Help,how to solve this java.lang.NullPointerException [message #134722] |
Fri, 12 January 2007 00:41  |
Originally posted by: nick_carterk.yahoo.com
i was trying to write multitabs text editor with VE, but when i reopen the file, a msg shown with java.lang.NullPointerException, i tested few times and i still can't solve this problem. Can anyone lend me a help pls?
below is my codes
import java.io.BufferedReader;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.FileReader;
import java.io.FileWriter;
import java.io.IOException;
import org.eclipse.swt.widgets.FileDialog;
import org.eclipse.swt.widgets.MessageBox;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.custom.CTabFolder;
import org.eclipse.swt.custom.CTabItem;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Text;
public class GUI {
private Shell sShell = null;
private CTabFolder cTabFolder = null;
private Integer tabCounter = 0;
private Button bOpen = null;
private Text textArea = null;
* This method initializes cTabFolder
public static void main(String [] args) {
Display display = Display.getDefault();
GUI thisClass = new GUI();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private void createSShell() {
sShell = new Shell();
sShell.setLayout(null);
createCTabFolder();
sShell.setSize(new Point(498, 204));
bOpen = new Button(sShell, SWT.NONE);
bOpen.setBounds(new Rectangle(19, 121, 46, 34));
bOpen.addSelectionListener(new org.eclipse.swt.events.SelectionAdapter() {
public void widgetSelected(org.eclipse.swt.events.SelectionEvent e) {
addtab();
private void createCTabFolder() {
cTabFolder = new CTabFolder(sShell, SWT.NONE);
cTabFolder.setBounds(new Rectangle(19, 7, 455, 105));
private void addtab() {
CTabItem filetab = new CTabItem(cTabFolder, SWT.NONE);
filetab.setText(tabCounter.toString());
tabCounter++;
textArea = new Text(cTabFolder, SWT.MULTI | SWT.WRAP | SWT.V_SCROLL);
filetab.setControl(textArea);
FileDialog fileDialog = new FileDialog(sShell, SWT.OPEN);
fileDialog.setText("Open");
fileDialog.setFilterPath("C:/");
String[] filterExt = { "*.txt", "*.*" };
fileDialog.setFilterExtensions(filterExt);
String selected = fileDialog.open();
if (selected == null)
return;
// code here to open the file and display
FileReader file = null;
try {
file = new FileReader(selected);
} catch (FileNotFoundException e) {
MessageBox messageBox = new MessageBox(sShell, SWT.ICON_ERROR | SWT.OK);
messageBox.setMessage("Could not open file.");
messageBox.setText("Error");
messageBox.open();
return;
BufferedReader fileInput = new BufferedReader(file);
String text = null;
StringBuffer sb = new StringBuffer();
try {
do {
if (text != null)
sb.append(text);
} while ((text = fileInput.readLine()) != null);
} catch (IOException e1) {
messageBox.setMessage("Could not write to file.");
messageBox.open();
return;
textArea.setText(sb.toString());
cTabFolder.setFocus();
FUDForum. Page generated in 0.05469 seconds
