Home » Language IDEs » C / C++ IDE (CDT) » Where is the Task list Saved, is there a backup available ?
Where is the Task list Saved, is there a backup available ? [message #136015] Mon, 24 January 2005 04:45 Go to next message
Originally posted by: qn.nym.us
Hi in which file can i find the task list entries ?
Is there a backup avaiable of this file ?
Tanks Sascha
Re: Where is the Task list Saved, is there a backup available ? [message #136244 is a reply to message #136015] Mon, 24 January 2005 12:12 Go to previous message
Are you referring to the Task View ?
Tasks are Markers, they are set by different components.
For example JDT looks for "TODO/FIXME"(configurable) in comments
and when the pattern is found put a maker of type task.
We done this in the past for the CDT but the code was removed.
The problem is that the parser after the preprocessing stage ...
remove the comments.
For more Info see the IMarker class in the Eclipse platform
Previous Topic:Recenter command
Next Topic:profiling support under windows?
Current Time: Wed Nov 19 23:57:07 EST 2025
Powered by FUDForum. Page generated in 0.03598 seconds
