Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP saves configurations in plugin's folder
TPTP saves configurations in plugin's folder [message #136295] Thu, 25 September 2008 06:14 Go to next message
I found out yesterday very interesting feature of TPTP. If TPTP is
installed and if at least one time profiler had been run you can't rename
folder where eclipse is located. As I found out TPTP saves it's parameter
in plugin's folder in file pluginconfig.xml. For example
<PluginConfiguration requires="org.eclipse.hyades.execution,
org.eclipse.hyades.logging.core">
<AgentControllerEnvironment configuration="default">
<Variable name="CLASSPATH" position="prepend"
value=" %PLUGINS_HOME%\org.eclipse.tptp.platform.collection.framewor k_4.2.200.v200804150100\hcframe.jar "/>
<Variable
name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK "
position="append"
<Variable
position="append"
value=" C:\eclipses\work\plugins\org.eclipse.tptp.platform.collectio n.framework_4.2.200.v200804150100\config.jar "/>
<Variable
position="append"
value=" C:\eclipses\work\plugins\org.eclipse.tptp.platform.collectio n.framework_4.2.200.v200804150100\hcframe.jar "/>
</AgentControllerEnvironment>
<Agent client="DYNAMIC" configuration="default" dataChannelSize="64M"
name="Java Profiling Agent" type="Profiler"/>
<Option name="Thread Analysis Agent" type="Profiler" value="hcthread"/>
<Option name="org.eclipse.tptp.platform.collection.framework"
type="version" value="4.2.200.v200804150100"/>
</PluginConfiguration>
As you can see some paths are hard coded and after moving eclipse to
another folder or renaming eclipse containing folder TPTP doesn't work. If
you try to profile anything you will get forever pending "Profile on ..."
dialog
This problem can be bypassed by removing all configuration files which
contain path information.
Re: TPTP saves configurations in plugin's folder [message #136435 is a reply to message #136295] Fri, 26 September 2008 17:15 Go to previous message
Hi Igor,
This problem is recently fixed in TPTP 4.51 with bug
https://bugs.eclipse.org/245285, please refresh your driver to pick up the
latest version of TPTP to resolve this problem.
Eugene
"Igor Lyashchevskiy" <igorlash@gmail.com> wrote in message
news:9ca57a66e44e852ee48409fca2615f64$1@www.eclipse.org...
> <Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK "
> position="append"
> position="append"
> position="append"
> dialog
Previous Topic:problem with AGR
Next Topic:tracing execution
Current Time: Thu Nov 06 17:01:10 EST 2025
Powered by FUDForum. Page generated in 0.03009 seconds
