Home » Modeling » GMF (Graphical Modeling Framework) » how to include figure inside figure
how to include figure inside figure [message #134828] Tue, 12 June 2007 04:50 Go to next message
Originally posted by: alexjaquet.gmail.com
I would like to know how can I include figure into a contener figure,
for example I've a figure named box and I would like to place it some
widgets (checkbox, label ...)
Thanks.
Alexandre
Re: how to include figure inside figure [message #135018 is a reply to message #134828] Tue, 12 June 2007 09:36 Go to previous messageGo to next message
Alexandre Jaquet a écrit :
> Thanks.
> Alexandre
I found it by defining a compartment, not sure it will solve all
my use case, I will try it.
Alexandre
Re: how to include figure inside figure [message #135030 is a reply to message #135018] Tue, 12 June 2007 09:38 Go to previous messageGo to next message
>> Thanks.
>> Regards,
>> Alexandre
> Alexandre
Is it possible to include a compartment inside another one ?
Alexandre
Re: how to include figure inside figure [message #135083 is a reply to message #135030] Tue, 12 June 2007 10:21 Go to previous messageGo to next message
Why do you want to do this ? Do you want to have 2 different figures in
one compartment ? In this case tou can create a compartement and set two
(or more) references to the property Child.
Tex
Re: how to include figure inside figure [message #135092 is a reply to message #135083] Tue, 12 June 2007 10:35 Go to previous messageGo to next message
> Tex
Hi Tex, this is not for that case, my compartment will represent for
example a table in this table I want to create other tables inside.
Thanks for your help.
Alexandre
Re: how to include figure inside figure [message #135132 is a reply to message #135092] Tue, 12 June 2007 10:39 Go to previous messageGo to next message
ok, you just want a "recursive" compartment. It's possible. Just add
another compartement to the figure that will be held in your 1st
compartment. :)
Re: how to include figure inside figure [message #135170 is a reply to message #135132] Tue, 12 June 2007 10:45 Go to previous messageGo to next message
--------------090208020407090804080809
Tex Twil a
Re: how to include figure inside figure [message #135182 is a reply to message #135170] Tue, 12 June 2007 10:50 Go to previous messageGo to next message
I think a compartment cannot contain directly another one. You have to
reference a node which itself can hav another compartment.
Re: how to include figure inside figure [message #135295 is a reply to message #135182] Tue, 12 June 2007 13:07 Go to previous messageGo to next message
I will try it.
Re: how to include figure inside figure [message #135357 is a reply to message #135295] Wed, 13 June 2007 02:37 Go to previous messageGo to next message
> I will try it.
I've a design question :
In my model I've a boxes class, this boxes can contain boxes do I've to
define an aggregation or an association.
Thanks.
Alexandre
Re: how to include figure inside figure [message #135467 is a reply to message #135357] Wed, 13 June 2007 05:28 Go to previous messageGo to next message
>> I will try it.
> Thanks.
> Alexandre
If your box "contains" another box, I would say you have to define
Composition i.e. when you delete your first box, the other is deleted to.
Re: how to include figure inside figure [message #135577 is a reply to message #135467] Wed, 13 June 2007 07:17 Go to previous messageGo to next message
--------------050705000205050307010502
Tex Twil a
Re: how to include figure inside figure [message #135603 is a reply to message #135577] Wed, 13 June 2007 07:39 Go to previous message
Ok, then it is the link Aggregation.
Previous Topic:Default int value doesn't appear
Next Topic:Implemeting Delete action
Current Time: Thu Jul 17 21:41:12 EDT 2025
Powered by FUDForum. Page generated in 0.10811 seconds
