvTnPmx8jgbuehwgJ7fULe6muoYZN0lpKIZhgja5RXxz1+V1P HrRcAv7iGDTr
qa5j8yCOJmkTAO5QDkYPB4ouBj/arf8As/d9oj87Z5f9p7h5e3fu8nzvvYx8 vmY68/f4qrgb
FhcQz6dazW0flwSRK0aYA2qQMDA4HFTcCnYf8g62/wCuS/yFZlFigAoAp2d3 Pp11qAOm3M6T
TiRHiaPBHlov8Tg9VPatIySRLQRSTXWsXN29nLbRtBFGolKEkq0hP3WP94VM nca0GHh5/wDr
7i/9p0kBX8U6BpuqW76hdtNFJaxMxeAqGZVydp3Aj17d6r2aqSSOavRhNcz6 HE6WNK8S39jp
U1q1sscbLE8AwwHLEMWyGydxzgHJ969mph5YOlzRehw4PGRqS9kkekLouljR V0eSxhn09VCm
CdBIrYOeQ2c88/WvJlNyd2esYXgQ6Zo3gbwvDFDDayajbQ4EUW3zpjb72ZsD 7xWNiSeuOvSk
2Bvx67p8v2fZcZ+0XMtpF8jfNLHv3r04x5UnJ4O3jqMoC/vouBj3t5arrKwP tMnkfvIeGa7R
twWMKeDggkk/dHszENMAsry1bWWgTaJPI/dQ8K1oi7Q0ZUcDJIII+8PZVJGw LV02dRt/+uUn
80qJDQ6pGFAFPUkle1QwxNK8c8MmxSASFkVjjJA6A96a0Yg1XU7i+0e9tItH vRJPA8almhwC
VIGf3nvWnMhWJL3/AFC/9dY//QxWRRzfjKzt9R8PXljdx+ZbXOpWUUqZI3K0 8AIyORwe1NaM
RR0fTb+28e2N7q8vnajNpt1bmTaq7oopbdUOFOPnYyS46jzdvO0U3sB3Fkkc unSQyoskbvKr
IwyGBdsgjuKa2sBwr2P2PQb2aJ7cW82oTJ5CxsJJfLldAGkLEbVRCwBXb8vP fPHjqVKlR5Ya
bed9P6e5nDmbuzpfBU95JoLfbZkkZZ3RApOUUHABz05yQMnAIq8I26Sv/wAM aPcqQNpF18S0
vNL+xy3Mdjcw6hNbbWdZPMtwiSleQ2EcANz8rY6Guu+gja1u6hhtoBJPHbSS ShYbmRgqwPtY
78n2BGP4s7TwTSArXN9Yx3NsfI+yxyXAY20iCNrh3ZQswH8RB5KnBGQxAKrl tgaWpNm0A/6a
x/8Aoa1LegxKgYUAFAFPTb+4061e2fSruUieZw8bRbSGkZhjLg9CO1aKSSJs FmZZLrULmW3k
txPOHRJCpbAjRedpI6qe9TJ3Y0Z+s/8AIna1/wBe91/7PXVgP97pf4o/mjKv /Cl6P8jjfg3Z
21x4W1F5raKRhqMgBdATjy4/WvSzuUo4rR9P1ZhhYp0ldHb6FPDbeEdKmnlS KJbOHLuwUD5B
3NeZi4uWKqJfzP8ANm1FpUYt9kXF1Swe3lnS9geKIZdkkDBfTpXJU/cx5qmi NoNTdo6k0E6X
CMUPKMUdcjKMOoPvUQmpq6KaaGznFxZn/pqf/QGqxFltjsjMqkocqSPunBGR +BI/GncQ7fRc
A30XAN9FwDfRcA30XAof2VZnVv7TcTSXI+6JLiR44zt27kjLbEbGRlQDgtzy cu4F/fSuAb6L
gV3tbd9QhvmjzcwxPEj5PCOVLDHTkxr+X1ouBY30XAN9FwDfRcA30XAN9FwD fRcDOguFhV0d
Jg3mueIWI5ckcgUhkv22L+5N/wB+H/woAPtsX9yb/vw/+FAB9ti/uTf9+H/w oAPtsX9yb/vw
/wDhQAfbYv7k3/fh/wDCgA+2xf3Jv+/D/wCFAB9ti/uTf9+H/wAKAD7bF/cm /wC/D/4UAH22
L+5N/wB+H/woAPtsX9yb/vw/+FAB9ti/uTf9+H/woAPtsX9yb/vw/wDhQAfb Yv7k3/fh/wDC
gCC9u42sLhQs2TGw5hcDp9KALMTbdRn/AOuUf83piFvLS3v4ljuFYqjblKuy EHBGQVIPQn86
mUVJWZcZODuilYaBp+myJJCJmdHd0MkzNtLE5wCcdGIzjPqScmpjTjF3RUqs 5KzNbfWlzIN9
FwDfRcA30XAN9FwDfRcDNtLlIrKCN45gyxqCPIfggfSkMm+2xf3Jv+/D/wCF AB9ti/uTf9+H
/wAKAD7bF/cm/wC/D/4UAH22L+5N/wB+H/woAq+YJFndQwH2qL7ylT/yz7Gg DVLBlKsAQeCD
3p3FYzrHRNM024ae0tVjlYYzuJwPQZPH4VtOvUqLlk9DKFGnB3ijS31jc1Df RcA30XAN9FwD
fRcA30XAp3Mnl3sEjK5URuMqhbBJX0HsaAD7bF/cm/78P/hSGH22L+5N/wB+ H/woAPtsX9yb
/vw/+FAB9ti/uTf9+H/woAhubmOSNEVZQTLH96JlH3x3IoAWO4SK5u1ZZCfM B+WNmH3F9BQB
L9ti/uTf9+H/AMKAH2DEWvIZcyOQGBBwXJHBp3EUpvDujSyTTLp1vBczHc9x BGI5S2d2d4Gc
5APv3pVV7WHJPVCUUndEmi6RaaDYm0s95RnMjM5yST9MAYAAAAHAqKcFTjZD NLfWlwDfRcA3
0XArXzE2vAZsSISFBJwHBPAouAz7bF/cm/78P/hSGH22L+5N/wB+H/woAPts X9yb/vw/+FAB
9ti/uTf9+H/woAPtsX9yb/vw/wDhQBlauwbwZrLDODb3R5GD/HXZgP8Ae6X+ KP5oxr/wpej/
ACOV+C3/ACKeo/8AYSk/9Fx16Oef718v1ZjhP4SOq0u3iuvBmjwTqTFJBaqw DFSR8nccivOx
U5Qxc3Hfmf5mlKMZUIqW1l+RbbRbG3uLi2tRLCGiRg6zMXRsuMqxJI4/r6mu bEuVZ8s36eRr
RjGmrwRatLX7OrF5Glnc5eRieeScDJOFGTgdvzNc9Kmqa7vuaylzMLj/AF9p /wBdT/6A1akl
igAoAKACgAoAKACgAoAKACgAoAKACgBCQoJJwB1JoARGDrlc4yRyMUNWEOoG FADVkV8hT0OO
n+fQ07WEOpDGGTBIVd23r8wGPzIqlG4hEnhkICSKSegzz+VKzQCysY4XcdVU kUhj6AIPtcWS
AJDgkZWJiMjg8gVoqUmrpEOcVpcfHOkrMq7gygEhkK9fqPY1MoOO41JPYc7r GjO7BUUZJJwA
KhtJXZSV9EUv7UiiumiuzHajYskZlkCswJYcg9Pu9PcZweK51iIqTU9O136/ 5Gvsna8dS5FL
HPGJIZFkjPRkOQfxreMlJXi7ozaadmK7FI2ZUZyASFXGW9hniqEZ39ry/YPt v9lXn2f+9uhz
nONuN+d2eNuM54xmq5WK5Zu2L6VOzIyEwsSrYyvy9DjipGOT/kIzf9ck/m9A FigAoAKACgAo
AKACgAoAKACgAoApPfTC+a0i065mcJvBVowGHcjc4JweD6ZHqMtK+wh9netd tMDazQeU+wmQ
oQT3AKsc46H346g4GrAQyf8ALz/19Rf+06QzQoAKACgAoAKACgAoAKACgAoA KAIbqc21rJMI
JZygz5cQBY/QEjNAFSTVJo4IZjpV0Y5iojZZIW355GMSc8c/QE9BVcrQrlm9 /wBQv/XWP/0M
VIwt/wDX3f8A11H/AKAtAFigCC9ma3sLiZMbo42YZ9QM1UVeSRMnZNktzp9p AET/AEia5k+4
v2qRd2OpODhVHc49MZJANVKqhokr9F/XT+twjTvuyrYvoV7b2zfbdk0yqfJ/ tFywYj7v3uue
KzpYqlUindXfTT7i50JRb0dl6li7tI9PltTA0uJpDGyvKzj7jNn5icfdreST izFaNCPcRxyb
CHLYBwqM2B+A9jWcYSkrotyUdxFuY2dUxIpY4G6NlzxnqR7UOnKKu0JTi9ET VBZHJPHEcE5b
so5P+fek2kBzWoeLp7K8uoU0p5Y7cFmcM/QKrHohA4cdTx3xkZOaCScpJf8A B0X3iOppjKKX
88tzPBDpV1I0JAbDRDIPRhlwcHnn2I6g1Si3sIlsbz7dbeeIJIVJIXzCp3D+ 8NpIIPY9+vTF
TsBmaz/yJ2tf9e91/wCz12YD/e6X+KP5oyr/AMKXo/yOX+Cdgl14S1J2lkUj UpBhSMf6uP2r
087inivl+rMcI7UkdZocIn8JaQm9k/0WBgy4yCFUjr9K8rGaYmp/if5mtD+D H0X5GlDbtHK8
rzyTO6hcvt4AzjoB6muaUnJ3Zqko6ImpFFe4/wBfaf8AXU/+gNQBYoAKACgA oAKACgAoAKAC
gAoAKACgAoAYXEcytIMoMbfTd7/0/wD1VcbCZFvtWLEJNyxztMmM55/Wq0ET Rb/KTf8AfwN3
1rJjIyyLI4mjlbn5ShbGMD0981atYA8+F4Fjt42DqW2ZzkHPOc84z1//AFVT asImrIoz7u+e
xjnZBzu3HplV28sAevTGP59K1hqS9COG+Msz2iszojKQzMCwOVOPUjBzk+h/ CpaISNC4/wCP
aX/cP8qwLJKAMULH9ruHbSX1JgABHGIyygyS8/OyjHA6HPSvQh8K1sccnaT0 JEWI3No66DLp
jrNgNKsQLgxvkDy2b0HXHaoq6RetyqTvLZo05YkniaOQZU+hwR6EEdD7jpXB KKkrM603F3Ri
8vfTfbLm7miRVjja288ZILbi3lgLnkA4zyp6dB5y9nGclOTfa1/00Or3nFcq t936lnSHlhto
4ru38iab5wxct5hIBwSxLbgOMN/d4yBxthanuqMlZ/n+t15/LQzrR1undGpX aYEH2OD7V9o2
HzOv3jtzjG7b03Y43YzjjOKBCX//ACDrn/rk38jQME/5CM3/AFyT+b0AWKAC gAoAKACgAoAK
ACgAoAKACgCKe3juECybhtOVZHKMp6ZDAgjgkcdiR3o2EPjjSKNY40VEQBVV RgADoAKBlGT/
AJef+vqL/wBp0AaFABQAUAFABQAUAFABQAUAFABQAUAQRWcEM7TIhDtn+IkL k5O0dFyeTjGT
yc0CEvf9Qv8A11j/APQxQMLf/X3f/XUf+gLQBYoAqap/yCL3/rg//oJq6fxo ifws0NWgVIje
xyiGeIYyc7ZBnhCByeTxgEgnjOSDjiqcXFzvZrr+n+RtSk78u6Od8lBY2MUM V1e3nyi5W4ku
VikAQlvvYXkjABGOeRivPcqajFQV5db81ttd9NTp967b0XTY2r66ju1090yC Lkq6N95G8p+D
/nngjIIr14VI1Kbcf62OGcXGSTM2+RX1CFXtvtIyp8kBSXISUgDcQM/UgVvQ +Exq7kFysMll
