Home » Newcomers » Newcomers » Ant/Eclipse problem: import using property fails
Ant/Eclipse problem: import using property fails [message #134682] Fri, 03 February 2006 12:21 Go to next message
Hello, all. I am wrestling with an Ant/Eclipse problem. I want to
define a user.properties file that contains a project name, and then
have ant use that name to import a particular file.
My test build.xml looks like this :
<?xml version="1.0"?>
<project name="test">
<loadproperties srcFile="user.properties"/>
<import file="${projectname}.xml" />
</project>
and my user.properties file contains:
projectname=required
so ant should try to import "required.xml". When I run ant from the
command line, it succeeds. But when I look at my build.xml in Eclipse,
I get the warning:
Cannot find ${projectname}.xml imported from [my build path]/build.xml
Does anyone have any ideas why this occurs? My system is running
Eclipse 3.1.0 (Build id I20050627-1435) on Linux, and my ant classes are
org.eclipse.ant.core 3.1.0, org.eclipse.ant.ui 3.1.0, and org.apache.ant
1.6.5.
Any help or suggestions anyone could provide, or suggestions towards
which group to post this to, would be greatly appreciated.
Many thanks,
Ed
Re: Ant/Eclipse problem: import using property fails [message #134731 is a reply to message #134682] Fri, 03 February 2006 14:08 Go to previous messageGo to next message
We have a bug within the Ant editor warning/problem indication.
Eclipse will properly run the buildfile.
The warning in the editor is incorrect.
Logged as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=126392
The workaround is to use
<property file="user.properties"/>
</project>
Darins
"Ed Beaty" <edbeaty@charter.net> wrote in message
news:ds03eo$rb6$1@utils.eclipse.org...
> </project>
> I get the warning:
> 1.6.5.
> Many thanks,
> Ed
Re: Ant/Eclipse problem: import using property fails [message #134745 is a reply to message #134731] Fri, 03 February 2006 14:19 Go to previous messageGo to next message
BTW...thanks for the excellent explaination of the problem and test
case...man that makes my life soooo much easier.
Also the bug has been fixed and will be in the next Eclipse 3.2 integration
build.
Darins
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:ds09nk$6pm$1@utils.eclipse.org...
> Logged as
> </project>
> Thanks
> Darins
> > </project>
> > I get the warning:
> > 1.6.5.
> > Many thanks,
> > Ed
Re: Ant/Eclipse problem: import using property fails [message #134771 is a reply to message #134745] Fri, 03 February 2006 15:17 Go to previous message
No, thank YOU for logging the bug, then fixing it so quickly!
Rock on,
Ed
> build.
> Thanks
> Darins
>>Logged as
>></project>
>>Thanks
>>Darins
>>></project>
>>>I get the warning:
>>>1.6.5.
>>>Many thanks,
>>>Ed
Previous Topic:Using BPEL plugins
Next Topic:Eclipse won't start
Current Time: Fri Nov 28 07:19:27 EST 2025
Powered by FUDForum. Page generated in 0.08779 seconds
