| [EMF Compare] Reference change detection bug in 3.5M6? [message #134508] |
Fri, 27 March 2009 11:32  |
--------------020001000107090004020901
Dear developers,
I think I found a bug concerning reference change detection, but I am not sure where it is located.
Please see the simple example attached:
eachonce.zip is a plugin project with a very simple ecore model (including generated code) with just one EClass and some attributes and references.
eachonce-runtime.zip contains two example models for the runtime workbench. If I select both (ref_v1 and ref_v2), select 'Compare with each other', EMF Compare does not show any difference. However, the xmi files clearly show the changed reference from
<children singleAttribute="changeUpdateReference" singleReference="UpdateReference"/>
to
<children singleAttribute="changeUpdateReference" singleReference="changeUpdateReference"/>
IIRC it was working in M5.
Surprisingly enough, I tried to create a simple ecore file, changed a reference there and compared them - that reference change was correctly detected!
So what is wrong?!
Best regards
Patrick
Content-Type: application/octet-stream;
name="eachonce-runtime.zip"
Content-Disposition: attachment;
filename="eachonce-runtime.zip"
UEsDBBQACAAIAIeCezoAAAAAAAAAAAAAAAAjAAAARWFjaG9uY2UvZWFjaG9u Y2UvbW9kZWxf
djEuZWFjaG9uY2V9kLEOgjAQhncT36HpLlUn04DEQRMHFyOJK5azbQItKafg 21vUMkDi+t/3
f3e5OO2qkjzBNdqahK6iJSVghC20kQnNLofFhqbb+SyGXChrBPC9QY0v0lWa D7V1X/Mi03Cf
J1Qh1pyxtm0jW8nIOsmup2NAgmrgQkBJ49eWsEN0+vZATzhrkfr9hMRC6bJw YKZQVhc5whnu
4Mde8+H/NoTKjYRx78cNwdTMvqewYO4/w0av8dkbUEsHCJsapv21AAAAVgEA AFBLAwQUAAgA
CACHgns6AAAAAAAAAAAAAAAAIwAAAEVhY2hvbmNlL2VhY2hvbmNlL21vZGVs X3YyLmVhY2hv
bmNlfZAxC8IwFIR3wf8Qstuok4TW4qDg4CIWXGv6TAJtUtKnrf/eVE2Hiq73 vrt7XJx2VUnu
4BptTUIX0ZwSMMIW2siEZqfdbEXT9XQSQy6UNQL41qDGB+kqzQfbsrf5INNw rydUIdacsbZt
I1vJyDrJzod9QELUwAWBksbXlrBBdPpyQ084a5H6fkJioXRZODDfUFYXOcIR ruDPPubF/3UI
lRsJY9+HG4RfHHs/xEJ+vw8bDeS1J1BLBwhDIFfFtQAAAFwBAABQSwMEFAAI AAgAh4J7OgAA
AAAAAAAAAAAAACIAAABFYWNob25jZS9yZWZlcmVuY2UvcmVmX3YxLmVhY2hv bmNlfZCxDoIw
EIZ3E9+h6S5VJ9OAxEETBxcjiSuWs20CLSmn4Ntb1DJA4vrf9393uTjtqpI8 wTXamoSuoiUl
YIQttJEJzS6HxYam2/kshlwoawTwvUGNL9JVmg+1dV/zItNwnydUIdacsbZt I1vJyDrJrqdj
QIJq4EJASePXlrBDdPr2QE84a5H6/YTEQumycGCmUFYXOcIZ7uDHXvPh/zaE yo2Ece/HDcHU
