Home » Language IDEs » Java Development Tools (JDT) » Adding source folders programmatically
| Adding source folders programmatically [message #134694] |
Wed, 14 January 2004 11:14  |
I want to automatically add new (unknown) source folders to an eclipse
project. (CVS update - include new modules created by others
automatically).
For that I use the following code:
// new source folder = path
IClasspathEntry cpe = JavaCore.newSourceEntry(path);
/** put current classpath (IClasspathEntry[] oldClasspath =
project.getRawClasspath(); )
together with new folder (cpe) in IClasspathEntry[] classpath. then set
it: */
project.setRawClasspath(classpath, new NullProgressMonitor());
As a result (with elicpse 2.1.1 and 2.1.2), I do not have a new source
folder, but my project is now dependent on another project (name = path
name).
What's wrong here?
Thanks in advance for help how to do this
Chris
PS: I found 1 posting
( http://dev.eclipse.org/newslists/news.eclipse.tools/msg60431 .html), where
the same solution was suggested, and the other guy seemed to be happy with
it. What am I doing wrong?
| Re: Adding source folders programmatically [message #134849 is a reply to message #134810] |
Thu, 15 January 2004 05:27   |
Right the source folder path should be /modulename/src/cejb. So this should
work. However just to make sure I understand your layout: your project is
external to your workspace, right?
Jerome
"Christoph schwitter" <christoph.schwitter@elca.ch> wrote in message
news:bu5h1e$rba$1@eclipse.org...
> Thanks for your hint, but I do not understand what I have to do.
> Just to be sure about an "absolute workspace relative path":
> Project root = d:/myproject
> Source folder to add = d:/myproject/modulename/src/cejb
> The path variable used in the code below should contain:
> That is how it is done, except hat on windows I have \\ instead of /.
> I do not see what I have to change.
> Chris
> Jerome Lanneluc wrote:
> > Use an absolute workspace-relative path for your source folder, not a
> > 1-segment path.
> > Jerome
> > "Chris" <christoph.schwitter@elca.ch> wrote in message
> > news:bu3ptn$tbn$1@eclipse.org...
> > > Hi
> > > automatically).
set
> > > it: */
path
> > > name).
> > > What's wrong here?
> > > Chris
where
with
| Re: Adding source folders programmatically [message #134860 is a reply to message #134849] |
Thu, 15 January 2004 05:47   |
yes, its an external project.
It does not work. Thew new classpath entry is created like this (new path
argument is copied from debug).
IPath path = new Path("\\module1\\src\\TestProject");
> > Project root = .../myproject
> > Source folder to add = ../myproject/module1/src/TestProject
That still creates project dependencies (to "TestProject"), not new source
folders.
From existing source folders, the classpath includes the myproject
element, but even if I add that, it does not help.
Chris
> Jerome
> > That is how it is done, except hat on windows I have \ instead of /.
> > Chris
> > > 1-segment path.
> > > Jerome
> > > > Hi
> > > > automatically).
> set
> > > > it: */
> path
> > > > name).
> > > > What's wrong here?
> > > > Chris
> where
> with
| Re: Adding source folders programmatically [message #134869 is a reply to message #134860] |
Thu, 15 January 2004 06:14   |
So ecjb is a project? It is still not clear what's your workspace layout.Can
you describe it in more details?
Jerome
news:bu5r35$7vs$1@eclipse.org...
> folders.
> Chris
should
is
> > Jerome
> > > Chris
a
> > > > 1-segment path.
> > > > Jerome
> > > > > Hi
eclipse
> > > > > automatically).
then
> > set
> > > > > it: */
source
> > path
> > > > > name).
> > > > > What's wrong here?
> > > > > Chris
> > where
happy
> > with
| Re: Adding source folders programmatically [message #134880 is a reply to message #134869] |
Thu, 15 January 2004 06:23   |
The project is a test project I use for testing this plugin. Project
location is:
D:\CSC\projects\leaf\eclipseIntegration\TestProjects\testPro ject1\
It has subfolders for modules, for testing only one:
D:\CSC\projects\leaf\eclipseIntegration\TestProjects\testPro ject1\module1\src\
In src we have the real source folders that should be added to the project.
src\cejb
src\TestProject
src\anything
When creating the classpath, I have "\\module1\\src\\TestProject" as IPath
(I also have tried "\\testProject1\\module1\\src\\TestProject").
