Home » Modeling » TMF (Xtext) » Re: [TCS] Problem with running TCS
| Re: [TCS] Problem with running TCS [message #12426] |
Tue, 29 April 2008 05:04  |
As stated on http://wiki.eclipse.org/TCS: the TCS toolkit worked with
older versions of ATL and AM3.
You should now use the language wizard and builder:
http://wiki.eclipse.org/TCS/Language_Project#Creating_a_Lang uage_Project_For_Plugin_Builder
Frédéric Jouault
Marcin Jakubowski a écrit :
> Hi, all!
> I posted last message without the proper title so I decided to write again:
> I have a problem with running TCS. I try to start with TCS Toolkit with
> sample posted on wiki. I read throughout the newsportal and found out
> that there are some problems with versioning of the branches on CVS. At
> this moment I have packages in configuration mentioned below the
> message. Everything compiles. I have added mdr libraries. I exported
> plugins to the seperate jars and added them to my eclipse plugins
> directory. Perspectives and tools seem to run properly. While running
> TCS Sample (SampleDSL_ExtractorCreation.xml and
> SampleDSL_InjectorCreation.xml especially) I found out that
> TCS-parser.jar and KM3-parser.jar are different in resources of
> org.eclipse.am3.core and org.eclipse.gmt.tcs.dsls, so I have replaced
> that from am3.core with newer ones from tcs.dsls (together with
> TCS.ecore). After that SampleDSL_ExtractorCreation.xml seems to work
> properly but Injector not... I got an exception that:
> [am3.loadModel] java.lang.RuntimeException: feature isDeep does not
> exist on TCS!ClassTemplate
> [am3.loadModel] at
> org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:263)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.ASMModelAdapter.actualSet(ASMMo delAdapter.java:49)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.ASMModelAdapter.set(ASMModelAda pter.java:88)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.TCSRuntime.set(TCSRuntime.java: 145)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.TCS_ANTLR3Parser.classTemplate( TCS_ANTLR3Parser.java:2840)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.TCS_ANTLR3Parser.template(TCS_A NTLR3Parser.java:2010)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.TCS_ANTLR3Parser.concreteSyntax (TCS_ANTLR3Parser.java:1454)
> [am3.loadModel] at
> org.eclipse.gmt.tcs.injector.TCS_ANTLR3Parser.main(TCS_ANTLR 3Parser.java:121)
> after that:
> [am3.saveModel] org.eclipse.gmt.tcs.extractor.TCSExtractionException:
> cannot find mathing template for: SimpleSemanticAction
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.PrettyPrinter.serialize(Pretty Printer.java:215)
> in the end builds is failed.
> I would really appreciate fast response so that somebody could give me a
> hint what I am doing wrong. I need to have this tool running as soon as
> possible. Below is information about my packages and their branching.
> Thanks in advance,
> Martin Jakubowski
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/tools,org.eclipse.orbi t/org.antlr.runtime,org.antlr.runtime,v3_0_0 "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.core,org.eclipse.am3.core "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.tools.tge,org.eclipse.am3.tools.tge "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.ui,org.eclipse.am3.ui "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlantEcore,org.eclipse.am3.zo os.atlantEcore "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlantic,org.eclipse.am3.zoos. atlantic "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticAsmL,org.eclipse.am3.z oos.atlanticAsmL "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticDSLTools,org.eclipse.a m3.zoos.atlanticDSLTools "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticEmfatic,org.eclipse.am 3.zoos.atlanticEmfatic "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticGME,org.eclipse.am3.zo os.atlanticGME "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticMisc,org.eclipse.am3.z oos.atlanticMisc "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticOWL,org.eclipse.am3.zo os.atlanticOWL "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticRaster,org.eclipse.am3 .zoos.atlanticRaster "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticSQLDDL,org.eclipse.am3 .zoos.atlanticSQLDDL "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticUML,org.eclipse.am3.zo os.atlanticUML "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticVB,org.eclipse.am3.zoo s.atlanticVB "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticXASM,org.eclipse.am3.z oos.atlanticXASM "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlanticXML,org.eclipse.am3.zo os.atlanticXML "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.atlantMOF_MDR,org.eclipse.am3. zoos.atlantMOF_MDR "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.am3.zoos.biblio,org.eclipse.am3.zoos.bi blio "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare,o rg.eclipse.emf.compare "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare-f eature,org.eclipse.emf.compare-feature "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare.d iff,org.eclipse.emf.compare.diff "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare.d iff.edit,org.eclipse.emf.compare.diff.edit "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare.m atch,org.eclipse.emf.compare.match "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare.s dk-feature,org.eclipse.emf.compare.sdk-feature "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare.s ource,org.eclipse.emf.compare.source "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf.compare/plugins/org.eclipse.emf.compare.u i,org.eclipse.emf.compare.ui "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3,org.eclipse.gmt.am3 "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.gmt.am3-feature,org.eclipse.gmt.am3-fea ture "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.core,org.eclipse.gmt.am 3.core "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.gmt.am3.dsls-feature,org.eclipse.gmt.am 