zL6nsGDuP8NGr/HZG1BLBwibGqb9tQAAAFYBAABQSwMEFAAIAAgAh4J7OgAA AAAAAAAAAAAA
ACIAAABFYWNob25jZS9yZWZlcmVuY2UvcmVmX3YyLmVhY2hvbmNlfZAxC8Iw FIR3wf8Qstuo
k4TW4qDg4CIWXGv6TAJtUtKnrf/eVE2Hiq73vrt7XJx2VUnu4BptTUIX0ZwS MMIW2siEZqfd
bEXT9XQSQy6UNQL41qDGB+kqzQfbsrf5INNwrydUIdacsbZtI1vJyDrJzod9 QELUwAWBksbX
lrBBdPpyQ084a5H6fkJioXRZODDfUFYXOcIRruDPPubF/3UIlRsJY9+HG4Rf HHs/xEJ+vw8b
DeS1J1BLBwhDIFfFtQAAAFwBAABQSwECFAAUAAgACACHgns6mxqm/bUAAABW AQAAIwAAAAAA
AAAAAAAAAAAAAAAARWFjaG9uY2UvZWFjaG9uY2UvbW9kZWxfdjEuZWFjaG9u Y2VQSwECFAAU
AAgACACHgns6QyBXxbUAAABcAQAAIwAAAAAAAAAAAAAAAAAGAQAARWFjaG9u Y2UvZWFjaG9u
Y2UvbW9kZWxfdjIuZWFjaG9uY2VQSwECFAAUAAgACACHgns6mxqm/bUAAABW AQAAIgAAAAAA
AAAAAAAAAAAMAgAARWFjaG9uY2UvcmVmZXJlbmNlL3JlZl92MS5lYWNob25j ZVBLAQIUABQA
CAAIAIeCezpDIFfFtQAAAFwBAAAiAAAAAAAAAAAAAAAAABEDAABFYWNob25j ZS9yZWZlcmVu
Y2UvcmVmX3YyLmVhY2hvbmNlUEsFBgAAAAAEAAQAQgEAABYEAAAAAA==
name="eachonce.zip"
filename="eachonce.zip"
UEsDBBQACAAIAFCCezoAAAAAAAAAAAAAAAAfAAAARU1GLUNvbXBhcmUtZXhh bXBsZXMvLmNs
YXNzcGF0aJ2QQUsDMRCFzxX6H5bcO2sFwcOuRWSFFlqlXXuVNBm2o+kknSRi /73VWhShHrzN
G7557zHV6G3jileUSJ5rNYRzVSAbb4m7Wj22d4MrNbrun1XG6RiDTuu96H0r 5CS74oXY1iqK
UcXH8jCWp0nj+Uh66QCNoxARnm0CpzOb9T4dJvPm6fZ+1t6MZ828/M0RJxTW DiyucgeZvi5R
YJE0Wy12OW13AcvJxaIZDOHyH4WCRTBeEAS3mQTtg8sdcfzLyucUcjq6rYg/ 4ar8+cB3UEsH
CGNzzMDOAAAAdgEAAFBLAwQUAAgACABQgns6AAAAAAAAAAAAAAAAHQAAAEVN Ri1Db21wYXJl
LWV4YW1wbGVzLy5wcm9qZWN0vVJNSwMxED0r+B/K3jfRWw/pFqr2VilUf0BM ptuUfDHJlv58
kzSrLKXgQbzNe/PevGEYtjwbPTsBBuXsonkij80MrHBS2X7RfLyv23mz7B7u mUd3BBFfIAhU
PiZ1Yu+Y5Qa61826fXbGc4QWztx4DYHR0soa4YwBGztGxyqzdWAogE7Q56C0 3HkQGVWY5htu
ZWFqrMOegNDKByBHGYlwmAp+4sUA+LNCcnDsh5wdKqZTgtGrlF/leglkw63a Q4ir/43diQMY
/iehlRlPnvLigFDVF3D72pd+XqDobnnyyls99Mq+XRnGOid+/8L01b4AUEsH CJPAPUDwAAAA
qQIAAFBLAwQUAAgACABQgns6AAAAAAAAAAAAAAAAJQAAAEVNRi1Db21wYXJl LWV4YW1wbGVz
L2J1aWxkLnByb3BlcnRpZXN1j8EKwjAQRO+B/YeAPdr0B1TwoNBDPXn0UrdL G0mzYZOA/r2p
t0Ld25sZhh1QO31ADh+x45ROsGCz4kWq2qECBeppvbEeXR4o6qM2+wcovb7u cj/X7e3abHjB
5bE0vGf33wzCgSRZihsZ6nGq2SNttVtkHxtQr16iQZ6DdWRYBpLlVVCRsyAZ UygKliDnFHL6
CWVYEb5QSwcI63WSz5YAAAANAQAAUEsDBBQACAAIAFCCezoAAAAAAAAAAAAA AAAmAAAARU1G
LUNvbXBhcmUtZXhhbXBsZXMvcGx1Z2luLnByb3BlcnRpZXN9Vt9v2zYQfjfg /4Foi/hl8ZYM
G7KhaZE6DmAgdoKmbvYm0NLJ4iaRAklV9Yb87zvySMWy5T4YEe/77ifvjhmP 3rL3qap3WmwL
+2Hsjj/3zk70bpG9G4/Go7pstkKueAXsms15WiiZAluqDEoEtfomMtABbtt2 Ct95VZcwVXo7