dKfClxZ/uZCJ5Ft9qEKSD8shPX0FbWt9pGSbb2f9fM3K847TnbUXrxqwkbDI r8dST1P+rP8A
nuapwj/X/DkjE0e2v9z3CymeZnSQrM6gqDtOQCAeFUdOcDNYTpwc7uKurdF0 vb7ru3qyk2jp
a1AguLOC62+chbGRwxGQeqnHVTgZU8HAyKNhE9AzD1n/AJE7Wv8Ar3uv/Z67 MB/vdL/FH80Y
1/4UvR/kYXwJ/wCRN1P/ALCkn/ouOvVzr/efl+rMMJ/CR03hv/kV9I/684f/ AEAV5GM/3mp/
if5m9D+FH0X5GnXKbBQBXuP9faf9dT/6A1AFigAoAKACgAoAKACgAoAKACgA oAKACgBCAQQR
kHqDQAiIsaBVGAPfNAh1AwoAYkSRliq4LHJp3EPpDEIBBBGQeoNAFeGyjgl3 xu4/2c8VTk3u
K1iaZS8EiqMkqQPyqRj6AKwtDHcvcW1xJbPIoV/LVMNgk5OVPPJrRVGlYhxV 7jjBNJLE817N
MIm3KrKgGcEdlB6E0ObatYajYnrMoqTaXp9zK0s9hbSyN1d4lYn8SKzdKnJ3 cV9xSqTSsmR6
Zpn2C3iWSXz5YoxEr7doVQAMAZOM4BPqfYADOhQVFd2XUqOb8i/XQZBQBXv/ APkHXP8A1yb+
RoAE/wCQjN/1yT+b0AWKACgAoAKACgAoAKACgAoAKACgAoAKAM+T/l5/6+ov /adAGhQAUAFA
BQAUAFABQAUAFABQAUAFABQBXvf9Qv8A11j/APQxQAW/+vu/+uo/9AWgCxQB BewtPYXEKY3S
Rsoz6kYqou0kyZK6aLb6tYyxNFPDOVdSrxtauwIPUHCkGtnFNWdiVK2pj3dp orvbyWEH2CWG
TcZIdNfcVKspA+Uf3s85GQODXJVwdOaSjZeljaOIkr81395cd7aVbK3sYpUi t5DIxeNk/hYd
WGSSWyTz3JroUY04csTJyc5XYs9qs0sUqu0U0TZWRAu4cEY5B45NTGbjsNxT EmgubiCSGXUb
ho5FKsNsYyCMH+Cq9q10FylisizJj0m4iRUW6hwqhRm2B6fjV8wrFuyszaIQ 0gkYk8hdoGST
wPx/QVD1dwLdAwoAKAMPWf8AkTta/wCve6/9nrswH+90v8UfzRjX/hS9H+Rh fAn/AJE3U/8A
sKSf+i469XOv95+X6swwn8JF/T5bhNK8PJb6KuqH+zPMeN2CqFURZ2kggyHd 8qnaDhssMc+T
i1/tVT1f5m1D+FH0X5Fi713QL21tE0ObQUup7lbeU3ioGtWZXIV4SyOXLJs2 ZDAknB2kVjaN
r2NRfCWq2usWt/c2n2VQt15ciWkiyRK4ijzsdeGU9QR2PIByBlazGjZuP9fa f9dT/wCgNQM0
Liy0y1tpbiSwt9kSF2xCucAZPauhRTdiG7K5QkS0t/NuZtAKQqmWJSE7QMkn Af8AkM8d+MNQ
TejRPM10LWoQaZpthNeSaZFJHENzLHApbGeT9B1PsKSjd2RZVaKFcSjSbZlP PkiFN4H+9uxn
8Mds964vrC5ttP68/wBDb2ehWg/su+8TQw29tBtgguUnh8tco4kjCll7ZAYq T1BJFei6fLC7
Xb9TjU7zsvP9Cvqt9oml3pt5rRpJiN/l2thJcMi5IBYRo20HBxnGdpx0OOVr U3FjutEl+z7E
hP2i5ktIv3H3pY9+9enGPKfk8fLx1GUBRufEPhu1kije3lcyySQxmHTJpQzo zq6gohG4GN+O
uFz05oswOittPsmnUGzgI54MY9KcdwZf/svT/wDnwtv+/S/4VrZEh/Zen/8A Phbf9+l/wosg
D+y9P/58Lb/v0v8AhRZAH9l6f/z4W3/fpf8ACiyAP7L0/wD58Lb/AL9L/hRZ AH9l6f8A8+Ft
/wB+l/wosgD+y9P/AOfC2/79L/hRZAH9l6f/AM+Ft/36X/CiyAP7L0//AJ8L b/v0v+FFkAf2
Xp//AD4W3/fpf8KLIA/svT/+fC2/79L/AIUWQB/Zen/8+Ft/36X/AAosgD+y 9P8A+fC2/wC/
S/4UWQB/Zen/APPhbf8Afpf8KLIA/svT/wDnwtv+/S/4UWQB/Zen/wDPhbf9 +l/wosgD+y9P
/wCfC2/79L/hRZAH9l6f/wA+Ft/36X/CiyAP7L0//nwtv+/S/wCFFkBXvLCw hiLrY24wP+eS
+oHp71cIKUkhSbSMC4utPhvUsyLVbiRS6R+THkgd+n+cH0NdcaEH0MXOS6k7 +UNMmKwRI5il
G5I1UkAL6D3rlxNOMH7ppTk3uX7eKObVZY5Y1kQxJlWGQeX7VzR3NWLqyWWn RW5i0m0meaXy
grKqAfKzZztP92lWqeySaVy6UOdu72MIawI0v5ZfD+nmO2kwArgEDYp/uc8k 88dh7nmeJlFX
cV9//AN1h4tpKX4f8E6G/XSdPezjk06F5bycW8KJCuWbaWJ5wAAiOx56KQMk gHvsjjCRdJi1
m20ttOh8+4gluEYQrtCxtGrA985lXHHY/iWQEd62l2eo2VgmkLc3V1uYJFFG NkalQ8jFiBtU
umQMsd3AODgsgND+y9P/AOfC2/79L/hRZAZeo3egaVqVnY3llCj3alo3FuCu fNiiCnHOS86A
cY65IxRZAan9l6f/AM+Ft/36X/CiyAP7L0//AJ8Lb/v0v+FFkBT1NdJ0q1S4 n06FkeeG3ASF
Sd0sqxqee2XGfbPWiyAuf2Xp/wDz4W3/AH6X/CiyAP7L0/8A58Lb/v0v+FFk BT1FdJ0xLeS4
06Hypp47cusKkIzttQkdcFyq8A8sCcAEgsgM+T/l5/6+ov8A2nWBZZ1trDSd AuNTksLaR40B
+eMcsSAMn6kZrV2UbmNSfJFyONvLfSrJ4f7T1t4NQmhE42RgRLnoNo47eh96 xem7OVyt8U3c
6nwnNY67oouJbK0aaKQwyOkKhXIAOQO2QRWsGpK50UajnG7LGsxaVpdrPe3N tBFbW0LTSsIQ
dqqCScAZPA7UpLXQ3Rkyar4fjsLK9WETRX0Ymt1gsnlkdCAd3lopYL8y5JGA WAOCRU2An02f
S9Ua7EFiE+yyLE/m2+wktEkg+UjI+WRQQQCCCMUbASaidO0y2S4mso2R54oA EiUndJIsannt
lxn2zSANLOnatpFlqVvZRrDdwJOivEoYKyhgDjPODRsBv/2Xp/8Az4W3/fpf 8K3siQ/svT/+
fC2/79L/AIUWQB/Zen/8+Ft/36X/AAosgD+y9P8A+fC2/wC/S/4UWQB/Zen/ APPhbf8Afpf8
KLICjqlrb20Ef2eCOLdLHnYgXPzr6VE1YaG2FvDcXV4k8KSqJAQHUEZ2L60o bjZof2Xp/wDz
4W3/AH6X/CtLIkP7L0//AJ8Lb/v0v+FFkBg+IdMuHurODSIrOBmSR5N8ScgF QOqN6n0rWk6S
lyzX9f0zKqqlrwZSi0PW1/1psm+giH/tCtmqHRf195inW6s19PsIH0Xfc2ts 1wrujMIl7SEd
lHYegrjm4Su4LT/LQ64qSS5ipqD6Tpdus11bxgM2xEjtzI7tgnCooLMcAnAB wAT0BrEog0+9
0nU7yW2gsGR4oI5z59oYTtdpFA2uAwOYm6gcEEZzTtYCfVDp2k6Re6lPZRtD aQPO6pEpYqql
iBnHOBSAqPqOkR+H9Q1o2A+zWP2nzFES7z5DOr4GcclDjkds4p26AQDX/D+0 /wChStIsksbR
wWDzuvlyvGWYRK21S0bbScZwfQgFgNLTjp2p2z3ENlGqJPLAQ8Sg7o5GjY8d soce2KWwFTX9
R0jw5ZLdXlgHjbzMCKJSfkhklPUj+GJgPcj6hpXAXSNT0rVb+6trWx8uWzJL M8SgcTSxcEH+
9A5+hX3ALWAXWf8AkTta/wCve6/9nrrwH+90v8UfzRlX/hS9H+RhfAn/AJE3 U/8AsKSf+i46
9XOv95+X6swwn8JG/wCHLmOy0nQp5VlMf9nKmY4mkwSsZHCg+hrycW0sVUv3 f5m1D+FH0X5G
NZ+HrWPTW0y+1a6ns49Lm0q1EWlTRvHDKEBLsdwZgI0wQFHXjnjnUkupqa2g 2d0L291C+u/t
Ny6RWwdbRrZDHHuZSEdmbO6VwTnHAwBjJjyQzVuP9faf9dT/AOgNQM1dSge5 0u7giAMksLoo
PHJBArqi7NMzkrpo46fQ72e8uJI7TUBPKGJWTVpHjXeCM+UZSoHXA24GOOlK KtJO6/r5Cbum
rGz4xi2eF7tkaUFmjUgTMuQ0gBHXoQxHpjHoKzm2o3R34GMZV0pK618+jORn ZrfVo4o5NTu4
GhZiILmWYhgwB4j5AXlc9D17inhKFJ1bNK1utv1N8fKf1XmirPmWytpZ/nv5 bHTeHbG7nuY7
+R7+2toshIbieUtKcEfMjn5VHbIySM8ADd21/ZwXJC3y/r+vy8SlzvWbM3xZ Z3VxfSHTNMvh
qZiKwahBcrFDG+W2ecvmAyKrHdtKOMM2AckHzup0mdqXhvVRq99eWLuYbdhf 2dujhFknLRl4
hz8hIhkBfHP2yT0bcXA0k0G4soPCttE32n+zrkyXU5AUuTbTK0pBOSzSOCep yxJzyaVwOqtf
+PhPx/lTjuDNGtiQoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgChq xIsnIGcAH/x5
a1o/xERP4Tz+bwvaSw3Dy3U0l/LL5q3bH50I+6BjHAHYY/DAx6CRzM31Vl0p gzM+IZhuYDLc
JzxxXFi/8v1N6Jr2X/IZk/65J/N64Y7m7OW11Td67qyT3E+23ZGt4xd7FLeS DgL2PJbPsR3q
JpSbue3h7Ro02ktb30v1/pfj0OesLMXOj34jtdTnu5QuCqysu4xKeccc5B57 EdsVxz5mmkvw
M6to1nqkrvt3PQNRiXTfE+gXrlvsawTadvZixR5TE0Zdm7EwlMk5Lug53ceq tDxjhn8GarJF
bww6E9leQ6cbfUtQjNtu1N/PtmkIJYmQyLFN/rlAO/D4DNQBseHfBf2fWdLu LvSXNjardSQR
3wtma1lZrbYVjhURxnMUrDZnqWJDOQADLi8K+IP7Ye8/syaKRtl1fBBaRQXV xHd2837ny8O+
QkwRp+RuGSu5jQBJqHhfWNd1m/1C40F47SaczNaXUkLNKitpx2EK7KS4tZgA TjpuKg0Abni6
