Home » Archived » Test and Performance Tools Platform (TPTP) » How to run .testsuite file from command line
How to run .testsuite file from command line [message #134646] Thu, 21 August 2008 06:56 Go to next message
Hi All,
I am running one TPTP Junit .testsuite file through RAD/Eclipse
environment. It also generate .execution file.
Now i wanted to run the same .testsuite through command line but as its
not java file i am not able to run it like treditional java program which
comes with main.
Can any body help me with the command which i can write on the command
prompt and can generate .execution file ? My TPTP Program is simple hello
world tptp program with one .testsuite and realted .java file.
do also mention if possible that which all jar i need to add to run it
from command line ?
to run simple java file i was using something like java
com.xx.xx.xx.helloworld
now to run test suite ???
please advice
Re: How to run .testsuite file from command line [message #134760 is a reply to message #134646] Fri, 22 August 2008 06:47 Go to previous message
Hi Amit,
You can run TPTP tests using the Ant/Java/Shell client adapters provided
by the TPTP Automatable Services Framework (ASF):
http://help.eclipse.org/ganymede/topic/org.eclipse.hyades.te st.doc.user/tasks/tlaunching-tests-from-scripts-and-applicat ions.htm
See the ASF test suite
( http://dev.eclipse.org/viewcvs/index.cgi/test-results/test/o rg.eclipse.hyades.test.core.services.tests/manual/Test.Execu tion.Services.testsuite?root=TPTP_Project&view=log)
for examples on how to use the Ant/Java/Shell client adapters.
Paul
"Amit" <ankur.shah@in.ibm.com> wrote in message
news:3c24082dc148d33c8ecb22d7105bb516$1@www.eclipse.org...
> Hi All,
> comes with main.
> from command line ?
> please advice
Previous Topic:Quick and Standard mode
Next Topic:AGR verification set up
Current Time: Wed Nov 05 22:43:28 EST 2025
Powered by FUDForum. Page generated in 0.02802 seconds