HiXrRRJ15pmwSicVyAapZ50pkqMrR55p4BZmhSgzz0yEhcrRV9AyLyajxHsS m1LIbY+5OkNm
AILRp0K1j1rVoK0A81VA29NwMDt7JTDHIDefIddgCicA3Q8oQNEFlJBaoeQj 30JS8g2UznKU
krVHrkHaHoNEBN8L0wedgKAvGqAHOUGA+KY8wJzkVe9Z2GKmyqaS5sgEaxFk ASWVh83fGDOJ
Oi4JiYBJ5QewE4VCrBRxKXXIuirg50rZwt+KN4NfJZwmE/In+++XF1JYNqUV p/nICzomhPJQ
g6TmmmuNndclg/J+1z2Lf7nOkhRbaqv0zjU6dTGbL++o15nvOLxKRmTTa1hP IS8VGINldner
FV5EZRjIVDXSgsYwhWS5QMNvMN43wUYcBW8lxBKDPZy4U/wMTKpF7SO8pmCB cSZxGDoTFZkY
D0zlsLt+lfoqd5iFxLG/hZzjzXzixuW83A0NfeTOv1uQBkM0SIVA6d9BDGTl RnCcPN98XiVH
6q57C6BCOoBVjbFYZl/eyWSKtZ1MMJBhbTOsXvBvwJTEX86sg1VZqha7lEGn GdrRB+wrRB3n
9gEVbH9Q/lrez/HmM2cCCXhk8XxEmBVKpOAiW3+5O79iN0+zxcJ/X/we/nya h4/7OVs8PZxf
Xf32x/kFWQrFE1JYwctE+SgOeoImBXvCtwEjDrOKpb5ZQlauWjMl81KggXgZ TsiidL+uUUYV
1dhx+GukwVJmLC243GJOtuCWpZHpN06EKp5hvRtr8BHxRQffL1PGbhXbqQbZ pnAxZsKkmCFy
hAmkiYlmPmLs+88CPR8Wrw3j6vbHIXbpwIuX04RfiTAAKoWrqH6dM/c4uf2z lvgWeqN3KG80
HOv+YE5TR/Ddt6vB28uV9lVxFnOyGLvTdHvv8mU69Cb+wJEhyqCrfbs/4VW6 hIZDEJrV/vWa
htYJL+juNnjGtdIPwg2d8xVS8LWlzSKtsLvEB4M7yJ8op7X8R6pWRiiO13gf y7jlDr9mX3nZ
QN+m8c/MjbVabBoLScwB58EjrIPC4iK1yj02Q1r+FTqhRL7wHwOcBFxsx746 6NjXkBb5Glby
zYLiPfosiPqVe8XX0tSQilxA1g1MsMYzHCm8JF4O5XzToScSj8FcDkRzOR79 D1BLBwg5qWyQ
1wMAAHEKAABQSwMEFAAIAAgAUIJ7OgAAAAAAAAAAAAAAAB8AAABFTUYtQ29t cGFyZS1leGFt
cGxlcy9wbHVnaW4ueG1svVZda9swFH0P5D9opq+2VgZjDDuhSxMIrFDWlD0O RbpxtNmWkOQ2
3q+fZDuO7CRb14z5wVi69xzdj3OF4+kuz9ATKM1FkQTX0dsAQUEF40WaBI+r RfghmE7Go3gK
NONSw8H3nfV1Jmt8E4bjEYqpkJXi6dZM3Ar7S7txtWRX41EYNhCZlSkvGgtC MewMFI4XScEL
kwRCpVF7ZAT5xn4LBVEKBShigH2ThP4gKQSTGu8o2p39unlKxZNga4z8iDEQ uhUFhaDvQjOi
dRLsrdG8/bhvT+h72wjuBIOsAYTOsSN24eXOGOAmrBh3eU0GeXqs5zJm3ETc QH6vxBNnoG4Y
kQbUglAjFAft5b6p96rfJyZbni7D5TnyapC0LqUUypZ9VUnQSd+I0OnQu+OW c7u0eroVOeGF
f+iQCP2B6MGokppSAXMsM1HYYprXkq0UwD+gcRSfyRqySwgsVoIy1YMo1ZFA T4v40Hzcdv9C
zZU8KuD5K/9JFPO1Re28pUfi4uzcjDYM0R4WLW8H+RQkhySY70guM0DzuwWq JwrNFBDjroDj
GPCe7bD1XDsNFN96vTq045EBbbVRh9WNTR1tQzWAc+ouRvfWeFNmGRbr79fv cQ+44Jm9KPhm
CGV/cey5kraeTT0P5XPlYqCp4tJ0sugez4LWglXIWMH4UHwGG2vIgJq+sHp1 9LtQN8DmVStc
R8sv7Wc/TNxxes1vWn25vN3gCeXrqtl5hQbmNXCoHnuTKL4urWX2EpKbOtFP RM0OwAFll5xH
9j9F1+T5Ir2htiZe45rynmqc/QPA3S/AL1BLBwgY1A/bXAIAAIUIAABQSwME FAAIAAgAUIJ7
OgAAAAAAAAAAAAAAACkAAABFTUYtQ29tcGFyZS1leGFtcGxlcy9NRVRBLUlO Ri9NQU5JRkVT
VC5NRnWSy07DMBBF95HyD9mwIxatxMZVF1AFCURRRSW2letM0xF+BD9C0q/H SUpIabuz517f