1tZLLwjbSeHPtdqL8AaT5cBwBZz4TazCP5cD+LHy8Z4oA5/XvCviC40GKCLT JmmgiuJNMFoL
QyWUjyu0aO83+rVE8hV8g5Uo+DgIaANS78M3k6XsC6M6atLqMc/9tx/ZyzQf bklVQzEuTHEF
G1k2/usDIC5AM/xN4Z1270sWdvozmewgkWwuLD7KWNy2WM7PcEyIGPltlG8w OJSWbCOwBT1X
Tzd+JTo9hbQr4qF1fStqsc0Rkjilt7jyN7KxnRVEsC5ZAoKqFJ+TIBoR6A+l eEtf06KzvbNt
biXT7S1ufsiEzOrqXEVqoQKFYMz5ZysTZAEYyAdTJ/y8/wDX1F/7TrnLNfUt Mi1jQ5tPmJVJ
4wu4dVPUH8CAa2teNjKpBTi4s43+yPE0UsEb6PYXdxbJ5MN8zDhOgyCc8A91 P41nyyOTkqrS
ydup1fhvRF0DR0s/MEkpYySuBgFj6e3AH4VpGPKrHRSp+zjYy/G1hqWpxafZ 6a8MWbyGWaaW
PzBEsRMqnbuUnMkcanB6MfqJlozZHMw6Pf2VpNa6npN5qciXs8tvd6VMtm+y UrK4JM6sFMju
Nu4g+WpI4BM3GR2nhXUkE+o3tpbTeIDqFi/2+MIHaNUtlnKtgFVO2cbeMgkY +bBLgZuleDdV
s44t1veG7SS0N3LLJbLHdOlzC7yr5ah5MBJCGmIcBuhLth3A7rwvZ3GneEtF sbuPy7m2soYp
UyDtZUAIyODyO1S9wOtrckKACgAoAKAMvW/9RD/11T/0NazmNDdK/wCP29/3 /wD2RKUNxs1q
1JIhbIuMNJxjrKx6Y9/9kfr6nIBl301tYavZGe4WKMwyjdNLxnMYxlj6D+Zq NIzTfZ/oDTat
/XUk/tnSv+gnaf8Af9f8av2ke5PI+wmnSJLoryRsHRp5irKcgjzW5FZL4H6v 8zR7nnul6DNY
2F0tx4bvJ42kjMUiNbwak7gPullmjlVW+9tDBg53uGByWZXAjm8J6leW2sXd 3p6T6mNLEelT
TMjz28gkuWjUSEkrIqvAC+eWGdzYzRcCpqPg3VZ5tekS3vJb65jvQs/mWyRT JIkgii37fOfA
eMbXIQFMg4RAXcDr9B0e+swZJ725gQXd3IbNREYpFe4ldGJ2lslXU4DDoMjr mWwIPE9ndXFw
TpmmXw1MwbYNQguVihjfJ2ecvmAyKrHdtKOMM2AckEQGNceD79bB5NKtYbDW bm91EzXsbLHI
YpRc+UXdfmK7mgOOSCFOMrw7gZN14K1JtEuYNN028hWTzQLe5e0iwxs7mPcE gAjGWljXcSWO
OQAgJdwPV6gZh6z/AMidrX/Xvdf+z12YD/e6X+KP5oxr/wAKXo/yML4E/wDI m6n/ANhST/0X
HXq51/vPy/VmGE/hI6PQJY4fCekySuqILOHLMcAfIK8fGtLEVG/5n+Z0YdN0 oJdl+Rqqyuiu
jBlYZBByCK5k77GtraC0AV7j/X2n/XU/+gNQBv10EEalvtLgk7QikemcnPb6 dz9B3AC4t4Lq
BoLiGOaJvvJIoZT35BpNX3KjOUHzRdmZQTSdNuHFjYJDcKVV2trM8DIJUsqH tg4+nTrTVO2q
KniKk1yzk397NO2uortGaIt8jbWDoUIOAeQQD0I/Om00ZJ3KGpXttYTwxtaT zyTBmAixwFxk
nLD+8K5qtSNNq6vc2p03NN3tYzbLxFa3SxGTS7qES3BgVtysud+0E/Nn0zxx nv1rNV4XScX+
H+Zo6DV7Nf18jdnWztbeW4uGSGCJS8kkj7VRQMkkk4AA711cqOe5C95YWllb 38heGGZokQyR
urbpWVEBUjKks6jBAxnnGDQopCuWL6+t9Os5Lq6k8uFMZIBYkk4CgDlmJIAU AkkgAEmqAkgm
W4t4p0DhJFDqJEZGAIzyrAFT7EAigCO8vrfT4FmupPLjaWOEHBPzyOEQcerM B+PNAEkE8N1b
xXFvKk0Eqh45I2DK6kZBBHBBHegCSgAoAr2F9b6np1tf2cnmWtzEs0T4I3Iw BBweRwR1oAsU
ARzzLbW8s7hykal2EaM7EAZ4VQST7AEmgAgnhureK4t5UmglUPHJGwZXUjII I4II70ASUAFA
BQAUAFABQAUAFABQBWu0EmxTkdeVYgj8RyKLtPQLXKy6fCest1/4FS//ABVU qkvL7kTyL+my
DVbaO30y4CbyTE+S7s56epJNZ1JOW5UUkFl/yGZP+uSfzes47lMTWbfSIGS5 u9HhvJ7iQRgi
BGdjtJ5LY7L60VZxpq7Vzoo1K1uWE2kvNlKHxZbww3K/2Tcw21mwjGwR4ChQ em7jqRgZ4A+g
x+tRitYv8P8AMboSk/iTb9f8jannlSZlVsAe1byk0zlSK8eomV5UjuEd4W2S KpBKNgNg+hww
OPQj1pczHYk+1Tf3/wBBRzMLFe41ZbWa1hmn2yXUhihG3O5gjPjgcfKjHn0o 5mFi9azSSSkM
2RjPSqi23qJlutBBQAUAFABQAUAcxJ/y8/8AX1F/7TrnLNjUNRi0jRZL6YFk hjB2j+InAA/E
kCtr2jcynJQi5M5iTUNaXy5bjX7KzuJY/OS0aNdgXsCxGf1H4VlzS7nNzT3c kvI6Hw7rI1zS
luigjmVjHKinIDj0Ppgg/jWsZcyub0p88bl2c2qywrO6LJM3lxBnwXbBbAHc 4Vjj0BPam0ma
DYVs7lC8DJKgZkLI+4BlYqw4PUEEEdiCKXKh3JPssP8Ac/U0cqC4fZYf7n6m jlQXD7LD/c/U
0cqC5NVCCgAoAKACgDL1v/UQ/wDXVP8A0NazmNDdK/4/b3/f/wDZEpQ3GzWr UkKACgAoARlV
1KsMik1cCL7LD/c/U0uVDuH2WH+5+po5UFw+yw/3P1NHKguH2WH+5+po5UFw +yw/3P1NHKgu
H2WH+5+po5UFw+yw/wBz9TRyoLjZLaJYnITBAJ6mk4pILnKaz/yJ2tf9e91/ 7PW+A/3ul/ij
+aM6/wDCl6P8jC+BP/Im6n/2FJP/AEXHXq51/vPy/VmGE/hI04XuLbwHpl/a yKktjYpcAOuQ
+ISNvUY69a8bG0fb4qdO9ryf5m9CqqVBSav7v6DoszW891DrMpg81pJbnT44 vLztXIIbeTjG
SR/eOenHFTqRwbdOau/NHRUh9YUZQdu1nub1rE0FusT3Mlw65zJJt3HnvtAH t0rondvmtYyh
ZK17jbj/AF9p/wBdT/6A1QWb9dBBEo/0uQ46oozj3bvj+p+g7gEtAHBeMNO1 O/kkt7KfULbF
9b3ObeBXSRUaFskmNvmXy22gYGcbsiqabSsSmk3c6Hw9DdfZJnuJLkO0oO6Z FV5MIg3MNowT
tPQAcnA6YT2SBbs4/VrjU5or++fULotYTTwxAQJjbvAzkAZHyjJ7Hb61xzjz avofR0KVFOFP
lXvJN6vt+fb5lDTWikis7eHXZXuHv1wimMkAzfeA2ntzzx7Y4rl5k5JLuvzO JxaTbXR/kd34
148K3Ej/APHrDLBLdg8g2yTI04I/iXyg+V53DIwc4r1Tyzm/EcFxc686XUWr S3A1awewWBbh
rYWyyQM5fy/3WQwnOZPmGAemygDDtdL8RX2nrBqd1qdzNLLZf2hCtrcwiOYX cBZkleUj5QJT
ut1VMAsSAI6ANzXDq9p4q09LE6hCltPaW8SLFeXK3NuXQSSPIH8lSFaRT5qs /wAm7cMoQAZ8
kus31v4X06S31aS4sILVdS822m2GdLyyJYuw2yEBJjvUsMBjnBzQBoWMMmhf BPUoITqFrqFh
pMiTGd5t0VwlvhvKZz9wEfKYzs4+WgCO4e8FnqEWlJrI0SX7Ovn3a3zzwSZl aRlQsty6nFuu
EYKN5PIEgIAeHJdRluNPPiJtZeFfksGihu4QzrczLmZVywUxC2P+kE5GTkne SAU9Ni1zTvAu
m6de2+oJNPZ2qm4hjuGW0hSMfL5MLLIJA+EYBgzeZuyURo4wDP1C81eLwZqN zrVxrqGDTrj+
zJraO8gIlSW4AeUIdyjyxbEGcnjJyTvJAOk0aHX/APhOZJby+vf+Pq4823+x z+T9my/k/vWk
8jp5J/dJ5meG/wCWhoA6DwVz4VtpE/49ZZZ5bQDgC2eZ2gAH8K+UUwvG0YGB jFAHQUAFABQA
UAFABQAUAFABQBBcfeT8aTGCdKSEUtc/5Bs3/XJ/5VMhoisv+QzJ/wBck/m9 THcbKPjPCQ6Z
NJfSWsK3WHZduBmN8Ekj2x1x8x9sZYrRRb7/AKM6MNduSS6fqjhZJ7b7JrAX XXkd3Plx7kPm
fIPbnnjj0/PinKLj8jsjGSktDsPE6avZNa3mlStdXMSm2aObJSQyBVWVlQDl ZAhYjAVDLgZx
XpvezPLOQ1C21eykuLRZ9Xv4oLkR29szXKNeAW1uoY3UX+q+fzCS3yMzNnBG 5UBfk1DWbWaz
s4bTUbrULfUr2d4ykixSwlLloUM5Hl7TuhAGTtOBgFcA0AzdCi1VvEunxNJf Xen293HMss9l
dQhGa3u1fm4Z3x/qh97aCwwASct7Aeq2X+uP+7RDcGXq1JCgAoAKACgAoA5i T/l5/wCvqL/2
nXOWaWtaUNb8OXGnbwhmjG1j0DDBGfbIFa2vGxjVhzxcTg7i0uZ7i2/tLwlc XWo2sQt1ZSTC
4AwpJxg9fUe+Kys+qOJptrmhqvuOz8I6G+gaEttNt8+RzLIE6KTgYH0AFawj yqx1Uafs4WZR
8cabqWpnw/FpjOkseomR3UsoCfZpwyl1GYw2dm8cqXBHIAqzY5/X01m4vbQa UdQ0eyjs0jsL
aHT5nMdwruroVikSJQuIgDNuiI5U7dxIB0GnJqUniy4sDevJp+mzyXRkErF3 aZcpA56EJvlb
ZxtX7KRnmgDrKACgAoAKACgAoAKAMvW/9RD/ANdU/wDQ1rOY0N0r/j9vf9// ANkSlDcbNatS
QoAKACgAoAKACgAoAKACgAoAKAGS/wCpf/dNJ7AcfrP/ACJ2tf8AXvdf+z1r gP8Ae6X+KP5o
iv8Awpej/IwvgT/yJup/9hST/wBFx16udf7z8v1ZhhP4SOm8N/8AIr6R/wBe cP8A6AK8jGf7
zU/xP8zeh/Cj6L8iS40ayupJZJUlzN/rAs7qrcAcgEDoAK4JUYSfM1qdUas4 qyZPb2NpaSzS
21rDDJO26V44wpkPPLEdTyevrW7lKSSb2MVGMXdILj/X2n/XU/8AoDVJRv10 EECD/TpTkf6t