3.dsls-feature "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.gmt.am3.dsls.km3,org.eclipse.gmt.am3.ds ls.km3 "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.extractor.launchers,org .eclipse.gmt.am3.extractor.launchers "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.modelhandler.emf,org.ec lipse.gmt.am3.modelhandler.emf "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.modelhandler.mdr,org.ec lipse.gmt.am3.modelhandler.mdr "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.core,org.eclip se.gmt.am3.platform.core "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.extensions.Glo balModelManagement,org.eclipse.gmt.am3.platform.extensions.G lobalModelManagement "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.extensions.GMM 4AMW,org.eclipse.gmt.am3.platform.extensions.GMM4AMW "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.extensions.GMM 4ASM,org.eclipse.gmt.am3.platform.extensions.GMM4ASM "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.extensions.GMM 4ATL,org.eclipse.gmt.am3.platform.extensions.GMM4ATL "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.runtime.core,o rg.eclipse.gmt.am3.platform.runtime.core "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.platform.ui,org.eclipse .gmt.am3.platform.ui "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/plugins/org.eclipse.gmt.am3.repository.lightweight, org.eclipse.gmt.am3.repository.lightweight "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/AM3/org.eclipse.gmt.am3.tools.ant,org.eclipse.gmt.am3.t ools.ant "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs,org.ecl ipse.gmt.tcs "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs-feature ,org.eclipse.gmt.tcs-feature "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.actions ,org.eclipse.gmt.tcs.actions "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.builder ,org.eclipse.gmt.tcs.builder "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.dsls,or g.eclipse.gmt.tcs.dsls "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.emfreso urce,org.eclipse.gmt.tcs.emfresource "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.extract or,org.eclipse.gmt.tcs.extractor "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.injecto r,org.eclipse.gmt.tcs.injector "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.metadat a,org.eclipse.gmt.tcs.metadata "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .gmt/org.eclipse.gmt.tcs/plugins/org.eclipse.gmt.tcs.wizard, org.eclipse.gmt.tcs.wizard "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl,org.eclip se.m2m.atl,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl-feature,o rg.eclipse.m2m.atl-feature,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt-featu re,org.eclipse.m2m.atl.adt-feature,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.build er,org.eclipse.m2m.atl.adt.builder,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.debug ,org.eclipse.m2m.atl.adt.debug,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.edito r,org.eclipse.m2m.atl.adt.editor,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.persp ective,org.eclipse.m2m.atl.adt.perspective,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.wizar d,org.eclipse.m2m.atl.adt.wizard,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.compilers .atl2006,org.eclipse.m2m.atl.compilers.atl2006,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.drivers.e mf4atl,org.eclipse.m2m.atl.drivers.emf4atl,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.drivers.m dr4atl,org.eclipse.m2m.atl.drivers.mdr4atl "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.drivers.m dr4atl-feature,org.eclipse.m2m.atl.drivers.mdr4atl-feature "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.drivers.u ml24atl,org.eclipse.m2m.atl.drivers.uml24atl,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.dsls,org. eclipse.m2m.atl.dsls "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine,or g.eclipse.m2m.atl.engine,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine-fe ature,org.eclipse.m2m.atl.engine-feature,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine.em fvm,org.eclipse.m2m.atl.engine.emfvm,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine.vm ,org.eclipse.m2m.atl.engine.vm,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/examples/org.eclipse.m2m.atl.examples ,org.eclipse.m2m.atl.examples,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/examples/org.eclipse.m2m.atl.examples -feature,org.eclipse.m2m.atl.examples-feature,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.ocl.core, org.eclipse.m2m.atl.ocl.core,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.sdk-featu re,org.eclipse.m2m.atl.sdk-feature,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.service.c ore,org.eclipse.m2m.atl.service.core,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/tests/org.eclipse.m2m.atl.tests,org.e clipse.m2m.atl.tests,R2_1_0_dev "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.m 2m/org.eclipse.m2m.atl/tests/org.eclipse.m2m.atl.tests-featu re,org.eclipse.m2m.atl.tests-feature,R2_1_0_dev "/>
| Re: [TCS] Problem with running TCS [message #14405 is a reply to message #12426] |
Thu, 01 May 2008 12:34  |
Originally posted by: mjakubowski84.gmail.com
Well, thanks, but I already knew that - as it was stated in my post. I was
dealing with a great mess in CVS but, fortunately, I succeeded to run TCS.
The biggest problem was with choosing appropriate projects from correct
branches, finding projects not mentioned in psf files, locating missing
libraries/files in AMMA or libraries of different versions in ATL and AM3
(for example TCS-Parser.jar). Problem is also with that, but it can be
understood, that tool is being still developed and there can be found bugs
that prevent from running tool correctly.
Kind regards,
Marcin Jakubowski
Current Time: Thu Nov 20 21:25:11 EST 2025
Powered by FUDForum. Page generated in 0.03423 seconds