OWN7yRTuwLr0A4xFrWgyIXdx9OhVLiBdHtVBnA7SG5NAk5tS+AJVuxmUdSO3 WiDvHdnyabPQ
smQGNlAzWQqwM4uqEOBC4twZ/3d0DDHCWAhm7Yq5PU3IyKtybVoEoyvMwZxA vGrOBB6Y6+J6
ykF8hy+PBvKsBu5bR6YqNFpJUI4mL9N1lk7IfRxldamNS1eMf7IizAKM77Xi cBtHw5pgGOmk
EBJFHB17pH1LmmhTEOACSwuEawPEeOVQdlljDeQurINhVqHFLQp0DZ0bgI7l v9vj/0qfDVZ7
w8Ge+0mF8H2pHq7wEgvXUmp1oVEHmuMZ0m/92pEOsJY4vMYDd1h1D7Vqv01D E8EOTRw9y9Pb
v0oWRz9QSwcIHm7bUkUBAADGAgAAUEsDBBQACAAIAFCCezoAAAAAAAAAAAAA AAAwAAAARU1G
LUNvbXBhcmUtZXhhbXBsZXMvZWFjaC1vbmNlL2VhY2hvbmNlLmdlbm1vZGVs zVXZitswFH0f
mH8w6nOiNFAoIc5QMkkZaIbQTqFvg0a+dkS1mCtl+/teeUsyneKW0sVPtnXO PecebdObg9HJ
DtArZ1P2ejhiCVjpMmWLlH1+WA7espvZ9dW0AGtcBnryHuwqviQHoyYdcUzE 66uEHqpn/YQG
U7YJoZxwvt/vh84UQ4cF/7K6Yw0EpEO4AIHUqvRQAcHkfDwajfkiwi5qt1b6 ua1XllSEW4Ug
g8NjyvhitRzMnSkFwgAOwpQaPPcoGyXIVPgpeIV0+AulKytrvS2UvbtNGaEf G/Rji2783gtD
AS2E3DgrgSXKlA4DYKRRn13P1O+wHRvCWV6S6moliPwBdjGwN3F+pSuPqIpN WCrQmU9ZLrSH
upMeX6dwHPZAZxE7zcmMKupZmBkIomqsNjnlF6MVnuZ2LeRXUYBPSoRcHc4D yJQvnRdPGtbo
dioDXIom9YDb2EKs2xRI2TO9V7w2VcvMtfCeVKqh6uMFAl/YoMKx5dXMJYiw RaJKpDeYb5TO
TiFGYoNIWfU1WbwLAdXTNkDyIwXuacNp6ICM/3lJs9VB9SpaF1R+7MReMlCi KwHD8ROtwPnG
KQn+YkKee/sIOSCdMr1xdMD/y1wVXK+3Vjhl985Gc9EWMVr1C7O/Z6gt/TdW jcho99OZL3Tv
0vkHCYw7L1N+2uT12cLPDpd4pfHv7jT6+w1QSwcIcpf9FAkCAAARBwAAUEsD BBQACAAIAFCC
ezoAAAAAAAAAAAAAAAAuAAAARU1GLUNvbXBhcmUtZXhhbXBsZXMvZWFjaC1v bmNlL21ldGFt
b2RlbC5lY29yZa1U0WrCMBR9F/yHkj1r1L2M0irbVBA2EJ2w1yy9bcPatCTp 1L/fTasuhcEm
Ni+Bk3PPPTkJN5gd8sz7AqVFIUMyHo6IB5IXkZBJSHZvy8EDmU37vQB4ocBf rBn/ZAl4h1z4
l6oJVvV7Hi4Uk9rHw5CkxpQ+pfv9fljkybBQCX1/XZEzRbcp+/uaMRmNxkh7 2fIUcjYQUhsm
ObTUayetYuCZKDXUCpDHVmVCF5ZGPMlyJAPjafEjJPVus7pIXA4RXyuIxcEp mNqKAJ4zprWI
BV7ZQ+++OZZWtgmlPjy3WkgjzLGps5VboypuKsWyJTDc4ReBR2OU+KjMxa/G +DNwYHhz+XNm
mAW8f4VwR+kCXaDk6fp2iXlI0BkQepvTvMqMcNCqLEE9FZWMQjIYOw07usF1 djcQg4LmbZ1g
Hfhky3ZoHu7GBnUeDvpXHp015qnIIkSuaenxQhomZA7SdPMdWBQJg0OBZd1/ 3o4CmnSSUEDd
mWAnJG2PSIS+AVBLBwjHpZdCegEAAF0FAABQSwMEFAAIAAgAUIJ7OgAAAAAA AAAAAAAAAEkA
AABFTUYtQ29tcGFyZS1leGFtcGxlcy9pY29ucy9mdWxsL2N0b29sMTYvQ3Jl YXRlRW50aXR5
X2NoaWxkcmVuMl9FbnRpdHkuZ2lmc/d0s7BMFGAQYDjCwPD////79/fb28cz MDDseXGp5+am
tDMzHQ40/P8fPz/e/v99+4aGBmTxXdPVgGjrJOV1XfJLm6TmVYrNLBH+9/c9 EP39fB6I/jxf
/PtuMwMMKP5kYQTROiACZCcDa4yCQl9KpJ0aw8yzh6dc2Dqpv7lvUomn8WeT nmvZkzTF1Pul
kjOdAzVmLz/BLtKnNefUSTcrBh21+94uFgJBDbNfJHxYdLKdaWGCm/yNlprb uVqnX6bnM+TU
