Home » Archived » Visual Editor (VE) » Extending VE Palette: EMF problem
Extending VE Palette: EMF problem [message #134752] Fri, 12 January 2007 10:24 Go to next message
Originally posted by: ruth.hawkins.yahoo.com
I am new at using and extending the Visual Editor. I am extending the
palette in the Visual Editor adding my own Custom Widget to it. I am able
to select my Custom Widget class from the "Select Bean" option on the
Palette and it's working fine. But now I am trying to add another
category on the palette and add the Custom Widget entry under it. I am
following the steps provided in the tutorial at:
http://www.eclipse.org/articles/Article-VE-Custom-Widget/cus tomwidget.html
When I perform an Eclipse Application Launch and create a Visual class and
open it using the Visual Editor, the new Category that I added is not
visible on thr palette. I tried checking the ".log" file available in the
runtime-workspace/.metadata and I found the following Exception stack
logged in there:
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ve.java.core".
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1$Diagno sticWrappedException:
org.xml.sax.SAXParseException: The prefix "xsi" for attribute "xsi:type"
associated with an element type "categoryLabel" is not bound.
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:307)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
Can anyone who has experience of such problem or knows where things might
be going wrong will help me to solve it? I am using the sample ".xmi"
file available with the example in the same tutorial and have done
necessary modifications to it. I don't have enough knowledge about
writing ".xmi" files so I am kind of stuck with this problem.
Any sort of help on the problem is appreciated.
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #134793 is a reply to message #134752] Fri, 12 January 2007 15:50 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
This means your palette xmi is invalid. Attach the palette xmi file and
we can take a look.
Rich Kulp
Re: Extending VE Palette: EMF problem [message #134831 is a reply to message #134793] Sat, 13 January 2007 02:35 Go to previous messageGo to next message
Hey,
Please have a look at the .xmi file below:
<xmi:XMI xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:palette="http:///org/eclipse/ve/internal/cde/palette.ecore"
xmlns:utility="http:///org/eclipse/ve/internal/cde/utility.ecore">
<palette:CategoryCmp>
<categoryLabel xsi:type="utility:ConstantString" string="Custom"/>
<cmpGroups xsi:type="palette:GroupCmp">
<cmpEntries xsi:tye="palette:AnnotatedCreationEntry" xmi:id="entry2"
icon16Name=" platform:/plugin/org.eclipse.ve.example.customWidget/icons/c ustom.gif ">
<objectCreationEntry xsi:type="palette:EMFCreationToolEntry"
creationClassURI=" java:/org.eclipse.ve.example.customwidget.prompter#MyCustomP rompter "/>
<entryLabel xsi:type="utility:ConstantString" string="Prompter"/>
<values xmi:type="ecore:EStringToStringMapEntry"
key="org.eclipse.ve.internal.cde.core.nameincomposition"
value="customPrompter"/>
</cmpEntries>
</cmpGroups>
</palette:CategoryCmp>
</xmi:XMI>
The file is almost same as the one provided in the Visual Editor article
on Eclipse site. I have just made necessary modifications for the name
change.
I am working with Eclipse SDK 3.2 and Visual Editor 1.2.
Please let me know where I might be doing wrong in the file.
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #134875 is a reply to message #134831] Mon, 15 January 2007 09:42 Go to previous messageGo to next message
First please try migrating to the new palette format. This version (the
article is unfortunately too old and doesn't contain the new version) is
deprecated.
See:
http://www.eclipse.org/vep/WebContent/docs/migration/migrati on.html
There are instructions on how to migrate.
Rich Kulp
Re: Extending VE Palette: EMF problem [message #134901 is a reply to message #134875] Tue, 16 January 2007 02:20 Go to previous messageGo to next message
Hey!
Thanks for letting me know that I was using the older version. I read
the instructions for migrating to the current version at the link you
pointed at. As instructed there I downloaded the migration utility and
ran for my palette xmi file [ Same as I attached in the earlier post ].
