Home » Archived » Test and Performance Tools Platform (TPTP) » Newbie question about reading in xmi models
Newbie question about reading in xmi models [message #12442] Mon, 28 March 2005 15:14 Go to next message
Originally posted by: colemanj.ca.ibm.com
I'm trying to read in the output produced by Rational Performance Tester
(which uses the Hyades Common, Hierarchy and Statistical models) so that I
can convert it to a custom xml format I've defined. The RPT output
consists of 5 files, an execution file (TPFExecutionResult) plus trcaxmi,
trcmxmi, trcnxmi and trcpxmi files (for TRCAgent, TRCMonitor, TRCNode, and
TRCProcessProxy). I think I have to create a fileURI for each file, then
do something like:
Resource resource1 = new XMLResourceImpl(fileURI1);
resource1.load(null);
for each fileURI. But what happens after I've loaded all 5 models? How
do I iterate through the execution file (which contains all the actual
data)? Thanks a lot for any advice you can give.
Re: Newbie question about reading in xmi models [message #14349 is a reply to message #12442] Wed, 06 April 2005 13:17 Go to previous messageGo to next message
Hi Joice,
You need to load only the execution result file and iterate through it's
content.
Use one of
test/org.eclipse.hyades.test.core/src/org/eclipse/hyades/tes t/core/util/EMFU
til.load() methods (from TPTP cvs) to load the execution result resource.
You need to run your code from a plugin (headless or not), to run it from a
Java standalone application the setup is more complicated.
Take a look at:
test/org.eclipse.hyades.test.tools.ui/src/org/eclipse/hyades /test/tools/ui/c
ommon/internal/report/jscrib/ReportDataUtils.java
in TPTP CVS for an example on how to navigate the execution result side of
the test model.
Please let me know if you have any problems.
Marius
"Joyce" <colemanj@ca.ibm.com> wrote in message
news:a9fdb6cbd1fe34f244f5d95a605de6e2$1@www.eclipse.org...
> do something like:
Re: Newbie question about reading in xmi models [message #25162 is a reply to message #14349] Thu, 04 August 2005 11:29 Go to previous message
Originally posted by: yliu.m1global.com
Could you give an example how to set up to run stand-alone?
I tried:
ResourceSet resourceSet = new ResourceSetImpl();
EPackage.Registry ePackage = EPackage.Registry.INSTANCE;
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(
Resource.Factory.Registry.DEFAULT_EXTENSION, // "*"
new XMIResourceFactoryImpl());
then:
URI uri = URI.createFileURI("e:/HyadesTests/results/TestRun1.execution ");
Resource rs = resouceSet.getResource(uri, true); --> exception!
exception:
"org.xml.sax.SAXParseException: Content is not allowed in prolog."
(Eclipse3.0.2, Haydes3.3.0)
Thanks.
Previous Topic:some problems about CBE&GLA
Next Topic:New TPTP "News" Mailing List Created
Current Time: Sat Jul 12 18:37:59 EDT 2025
Powered by FUDForum. Page generated in 0.04416 seconds
