Home » Eclipse Projects » GEF » adding layer
adding layer [message #136055] Thu, 03 June 2004 14:51 Go to next message
i wish to add a background graphic to my entire diagram.
to do this, i figured i could add a new layer to the ScalableRootEditPart.
i thought this would cause the least refresh of this graphic, and also
have the benefit of not being part of the printed diagram since i can put
the graphic on a layer below the PrintLayer.
i do, however, need a way to update this graphic, so i also need a way to
refresh the layer.
is there a way to add a layer to the layer pane of the
ScalableRootEditPart, or should i subclass it.
i am currently using the 2.x code. if there is something in 3.0, i can
upgrade.
or am i completely barking up the wrong tree?
thanks,
steve
Re: adding layer [message #136327 is a reply to message #136055] Fri, 04 June 2004 16:06 Go to previous messageGo to next message
Why can't your contents editpart just paint the image on its figure? You
could also add a layer, but then you need a "glass" primary layer so you can
see it. Do you want the image to scroll?
"Steven Melzer" <smelzer@paymentech.com> wrote in message
news:c9ns0b$3m5$1@eclipse.org...
> refresh the layer.
> upgrade.
> thanks,
> steve
Re: adding layer [message #136390 is a reply to message #136327] Fri, 04 June 2004 22:27 Go to previous messageGo to next message
i can easily add the image to the content edit part. i was just concerned
that the diagram (meaning my background image) may be redrawn when
children are redrawn which seemed like a lot of overhead.
as for the printing part, i assume i can draw the children on an offscreen
image and print the offscreen image, thus not printing the diagram
background image.
steve
> > refresh the layer.
> > upgrade.
> > thanks,
> > steve
Re: adding layer [message #136713 is a reply to message #136390] Mon, 07 June 2004 10:49 Go to previous messageGo to next message
You can also just set a flag termporarily on your contents figure telling it
not to draw its background image.
"steven melzer" <steven.melzer@verizon.net> wrote in message
news:c9rb1r$v57$1@eclipse.org...
> background image.
> steve
You
can
also
put
to
> > > refresh the layer.
can
> > > upgrade.
> > > thanks,
> > > steve
Re: adding layer [message #137789 is a reply to message #136713] Fri, 11 June 2004 08:39 Go to previous message
in the end i decided to add a new layer because i wanted the grid to
appear on top of the image, not behind it (and i was curious to try it).
i subclassed ScalableRootEditPart to add an additional layer to the
ScaledLayer and changed createGridLayer to create my subclass of
GridLayer, and it works very well. it was actually pretty easy.
i now have a white, shadowed "page" and a colored background, and the grid
only shows in the page, not the whole view.
thanks,
steve
> > background image.
> > steve
> You
> can
> also
> put
> to
> > > > refresh the layer.
> can
> > > > upgrade.
> > > > thanks,
> > > > steve
Previous Topic:Automatic Routing of Connections
Next Topic:Add TextField-like-Component to Draw2d-Figure ?
Current Time: Wed Nov 05 04:24:00 EST 2025
Powered by FUDForum. Page generated in 0.16444 seconds
