Home » Archived » Voicetools » CCXML editor invalidates valid CCXML codes
CCXML editor invalidates valid CCXML codes [message #12512] Fri, 17 March 2006 15:24 Go to next message
Originally posted by: yliu.m1global.com
The VTP CCXML editor invalidates CCXML codes which comply to W3C CCXML
stabdards v1.0.
It appears only follow the DTD: http://www.w3c.org/TR/ccxml/ccxml.dtd
which does not encompass the entire stabdard.
For example, the editor invalidates the following code:
<ccxma>
<eventhandler>
</venthandler>
</ccxml>
It displays a syntax hint according to the above mentioned DTD -- in which
"eventhandler" is not even defined.
How the CCXML editor perform syntax check and code completion?
May we add more name spaces -- DTD? in case of W3C CCXML standards, using
xsd files?
Or maybe even ABNF files?
Thanks.
Re: CCXML editor invalidates valid CCXML codes [message #12534 is a reply to message #12512] Fri, 17 March 2006 16:52 Go to previous messageGo to next message
You're right, thanks for catching this inconsistency. You are correct that
it uses the DTD on w3c.org as its source of what is the correct tag and
attribute set. I am not sure why they are not up to date but obviously this
is a problem. I will open a bugzilla to track this problem, which you can
add yourself to:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132404
It is possible to define your own schema or DTD to use by going into
Window->Preferences->Web and XML->XML Catalog and defining a new dtd or
schema entry, then going to Window->Preferences->Voice->Catalog Defaults and
selecting your new schema/dtd as the one to use with new CCXML files.
I'm curious, do you know of a freely available DTD that has the proper tag
set?
"Yuming Liu" <yliu@m1global.com> wrote in message
news:97865aed3e694948cd867bd651feaa5f$1@www.eclipse.org...
> stabdards v1.0.
> <ccxma>
> <eventhandler>
> ... </venthandler>
> </ccxml>
> xsd files?
> Thanks.
Re: CCXML editor invalidates valid CCXML codes [message #12554 is a reply to message #12534] Fri, 17 March 2006 16:58 Go to previous message
I may have to take this back. According to the working draft on w3c.org the
tag you mention was renamed (see Changes in Last Call Working Draft):
"Update references of <eventhandler> to <eventprocessor>. (All)"
The confusion in the spec is that they seemed to have done an incomplete job
replacing the name; there are a lot of </eventhandler> entries remaining and
a lot of uses of the phrase eventhandler in the middle of sentences.
I'm going to close that bug; if anything else is missing we will reopen.
"Brent D. Metz" <bmetz@yahoo.com> wrote in message
news:dvfb33$oqo$1@utils.eclipse.org...
> this is a problem. I will open a bugzilla to track this problem, which you
> can add yourself to:
> and selecting your new schema/dtd as the one to use with new CCXML files.
> set?
>> stabdards v1.0.
>> <ccxma>
>> <eventhandler>
>> ... </venthandler>
>> </ccxml>
>> which "eventhandler" is not even defined.
>> xsd files?
>> Thanks.
Re: CCXML editor invalidates valid CCXML codes [message #573922 is a reply to message #12512] Fri, 17 March 2006 16:52 Go to previous message
add yourself to:
set?
> stabdards v1.0.
> <ccxma>
> <eventhandler>
> ... </venthandler>
> </ccxml>
> xsd files?
> Thanks.
Re: CCXML editor invalidates valid CCXML codes [message #573945 is a reply to message #12534] Fri, 17 March 2006 16:58 Go to previous message
> set?
>> stabdards v1.0.
>> <ccxma>
>> <eventhandler>
>> ... </venthandler>
>> </ccxml>
>> xsd files?
>> Thanks.
Previous Topic:Stopping an IVoiceXMLBrowser implementation
Next Topic:Observations on extending the VTP
Current Time: Fri Jul 18 02:07:08 EDT 2025
Powered by FUDForum. Page generated in 0.50069 seconds
