Relative bendpoint positioning [message #135307] |
Tue, 01 June 2004 06:58  |
In my diagram I have a container akin to "circuits" in the logic example.
When I add nodes to the container I store in the model the relative
positioning of the nodes using:
parent.getFigure().translateToRelative(location);
Assuming that parent always return the container. This works well - when
I move the container, the contents remain relative.
I now wish to be able to add edges and waypoints (connections and anchors)
into the container. While edges are straightfoward, waypoints are posing
some difficulty. Unfortunately I cannot use the same approach as nodes
above to find the relative positioning of waypoints since editparts for
edges are parented by the connection layer and not their logical container.
Looking at the logic example I see that RelativeBendpoint is used (whereas
I'm using AbsoluteBendpoint). However, in order to use this I would need
to change my model in order to accomodate the storing of the two
dimensions. I would really like to avoid changing the model at all costs.
Does anyone have any suggestion to how I might solve this problem?
James
Re: Relative bendpoint positioning [message #135384 is a reply to message #135307] |
Tue, 01 June 2004 14:21  |
You could make the bendpoints relative to the "lowest-common-ancestor". So
if two parts have the same "circuit" parent, the bendpoints could be stored
relative to that circuit. If they have nothing in common, the bendpoint is
relative to the diagram. However, reparenting of nodes would become tricky.
Also, how would you migrate existing documents to this new convention?
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:c9hngu$7e2$1@eclipse.org...
container.
> James
FUDForum. Page generated in 0.03137 seconds