OMDPVu/X8+PTvS6gT0wKN7qFlARFNdWySBlJSR1BAyOcEj65/n0p8reyFzJb stQXEFzH5lvN
HKmcbkYMPzFDTW4Jp7HOapovhm3uC19BMJLou5CPM27JBY4U8ckVzVHSg/e6 +p6NLFYpq0Ht
bovluW9P8SaPKqpbiSASTsiqbdlDOXIzkDHzNzzzzzg5oWIp3t+jOaVCotX+ aNyugwI4IIbW
3it7eJIYIlCRxxqFVFAwAAOAAO1AElAEc88Nrby3FxKkMESl5JJGCqigZJJP AAHegCSgCOeC
G6t5be4iSaCVSkkcihldSMEEHggjtQBJQAUAFAFO80nTdQuLW4vdPtbme0bf byTQq7QtkHKE
jKnIHI9BQBYnghureW3uIkmglUpJHIoZXUjBBB4II7UASUAFABQAUAFABQAU AFABQAUAZlpr
OjatHFLY6tZ3UbymFGguEcNIF3lAQTltoLY64GaVgLkzwWdtLcXEywwRIXkk kYKqKBkkk8AA
d6LAZcmteHtUvX0VNcsZL8l4jbRXUZmBAO4bM5yMHIxxg0nG4bF6GC0j1KQJ OGuVjQvFvBKq
SwUkdQCQ3PfafQ0KKQ7ktvf2d3LJFbXcM0kX31jkDFPmZeQOnzI6/VWHY1Qi VIo42kZI1VpG
3OVGCxwBk+pwAPoBQAyS1SRyxLAn0qXFMdxn2KP+8350uRBcPsUf95vzo5EF w+xR/wB5vzo5
EFySK3SJiyk5xjmmopBclqhBQAUAFABQAUAcxJ/y8/8AX1F/7TrnLNy5vYNN 0t7y4bbFDHub
HU+w9z0ra9o3M5SUU2znl1nxJMqXEVlYxxyL5iW0rnzWX65/p+dZ88uxz89V 6pI3dG1WHWdN
S7hVkJJV426ow6g1pGSkro2hNTjdF+qLCgCOOCGF5niiRHmbfIyqAXbaFyfU 4VRn0AHagCSg
AoAKACgAoAKACgDL1v8A1EP/AF1T/wBDWs5jQ3Sv+P29/wB//wBkSlDcbNat SQoAKACgAoAK
ACgAoAKACgAoAKAGS/6l/wDdNJ7AcfrP/Ina1/173X/s9a4D/e6X+KP5oiv/ AApej/IwvgT/
AMibqf8A2FJP/RcdernX+8/L9WYYT+EjpvDf/Ir6R/15w/8AoAryMZ/vNT/E /wAzeh/Cj6L8
jTrlNgoAr3H+vtP+up/9AagDfroIIlP+lyLnoinGfdu2f6D6nsAS0AcB4vvt Vt5Z4NJ1GCzm
N/byyCSIszIDCSQRImFAV9y87hlRjNU02lZEJpN3Z0Xhye4u7a4uHnikZ5hv dYiFchIwSo3H
A4bjJxxyccjvZX/rUcbXdjP8SfbRrWmhLyCIG2l5aI8sCm7+LocjA7YPJzxw Yle9H5/odtC3
I/Vfqc1YjURZWg/tC2LHUVCqYScEzcEjcMjPOOOOM96wfxK3dfmb6a+j/I9C 1v8AtEaPPJpP
zX0W2WOP5R521gxiy3C7wCm7+HdntXqHmnB3/iDU5JoNWh1DT7OC+s7qeymv ikSQW/nWaIfO
KEqXUtIAynDSIrK2wUAR3HjibT/Dmr3c+rzW27RjNpcmqC3SWe4D3AJTYPLl 4WAjbkFWQ/x5
IBn+N/FV60mu6el9CLW5tb61fTprmP7REEtZm8wQiIOqs0QIZpGBWQHaNw2g HsFABQAUAFAB
QAUAFABQAUAFABQAUAFABQAUAFAGZ4jhsrnwxq0GoyyRWMlnKlxJEMusZQhi owckDOOD9DSb
SV2VGMpyUYq7ZyUdzceIYNRmsZtM1e/0/wCzXVtqOmIIlndHdja7y77W2hlJ 38LdcrgncySO
K9vvENx9gaJzp+vTx6hA7y7lFjGVDrsP8Egjhypx/wAfrAqfLfIB0ln/AMlD 1n/sF2P/AKNu
qAM+fXdH0T4h6p/auq2Vh52l2fl/arhIt+JbrONxGcZH5igDj5PEV1Druv3x 8QfZtWitXSys
v3I/tBor2+SKHYyl2+6i4jIY7uuSDQBsX/iLUodF3Prf2OafVL5Vu7m4gtYI o4Z3iWDzGhkG
4gBgCpY7XO7C4IBHoni/V7mxg8QahduLA3lolzBBbh1iSWwRwEVVMjFrieMY yx6dBuyAd5oX
9o/8I9pn9r/8hP7LF9r+7/rdo3/d4+9npx6UAaFABQAUAFABQAUAFABQAUAc xJ/y8/8AX1F/
7TrnLL3iHTJdY8K3VjA2JpI1Kc4yykMBntkjFatXjYwrQc4OKPPb250u/urR 9Ui1KK/t4Bbv
ZIMeYwBAIIORnPoaxdnujhk4ya5r3XQ6TQpT4L8MWx1K3uGlv7s4ijAZo8oT zkjosZJAye2D
VcyowvI3pv2EFzdWR+KzZeLofDUenXygnVmMU4XJt50tZ3RmQ4OVcK2xsZxg jBrWMlJXR0xn
GavFmVZ/2joHiHWdeuv3Nw9rY6jq8PytiItdIybhkfuYwhygy/kdMuaooBpn iK78V3GpRzfZ
vEI0u2R/ljf7PFcT3W5OuxvJ/dNnq/2fHHmGgDHstR1Tw5aJo2iXdlplhZy3 Yso7q42/anF7
cL5QUxSPPtCRjZGUf94OSWXABuahrPiS10a41Cy1S6uru8vNTsre0+zxMsRh W6MRjCoGZ826
DDFgctxkjAB1GieJLbXPFWqwabqlrf6fbWdq6m2kSRUld5w+WXvhI+CePx5A OkoAKACgAoAy
9b/1EP8A11T/ANDWs5jQ3Sv+P29/3/8A2RKUNxs1q1JCgAoAKACgAoAKACgA oAKACgAoAZL/
AKl/900nsBx+s/8AIna1/wBe91/7PWuA/wB7pf4o/miK/wDCl6P8jC+BP/Im 6n/2FJP/AEXH
Xq51/vPy/VmGE/hI6bw3/wAivpH/AF5w/wDoAryMZ/vNT/E/zN6H8KPovyNO uU2CgCvcf6+0
/wCup/8AQGoA366CCJd32uTP3Ni469ctn29OnPr2oAloAjm4jHBPzr0JH8Q9 P/1evFAElAFa
70+yvwgvLOC5CfdE0Yfb9M1MoRl8SuVGco/C7Gfb6R4e0++igh0+zjuiTLH+ 5BYEknIbHHfA
zwBxwK574eFRU9OZ6o15qsouV3Y2a6jAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
oAqXt+tl5aLDJc3EmfLgh272A6n5iAAMjJJA5A6kAzKXL6m9Gg6t22oxW7d7 Ltsm7vsk3u9k
2q0WmSXUyXOr+RcSxsHhhRP3cB65GfvOOm/A4HAXLZlQbd5/8N/Xf8jWWIjT i4Ye6T3fV/ds
v7uvm5WVtStDjCgAoAKACgAoAp3ml2l/cWs10jyG2bfGnmsIy2QQWQHa5BAI LA7SMjB5oAuU
AFABQAUAFABQAUAFABQAUAcxJ/y8/wDX1F/7TrnLOge4itLE3E7iOKKPc7Ho ABzW60Rm2lqz
nx4p1CWP7VbeH7iSx+8JDIFcr67cf1/Ks/adUtDD2snqo6F9oNJ8W6Xazyxm e2V/NQFmQq4B
UggEdiwIPFU4xqLUu0K0U3salvbw2kCQW8KQwxjCRxqFVR6ADpVpW0RokkrI jvLG31CBYbqP
zI1ljmAyRh43DoePRlB/DmgZYoAKACgAoAKACgAoAKAMvW/9RD/11T/0Nazm NDdK/wCP29/3
/wD2RKUNxs1q1JCgAoAKACgAoAKACgAoAKACgAoAZL/qX/3TSewHH6z/AMid rX/Xvdf+z1rg
P97pf4o/miK/8KXo/wAjC+BP/Im6n/2FJP8A0XHXq51/vPy/VmGE/hI6bw3/ AMivpH/XnD/6
AK8jGf7zU/xP8zeh/Cj6L8jTrlNgoAr3H+vtP+up/wDQGoA366CCJR/pchx1 RRnHu3fH9T9B
3AJaAOA8X3V7ayztp2m2N3Ob+3R2uW+dYyYcgDy3+UgvuPG0ZYZNU5uKSuQo pt3R0XhyWSS2
uGS2t4h5w3RxOdkZ2R5C/KMjljnAz6DPA3dJ/wBbjirNo4XxrNq8fieUWGq6 tEhijMsVtLmO
OTHKrnHGNp+rHp0rN46NL3LLTujnrYTFVJc1JOz87fqiHStX1FBbveedJNZY KSzqfOmBcsdz
AkYB2qOn38V4eZ1lOpDExSvF9FbT/L/M9XLaOIjCVGurLpqn3v1f9I9XdYb+ xZRIxguI8b4p
ChKsOqspBBweCCCO1e7FqSutjlaadmeOreX8U2rpHPrMrWUUiWl3/aL+RZP9 vvI0luA0mZEU
JHuJWTCRncMDliOwsLK+1Hx7rU0vnPY2l/GiuNYuYvLxawuFFuo8t1LNk5Iz uOQccgFjxlb3
UHm6xM00+kWVqZZoINSnspIgm5pHXyv9czLgBXKgFOD87EAEkniLWhf3GmW2 lpc6haNcTSR8
xxywBSbcI5Pyu5eNdzDbmK4x9wUAZemaxreqeLdMtjqkKTQRXa31u2nSwhdr Wh8soZiC4Ehx
KGZcPwCDkgFO18c+KLrTra6fTrWzTVFtpLJ7hEIjWW4hj+6k5eYBZ87sRYKj I+fAAOg8P+It
SvdXjs74WrpOt4EMMbRlGtZ1gcnLNkOW3AcbANpL/eoArw6ncxeEjcvI80h8 QNb5eVwQh1Qx
gZBBwFOAM4wACCMggHP6L4i17w/4M8LWqjT7173TrRrRTG8AjXzbWEo7bn3E i4HzgDBTO1s4
AB0GpeJ9X0/WbaGKFL2zgntrHUJY7YRqk8rIMhmm3AYljbaI3HON+clQCOw8 XaxD4Z0XX9Ys
4ZLXULXzHh0+N3kSRoleJRuODvIkXHXfJEg3cswBY8QWH9pjwbZ+ILSyu5JL /wD0qER74GkF
ncE4V+q7hkZ54FAFe31nW5/FWqaFa3FlFcC6mlW5mgllQRJDakJ5fmjDf6QM srBfkJ2ZckAG
H8LNSmhgg0/akME62r+dKCfOYaba/uo8HAcD5zu/hU7Q3zmMA7DwldtD4bZt R1F53TUbu3+0
XTqGci7kjQE8DJ+VQAAOgAHAoAy7bVNef4nW9tfWN7b2MlreLFGJITAUSSHZ McPvZjnuo2+Y
qheHcgFzXFXWri2TR9UunvpYFltpLa6Zbe1Qk4uXCECUHjaj7g5TAAXzGABr f2k+q/utIbNu
3DagpVox6iPk727ZxtBzkkqUOXPz6Q+//L+rfkd31dYf3sRv/Jqn8+y+fM9L JJqS5qwk1aHw