NKU2NmWrKjJYAwBQSwcI3bcz9s4AAADfAAAAUEsDBBQACAAIAFCCezoAAAAA AAAAAAAAAABI
AAAARU1GLUNvbXBhcmUtZXhhbXBsZXMvaWNvbnMvZnVsbC9jdG9vbDE2L0Ny ZWF0ZUVudGl0
eV9jaGlsZHJlbl9FbnRpdHkuZ2lmc/d0s7BMFGAQYDjCwPD////79/fb28cz MDDseXGp5+am
NKU2NmWrKjJYAwBQSwcI3bcz9s4AAADfAAAAUEsDBBQACAAIAFCCezoAAAAA AAAAAAAAAAA7
AAAARU1GLUNvbXBhcmUtZXhhbXBsZXMvaWNvbnMvZnVsbC9vYmoxNi9FYWNo b25jZU1vZGVs
RmlsZS5naWZz93SzsEwUYBBguMrA0NDQEB8fv3///v/35x84cADIZfjPwMDw H8j+/x/M+g9i
z5kz50CDAxBsmWALRBv67db0OCzvdlrU4Ty31XV6k1tzuW9dqV91ccCVTZm3 9tY8ONH/89ef
7z9/f/3x+9PX3x++/n776derDz/vv/xx5/l3BuoBxZ8sjAwMbAw6IA7ITwxs 5Q7NBR46Qoon
VC5ptFTMu8DbovkzYr3MykKmV1XWNz0nCmm1yz0TWBohuJOTvyk6RDPK7Yf7 w0b5yC5xFRVe
1hbeJnFXpoJWlpZCJlf+Kl6Waf38XT1T+1kmukioqra1LpJwlVRbVcW/Sk3S VWqTVAHLZikf
Jyb++S6ODNYAUEsHCMZXQJcPAQAAWgEAAFBLAwQUAAgACABQgns6AAAAAAAA AAAAAAAAMAAA
AEVNRi1Db21wYXJlLWV4YW1wbGVzL2ljb25zL2Z1bGwvb2JqMTYvRW50aXR5 LmdpZnP3dLOw
TBRgEGDYzAAGDWDc0HDgwIGGhgaG/0DufyD7/38w6///PS8u9dzclHZmpsOB BsWfLIwMDJwM
OiCNIDMYWPQMTnqu3mvx+ss3Ff6Hha7bTVlvpSR4LVj41Ubv4zS1q2blPSs1 +XWXM3a6HZko
JMzIYA0AUEsHCBuL7Od3AAAAgQAAAFBLAwQUAAgACABQgns6AAAAAAAAAAAA AAAANgAAAEVN
Ri1Db21wYXJlLWV4YW1wbGVzL2ljb25zL2Z1bGwvd2l6YmFuL05ld0VhY2hv bmNlLmdpZs2T
+z8TCh/HVzznGBPdkdMhc4oWmjqHpBS5zimOEsql4bjlLrkcz2TozGU217WZ y+aazd02t5aJ
bcahickmZmGG5tLF0Tme/BfP+/V+fX/8vD6fH752DrZm5n5OgOuAz4A9dnd3 19a/rK1/prMm
hvjiIf6cRLqxuv7FwjPL0ivb0iuLyWQSCAQmwuob1n55N+BYG788WzjWFo6x D8h3Di66GVpy
M7TY5SHO9SHOLeKZexTBPQrvGUv0jC29H1/uk1Dpu2cFPIkUmFIVnFoTllYX kfE8MqM+5k/K
o+zGRHTzH9jWPzAtacU0ZDENVdqVVdqNITGxe74orO7D1fXj6liEhoGyRnb5 noPkFm49fYTa
NUpjTdD7J/t4QvbYLH96aXx6cUIkFbxbnpGsCcUrC7JNiXT98r3sK/dzLO9l XfXOveqdc80X
bfPg2wqMXUC+rT/G8fcCWHChSzjONRznFvnMPZrgHo33iCV67JUv802s9Emo 8E2sgCeTAlKq
wpB1ocjaGBQlLrsxAd2MKGxPK6EhS2iZeAaK2I0iduWU9+RW9OZW9GDITCyZ iSG9wJBfYMkv
Cmte4ur7y5vYZY2D5U2DpFZudTuvjj5C6Rqldo82975uezneNSjo5bx9yRMO js0OjYuHJySj
UwsjkxL+9OIbkVQkWZsWr8wufJiRrK7IP5XUswiUV2XfApsGqzt4lO5RWv9E L/dt/18z7Nez
3PE5vnBpdOr9yOT8xIxUsrwhXpIvf/i0tLo1+Hp2eHKeL1x8MyMVzC6/W/gg kqxOi2Uy+afl
Dx+XVjc/bH5Z2/i8sLIpWV5fWtta3fi8RfXZmm7ZnBuY7K9qby0tJhVn4IuS C7FxmDx4ajqx
uaWW1tbdx/jmwGBHN6OhEo/tYQ2+m53hDfw1wh4b401MCeYB/5dA9s7eLwCU dgEKStr2TeUv
05QOG94LMjm23xWk50gwG9Oty1I3CBGeOV+EyNQwjtZ2wPpCMnWsAyGclnmH AsPzHYQ6uT8A
