Home » Language IDEs » Java Development Tools (JDT) » CanŽt create java project (new to eclipse)
CanŽt create java project (new to eclipse) [message #135230] Fri, 16 January 2004 01:19 Go to next message
Originally posted by: holger.burbach.otelo-online.de
I have installed Eclipse V2.1.2 and j2sdk1.4.2_03 under Windows 98.
When starting Eclipse I use the -vm option with the correct path.
When I click on File->New->Project I am only offered 'simple' as possible
projects. How can I create java projects or plug-in development projects?
Thanks for all answers.
Re: Can [message #135319 is a reply to message #135230] Fri, 16 January 2004 04:35 Go to previous messageGo to next message
You need to download the Eclipse SDK, not the Eclipse Platform only.
Jerome
"Holger Burbach" <holger.burbach@otelo-online.de> wrote in message
news:bu7vpl$np9$1@eclipse.org...
Re: Can [message #135398 is a reply to message #135230] Fri, 16 January 2004 10:18 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Fri, 16 Jan 2004 06:19:33 +0000 (UTC),
Are you sure that you don't have a Platform drop? It doesn't contain
the JDT components.
Also check in your .metadata directory if you don't have something in
your .log file.
Olivier
Re: CanŽt create java project (new to eclipse) [message #135511 is a reply to message #135230] Fri, 16 January 2004 17:48 Go to previous message
Holger Burbach wrote:
Now I have detected the problem. I missed the minor fact that there is a
difference between the two Eclipse V2.1.2 links on the download page
http://www.eclipse.org/downloads/index.php (and the german mirror).
The build date of both links is exactly the same which suggests that it
doesnŽt matter which one to choose. I happended to chooose the wrong one.
I think it would be a good idea to mention the difference on download page.
Does anyone know, where I can e-mail this suggestion?
Previous Topic:Method separator lines
Next Topic:clone jar settings from existing project to new project
Current Time: Wed Nov 05 22:42:32 EST 2025
Powered by FUDForum. Page generated in 0.03431 seconds