When the migration utility is run for the file I get following exception
at the console:
Exception in thread "main" java.lang.IllegalArgumentException: The class
'Entry' is not a valid classifier
org.eclipse.ve.internal.cde.palette.impl.PaletteFactoryImpl. create(PaletteFactoryImpl.java:87)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XM LHelperImpl.java:797)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XM LHelperImpl.java:832)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1933)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:1907)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1783)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1587)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:881)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:860)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:627)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:878)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1693)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:900)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at migrate.MigratePalette11.main(MigratePalette11.java:79)
Can you please help me out with this? Let me know where I am doing wrong.
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #134913 is a reply to message #134901] Tue, 16 January 2007 10:22 Go to previous messageGo to next message
Did you use the target versions as shown:
Eclipse SDK 3.1, GEF 3.1, EMF 2.1, and VE 1.1
Rich Kulp
Re: Extending VE Palette: EMF problem [message #134926 is a reply to message #134913] Tue, 16 January 2007 10:35 Go to previous messageGo to next message
Hey,
Thanks for pointing this out. I should have mentioend this earlier. The
target versions that I am using are as follows:
Eclipse SDK 3.2,
GEF 3.2,
EMF 2.2,
Visual Editor [ VE ] 1.2.
Please help me, providing more information regarding migration of the xmi
file to the latest Eclipse versions so that I can successfully extend the
Visual Editor's palette.
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #134939 is a reply to message #134926] Tue, 16 January 2007 11:32 Go to previous messageGo to next message
I got it working finally!!! It was my fault really that I was using wrong
Eclipse SDKs versions. The version mentioned in the migration tutorial
should only be used. The migration tool doesn't work for the higher
versions. Using the appropriate versions I successfully migrated the xmi
file to be latest version compatible.
I am working on it further right now.
Thanks for the support!
Ruth
Re: Extending VE Palette: EMF problem [message #138031 is a reply to message #134752] Thu, 14 June 2007 03:20 Go to previous message
Originally posted by: vaibhava.choudhary.gmail.com
Hi Ruth,
can you help me out?
My question is , Once we add composite component to VE pallatte
and use this component in new visual class, i am not able to change the Label text or Button text once we click on the componet a dialog box gets open where we can enetr the text of the component , Can you guide me on this .
Thanking you
Vaibhav.
vaibhava.choudhary@gmail.com
Re: Extending VE Palette: EMF problem [message #614987 is a reply to message #134752] Fri, 12 January 2007 15:50 Go to previous message
we can take a look.
Rich Kulp
Re: Extending VE Palette: EMF problem [message #614990 is a reply to message #134793] Sat, 13 January 2007 02:35 Go to previous message
Hey,
</cmpEntries>
</cmpGroups>
</xmi:XMI>
change.
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #614993 is a reply to message #134831] Mon, 15 January 2007 09:42 Go to previous message
deprecated.
See:
Rich Kulp
Re: Extending VE Palette: EMF problem [message #614995 is a reply to message #134875] Tue, 16 January 2007 02:20 Go to previous message
Hey!
at the console:
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #614996 is a reply to message #134901] Tue, 16 January 2007 10:22 Go to previous message
Rich Kulp
Re: Extending VE Palette: EMF problem [message #614997 is a reply to message #134913] Tue, 16 January 2007 10:35 Go to previous message
Hey,
Eclipse SDK 3.2,
GEF 3.2,
EMF 2.2,
Thanks & Regards,
Ruth
Re: Extending VE Palette: EMF problem [message #614998 is a reply to message #134926] Tue, 16 January 2007 11:32 Go to previous message
Ruth
Re: Extending VE Palette: EMF problem [message #615336 is a reply to message #134752] Thu, 14 June 2007 03:20 Go to previous message
Hi Ruth,
Thanking you
Vaibhav.
Previous Topic:Setting a Property of a component programmatically
Next Topic:How to Edit text on swt component at design time.
Current Time: Sat Oct 25 20:18:50 EDT 2025
Powered by FUDForum. Page generated in 0.04897 seconds
