Home » Eclipse Projects » Eclipse Platform » Eclipse crash at startup after update to JVM 1.4.2
Eclipse crash at startup after update to JVM 1.4.2 [message #135211] |
Wed, 24 September 2003 11:39  |
Originally posted by: maxcalipari.xxxxxxxxx.it
Hi, i've just updated mi JVM to 1.4.2 and now eclipse crash at startup!
here is the log:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77D38E45
Function=MapVirtualKeyExW+0x26
Library=C:\WINDOWS\system32\USER32.dll
Current Java thread:
at org.eclipse.swt.internal.win32.OS.DrawTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.DrawText(OS.java:1320)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1242)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1194)
at org.eclipse.swt.custom.CLabel.onPaint(CLabel.java:394)
at org.eclipse.swt.custom.CLabel.access$0(CLabel.java:297)
at org.eclipse.swt.custom.CLabel$1.paintControl(CLabel.java:102 )
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:80)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:861)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:845)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:72 6)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2811 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2283 )
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.j ava:1127)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1007)
at org.eclipse.swt.widgets.Shell.open(Shell.java:679)
at org.eclipse.jface.window.Window.open(Window.java:553)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:428)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1287)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 221)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1139 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:867)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:1091)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:868)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1371)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Dynamic libraries:
0x00400000 - 0x00407000 C:\WINDOWS\system32\javaw.exe
0x77F40000 - 0x77FED000 C:\WINDOWS\System32\ntdll.dll
0x77E40000 - 0x77F31000 C:\WINDOWS\system32\kernel32.dll
0x77DA0000 - 0x77E3D000 C:\WINDOWS\system32\ADVAPI32.dll
0x78000000 - 0x78086000 C:\WINDOWS\system32\RPCRT4.dll
0x77D10000 - 0x77D9C000 C:\WINDOWS\system32\USER32.dll
0x77C40000 - 0x77C80000 C:\WINDOWS\system32\GDI32.dll
0x77BE0000 - 0x77C33000 C:\WINDOWS\system32\MSVCRT.dll
0x08000000 - 0x08136000 C:\Programmi\Java\j2re1.4.2\bin\client\jvm.dll
0x76B00000 - 0x76B2D000 C:\WINDOWS\system32\WINMM.dll
0x10000000 - 0x10007000 C:\Programmi\Java\j2re1.4.2\bin\hpi.dll
0x00820000 - 0x0082E000 C:\Programmi\Java\j2re1.4.2\bin\verify.dll
0x00830000 - 0x00848000 C:\Programmi\Java\j2re1.4.2\bin\java.dll
0x00850000 - 0x0085D000 C:\Programmi\Java\j2re1.4.2\bin\zip.dll
0x03270000 - 0x03278000
E:\eclipse\plugins\org.eclipse.core.resources.win32_2.1.0\os \win32\x86\core_2_1_0a.dll
0x03390000 - 0x033D7000
E:\eclipse\plugins\org.eclipse.swt.win32_2.1.0\os\win32\x86\ swt-win32-2132.dll
0x77180000 - 0x772A1000 C:\WINDOWS\system32\ole32.dll
0x77310000 - 0x7739B000 C:\WINDOWS\system32\COMCTL32.dll
0x76360000 - 0x763A6000 C:\WINDOWS\system32\comdlg32.dll
0x033E0000 - 0x03444000 C:\WINDOWS\system32\SHLWAPI.dll
0x773A0000 - 0x77B9E000 C:\WINDOWS\system32\SHELL32.dll
0x770F0000 - 0x7717B000 C:\WINDOWS\system32\OLEAUT32.dll
0x76340000 - 0x7635C000 C:\WINDOWS\system32\IMM32.dll
0x78090000 - 0x78174000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595 b64144ccf1df_6.0.10.0_x-ww_f7fb5805\comctl32.dll
0x5B180000 - 0x5B1B4000 C:\WINDOWS\System32\uxtheme.dll
0x746B0000 - 0x746F4000 C:\WINDOWS\System32\MSCTF.dll
0x74C10000 - 0x74C3C000 C:\WINDOWS\system32\oleacc.dll
0x76030000 - 0x76091000 C:\WINDOWS\system32\MSVCP60.dll
0x76C50000 - 0x76C72000 C:\WINDOWS\system32\imagehlp.dll
0x6DA30000 - 0x6DAAD000 C:\WINDOWS\system32\DBGHELP.dll
0x77BD0000 - 0x77BD7000 C:\WINDOWS\system32\VERSION.dll
0x76BB0000 - 0x76BBB000 C:\WINDOWS\system32\PSAPI.DLL
Heap at VM Abort:
Heap
def new generation total 576K, used 339K [0x10010000, 0x100b0000,
0x104f0000)
eden space 512K, 57% used [0x10010000, 0x10059be8, 0x10090000)
from space 64K, 69% used [0x100a0000, 0x100ab108, 0x100b0000)
to space 64K, 0% used [0x10090000, 0x10090000, 0x100a0000)
tenured generation total 5472K, used 3999K [0x104f0000, 0x10a48000,
0x14010000)
the space 5472K, 73% used [0x104f0000, 0x108d7d08, 0x108d7e00,
0x10a48000)
compacting perm gen total 14848K, used 14602K [0x14010000, 0x14e90000,
0x18010000)
the space 14848K, 98% used [0x14010000, 0x14e52af8, 0x14e52c00,
0x14e90000)
Local Time = Wed Sep 24 17:14:40 2003
Elapsed Time = 36
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2-b28 mixed mode)
Re: Eclipse crash at startup after update to JVM 1.4.2 [message #135277 is a reply to message #135211] |
Wed, 24 September 2003 11:51  |
Originally posted by: max.xxxxx.it
ooops.... i've just readed that my problem was a well know bug!!!
