date format thru Tomcat [message #134787] |
Thu, 23 February 2006 01:19  |
Originally posted by: simon.pearce.bt.com
I have BIRT running under Tomcat 5.5. After loading the daily build
N20060222.zip it all works nicely. (2.0.0 does not work for Firefox, only
IE - weird).
But I have a problem with dates - on my XP machine, the report dates
display normally (I'm in Oz, so that's 23/2/2006). But on my server
running NT server 2000, it displays as 23/2/2006.
I feel sure I must have a setup wrong somwhere - perhaps even in Tomcat
But I am somehwat at a loss as to where that might be. I tried settign the
local for Tomcat, but that did not seem to work.
Any ideas? [I don't think this is a BIRT problem as such, it's a config
problem, possibly Tomcat, so I apologise]
Simon
Re: date format thru Tomcat [message #135496 is a reply to message #134787] |
Thu, 23 February 2006 18:44  |
The issue with Firefox is that BIRT 2.0.0 is probably related to Firefox
1.5, which does not work with 2.0.0.
The 2.0.1 release will address the Firefox issue.
In terms of the dates, I may be a little thick here but I do not see a
difference between the two styles. Could you provide a little more
explanation.
Scott Rosenbaum
BIRT PMC
> only IE - weird).
> the local for Tomcat, but that did not seem to work.
> Simon
FUDForum. Page generated in 0.03522 seconds
