Eclipse UI SWE TIBCO Software [message #12452] |
Mon, 15 January 2007 17:45 |
Originally posted by: ashort.tibco.com
Software Engineer Eclipse UI Developer
Job Location - TIBCO Software, Palo Alto, Ca.
Job Description: This software engineer will be a key contributor to the
development of Eclipse user interface for TIBCOs state-of-the-art SOA
Platform. The individual will work with senior engineering architect and
user interface designer to develop an easy to use design-time tool.
This software engineer will be expected to perform the following
tasks/assignments:
Implement the assigned Eclipse user interface components
Unit test the assigned Eclipse user interface components
Work with QA manager and engineers on test planning. E.g. help identify
test cases and suggest appropriate test environment. Actual test plan,
test specs and regression tests are owned by the QA engineers
Work with QA engineers to reproduce reported defect when necessary and
to provide code fix for the defects
Required Skills: The following skills / experience background are
required:
BS in Computer Science or related Engineering major
3+ years of Java software development experience
1+ years of Eclipse UI development experience
Eclipse SWT/JFace development experience
Experience and knowledge of UI design patterns. For example,
drag-and-drop, layout management, keyboard handling, handling of large
and/or complex data set
Experienced user of ANT and JUnit
Excellent verbal and written communication skills
Optional Skills: The following skills / experience background are
optional but desirable:
Java Swing UI development experience
Eclipse EMF, RCP and Plug-in development experience a big plus
XML technologies
UNIX (Solaris, AIX, HP-UX, Linux) and Windows (2000/ 2003) operating
systems experience
Please reply to: ashort@tibco.com
FUDForum. Page generated in 0.03529 seconds
