Home » Language IDEs » C / C++ IDE (CDT) » cdt 2.0 mac osx no binary when complile
cdt 2.0 mac osx no binary when complile [message #135323] Tue, 18 January 2005 10:32 Go to next message
Originally posted by: gahr.geo.uni-koeln.de
Hi I installed, eclipse and the cdt.
Ok great tool. Everything works fine. My simple Hello World program
compiles and i can run it from the command line. But if i try to run it
from eclipse, it just said that there is no binary file.
I try'd now every binary parser (which is the right one for osx (*nix
BSD-sytem)?) But nothing happend.
What can i do. I want to use this great tool also for running and
debugging.
Thanks Lex
Re: cdt 2.0 mac osx no binary when complile [message #135376 is a reply to message #135323] Tue, 18 January 2005 10:56 Go to previous messageGo to next message
Originally posted by: gwatson.lanl.gov
Alexander Gahr wrote:
> Hi I installed, eclipse and the cdt. Ok great tool. Everything works
> fine. My simple Hello World program compiles and i can run it from the
> command line. But if i try to run it from eclipse, it just said that
> debugging.
> Thanks Lex
This is fixed in CDT 2.1. I suggest using this version.
Greg
Re: cdt 2.0 mac osx no binary when complile [message #135400 is a reply to message #135376] Tue, 18 January 2005 11:12 Go to previous messageGo to next message
>> debugging.
>> Thanks Lex
> Greg
It's ok now. There was only the problem that you can't install the ctd 2.1
from software update.
Thanks a lot.
Re: cdt 2.0 mac osx no binary when complile [message #135451 is a reply to message #135400] Tue, 18 January 2005 11:59 Go to previous messageGo to next message
Originally posted by: roelandm.roelandmeyer.org
Eh? I installed from update just fine. You do have to jigger the config to
allow "compatible" updates though.
"Alexander Gahr" <gahr@geo.uni-koeln.de> wrote in message
news:csjcgq$c7n$1@www.eclipse.org...
> >> debugging.
> >> Thanks Lex
> > Greg
> Thanks a lot.
Re: cdt 2.0 mac osx no binary when complile [message #135631 is a reply to message #135451] Wed, 19 January 2005 18:07 Go to previous messageGo to next message
Originally posted by: JohnsonM.central.edu
Was that using OS X? I get an error trying to retrieve
org.eclise.cdt.source.macosx.carbon.ppc_2.1.0.jar
The downloads page also is still not listing OS X versions. Any ideas?
Mark Johnson
Central College
>>>> debugging.
>>>> Thanks Lex
>>> Greg
>> Thanks a lot.
Re: cdt 2.0 mac osx no binary when complile [message #135656 is a reply to message #135631] Thu, 20 January 2005 08:07 Go to previous message
I tried the same but I get an error too even if I cange the update setting
like said before.
It would be fine if someone could fix this.
Grettings Lex
> Mark Johnson
> Central College
>>>>> debugging.
>>>>> Thanks Lex
>>>> Greg
>>> Thanks a lot.
Previous Topic:Create session error on debuging with GDB 6.3
Next Topic:What's going on when I save a file???
Current Time: Fri Nov 07 11:47:46 EST 2025
Powered by FUDForum. Page generated in 0.04165 seconds
