| CCXML editor invalidates valid CCXML codes [message #12512] |
Fri, 17 March 2006 15:24  |
Originally posted by: yliu.m1global.com
The VTP CCXML editor invalidates CCXML codes which comply to W3C CCXML
stabdards v1.0.
It appears only follow the DTD: http://www.w3c.org/TR/ccxml/ccxml.dtd
which does not encompass the entire stabdard.
For example, the editor invalidates the following code:
<ccxma>
<eventhandler>
</venthandler>
</ccxml>
It displays a syntax hint according to the above mentioned DTD -- in which
"eventhandler" is not even defined.
How the CCXML editor perform syntax check and code completion?
May we add more name spaces -- DTD? in case of W3C CCXML standards, using
xsd files?
Or maybe even ABNF files?
Thanks.
| Re: CCXML editor invalidates valid CCXML codes [message #12554 is a reply to message #12534] |
Fri, 17 March 2006 16:58  |
I may have to take this back. According to the working draft on w3c.org the
tag you mention was renamed (see Changes in Last Call Working Draft):
"Update references of <eventhandler> to <eventprocessor>. (All)"
The confusion in the spec is that they seemed to have done an incomplete job
replacing the name; there are a lot of </eventhandler> entries remaining and
a lot of uses of the phrase eventhandler in the middle of sentences.
I'm going to close that bug; if anything else is missing we will reopen.
"Brent D. Metz" <bmetz@yahoo.com> wrote in message
news:dvfb33$oqo$1@utils.eclipse.org...
> You're right, thanks for catching this inconsistency. You are correct that
> it uses the DTD on w3c.org as its source of what is the correct tag and
> attribute set. I am not sure why they are not up to date but obviously
> this is a problem. I will open a bugzilla to track this problem, which you
> can add yourself to:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=132404
> It is possible to define your own schema or DTD to use by going into
> Window->Preferences->Web and XML->XML Catalog and defining a new dtd or
> schema entry, then going to Window->Preferences->Voice->Catalog Defaults
> and selecting your new schema/dtd as the one to use with new CCXML files.
> I'm curious, do you know of a freely available DTD that has the proper tag
> set?
> "Yuming Liu" <yliu@m1global.com> wrote in message
> news:97865aed3e694948cd867bd651feaa5f$1@www.eclipse.org...
>> stabdards v1.0.
>> <ccxma>
>> <eventhandler>
>> ... </venthandler>
>> </ccxml>
>> which "eventhandler" is not even defined.
>> xsd files?
>> Thanks.
| Re: CCXML editor invalidates valid CCXML codes [message #573922 is a reply to message #12512] |
Fri, 17 March 2006 16:52  |
attribute set. I am not sure why they are not up to date but obviously this
is a problem. I will open a bugzilla to track this problem, which you can
add yourself to:
schema entry, then going to Window->Preferences->Voice->Catalog Defaults and
set?
> stabdards v1.0.
> <ccxma>
> <eventhandler>
> ... </venthandler>
> </ccxml>
> xsd files?
> Thanks.
| Re: CCXML editor invalidates valid CCXML codes [message #573945 is a reply to message #12534] |
> set?
>> stabdards v1.0.
>> <ccxma>
>> <eventhandler>
>> ... </venthandler>
>> </ccxml>
>> xsd files?
>> Thanks.
FUDForum. Page generated in 0.05961 seconds