1NcabaTX+o3GqXVtc3cQgFwIo7iZFf5yiMwVVRQeF3A7SF2m4wUdjCtiJ1rJ 7LZdF6L8+r3b
b1E8O6ldt4e8A3jq8d3qaxW95LMFeW4RbSeRSz5JILjeOc/Mc4JYVRgdtM7I V2nGc0mAqOxH
JoAq6rcS21jLJC+11jYg4B5AqZNoaI7W7nk1N4WfMYjUgYHU7v8AAUoybYNG nWggoAKACgAo
AKACgAoAKACgAoAKACgDmJP+Xn/r6i/9p1zllrxRZXOo+ELu2tATOY1ZAOp2 kNge5xitWrws
c9eLlBpHEXOpWuovZX//AAkM2nxwWoimgRGEgZQQdvGOT61i2nrc43NSs+a2 h1fgCzurTw4X
ug4a4maZQ4w20gAZ+uM/jWtNWidOGi1DXqS+Poi3gXWrhLi6t57OzmuIZLa5 khZXWNipJQgk
Z7HI9q0Ogx7y+1DSPFlt4e0aZIxOtugn1B57wqGW9kbhpQScwKM5zg4OQqgA Eb+NNYax1W5i
SyT+wrWW4vFaJ2+1+XNcRER/OPJz9lY5PmY8wDnblgDY0i0Gt3VzqOoXN6t7 aX80It4ryWGO
JI5D5QaJGAbcmyQ7wdwk/uFQADDfxlrw07SbhTp4fXYILm0Bt3ItFe4toyr/ ALz96cXQ5Hl8
p0+bgAsWuq69eePLXS2vrVHsFuo7tlt38q5UCykBWPzPkcCcqGLPjDHHzYAB c8PeKdR1TxCt
tPa50y/tZL3T7ryVi3xK0YHAlctlZlOWWMjH3eSFAOwoAKACgDL1v/UQ/wDX VP8A0NazmNDd
K/4/b3/f/wDZEpQ3GzWrUkKACgAoAKACgAoAKACgAoAKACgBkv8AqX/3TSew HH6z/wAidrX/
AF73X/s9a4D/AHul/ij+aIr/AMKXo/yML4E/8ibqf/YUk/8ARcdernX+8/L9 WYYT+EjpvDf/
ACK+kf8AXnD/AOgCvIxn+81P8T/M3ofwo+i/I065TYKAK9x/r7T/AK6n/wBA agDfroIMrUb2
S0uBHbohu7kxww7sEZJckkDBwqqzYJGduAQTWc5OOi3Z04elGo25/DFXf5Jf NtK9na92rIT+
ydQb5n8Q3queWEUUAQH/AGQ0bED0ySfc9aXJL+Z/h/ka/WaK0VGNvNyv87SS v6JLyRSu/DSy
N51zq11K5Krue3tCeSAOTF71SU1tN/h/kJ4ig96EP/J//kyxB4fntY/Lt9dv okznakNso/IR
UnGT3m/w/wAhrE0VtQj98/8A5My734e2moXkt3c61qrTy4LsskSZwABwEA6A VzzwcJy5pN3+
X+R0wzP2ceWNGFv+3v8A5Ihi+Hum20rxJrmpiSZNpVpoiSoYNxlPVV5HpWbw VHWm3v00KeaN
q/sY6f4v/kjTm8JLdaWNMutXu7mxCqnkTwW0iELjbkNEc4wOvpXTGk4RUYyd l6f5HNLGU5Nt
0I/fP/5MktvDLWW37LrN3BtiSEeXb2q4jTOxOIfuruOB0GTjrVckv5n+H+RP 1ql/z4j98/8A
5Mzx8O9JW8hvA4F1Bs8qYWFnvTYAEw3kZG0KAMdMDHSjkl/M/wAP8g+tUv8A nxH75/8AyZYu
vBVrfajBqF5fS3F9b7fKuJbO0eSPacrtYw5GCSRjvRyS/mf4f5B9apf8+I/f P/5MkbwmHe9e
XWr+U3yiO482O3cSIFwEIMRGzBb5emWY4yxJOSX8z/D/ACD61S/58R++f/yZ Gngq1js7Wzjv
pUtbSUTW8K2doEhkBJDovk4VsknI55NHJL+Z/h/kH1ql/wA+I/fP/wCTCHwV a28tzLDfSxSX
MqzTslnaAyyK25XYiH5mDfMCeQeaOSX8z/D/ACD61S/58R++f/yZYi8MtBKs sWs3cci+ZtZb
e1BHmMGfB8n+JgGPqRk0ckv5n+H+QfWqX/PiP3z/APkynH4D0+G9mvYrlku5 m3yTLZWYd23h
8lvJyTvVWz6gHqKOSX8z/D/IPrVL/nxH75//ACYWXgPT9NSRLC5a1SRkd1gs rNAzI25CcQ8l
TyD2PIo5JfzP8P8AIPrVL/nxH75//Jkl14Ktb7UYNQvL6W4vrfb5VxLZ2jyR 7TldrGHIwSSM
d6OSX8z/AA/yD61S/wCfEfvn/wDJkj+Ew9vaWx1q/W3s2R4YUjt1jQoPk+UR YIXggEYBCkcq
CDkl/M/w/wAg+tUv+fEfvn/8mSXHhqW7ntJp9f1J5LSUzQnbbjY5RkJ4i5+V 2HPr9KOSX8z/
AA/yD61S/wCfEfvn/wDJlO58CWd8Llb2/uLtLmcXMqXNvayqZRGsYYBoiAdi gcf1NHJL+Z/h
/kH1ql/z4j98/wD5MsReEY4Lf7PDqdxHBujfy0tbQLuQKEOPJxlQiYPbauOg o5JfzP8AD/IP
rVL/AJ8R++f/AMmR2fgq10+zNnZX0ttamVZjDDZ2iJ5gIIfaIcbgVUg9flHp RyS/mf4f5B9a
pf8APiP3z/8Aky4dAuGuEuG16/M8asiSGG23KrEFgD5WQCVXI/2R6Uckv5n+ H+QfWqX/AD4j
98//AJMxrz4cabqE0BvLjzo7aOKO2zY2m+EIxIUN5XCdMKAB16g4qXSk9HJ2 +X+RtTx1Kk1K
FCKkr63n8re9o1rrftazVzd/si+/6GPUv+/dt/8AGqrkl/M/w/yMfrVL/nxH 75//ACZT03wj
Ho1u1vpep3FjAzb2jtrW0jUtgDOFhAzgDn2o5JfzP8P8g+tUv+fEfvn/APJl CfQJ9K1jQruT
WLmbSLGVYorPyYI0hkZHhRsogJX94ECDAG4HOARR70Gru6/r+tikqWJjJQhy ySbVm7NLV73a
dru/NbS1ru51Vx95PxrRnACdKSEUtc/5Bs3/AFyf+VTIaIrL/kMyf9ck/m9T HcbNmtiQoAKA
CgAoAKACgAoAKACgAoAKACgDmJP+Xn/r6i/9p1zlnSRf6lP90VutiCs+k6bJ dfapNPtnuMg+
a0KlsjvnGaLInki3excplEc8EN1by29xEk0EqlJI5FDK6kYIIPBBHagDL1nw vo+vz2supWMN
x9nlEhWSJHWXakiqrhgdyjzXYDsefXIBYl0LR5vsPm6VZP8A2fj7Hut0P2bG MeXx8mNq9MdB
6UAF1oWj32owaheaVZXF9b7fKuJbdHkj2nK7WIyMEkjHegAh0LR7eW5lh0qy ikuZVmnZLdAZ
ZFbcrsQPmYN8wJ5B5oAkm0nTblw8+n2sridbkM8KsRMqhVk5H3wAAG6gACgC O10LR7DUZ9Qs
9Ksre+n3ebcRW6JJJuOTuYDJyQCc96ANCgAoAKAMvW/9RD/11T/0NazmNDdK /wCP29/3/wD2
RKUNxs1q1JCgAoAKACgAoAKACgAoAKACgAoAZL/qX/3TSewHH6z/AMidrX/X vdf+z1rgP97p
f4o/miK/8KXo/wAjC+BP/Im6n/2FJP8A0XHXq51/vPy/VmGE/hI6bw3/AMiv pH/XnD/6AK8j
Gf7zU/xP8zeh/Cj6L8jTrlNgoAr3H+vtP+up/wDQGoA366CDD1U/8T/RFz0u s4z/ANO9x2z/
AEH1PbKfxR9f0Z3YX+FX/wAK/wDS4G5WpwnD+LNcuNIaWWKxvL1jfW8A8m5E aRo7QqQQZU+Z
vMbaRkA43YFW5cqRCV2ze0K7knt528i4VfNGEllDtFlEJUtuOSCxPBI4OD0y m7pMcdLo4vxl
4j8Q6V4jeCw1hIbd4kkELWgkMJIwVLDOTxu5/vDtS+s0afuyim/WxyV44nm/ dp28lf8ARlfS
/FN1cy2t3fOJLqzwJZhmPzlLM2FQgYwoZSefvCvBzKrBV6eKpq1nZpO+n9X+ 89XLfbVKU6NW
LXm1a/4LbQ9G1o6gdGmOknN0du0rt3bdw37N3y79u7bu+Xdt3cZr3TnOT0rW tYPiXT9Lhnur
s7bk6hDqrQxS25U2pXBgjKMQk24AHB8zlgRgABN8RZFu5rWDSkneRk+wSiWZ IbhGuIod5keE
DH79GBj8wEZ5+6WANCPxXqVxfto9vpNqdaiaQTRvestuqosLErKIyzHFzFwU HO/ngbgDH0Lx
xJaaN4Vt7iF75LizsY7q7UzSSRzzKgAc+WYwSXRjvkVsNnByu4A1NN8X6pq+ naRLaaFDFeap
ateww3N9tVYVEW4l0RvmLSrtGOV5JU/IACPS9VvrfwL4K1KS5eRJVskvi/zy TCaMRrye/myR
sTkHCt16EAw/+E8vbvQHubaaZZreK91KU7Y0LWotxNDGpKsA6i7teSpGY3yW H3wDQ1zxfeW1
zp+qm18rQrS/vElaK5Jnn+z290HUxbQu3fESMufuoSAT8oBY1Dxzqej3kun6 hocP28+R9nS0
uZrhH8wTn5tsG8YFs/3UbqM4GSACxoPiPWNZ8TPGbD7PYCwhlmiuS8UsMhlu ELIrRhnVvKXG
/YQuDtySKALF8mpf8J9p1tFrt7FY3FrNcvarHAUzE8ChQTGX2t5jZ+bPoRQB Tj8dzfZbO4l0
pFTVYEuNMC3JYurywxqJvkHlHNxFnb5mBv64G4Aw/Efiq/XWLOOXzrKaxlEV 5BZyvMjn7Xpz
fLhQ0mYpyuNgPzOoBByQDQuvFusz69pMGmQQ7rvyJRBJdoYZIpIr1l/eJGxD YgjYlSy5ACnG
WYA6TVJ5pvEujaTHK8MTrNezMjEGRYTGoj4wQC8yMTnkRlSCGNAHLz6vruk2 t3Pql9qEN/bQ
fbZLd47VraWGGWNrn7OUUvjYSqCUhv3i55BZQCxF4tu73WbnS7WZ0nm1aKO1 Z412pAjSLMh6
nLGxu8HBP7yPkc7ACxpthrF/L4mspPFGoO9pOLa0kkjhHlN5EMyyERohYh3P yk7WXgg5NAHS
aFqf9t+HtM1XyfJ+3WsVx5e7ds3qGxnAzjPXFAEPiP8A5BkP/X9af+lEdZVf h+a/NHdgP4r/
AMM//SJF+4+8n41oziBOlJCKWuf8g2b/AK5P/KpkNEVl/wAhmT/rkn83qY7j Zs1sSFABQAUA
FABQAUAFABQAUAFABQAUAcxJ/wAvP/X1F/7TrnLOki/1Kf7ordbED6YBQAUA FABQAUAFABQA
UAFABQAUAZet/wCoh/66p/6GtZzGhulf8ft7/v8A/siUobjZrVqSFABQAUAF ABQAUAFABQAU
AFABQAyX/Uv/ALppPYDj9Z/5E7Wv+ve6/wDZ61wH+90v8UfzRFf+FL0f5GF8 Cf8AkTdT/wCw
