Home » Eclipse Projects » Eclipse Platform » workspace - project question
workspace - project question [message #135805] Thu, 25 September 2003 07:21 Go to next message
Originally posted by: dario._nospam_necco.net
how am i supposed to work many unrelated projects? for example i created one
project's run time settings, and then created another one only to see that i
till have first project's run icon to select from run menu.
it could be desired if projects are related somhow, but if i have many
completely unrelated projects, having them sahre the same workspace is not
very neat.
is there anything i am missing besides "-data" command line parameter.
thanx
dario
Re: workspace - project question [message #135917 is a reply to message #135805] Thu, 25 September 2003 10:44 Go to previous message
Originally posted by: richkulp.NO--SPAM.us.ibm.com
You can have as many launch configurations on the run icon as you wish.
One for each main in your entire workspace, if you like. All of them
will show and you just pick the one you are interested in at that time.
There is no problem with unrelated launches being shown.
However, if you want to keep everything totally separate, then you need
to use separate workspaces, which is what the -data is for. The problem
with that is your common preferences will need to be set in each
workspace, rather than sharing them all in one workspace.
Rich
Previous Topic:Accessing added jars from a plugin
Next Topic:Parse Errors On First Help System Search
Current Time: Sun Aug 31 13:34:33 EDT 2025
Powered by FUDForum. Page generated in 0.02939 seconds