Sorry
> here is the log:
> PC=0x77D38E45
> Library=C:WINDOWSsystem32USER32.dll
> at
> at
> at
> at
> Dynamic libraries:
> 0x00400000 - 0x00407000 C:WINDOWSsystem32javaw.exe
> 0x77F40000 - 0x77FED000 C:WINDOWSSystem32ntdll.dll
> 0x77E40000 - 0x77F31000 C:WINDOWSsystem32kernel32.dll
> 0x77DA0000 - 0x77E3D000 C:WINDOWSsystem32ADVAPI32.dll
> 0x78000000 - 0x78086000 C:WINDOWSsystem32RPCRT4.dll
> 0x77D10000 - 0x77D9C000 C:WINDOWSsystem32USER32.dll
> 0x77C40000 - 0x77C80000 C:WINDOWSsystem32GDI32.dll
> 0x77BE0000 - 0x77C33000 C:WINDOWSsystem32MSVCRT.dll
> 0x08000000 - 0x08136000 C:ProgrammiJavaj2re1.4.2binclientjvm.dll
> 0x76B00000 - 0x76B2D000 C:WINDOWSsystem32WINMM.dll
> 0x10000000 - 0x10007000 C:ProgrammiJavaj2re1.4.2binhpi.dll
> 0x00820000 - 0x0082E000 C:ProgrammiJavaj2re1.4.2binverify.dll
> 0x00830000 - 0x00848000 C:ProgrammiJavaj2re1.4.2binjava.dll
> 0x00850000 - 0x0085D000 C:ProgrammiJavaj2re1.4.2binzip.dll
E:eclipsepluginsorg.eclipse.core.resources.win32_2.1.0oswin3 2x86core_2_1_0a.dll
> E:eclipsepluginsorg.eclipse.swt.win32_2.1.0oswin32x86swt-win 32-2132.dll
> 0x77180000 - 0x772A1000 C:WINDOWSsystem32ole32.dll
> 0x77310000 - 0x7739B000 C:WINDOWSsystem32COMCTL32.dll
> 0x76360000 - 0x763A6000 C:WINDOWSsystem32comdlg32.dll
> 0x033E0000 - 0x03444000 C:WINDOWSsystem32SHLWAPI.dll
> 0x773A0000 - 0x77B9E000 C:WINDOWSsystem32SHELL32.dll
> 0x770F0000 - 0x7717B000 C:WINDOWSsystem32OLEAUT32.dll
> 0x76340000 - 0x7635C000 C:WINDOWSsystem32IMM32.dll
C:WINDOWSWinSxSx86_Microsoft.Windows.Common-Controls_6595b64 144ccf1df_6.0.10.0_x-ww_f7fb5805comctl32.dll
> 0x5B180000 - 0x5B1B4000 C:WINDOWSSystem32uxtheme.dll
> 0x746B0000 - 0x746F4000 C:WINDOWSSystem32MSCTF.dll
> 0x74C10000 - 0x74C3C000 C:WINDOWSsystem32oleacc.dll
> 0x76030000 - 0x76091000 C:WINDOWSsystem32MSVCP60.dll
> 0x76C50000 - 0x76C72000 C:WINDOWSsystem32imagehlp.dll
> 0x6DA30000 - 0x6DAAD000 C:WINDOWSsystem32DBGHELP.dll
> 0x77BD0000 - 0x77BD7000 C:WINDOWSsystem32VERSION.dll
> 0x76BB0000 - 0x76BBB000 C:WINDOWSsystem32PSAPI.DLL
> Heap at VM Abort:
> Heap
> 0x104f0000)
> 0x14010000)
> 0x10a48000)
> 0x18010000)
> 0x14e90000)
> Elapsed Time = 36
Current Time: Thu Jul 17 19:59:07 EDT 2025
Powered by FUDForum. Page generated in 0.02607 seconds