pJ/6Ljr1c6/3n5fqzDCfwkdN4b/5FfSP+vOH/wBAFeRjP95qf4n+ZvQ/hR9F +Rp1ymwUAV7j
/X2n/XU/+gNQBv10EGHqpP8Ab+iDDY+1cEg4/wCPe46c4z+Hp14xlP4o+v6M 7sL/AAq/+Ff+
lwNytThMy+0WwupTPLExkdl3FXfnoOikduM9u/SncVi3Z2Ntp8Jito9iFtxy xYk/U89hQ3cE
rHP6z4c0uXUZb281i4s3uCDsEsaKcKF43KT0A71w1qFJy5pytfzO6liZxiox inb1/wAyGx8K
aPN5xt9YuLslAhIlibZ8ysDwvBynf3rP6nQqxcVK6fmipYuorXil9/8An5nQ PpVvJo6aW0lw
IEjSMNFO8MmFxj50KsOnOCM/Su6EFCKgumhxSk5Scn1KsPhfSbf7O0UMyzQS mUT/AGqUzOx2
5Dybt8inYgKsSCEQEYUYskrx+CtBjukuFtZi0W3yka7maOELIkirHGW2ooeK M7VAGFAxjigC
xd+F9JvJ5rh4ZoriaXzXmt7qWCQsURCN6MCFKxx5UHBKKSMjNAFdfBWgx/Yx FazRR2nk+XFH
dzJGTDt8tnQNtkZdiDcwJwqgngUAWJPC+kyadY2KwzQQ2EQhtmt7qWGSOMAD Z5iMHK/KuQTg
lVJyQKALH9iad/wj39gfZ/8AiWfZfsfk72/1W3Zt3Zz93jOc+9ABeaJp1/8A 2h9pt9/9oWos
7n52G+Ib8LweP9a/IweevAoApy+ENDnv/tk1o8h3SP5D3Eht9zqyufI3eXlg 75O3ksxPJJoA
y9J8BQ232uXVb6a+urjygssc9xG0Ij37SjvM8it+9kBKuAQcYGW3AG5beHdM sri2uLaB4Zbd
SgZJnHmAlifN5/enLu2X3Hc7N1JJALj2NvJqMN+0ebqCJ4Y3yeEcoWGOnJjT 8vc0AZcfhDQ4
klRbRyki7FVriRhAoYMBDlv3IBVCBHtwUQj7q4ABfCGhqYGNo8kkLb1lluJH kZvMikyzsxZz
ugi5YnAQL04oAJPCGhyXF3cfZHjnumV3khuJI2RlLnKFWBjJMsmSmN3mPnO4 5ALmoaZ9svLC
8im8i6spdyvtyHjYYeNuQSpGDjOAyIxB24IBHpvh/T9KuGuIPtUs5XYJLq8m uWRSQSFMjMVB
IGQMZ2rnOBgAks9E06w/s/7Nb+X/AGfamztvnY+XEdmV5PP+qTk5PHXk0AR3 ujLLZanDYzvY
z6kwae4jLFwdixlkOflfYgCkcAgHB5BANCCCG1t4re3iSGCJQkccahVRQMAA DgADtQBm+I/+
QZD/ANf1p/6UR1lV+H5r80d2A/iv/DP/ANIkX7j7yfjWjOIE6UkIpa5/yDZv +uT/AMqmQ0RW
X/IZk/65J/N6mO42bNbEhQAUAFABQAUAFABQAUAFABQAUAFAHMSf8vP/AF9R f+065yzpIv8A
Up/uit1sQPpgFABQAUAFABQAUAFABQAUAFABQBl63/qIf+uqf+hrWcxobpX/ AB+3v+//AOyJ
ShuNmtWpIUAFABQAUAFABQAUAFABQAUAFADJf9S/+6aT2A4/Wf8AkTta/wCv e6/9nrXAf73S
/wAUfzRFf+FL0f5GF8Cf+RN1P/sKSf8AouOvVzr/AHn5fqzDCfwkdN4b/wCR X0j/AK84f/QB
XkYz/ean+J/mb0P4UfRfkadcpsFAFe4/19p/11P/AKA1AG/XQQYetDyb2y1B hiCznSSZsdEK
Sx7s4xhTIGOTwoY8d8qmjUuz/wA1+p3YP3lUpLeUbL1TUrertZd20jZiljnh SaGRZIpFDI6H
IYHoQe4rRNNXRxyjKEnGSs0NuRmJRjPzoemf4h7H/PcdQyQFyhxhZOcdYmHX Ht/tD9fQ4AMr
U5mGoWjxM6M1tKQQpDD5ouxU/wAqmKvVXo/0G3aD/ruZzTTfbbe5YyrNG8cX mHcN6tKoKkGN
R0Y/kD2zSr0UpKqnrovlcKc3bkZ1dWI5PxR4ons9I8RLpdpdNPptnMz3qiLy reZYPNVSGbcx
wUPCsvzAE8NgAkv/AB9omla9c6Tfy/Z5LeJpWk82KTIWIyt+7RzKMIGOWQA4 4JyuQA/4TWEx
aeBpF613qW9rO1Wa1Lzxqqs0iN53llcMOA248kDAJABYsPFkF7qK2x069t4Z bqazgupfLMc8
sRcOqhXLj/VSEFlAwvXJAIBhx/Eq31KWxj0axe8ne8EFxaxT28smxoJnVldJ TEDuhPBfOAeO
VJANDw94onuJjaalaXSGbUby1trxhF5Uxjml2xgK24ERxnllAOw8kkZAOsoA KACgAoAKACgA
oAKACgAoAKACgAoAxtcljuZLPSopFa7kuYZzGDkpHHIJC7DqFPllQcY3Mo71 lUadoLfT8NT0
MHGUFOvJe6lJX7trlSXnrdrsmzSuPvJ+NaM4ATpSQilrn/INm/65P/KpkNEV l/yGZP8Arkn8
3qY7jZs1sSFABQAUAFABQAUAFABQAUAFABQAUAcxJ/y8/wDX1F/7TrnLOki/ 1Kf7ordbED6Y
BQAUAFABQAUAFABQAUAFABQAUAZet/6iH/rqn/oa1nMaG6V/x+3v+/8A+yJS huNmtWpIUAFA
BQAUAFABQAUAFABQAUAFADJf9S/+6aT2A4/Wf+RO1r/r3uv/AGetcB/vdL/F H80RX/hS9H+R
hfAn/kTdT/7Ckn/ouOvVzr/efl+rMMJ/CR03hv8A5FfSP+vOH/0AV5GM/wB5 qf4n+ZvQ/hR9
F+Rp1ymwUAV7j/X2n/XU/wDoDUAb9dBBAhX7dKARuEaE+uMtjt9e5+g7rqBS l8N6FPM802i6
fJLIxZ3e2QliepJxyah0qbd3Ffcdkcfi4RUY1ZJL+8/8yvc+GfD0cSt/Yemr 86Ln7JH3YDH3
T6//AFx1pexp/wAq+4r+0sb/AM/pf+BP/Mm/4Rbw9/0AdN/8BI/8KPY0/wCV fcH9pY3/AJ/S
/wDAn/mZWq+DbGS4t5NP0XSgqo6urxLHkkqQRhGBxtYcjvR7KmnflQPMca1b 20v/AAJ/5lRP
BYbykl0XRwgmR3cBS20MCVAESg5AI/GiVOEtORL+vQSzHGr/AJfT/wDAn/mb F/4L8PX2nXNn
/ZNpb+fE0fnQW8aSR7gRuVtvDDOQfWj2NP8AlX3D/tLG/wDP6X/gT/zM+/8A hxod7PctGptI
bmJo5IYIINoYoU3qzRl0YcEbWAyucZLZPY0/5V9wf2ljf+f0v/An/mRy/DTR Xv8A7RHJJBEG
kkS2SC3aNGdWXOWiLMAXLBWYqCFwMKAD2NP+VfcH9pY3/n9L/wACf+YH4aaK 1ukLSSHLM1ww
gt1a4BAG0kRDywAuB5Ww8k53HdR7Gn/KvuD+0sb/AM/pf+BP/Mr6b8MtMU3L aqFuUknuXjto
0jSOJJJH2YdUWTIjYDBYhTyv3VIPY0/5V9wf2ljf+f0v/An/AJkifDDRx5zy XVxLcPs8uU29
qvk7d/3UWERnIcg7lbop4KqQexp/yr7g/tLG/wDP6X/gT/zNCPwD4ej+zf6B E3kXUtz80UZ8
zf5n7tvl5RfM+Ve2xPSj2NP+VfcH9pY3/n9L/wACf+Zof8It4e/6AOm/+Akf +FHsaf8AKvuD
+0sb/wA/pf8AgT/zD/hFvD3/AEAdN/8AASP/AAo9jT/lX3B/aWN/5/S/8Cf+ Yf8ACLeHv+gD
pv8A4CR/4Uexp/yr7g/tLG/8/pf+BP8AzD/hFvD3/QB03/wEj/wo9jT/AJV9 wf2ljf8An9L/
AMCf+Yf8It4e/wCgDpv/AICR/wCFHsaf8q+4P7Sxv/P6X/gT/wAw/wCEW8Pf 9AHTf/ASP/Cj
2NP+VfcH9pY3/n9L/wACf+Yf8It4e/6AOm/+Akf+FHsaf8q+4P7Sxv8Az+l/ 4E/8w/4Rbw9/
0AdN/wDASP8Awo9jT/lX3B/aWN/5/S/8Cf8AmH/CLeHv+gDpv/gJH/hR7Gn/ ACr7g/tLG/8A
P6X/AIE/8w/4Rbw9/wBAHTf/AAEj/wAKPY0/5V9wf2ljf+f0v/An/mH/AAi3 h7/oA6b/AOAk
f+FHsaf8q+4P7Sxv/P6X/gT/AMw/4Rbw9/0AdN/8BI/8KPY0/wCVfcH9pY3/ AJ/S/wDAn/mH
/CLeHv8AoA6b/wCAkf8AhR7Gn/KvuD+0sb/z+l/4E/8AMvWen2WnQmGxtILW ItuKQxhAT0zg
d+B+VXGMYq0VY5qterXlzVZOT83f8xL2Tyot46genuBWkI80kmYydkYkurtH E8q3SiJN25vl
wMdcnHbBz9K7I0YPoYubEubyW40qYStuby5ecAcAL/jXLiYKD0NKcm9yxA2z Up3/ALsCnrjp
vrmpq8kjR6Iq6r4mi0nyvPcbpnCRoqszMSewBycZ/wAkgV3qhFmDqNF211KS aUo4GPlwVJHV
gPX3qatFQV0OM23qNbUpt3y7NvbO7/GrVCNuovaMT+0rj/pn/wCPf40/q8PM PaMT+07n/pn/
AOPf40fV4eYe0Yv9pXGCf3eACTndwB/wKl7CHmHtGDajcocExdcdT15/2v8A ZP5UKhB9w9ow
/tK4/wCmf/j3+NP6vHzD2jE/tO5z/wAs/wDx7/Gj6vDzD2jF/tK4/wCmf/j3 +NH1eHmHtGS2
t5NPeRRscBlfIBOPlKf/ABf6CsatNQWn9b/5FRk2ylqviNNJtBdT5EO5VJVH bbk4ycHp/nrg
VoqESXUZNb6w0w3BkeIxs4ZCeQFJBByc0ToRjG6GqjbK8n/Lz/19Rf8AtOvN Og6SL/Up/uit
1sQPpgFABQAUAFABQBycXi6+Ph/+35tGRNJkgjvI5ku9zJbkqWaVSoKusbF9 qb87GXOdu4A3
LzW9OsP7Q+03Hl/2fai8ufkY+XEd+G4HP+qfgZPHTkUAY8ev+IDrml6bNoNl B9ttTcyFtRYv
CE8oSqQIiGYNLgYbDbc5XNAG5qWrabo1utxqmoWtjAzbFkuZljUtgnALEDOA ePagAOraat+l
g2oWovHZkSAzL5jMqh2AXOSQrKxHYMD0NAGXe6zrH/CQz6TpOl2Vz9ntYbiS S6vng/1jSKAA
sT5x5R5yOooAsab4o0fU4tL8u+hhutTtUu7ezmlRZ2jZdwOzOTwDnGRwfSgC PRvFOm6rZaO0
t1a2uoapZx3cdi1wpl2sm7gcFgMNyB/CaAK+j+OtB1pFeC8SJDp0epFppEUL CzOrZwxwUKEP
