Problem with Eclipse 2.1 and JDK 1.4.1_02 [message #12399] |
Fri, 02 May 2003 15:15  |
Originally posted by: mb.nose.demon.nl
Hi there,
I installed the new Eclipse 2.1 with Lomboz 2.1 and EASIE for JBoss (1.2.0).
I have JDK 1.4.1_02 installed and made all the configurations as noticed in
the appropriate docs. When I try to start the JBoss server I get the
following error:
"Error occured during initialization of VM
java/lang/NoClassDefinitionFoundError: java/lang/Object"
I also tried with JDK 1.4.0_01 but with the same error.
The error is quite obvious but does anyone know what causes this?
Michiel.
Re: Problem with Eclipse 2.1 and JDK 1.4.1_02 [message #12438 is a reply to message #12418] |
Sat, 03 May 2003 05:50  |
When I open a project I created in the proir version of Eclipse I can
compile and run the server. Then, when I open a project created in 2.1 the
server suddenly runs too.
Try to do the same as I did. It might help, although I several error from my
server (JBoss). 'have to gigure this on out.
"Doug Spelce" <doug@journee.com> wrote in message
news:b8uo0n$hmq$1@rogue.oti.com...
> Michiel,
> I got a similar NoClassDefFoundError exception today when installing
> Eclipse 2.1 with Sun's JRE 1.4.1_02 on my W2K box. The only additional
> plugin was the one my company is developing (contributes a perspective
> and a new editor). However, everything has worked fine for awhile on
> JRE 1.4.0_02. Here's the contents of the .log file:
> Doug
> !ENTRY org.eclipse.core.launcher 4 0 May 02, 2003 15:21:01.881
> !MESSAGE Exception launching the Eclipse Platform:
> !STACK
> java.lang.reflect.InvocationTargetException:
> java.lang.NoClassDefFoundError: javax/xml/transform/Source
> at java.lang.Class.getConstructor0(Native Method)
> at java.lang.Class.getConstructor(Class.java:922)
> at
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivatio
n(PluginDescriptor.java:701)
> at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(Plugin
Descriptor.java:188)
> at
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginCla
ssLoader.java:112)
> at
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParents
Self(PluginClassLoader.java:185)
> at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf
(DelegatingURLClassLoader.java:485)
> at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegating
URLClassLoader.java:882)
> at
URLClassLoader.java:862)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:250)
> at
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension
(PluginDescriptor.java:130)
> at
(PluginDescriptor.java:167)
> at
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExten
sion(ConfigurationElement.java:103)
> at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:158)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
> at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:155)
> at
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(Perspec
tiveDescriptor.java:98)
> at
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:653
> at
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:278)
> at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:177)
> at
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:9
65)
> at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:1692)
> at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:369)
> at
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:41
3)
> at
org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:1188)
> at
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:1185)
> at
> org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1074)
> at org.eclipse.ui.internal.Workbench.init(Workbench.java:874)
> at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
> at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
> at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
> at java.lang.reflect.Method.invoke(Native Method)
> at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
> at org.eclipse.core.launcher.Main.run(Main.java:747)
> at org.eclipse.core.launcher.Main.main(Main.java:583)
> Michiel Bakker wrote:
> > Hi there,
(1.2.0).
in
> > following error:
> > Regards,
> > Michiel.
FUDForum. Page generated in 0.04444 seconds
