Home » Eclipse Projects » Eclipse Platform » Plug-In startup(?) problem
Plug-In startup(?) problem [message #135019] Wed, 24 September 2003 08:55 Go to next message
I have written three plug-ins (called
"de.uni.saarland.cs.st.{ddcore|ddcore.ui|isolate}"). The "isolate" plug-in
requires the "ddcore" plug-in, so I have set the appropriate dependencies
in the plugin.xml file. All three plug-ins compile fine, but when it comes
to execution, "isolate" tries to display a view. This view, however,
cannot be displayed, because a class in the "ddcore" plug-in cannot be
found. Now, I inserted the following lines before the error occurs
Plugin plug = Platform.getPlugin("de.uni.saarland.cs.st.ddcore");
System.out.println("plug == " + plug);
Plugin plug2 = Platform.getPlugin("de.uni.saarland.cs.st.ddcore.ui");
System.out.println("plug2 == " + plug2);
(And I also added a reference from "isolate" to "ddcore.ui" in the
plugin.xml, just to be on the safe side.)
The strange result is the output:
plug == null
plug2 == de.uni.saarland.cs.st.ddcore.ui
So, there is no de.uni.saarland.cs.st.ddcore plug-in in the plugin
registry, right?!
What does that mean? I suppose ddcore got shut-down due to an early
startup error? Could that be the case?
Note, that not even the constructor (or getDefault method) of the plug-in
class of ddcore are called.
I tried to add "ddcore" to early startup to see what happens, but all I
get is a "uncaught exception, reason uncaught exception" error...
Do you have an idea what this could mean? How can I trace down the error?
Oh -- one last thing: I stripped the "ddcore" plug-in class down to a
skeleton which only provides generation of the class and access via
getDefault() - no change: The error still occurs.
Thanks for any advice,
Philipp
Re: Plug-In startup(?) problem [message #135071 is a reply to message #135019] Wed, 24 September 2003 10:37 Go to previous messageGo to next message
An error occurred when Eclipse tries to activate your dd.core plugin
(constructor / startup code). Look at the error log for more details
(Window> Show View > Others -> PDE Runtime -> Error Log). The exception
should give you the line number where the error occurred.
HTH
Balaji
"Philipp Bouillon" <Philipp.Bouillon@t-online.de> wrote in message
news:bks483$ibf$1@eclipse.org...
> plug == null
> registry, right?!
> Philipp
Re: Plug-In startup(?) problem [message #135160 is a reply to message #135071] Wed, 24 September 2003 11:10 Go to previous messageGo to next message
thanks for your help! The log told me that the error occured in the
constructor of the "isolate" plug-in. The code of the constructor is shown
below.
java.lang.ClassNotFoundException:
de.uni.saarland.cs.st.ddcore.DeltaDebuggingPlugin
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:866)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:700)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:306)
org.eclipse.core.internal.runtime.InternalPlatform.getPlugin (InternalPlatform.java:405)
at org.eclipse.core.runtime.Platform.getPlugin(Platform.java:31 9)
de.uni.saarland.cs.st.isolateinput.IsolateInputPlugin.<init >(IsolateInputPlugin.java:60)
... (several more lines following).
The constructor:
public IsolateInputPlugin(IPluginDescriptor descriptor) {
super(descriptor);
// The next line causes the exception (IsolateInputPlugin.<init>:60)
So, I cannot find the ddcore plugin. But there is no hint in the error
log, _why_ the ddcore plugin could not be found.
I still cannot figure out, what's going on here... Do you have any further
ideas?
Philipp
> HTH
> Balaji
> > Hi,
> > plug == null
> > registry, right?!
> > Philipp
Re: Plug-In startup(?) problem [message #135185 is a reply to message #135160] Wed, 24 September 2003 11:24 Go to previous messageGo to next message
It seems like u don't have a dependency on dd.core project in your
plug-in.xml file. When you said you have updated the plug-in, do u have a
dd.core in the requires sub-element of plugin.xml
<requires>
<import plugin="de.uni.saarland.cs.st.ddcore"/>
HTH, balaji
news:bksc54$s7t$1@eclipse.org...
> below.
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
r.java:306)
> at
m.java:405)
> at
gin.java:60)
> The constructor:
> super(descriptor);
> ideas?
> Philipp
> > HTH
> > Balaji
> > > Hi,
plug-in
dependencies
comes
> > > plug == null
> > > registry, right?!
plug-in
I
error?
> > > Philipp
Re: Plug-In startup(?) problem [message #135198 is a reply to message #135160] Wed, 24 September 2003 11:25 Go to previous message
Hi again,
ok, it was an error (_my_ error, to be precise) in the plugin.xml file of
the ddcore plugin... I specified invalid package prefixes in the
runtime-export section.
Philipp
> below.
> at
> at
> at
> at
> at
> at
> The constructor:
> super(descriptor);
> ideas?
> Philipp
> > HTH
> > Balaji
> > > Hi,
plug-in
comes
> > > plug == null
> > > registry, right?!
> > > Philipp
Previous Topic:using jsse classes from a plug-in
Next Topic:[ANN]: eclipse-games 3.0M2 released
Current Time: Thu Jul 17 23:18:58 EDT 2025
Powered by FUDForum. Page generated in 0.34139 seconds