bQCnkjmbgZAypejllSn+Aqf8OvxQafBW0C1XB2ujc1MXAK7kW3EoQud6zSTe vcK2EGVSPNUa
xK933smfc290Z4WIEtXdoYGcjWXREC2C6tUZeS55B7rGqok5LA6ZoEWR/dF2 +qR2RVfwfRpA
LznJFIFAZ6idtq11KgzmU1xpqCNAbKg9KYhDPIf3CBxWtUj6B6R1VjwWl1/n SnkWF+pJuY/2
/PXEsVleJyw6Zdt86y6OfPv02d5nH1feN//O2tVCn40MfFkat3PZw5IqYFio LJ8Kv4x7b98G
zzyuJovY9uqSQEWJJz8uzMQBh2kieAPjGCelzcp+6HET75Syb8m+wIJw46OP Z+NiNS+URYGv
mOEVhp3tdSEk4SOvWGScgOgnf2WXZ6TfMkAIA5kxAZCvLmccoEaBj2BG2o+W 5jLl+hoO8Wq2
5l4KahfKxah5VQ9wrLcBh5jqp1+FPPS9WR3pDwvuAlPhzANcFVgz3BxRPJ66 PXPD/2Qk0zCp
yEHrz4PVHABe7Su9Evy07wnOqBN0GKbQo50PKvXJsHUkJlErpdVAaod2mDrV oB71tOgSwIgB
wfCgICW9bHKB0e72kWpceL2UCNQ0VQbnS3+ZLj+g6LV0Fst0rYcMHECs3Adp tA6RCzrsuPva
NoJX21NOklVigus5gQqVvQZ/QiQjCVhIvO5mWIMOxgB1JnEgVNYNtFQ5+bDt liaEHvqzzhBd
whW/z+M1yAK64LnARuLERGdwx3eaengk89Io81UfVN2E4Tij6AQdsPLSIDry KuVd65/MjWuU
Vp8Yo8M8k88PhIbwon67yoE6svXgbhtVp2tWmijqxyXQ3qN/8Zg8TRWhbiZW /nW6isx70HLG
sZzXxBVQXY17/+YKAQr+pqJGvkx6B2bqsX2v/Q0wtOcjNzllmFT7IJ9CmwqD 7sqxic0NFD4k
4iyhvdt6+u84tFp/Q9tMEl9IRz886AYy/e2wdwvnmt5MnOj7cz2BvATrA4wp khcP8T5s0MZM
6DE0LOfStcAQaRU+5dJyvsWox/nytpzFaffBtQTxDTVw4geGbGSH9lxN8ets evyVX0RAVWuV
+Vyfhp3X2M+qjwEsX2L+QtOJMqio/EfyPyIRusfihdj911GTl13e/3SpPCdI d72t2TvVR16w
xxr3SXEjJiBEyXkXpyBZTInehYvXnAMi4LuOzz5/6ehsBMtPv1fQUpykKduV NCGPXKhQPl2i
7l2g7KKZXSa5xK7YEvprDN3VAB9oYt3W8Uu3Aon1dhGCvuO5Ki5a5B9VLc+o k0DWmtRrT47U
2N8wuHQKiH7cf7CD/so2aB3JOfFUxedLY1T6KuJESOXNcTOQv80pYGT2/EGs iZ1R9JhSvEQM
PPc0z9s3Et6sfpQuGC8yqjuf2mf1nTa+ma13gYXJC7M1zTbhOGjNYe1u6Q4d ENsZG6Bj0z1J
WpaCIhvHjYJamL5hli8Hdkd+Byi9MfjvMYBLMyfjBFRyE1bH9SZiC9FCEusB zol5kBtB0lY6
HM8B+FQeOjKMqAbnyJXA92R3Vk2fGi+RT7oYtGbMZ6WbaDCzA01IhEXYovlw Ahe2AUSgrNk/
R5k7Gl7UyXFwrH4+gdv9NaaylcCH9VkwbNuQYTFFPlKXLRDO6qOijobErcYG p+ucqpwT3m7B
Ng4T3Er9kluRLuE5P9HNDoC1laG1a7up203Ir9eL6dp59vsW6wMEW9WyZPCh 2tuUKQqvqlAP
ZBngyR7Jc9O0v53hMJSALP0J9ERAcNf4z35Q5s/jP91RNZx9cjCbTI3JzbO/ S/w73jLxKPgY
9u712+lar/1RLSX7zesd9HHIH1ydG1RC77rtuOXtI1/U7AFk+H7vJOjT+tSU cfQ7K3cS0hWg
2uivH3QZr5G1DwQ4VsgZguuQiocX9IGJfjCoDV5xoORTQVUOkigsujLV3Fal bWA4ItDTc0pL
twEeT/1h14jbm4swLb6/cajEhoQdfkX5b2JhyPXAt3f2v1I+7YcChsfJ3vav rzcwzCXvHoDv
TXcO0yc266J/iWGv60sZj555vlHOvMjQP45I264OYznUzCkHdFL0ZaF+0iL/ 5Q3GSgXm39gk
esu/Bd3vxte00rx8ZLX9Ids5s4sH1NUBFv8DUEsHCDhCsWwvCQAAngkAAFBL AwQUAAgACABQ
gns6AAAAAAAAAAAAAAAANgAAAEVNRi1Db21wYXJlLWV4YW1wbGVzL3NyYy9l YWNob25jZS9F
