Profiling show no information when I use attach to an existing process method [message #135099] |
Wed, 27 August 2008 05:24  |
Hi.
I met issue when profiling my application.
I appreciate your any answer or tips.
I want to see why my app cost so many memory, so I launch an java
application out of eclipse with following arguments
-agentlib:JPIBootLoader=JPIAgent:server=controlled;HeapProf: allocsites=true
after it launched, I attach to it and at first I can get some log like
this:
------------------------------------------------------------ -------------------------------------START------------------ -
Process ID: 2684
Process command line:
Machine name: BENNY-DEV
Type Date Time TID Level Client Message
Informative 08/23/08 12:27:59 2324 0 CJVMTIInterface
Using JVMTI
Informative 08/23/08 12:30:10 2324 0
CJavaInstrumentorManager Using Martini Heap Instrumentation Technology
Informative 08/23/08 12:30:10 2324 3 CJVMTIInterface
[GetLineNumberTable] user-supplied buffer is too short. table size = 17,
buffer size = 1, buffer actual size = 17)
[GetLineNumberTable] user-supplied buffer is too short. table size = 24,
buffer size = 1, buffer actual size = 24)
Informative 08/23/08 12:30:11 2324 3 CJVMTIInterface
[GetLineNumberTable] user-supplied buffer is too short. table size = 4,
buffer size = 1, buffer actual size = 4)
[GetLineNumberTable] user-supplied buffer is too short. table size = 13,
buffer size = 1, buffer actual size = 13)
[GetLineNumberTable] user-supplied buffer is too short. table size = 5,
buffer size = 1, buffer actual size = 5)
[GetLineNumberTable] user-supplied buffer is too short. table size = 44,
buffer size = 1, buffer actual size = 44)
[GetLineNumberTable] user-supplied buffer is too short. table size = 18,
buffer size = 1, buffer actual size = 18)
... so many lines
------------------------------------------------------------ -------------------------------------END-------------------
and after some while, this log stop to grow and my app hung (at least
seems stop to run)
from the start to the end, I can not see anything from profiling monitor
view (I can see process when I launch profiling app from eclipse)
I am not sure what is the issue here. Could you help me?
Platform:
win2k3 SP 64bits
jdk1.5.11_b3 x86 version
eclipse 3.3.1.1
tptp platform 4.4.100
tptp monitoring tools project 4.4.2.v2
tptp tracing and profiling tool project 4.3.100
Re: Profiling show no information when I use attach to an existing process method [message #135326 is a reply to message #135099] |
Sun, 31 August 2008 09:21  |
Wu,
Please try to launch your application with the "server=standalone" option.
(e.g. -agentlib:JPIBootLoader=JPIAgent:server=standalone;HeapProf. ..)
This will cause the profiler to dump information to a file named
trace.trcxml in the current directory. Keep an eye on this file and let
me know whether it continues to grow or stops growing when your
application hangs.
If it keeps growing, it may indicate that the profiler generates too
much data that the workbench cannot process (in "controlled" mode). You
can try to set up some filters to reduce the amount of data collected.
(search this newsgroup for previous posts explaining how to define
filters...).
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
FUDForum. Page generated in 0.07165 seconds
