Home » Eclipse Projects » Subversive » Compatibility with EclipseME
Compatibility with EclipseME [message #12395] Tue, 29 January 2008 17:15 Go to next message
Originally posted by: sergei.synopsia.net
Are any versions of Subversive plugin compatible with EclipseME 1.7.7? If
yes, which ones? Otherwise, could you recommend some other SVN plugin?
Sergei
org.eclipse.pde.ui (was: Compatibility with EclipseME) [message #12404 is a reply to message #12395] Wed, 30 January 2008 17:32 Go to previous messageGo to next message
Hello again,
I working with Motodev Studio, which is based on Eclipse 3.3 with
EclipseME 1.7.7. Tried installing subversive, which required Mylyn Bridge,
which in turn requires something else -- here is the error message:
Mylyn Bridge: PDE, CVS and Ant (2.3.0.I20080125-1200) requires plug-in
"org.eclipse.pde.ui".
Can someone please point me to where I might be able to get that?
Thanks in advance.
Sergei S. wrote:
> Sergei
Re: org.eclipse.pde.ui [message #12413 is a reply to message #12404] Wed, 30 January 2008 23:50 Go to previous messageGo to next message
Sergei S. wrote:
> Hello again,
> Bridge, which in turn requires something else -- here is the error message:
> Thanks in advance.
> Sergei S. wrote:
>> If yes, which ones? Otherwise, could you recommend some other SVN plugin?
>> Thanks,
>> Sergei
I am not sure, what else is behind EclipseME 1.7.7 (I just finished an
article about Mobile Eclipse Development, so I looked at it, but not
every single Plugin it uses ;-) but you probably need to check older
(propriatory) versions of Subversive still hosted by Polarion.
Either their UpdateManager still works, or they can be downloaded somehow.
Of course if it was totally incompatible, the alternative SVN Team
client by ColabNet (Subclipse or so I think?) might work, too.
Re: org.eclipse.pde.ui [message #12874 is a reply to message #12404] Fri, 01 February 2008 09:35 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hi Sergei,
Subversive provides optional integration for the Mylyn project. So, if you
won't installing Mylyn, please uncheck corresponding feature in the
Subversive update site. If Eclipse distribution which you use does not
contain JDT you also can switch off corresponding integration in the
Re: org.eclipse.pde.ui [message #12882 is a reply to message #12874] Sun, 03 February 2008 09:35 Go to previous message
I think Sergei's main issue is the actual Eclipse release behind
EclipseME, not if Mylyn works or not?;-)
Previous Topic:Update site in flux
Next Topic:FastTrack and Subversive 0.7
Current Time: Tue Jul 22 12:01:51 EDT 2025
Powered by FUDForum. Page generated in 0.03869 seconds