YWNob25jZUZhY3RvcnkuamF2Ya1TUUrEMBD9bqF3GGFBXWh7AGtRpML+LKJ7 gTSdttE2Kcms
uoh3N01bFruusOjfZPJm5r15SbxcBj4sIeGq22lR1ZQO5/h7wiUXq2LRB3Hg d4y/sAoBGa+V
5HgV+IEv2k5pAqWrCHkjOoMRtqWNlcYou2eclN45ZDyNPQtDyLESMtwa1GGh OIThQGFTIyR5
OpYlcZ5CqTSQTbeqwCZyqBVBp9WrKNAAA66Rkb1HqlXh4D1BkEqGLDekbS/g DTMGVDnv5Lig
LA6Z3BjcK42yMXgYVjAgKpSo7ehi2s82bwQHIQl1yTjCVDXKAXwnO8vAtBb4 CHzPrcUbtRsh
qwZJSdvFELO1E+lyKIkG7NEdesdFeTPOniPtHZBcrZ82t+u7DK73+q3LTTRD rvqckIIuLp2/
eyWPSFste28kvoHKn9FaYHUMLpwn2KaZJEHWYBue/1WTduNOnPbTJhxqfE/D 4ai03pLpP5ht
1/8BLCDf2Qth/susUdgps34xeHy7UCHNUqPKT4jjmceB/wVQSwcIZ3bFIooB AAAtBAAAUEsD
BBQACAAIAFCCezoAAAAAAAAAAAAAAAA2AAAARU1GLUNvbXBhcmUtZXhhbXBs ZXMvc3JjL2Vh
Y2hvbmNlL0VhY2hvbmNlUGFja2FnZS5qYXZhzVldb+I4FH0Gif/g7Y7UmWoh O+yXtMOgMjSd
jUSZCoK0+4RCYsDbkCDHSFuN+t/XduJ8OyFpgL5UqWOce8651/f6Wrm56bTB DRiY7v4Zo82W
DP3/leQAH3ynWe/Yg9Jp7w3zydhAAA1z6zom/NRpd9pot3cxAS7e9KBpo70H e3C3ps8uhj11
RAhGqwNhc4tnjm3D80pnPfomlM6bwTXEUNioCMA/dLtgBTfI6R48iLuWa4Ju 1wevbyEYrIbB
BwbKagjWLgaEDu9cC9o9PksjwHQdYiDHA4ZpQs9zsRdNhMQA7upfaBIPEBdg uMfQgw7xv36w
/U8BMLDRkLEITIb6p4FC/0+/WkODHDAE7hqUTYXOYZd5YziW/0PLoFaR5z2M ZgwUYQunBDpW
lpBbD0ZS99Tg4d4wiYuf/RmcGPCEHOvzVeAcV/6bDXQgNgi0hOscVjYyAXII xGvDhECs9yh8
6j9CrfCAUBh877RbXLdWII7wPsfYwZ4/LNWzJUfWSpnX4va15tRPnQ2A09GD Cj6DKwH8ijuQ
3BJvz9AsZtoJTZov6frMqC0h+z8VpZptJ+Zrvnycqffa32WkeXS6DYnrUCfw iEFnMc8mkcnN
25jxMW0610fTMRM4dGy6j9i91EyNjSEHkfcfcpDEohwgKwz+6++3NnKe0is7 BJFntiAYwN3Q
/3eg0MeXaz+kX4s7Eaapb8qnZAH/uIHE/+X7D1JKaQADdapr+j+Uw59zyBG7 VpwYBpxurXPu
ASBMCWyP5UxcA0OMNesE4NbFFs0DefYvl3Nt+nWiLke6PtO+LHS1OqKHg01Q MSBgI4+cE9XD
YqJrCVAfa8kUZtAYKizGLiAT3WTUmeoHb7+OTIWALiRTHNQv1UCNt8i2qO0x NEFlsqMFxwWR
jf/SJncUFIX0azVII8tCBLmOYb+dTWJ0d6fp2rfpaJKIqd/qidV/s2r1Kajf c0DRynIFMUvV
HsEHkwKk6gRIPZHBr1OpraHMVgHHvTrSFzN1Of62mOoUyh8cShzMDFKTadWe qtO5VNzabAL3
EWXz9mtxYW5KkSVpPnt5idyfIK9++IkKxLL6p+MZYWNRDpMwwyoGP1uE4crJ yib6U9OWMldq
RBGROWjCQohNP6o+ig68EfHLzKq1hWC7Q5EaPNMlxcjUKOfVwrdYZkiZHkk8 DcmRXrSiGtFe
XRoWYckRD4tYHXIOKWLmSo04LizC39TQIWIiHRaxVWsLcVRYJMXI1ITn1SId FtX0SOJpSI70
ohXVkJczRcqIwohrEpW05xCjyOCMNWWKiMkNaREtd4qcHdXZyVSRX39fIHdL DSmTIQdZQ0kj
d+Wzhkg/ESP9txUk/UpR0m84TPqFUqz9ljV9NggwMT27QP+FaESG5xjR6G+K 0XpfLuhkBt13
TkFyKMNAof13cI0c+nUbEfolW3aDwcyO3WHwZfnFAXuS3WKk3hVeY6Tmxu8x olfSiwxujxIa
VK05HF1FTAQJ7MohIFAcf+MxEZDVSMO3WKEiNNn4yvZ8ZXNKm74ZrgKyxGEy bP2GrfRe5nxZ