What other information do you need?
Chris
> Jerome
> > IPath path = new Path("\module1\src\TestProject");
> > folders.
> > Chris
> should
> is
> > > Jerome
> > > > That is how it is done, except hat on windows I have instead of /.
> > > > Chris
> a
> > > > > 1-segment path.
> > > > > Jerome
> > > > > > Hi
> eclipse
> > > > > > automatically).
> then
> > > set
> > > > > > it: */
> source
> > > path
> > > > > > name).
> > > > > > What's wrong here?
> > > > > > Chris
> > > where
> happy
> > > with
| Re: Adding source folders programmatically [message #134892 is a reply to message #134880] |
Thu, 15 January 2004 06:31   |
You said it was creating a project dependency. I assume then you have
another project, don't you?
Jerome
news:bu5t84$as7$1@eclipse.org...
> location is:
c\
project.
> src\cejb
> src\TestProject
> src\anything
> Chris
layout.Can
> > Jerome
path
source
> > > folders.
> > > Chris
this
> > should
project
> > is
> > > > Jerome
> > > > > Chris
not
> > a
> > > > > > 1-segment path.
> > > > > > Jerome
> > > > > > > Hi
> > eclipse
> > > > > > > automatically).
> > then
> > > > set
> > > > > > > it: */
new
> > source
(name =
> > > > path
> > > > > > > name).
> > > > > > > What's wrong here?
> > > > > > > Chris
> > > > where
be
> > happy
> > > > with
| Re: Adding source folders programmatically [message #134905 is a reply to message #134892] |
Thu, 15 January 2004 07:11   |
No, in the test setup there is no other project. The other project's name
is just the folder's name, a project with the same name does not exist.
There is only the folder..
Christoph
> Jerome
> > location is:
> > D:CSCprojectsleafeclipseIntegrationTestProjectstestProject1
> D:CSCprojectsleafeclipseIntegrationTestProjectstestProject1m odule1sr
> c
> project.
> > srccejb
> > srcTestProject
> > srcanything
> > When creating the classpath, I have "\module1\src\TestProject" as IPath
> > (I also have tried "\testProject1\module1\src\TestProject").
> > Chris
> layout.Can
> > > Jerome
> path
> > > > IPath path = new Path("module1srcTestProject");
> source
> > > > folders.
> > > > Chris
> this
> > > should
> project
> > > is
> > > > > Jerome
> > > > > > Chris
> not
> > > a
> > > > > > > 1-segment path.
> > > > > > > Jerome
> > > > > > > > Hi
> > > eclipse
> > > > > > > > automatically).
> > > then
> > > > > set
> > > > > > > > it: */
> new
> > > source
> (name =
> > > > > path
> > > > > > > > name).
> > > > > > > > What's wrong here?
> > > > > > > > Chris
> > > > > where
> be
> > > happy
> > > > > with
| Re: Adding source folders programmatically [message #134917 is a reply to message #134905] |
Thu, 15 January 2004 07:26   |
I'm confused. In your original post you said 'my project is now dependent on
another project'. What did you mean?
Jerome
news:bu6019$e65$1@eclipse.org...
> Christoph
> > Jerome
> > > location is:
> > c
> > project.
> > > srccejb
> > > srcTestProject
> > > srcanything
IPath
> > > Chris
> > layout.Can
> > > > Jerome
(new
> > path
new
> > source
> > > > > folders.
> > > > > Chris
> > this
> > > > should
> > project
> > > > is
> > > > > > Jerome
message
do.
of
> > > > > > > Chris
folder,
> > not
> > > > a
> > > > > > > > 1-segment path.
> > > > > > > > Jerome
> > > > > > > > > Hi
to an
> > > > eclipse
others
> > > > > > > > > automatically).
classpath.
> > > > then
> > > > > > set
> > > > > > > > > it: */
a
> > new
> > > > source
> > (name =
> > > > > > path
> > > > > > > > > name).
> > > > > > > > > What's wrong here?
> > > > > > > > > Chris
> > > > > > where
to
> > be
> > > > happy
> > > > > > with
| Re: Adding source folders programmatically [message #134944 is a reply to message #134917] |
Thu, 15 January 2004 07:44   |
Initially, I have a normal eclipse project, no source folders.
Then I execute my plugin.
Result:
still no source folders, but: project - properties - java build path -
projects: each source folder (that should be a source path) is listed as
project (as project required in the build path, but these projects do not
exist).