2UkDNAG5Y39nqdnHeWF3Dd2smdk0EgdGwcHDDg8gj8KALFABQAUAFABQAUAF ABQAUAFABQBz
Pi//AJF3Wv8Aryl/9FmtsH/vlP8AxR/NGdf+DL0ZyvwJ/wCRN1P/ALCkn/ou OvTzr/efl+rM
cJ/CR03hv/kV9I/684f/AEAV5GM/3mp/if5m9D+FH0X5GnXKbBQBXuP9faf9 dT/6A1AG/XQQ
RKf9LkXPRFOM+7ds/wBB9T2AJaAIrk7YlOcfOg64/iHuP89j0IAC6t2xtnjO cYw45zjH/oS/
mPWi4GNrXkTXlmzpBMn2eV0Miq6/ei55IHQ+tZOnGpUipK6s/wBCuZxi7Gdb XEdtfRS2fkwv
ujjljiWMJIGkC52q5II3dfb3xSqYf2UlUp6LRWt5/IcanOuWR19bEGO3ijSU 1iTS2mmW4ilW
GRzayiFJGVWVDLt8sMQ6YG7JLAdSBQBXh8a6Dc6db31pdTXcFxnyfs1pNM0g AUswRFLFV3Kr
NjCsdpIbigAbxjpKXlxF5/mRxxQSRmCKWV5/NDsvlqqHzF2oTmMt918hdpJA LCeKNJlltYoJ
pp5LnGFhtZZDHliv70Kp8r5lZf3m3BRwfutgAPC/iCLxP4es9Vit5rfz4kdo 5YnTazKGIUsq
71+bhwMHtQBsUAFABQAUAFABQAUAFABQAUAFABQAUAFABQBQ1YkWTkDOAD/4 8ta0f4iIn8J5
3ceFoXvGWG6eHSpm82a0U4DOOmPQHuPYe230Ejmeh0aoselMqIEjWGYKAMAA BOlcWL/y/U3o
mgM/a7zAyfswwB/wOuSj/ERtL4WcpqmmznWbfWLApJcLiOSKZvlKHjKnnaRk 9Pf3Dexaxxs6
GwJMxwMgNHz/ANtUrOv8K/roOne5EZcYBBBAwc1okK4ebTsK4ecBSsFxGlzH IoHLIy8n1BFN
JXQNuw1pS8u7AA37uvvIf/Zx+VNJJf15f5Cu7/15/wCY/wA3FKw7h5w6UWC4 ebRYLmhpQLX0
DYONk384q5K+33fqa09/v/QwdWa9k0l4LKOJp5MRkTfdUHgkjHOPQ/r0PVbs ZiaJpqaVp5so
ZHlCQylmY9SUOcDsM9v681NTSP3Cje5ryf8ALz/19Rf+068Q7zpIv9Sn+6K3 WxA+mAUAFABQ
AUAFAHJ6Z4ZmXWbq6v8ATtJt4J4JYbpLJSV1JnZSZZkKgAgK+FJk/wBcw3dS wBTh8D3h+z/a
9Umud8phvfNnL+faJt8pDlfmY+Um8N8p8+5x98YAOkn02aXxVp+qKyCC3s7i 3ZSTuLSPCykc
YxiJs89x+ABX1iw1L+2bHV9Litbie2gmtmguZ2hUrI0Tbg6o5yDCBjbzuzkY wQDn9K8AzaTo
01lHLayTteabILjaUaSG1W2BDcEg5hkIXJA39eTQBsXnhDTdV8VXeqavpmn3 8D2cFvAtzAsr
RsjzM5G4EAESJ0POOegoAzPEHh7VdT8SW5W5ilh+1211EJNRmhMMUMkTOgt1 UpNypO9iCDIB
wFWldXsVyy5ea2n9f5MztE+Hl9pjafFcGG4jT7FLNINQuUSOSCKFMC3XCS8w Ah2II3DKnYAz
JLH/AAgd+uipYG4hby7CytQyzPEWNnOZIyGUZTzFY5I5jI48zqADpPC+jSaP ZXIniSKe6nMz
qt3NdEHYqDMsp3OcIOygDAxxuIBuUAFABQAUAFABQAUAFABQAUAFAHM+L/8A kXda/wCvKX/0
Wa2wf++U/wDFH80Z1/4MvRnK/An/AJE3U/8AsKSf+i469POv95+X6sxwn8JH TeG/+RX0j/rz
h/8AQBXkYz/ean+J/mb0P4UfRfkadcpsFAEFzHIxheIKWjfdhmwD8pHXB9aA Jftupf8APOH/
AL+n/wCIquZisNF3qIct5cWSAP8AXHH5bfejmYWHfbdS/wCecP8A39P/AMRR zMLB9t1L/nnD
/wB/T/8AEUczCwfbdS/55w/9/T/8RRzMLFef7XcSpLJBEXRWRWE7KQCQT0X/ AGR+VCk07hZW
sQ/Zp9wJhVsMrANdyMAVYMDgj1ApyqSkrMSilsXvtupf884f+/p/+IpczHYz 5LEy/ad9lCft
N1FeS/6Q3zSx+Xsb7vGPKj4HB28jk5OZhYLOxNh/Z/2ayhj/ALPtTZ23+kMf LiOzK8rz/qk5
OTx15NHMwsZ8nhTTJ4rSK40SyuIbSKGGKOeVpECRLIsYKspDYEsnXPXPUDBz MLGhp2nrpErv
pumWVnuiSEpA2xAis7ABQmB80rngc7uaOZhYsWAutM062sLO3hitbWJYYk85 jtRQABkrk8Ad
aOZhYsfbdS/55w/9/T/8RRzMLB9t1L/nnD/39P8A8RRzMLB9t1L/AJ5w/wDf 0/8AxFHMwsH2
3Uv+ecP/AH9P/wARRzMLB9t1L/nnD/39P/xFHMwsH23Uv+ecP/f0/wDxFHMw sH23Uv8AnnD/
AN/T/wDEUczCwfbdS/55w/8Af0//ABFHMwsH23Uv+ecP/f0//EUczCwfbdS/ 55w/9/T/APEU
czCwfbdS/wCecP8A39P/AMRRzMLB9t1L/nnD/wB/T/8AEUczCwfbdS/55w/9 /T/8RRzMLB9t
1L/nnD/39P8A8RRzMLB9t1L/AJ5w/wDf0/8AxFHMwsRyzX8ygPFFx0KzspH4 haanJCaTK3kX
X+3/AOB8v+FX7aXl9y/yFyL+mwkhu3tZYRHH+8Urue4dyMj1K5/ColNy3Gop bEskc63TyRJG
yuir80hUggk9gfWpTad0Nq5GYbsnOH/8D5f8K09tLy+5f5E8i/psdGt3EwYI GI6eZdyPj6ZB
xSdWTVv0QKCQrfbXYsV5PpeSAfoKFUkh8qE23nof/A2T/Cj2kv6SFyoNt56H /wADZP8ACj2k
v6SDlQbbz0P/AIGyf4Ue0l/SQcqDbeeh/wDA2T/Cj2kv6SDlQbbz0P8A4Gyf 4Ue0l/SQcqDb
eeh/8DZP8KPaS/pIOVBtvPQ/+Bsn+FHtJf0kHKh6NeRggRRnIwS9wzEj0yV6 UnOTHypETRXb
HJD/AIX8o/pVe2l5fchci/pipFdIwOzdjs95I4/Igih1ZNW/RAoJAbe4aKYl YxI8ySBQ5I+X
bxnH+z6VkWWheaiqgCKEAcD96f8A4mq5mhWF+26l/wA84f8Av6f/AIijmYWD 7bqX/POH/v6f
/iKOZhYPtupf884f+/p/+Io5mFg+26l/zzh/7+n/AOIo5mFg+26l/wA84f8A v6f/AIijmYWL
NjcXcs7LcJGE25G18nP/AHyKqLbYmaFaCCgAoAKACgAoAyda/wBHuNLvxwIL pY5Cv3mSUGML
7je0bEf7GeSBWVTRxl5/np+djuwnvxqUu8W12vH3r+vKpJettmzWrU4QoAKA CgAoAKACgAoA
KACgAoAKACgAoA5nxf8A8i7rX/XlL/6LNbYP/fKf+KP5ozr/AMGXozlfgT/y Jup/9hST/wBF
x16edf7z8v1ZjhP4SOm8N/8AIr6R/wBecP8A6AK8jGf7zU/xP8zeh/Cj6L8j TrlNgoA5nx7d
3Nn4TuHtZmikZlQsvXBPP0r0cspwq4uEZq61/BNnJjJyhQlKLs/+CeX6Jpvi HxBPLBp95O8k
a72DXBXjOO5r6XHVcFgnGM6N+a+0Y9Ld2u55OGhiMQm41LWtu319L9iTWtF8 TaAEN/c3Ch+6
XBYD64NZYTGZdiqvsVSUZbpNR19LX27f8EuvQxdCHO53Xk3p+Rj/AG7Uv+f+ 6/7/ADf416/1
PC/8+4/cjh+sVv5397D7dqX/AD/3X/f5v8aPqeF/59x+5B9Yrfzv72H27Uv+ f+6/7/N/jR9T
wv8Az7j9yD6xW/nf3sPt2pf8/wDdf9/m/wAaPqeF/wCfcfuQfWK387+9h9u1 L/n/ALr/AL/N
/jR9Twv/AD7j9yD6xW/nf3sPt2pf8/8Adf8Af5v8aPqeF/59x+5B9Yrfzv72 H27Uv+f+6/7/
ADf40fU8L/z7j9yD6xW/nf3sPt2pf8/91/3+b/Gj6nhf+fcfuQfWK387+9i/ bNT25+3XWPXz
W/xrN0MEpqDhG76WVylVxDjzKTt6sPtmphc/brrHr5rf40KhgnNwUI3XSyuD q4hR5uZ29Wd3
8M5Zr26v4b1/tKKisvnDeQc44J5r57PaFKk6bpxSvfbTa3+Z6mW1ZzUlJ3tY 9G+wWf8Az6Q/
9+xXzh6wfYLP/n0h/wC/YoAPsFn/AM+kP/fsUAH2Cz/59If+/YoAPsFn/wA+ kP8A37FAB9gs
/wDn0h/79igA+wWf/PpD/wB+xQAfYLP/AJ9If+/YoAPsFn/z6Q/9+xQAfYLP /n0h/wC/YoAP
sFn/AM+kP/fsUAH2Cz/59If+/YoAPsFn/wA+kP8A37FAB9gs/wDn0h/79igA +wWf/PpD/wB+
xQAfYLP/AJ9If+/YoAPsFn/z6Q/9+xQAfYLP/n0h/wC/YoAPsFn/AM+kP/fs UAH2Cz/59If+
/YoAPsFn/wA+kP8A37FAB9gs/wDn0h/79igA+wWf/PpD/wB+xQAfYLP/AJ9I f+/YoAPsFn/z
6Q/9+xQAfYLP/n0h/wC/YoAPsFn/AM+kP/fsUAH2Cz/59If+/YoAPsFn/wA+ kP8A37FAB9gs
xQBc062t4bhmigjjbbjKqAeoq4biZp1qSFABQAUAFABQBU1Sx/tHS7mzEnlP KhCS4yY3/hce
6nBHTkCpnHmi0b4at7CrGpa6T1XddV6NaPyDSr3+09Isr/y/L+0wJNsznbuU HGe/WiEuaKl3
DE0fYVp0r35W19zsW6owCgAoAKACgAoAKACgAoAKACgAoAKAOZ8X/wDIu61/ 15S/+izW2D/3
yn/ij+aM6/8ABl6M5X4E/wDIm6n/ANhST/0XHXp51/vPy/VmOE/hI6bw3/yK +kf9ecP/AKAK
8jGf7zU/xP8AM3ofwo+i/I065TYKAOX+IC7vCzr/ANNU/nXp5TpjIfP8mcWO /wB3l8vzRzPw
3mj0/V7+eZgkSWjMzHsAy5NernacqtJLtL/204ctkowm35fqaMgjl8Aa7cCM ETXsjwyFfvI0
gwQfQ815koJ4ik2tU4f+lI7ISaoT7NS/JnIeHtMFzqfmOkLR20bTsJ3VYyVH yK24gFS5RSPQ