Chris
> Jerome
> > Christoph
> > > Jerome
> > > > location is:
> > > c
> > > project.
> > > > srccejb
> > > > srcTestProject
> > > > srcanything
> > > > When creating the classpath, I have "module1srcTestProject" as
> IPath
> > > > (I also have tried "testProject1module1srcTestProject").
> > > > Chris
> > > layout.Can
> > > > > Jerome
> (new
> > > path
> new
> > > source
> > > > > > folders.
> > > > > > Chris
> > > this
> > > > > should
> > > project
> > > > > is
> > > > > > > Jerome
> message
> do.
> of
> > > > > > > > Chris
> folder,
> > > not
> > > > > a
> > > > > > > > > 1-segment path.
> > > > > > > > > Jerome
> > > > > > > > > > Hi
> to an
> > > > > eclipse
> others
> > > > > > > > > > automatically).
> classpath.
> > > > > then
> > > > > > > set
> > > > > > > > > > it: */
> a
> > > new
> > > > > source
> > > (name =
> > > > > > > path
> > > > > > > > > > name).
> > > > > > > > > > What's wrong here?
> > > > > > > > > > Chris
> > > > > > > where
> to
> > > be
> > > > > happy
> > > > > > > with
| Re: Adding source folders programmatically [message #134990 is a reply to message #134694] |
Thu, 15 January 2004 08:30   |
Originally posted by: jparks.noteworthyms.com
You have to create the source folder (or, as the case may be, create a
source folder reference) in the project, and then you have to update the
classpath entries of the project. You're only performing the latter.
This is adapted from the book "Contributing to Eclipse":
private IPackageFragmentRoot createSourceFolder(String path) throws
CoreException {
IFolder folder = project.getFolder(path);
folder.create(false, true, null);
IJavaProject javaProject = (IJavaProject) project; // not sure if this
is correct
IPackageFragmentRoot root =
javaProject.getPackageFragmentRoot(folder);
IClasspathEntry [] oldEntries = javaProject.getRawClasspath();
IClasspathEntry [] newEntries =
new IClasspathEntry [oldEntries.length + 1];
System.arraycopy(oldEntries, 0, newEntries, 0, oldEntries.length);
newEntries[oldEntries.length + 1] =
JavaCore.newSourceEntry(root.getPath());
javaProject.setRawClasspath(newEntries, null);
return root;
> Hi
> automatically).
> it: */
> name).
> What's wrong here?
> Chris
| Re: Adding source folders programmatically [message #135014 is a reply to message #134944] |
Thu, 15 January 2004 09:51  |
I understand now, but I cannot reproduce in 2.1.2. Have you tried creating
the folder as Joe suggested?
Jerome
news:bu61uk$gl5$1@eclipse.org...
> Result:
> exist).
> Chris
dependent on
> > Jerome
name
exist.
> > > Christoph
have
> > > > Jerome
Project
> > > > > location is:
> > > > c
> > > > project.
> > > > > srccejb
> > > > > srcTestProject
> > > > > srcanything
> > IPath
> > > > > Chris
workspace
> > > > layout.Can
> > > > > > Jerome
this
> > (new
> > > > path
.../myproject/module1/src/TestProject
not
> > new
> > > > source
> > > > > > > folders.
myproject
> > > > > > > Chris
> > > > this
> > > > > > should
your
> > > > project
> > > > > > is
> > > > > > > > Jerome
> > message
to
> > do.
path":
instead
> > of
> > > > > > > > > Chris
> > folder,
> > > > not
> > > > > > a
> > > > > > > > > > 1-segment path.
> > > > > > > > > > Jerome
> > > > > > > > > > > Hi
folders
> > to an
> > > > > > eclipse
> > others
> > > > > > > > > > > automatically).
oldClasspath
> > classpath.
> > > > > > then
> > > > > > > > set
> > > > > > > > > > > it: */
have
> > a
> > > > new
> > > > > > source
project
> > > > (name =
> > > > > > > > path
> > > > > > > > > > > name).
> > > > > > > > > > > What's wrong here?
> > > > > > > > > > > Chris
> > > > > > > > where
seemed
> > to
> > > > be
> > > > > > happy
> > > > > > > > with
Current Time: Sat Nov 08 11:36:19 EST 2025
Powered by FUDForum. Page generated in 0.04191 seconds