9utfXYqryU7K927aXv52t1SuzwqEOad+2uv4fjY07mGz0vU5nlihj+2Rxzxy wwQ3UaZB8xFQ
naF35AOcgJjnJNc8HOtTSTfutpptxfk2972+Tv5G0uWnNt9bPRJ+qttv+RJq mkwyC1sLpGF/
Ba3LedCyrCPLlnYgR7RwdpAwRjI44wZo1pK9SHwtx0e+qit7+fZ+pVSCdoS3 Sfpo5dLEo0HT
tNu7pbS6aae2iubeYfMQT9nl55RQnKn5dzZyeflyZ+sVasY86sm4tbfzR83f fey9NR+yhCT5
Xqrr8H5K33v8CnNp63HxDlFxFIbefVJIwwAwT5n+0CpxuUkEHI471rGo44Jc r1UE/wAPJp/M
zcb4nXZyf5kUOgaaumia8lkS4gSOeeKOTcxiZ1AwCgUHa6nO9vQgZOKliavt LQWjuk/NJ+d9
1bZevdKlBRvJ6qzfo7eVtn3f+TV8OW1vcJFdzK4jDy3DxzYRYtwSMghGbJY5 +6cq6HjJIbxU
pRvBb2S01vu+qWi03WqaF7GMXaT9fTZdH+WzRn6vpcVhqTwQSebCUSRG5+66 BgOQM43YzgZ9
B0rooVXUp80lZ6r7nb+tX6syqwUJWW3+ep0fgOMoNUW++z/2CYR9uE347NuO d2c4x/PFeFnD
h7SHJf2nl26fO+1v8j1Mu5uSXN8H9fhbf/hw8dxlhpa2P2f+wRCfsIh/Dfuz zuzjOf55oydw
VSfPf2nn26/O+9/8wzDm5I8vwf1+Ftv+GJ/hpH5eo33vEv8AOoz939n8/wBB 5X9v5fqek18w
eyFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUA
FABQAUAFABQAUAFABQBZsv8AXH/dq4biZerUkKACgAoAKACgAoAydE/0d9R0 9vvwXUkgJ4Lp
KTKGx6Zdkz3MZ9wMqel4+f56/wDA+R3Yz31TrLZxS9HFctvWyUvJSXq9atTh CgAoAKACgAoA
KACgAoAKACgAoAKAOZ8X/wDIu61/15S/+izW2D/3yn/ij+aM6/8ABl6M5X4E /wDIm6n/ANhS
T/0XHXp51/vPy/VmOE/hI6bw3/yK+kf9ecP/AKAK8jGf7zU/xP8AM3ofwo+i /I065TYKAOc8
bru8PFf+mq/1r0sq0xcPn+TOLHf7vL5fmjz+wubvTJ2ms5vKkZChO0NkHBxg g+gr6jF4OGKc
XJtWvtbrbun2PDoYmVBNRSd+5au9b1e+tGtLm8LwNjKeWgzg5HQe1csMqpQm pc8nZp9Ojv2N
5Y+pKLjZa6df8zNWN0V1RmVXG1gDjcMg4PryAfwr1nZ7nAm1sWbe91CzXbbX 1zAuNuI5WXjJ
OOD6sT+J9aznSpT+KKfyLjVnH4W0Qjzl24lkGxCi4Y8Kc5A9juPHufWrtHsR zPuSPcXsiRI9
3OyxIUjDSEhFIwQPQEcY9KlU6abaitfIp1Juyb2HQXV1Ddx3JkaSWOQzKZGL YkP8fXk5APPX
AzkcUpU4Si4WsmrfLt6f0hxqSUub5/PuN+0Xv2L7F9rn+yf88fMOzrn7vTrz T9nT5+flV+9t
Re0ny8t9Ow2OS6huEuIriVJ0AVZFchlAG0AHr04+lNxhKPK0rCU5J8yeo2fz rqZpriWSaVvv
PIxZj25JpxUYLlirIUpOTvJ3ZF9n9qThByU2lddeo1OSjyp6B9n9qFCCk5pK /fqDnJx5b6HW
eBWitb+6aWRY1MYGWOB1r5/PXf2fz/Q9fK/t/L9Tuft9n/z9w/8AfwV82eyH 2+z/AOfuH/v4
KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+C gA+32f8Az9w/
9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH2+z/AOfuH/v4KAD7fZ/8/cP/ AH8FAB9vs/8A
n7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQAfb7P/n7 h/7+CgA+32f/
AD9w/wDfwUAH2+z/AOfuH/v4KAD7fZ/8/cP/AH8FAB9vs/8An7h/7+CgA+32 f/P3D/38FAB9
vs/+fuH/AL+CgA+32f8Az9w/9/BQAfb7P/n7h/7+CgA+32f/AD9w/wDfwUAH 2+z/AOfuH/v4
n7h/7+CgA+32f/P3D/38FAB9vs/+fuH/AL+CgA+32f8Az9w/9/BQBc065t5r hlinjdgucKwJ
6irhuJmnWpIUAFABQAUAFABQBkzf6H4ot5jxHfwG3Ynn95GWdAPTKtMSTx8o 6d8n7tRPvp93
9M7ofvMJKPWDv8pWTfyajb1e/TWrU4QoAKACgAoAKACgAoAKACgAoAKACgDm fF//ACLutf8A
XlL/AOizW2D/AN8p/wCKP5ozr/wZejOV+BP/ACJup/8AYUk/9Fx16edf7z8v 1ZjhP4SOm8N/
8ivpH/XnD/6AK8jGf7zU/wAT/M3ofwo+i/I065TYKAOf8Zf8gL/tqv8AWvRy v/e4fP8AJnFj
v93l8vzRs/8ACGeH/wDnw/8AIz//ABVbf2jiv5vwX+RP1Kh/L+LD/hDPD/8A z4f+Rn/+Ko/t
HFfzfgv8g+pUP5fxYf8ACGeH/wDnw/8AIz//ABVH9o4r+b8F/kH1Kh/L+LD/ AIQzw/8A8+H/
AJGf/wCKo/tHFfzfgv8AIPqVD+X8WH/CGeH/APnw/wDIz/8AxVH9o4r+b8F/ kH1Kh/L+LD/h
DPD/APz4f+Rn/wDiqP7RxX834L/IPqVD+X8WH/CGeH/+fD/yM/8A8VR/aOK/ m/Bf5B9Sofy/
iw/4Qzw//wA+H/kZ/wD4qj+0cV/N+C/yD6lQ/l/Fh/whnh//AJ8P/Iz/APxV H9o4r+b8F/kH
1Kh/L+LD/hDPD/8Az4f+Rn/+Ko/tHFfzfgv8g+pUP5fxYf8ACGeH/wDnw/8A Iz//ABVH9o4r
+b8F/kH1Kh/L+LD/AIQzw/8A8+H/AJGf/wCKo/tHFfzfgv8AIPqVD+X8WH/C GeH/APnw/wDI
z/8AxVH9o4r+b8F/kH1Kh/L+LD/hDPD/APz4f+Rn/wDiqP7RxX834L/IPqVD +X8WH/CGeH/+
fD/yM/8A8VR/aOK/m/Bf5B9Sofy/iw/4Qzw//wA+H/kZ/wD4qj+0cV/N+C/y D6lQ/l/Fh/wh
nh//AJ8P/Iz/APxVH9o4r+b8F/kH1Kh/L+LD/hDPD/8Az4f+Rn/+Ko/tHFfz fgv8g+pUP5fx
Yf8ACGeH/wDnw/8AIz//ABVH9o4r+b8F/kH1Kh/L+LD/AIQzw/8A8+H/AJGf /wCKo/tHFfzf
gv8AIPqVD+X8WH/CGeH/APnw/wDIz/8AxVH9o4r+b8F/kH1Kh/L+LD/hDPD/ APz4f+Rn/wDi
qP7RxX834L/IPqVD+X8WH/CGeH/+fD/yM/8A8VR/aOK/m/Bf5B9Sofy/iw/4 Qzw//wA+H/kZ
/wD4qj+0cV/N+C/yD6lQ/l/Fh/whnh//AJ8P/Iz/APxVH9o4r+b8F/kH1Kh/ L+LD/hDPD/8A
z4f+Rn/+Ko/tHFfzfgv8g+pUP5fxYf8ACGeH/wDnw/8AIz//ABVH9o4r+b8F /kH1Kh/L+LD/
AIQzw/8A8+H/AJGf/wCKo/tHFfzfgv8AIPqVD+X8WH/CGeH/APnw/wDIz/8A xVH9o4r+b8F/
kH1Kh/L+LD/hDPD/APz4f+Rn/wDiqP7RxX834L/IPqVD+X8WH/CGeH/+fD/y M/8A8VR/aOK/
m/Bf5B9Sofy/iw/4Qzw//wA+H/kZ/wD4qj+0cV/N+C/yD6lQ/l/Fh/whnh// AJ8P/Iz/APxV
H9o4r+b8F/kH1Kh/L+LD/hDPD/8Az4f+Rn/+Ko/tHFfzfgv8g+pUP5fxYf8A CGeH/wDnw/8A
Iz//ABVH9o4r+b8F/kH1Kh/L+LD/AIQzw/8A8+H/AJGf/wCKo/tHFfzfgv8A IPqVD+X8WH/C
GeH/APnw/wDIz/8AxVH9o4r+b8F/kH1Kh/L+LD/hDPD/APz4f+Rn/wDiqP7R xX834L/IPqV
Re: No SWT Controls on palette [message #615168 is a reply to message #136945] Tue, 27 March 2007 14:24 Go to previous message
Success! Thank you very much for your help.
The screen shot you took showed me what the problem was (a picture is
worth 1000 words). I did not have the SWT library loaded in my project.
You told me that earlier but the picture made the issue clear.
In case someone else has this problem and stumbles upon this thread,
here's what I did:
1. I right-clicked on the project in the Package Explorer and selected the
Properties menu.
2. I clicked the Java Build Path option on the left.
3. I clicked the Libraries tab.
4. I clicked Add Library.
5. I selected Standard Widget Toolkit from the list of choices.
The SWT Library included the SWT jar file that I already had in the list
so I removed the entry I had added for this jar file earlier.
Now when I open a Visual Class, VE is the editor and I have SWT controls
on the palette.
Thanks again for all of your help.
Scott
Previous Topic:Be unable to load class
Next Topic:VE project is dead? ... or sleeping? )))
Current Time: Fri Nov 07 22:13:22 EST 2025
Powered by FUDForum. Page generated in 0.07782 seconds