hcEKnWHhSA2wlwsw2vQL+sM5sGWnuxo0HNtOPj8V2aZyHhP5B6v6/lDcsT0x CVG+KWhEy/0h
U0jX9ofyvvX5qch2r6X+0AQRlXrd52cj1vHOoyFdzNcg4NjO+Pl3Bkl/PI+H ghL6FT5xXEv9
ck7RL/GKsHZ9YX9fgKKk0nSn/T9QSwcIgXlz0gkFAACwIwAAUEsDBBQACAAI AFCCezoAAAAA
AAAAAAAAAAAtAAAARU1GLUNvbXBhcmUtZXhhbXBsZXMvc3JjL2VhY2hvbmNl L0VudGl0eS5q
YXZh1VjRbpswFH1OpPzDXVepabWAlMeNRa2mPlTatKnd++TADXHr2MiYdlHV f5/BECBAAjSd
0jdi7OMT33OObeyLi9EQLsBxRbCW1F+qmfltlxuSxtMb7zR+sEfDgLgPxEdA 4i4Fd/HLaDga
0lUgpAIhfQtdRoMQLVwtLFesVoJbkaLMuv5OQ7WrM7pConX9c36PruloZxQ/ TCYwR5/ySRSi
nHjChcnE0L0CiYHEELkiigoOYgFqibASHjIQCRicObiaOfPZNVdUrR17PnNs 3XJm5fDIvQq4
eRuYiX5r0IVgTDxR7sMCiYr0tEAkQhgF8T9C77MZETEzBMBhdPZ8ySh/2KyX ZUh89FHdaSSG
V0pJOo8UQszStMGmMSH64tgaqBXmj4gpWoZMmvojGka3uECJ+k2R5aaxF8sy pGHZG/HbkjJP
j0ywsh9dQa48j8YiIqy8gnl7/2XMOE1LDKfbMI6dqcexg1yFlyFiATV9+GW8 GMObicbnpnei
fvPoI0dJtDgz/0ZzRl2gXKFcEL34ZiTgX6U9EEJqQHgeDQeJAQca5Ra12nmY OOuRsAgzm2XO
qso28xiQrM0yWI1uHmRuix9uUhsj4bHfitPVWqQwD9CQnylwGRL5yaDpsdqn EgljawiXImKe
pqBDQib/hICHoStpkCRI3NeyMrZ2xqghJuJXlzJZn4bl2cc3nSkp8cewEgvj O/3A/fNCr/1C
+LMNkg03uUi9rydKRniSthZEMkhUMjCTQjWlxudJNufauENVJ4xDxF5X8eyo UEAkWaUUY34c
n15bqrq1aVzPR0E9aCyuobK9sntdV0n2qumA6W03pR1vYfFPcIV2P1dm94ox 1wFCWrB78kgs
RrhvGWovh7Jt3Ta0TfTYrNuGs9XNmOUNuuzLRvUkhyfHFGQGlW2+4sm2eV3Y bjfSkVnbgfO6
vLUX5jm2ou/jW5/Xm+5jU+heeZ2DtNSF2burp7RDpXSbY19XyRwqpdsVqG5t Wqb0dklfldI7
rdY5pbcKduCQbrbq8Yb0bs59QrqzGZOQNgh5SDdbcq9w8mvMRjGxJgjlK62L I1RP6d61i+yx
Sag18Y46ynC3jt8F/H3n8Iqocsiucqq/xb7dPa3x1nzEd7U2nLf3/5qvBv3u bHVA7aInv63V
Yrz2LND9u8h/v7l1LlzTWu09GzSXu+f5oPAt6J3l/PTdBv1+5j2TfvoGUT9N HfwCtp1+rhsN
/wFQSwcITdHem5UDAADAFwAAUEsDBBQACAAIAFCCezoAAAAAAAAAAAAAAAA/ AAAARU1GLUNv
bXBhcmUtZXhhbXBsZXMvc3JjL2VhY2hvbmNlL2ltcGwvRWFjaG9uY2VGYWN0 b3J5SW1wbC5q
YXZhtVRNT+MwED27Uv/DUCGRFjW5U0AgyEq9FLTbyx5dZ5p613Uix+FDK/77 Ov5IQxrEBS6J
PR7PvDfzPMlsNh7BDC5ZUb4qnu/0tdsn7w3WeLrMTptFMh6VlP2lOQJStisk w5jvS7EYj8Yj
syiUPhzMutZC5TEywcsKY9xvzbpQGKd3glbV4jOvh80fZPpTt0cH7fO0DeQ4 /UGZLtTrsod/
+Eop6pzLOG02j3Zt7yShiifzOWzQmOd1hWqeFQzmc1fRWwlNQtyj1FTzQkKx Bb1D2BcZCrjc
XHskl8nmOj6EQ5kdB7vJUaKiGrPQj3ojOAPWFBJSX/sONcAXbSKZs66xBXR0 B/6NR8TSIibd
nUKTq7JwM9zSWmjYesf3pGJ34cNCkI9pkR4vYokRz6xq4rMjmFxyHU0tWqI9 bEL6XgZ333QF
Uc80DcqJfxrglYkWL1e/1reruzTOUYfCRZOd1uVFkgSFT6YLsFn5FqKBTCdX IGshPEhCFOpa
yQFMC3v+1nzth1HNdgbmC8PSCgbDKsTq6PCAVRR5dPBctOF8XonPQwKJrOdb o+bjvlOjXWk6
YK4E1fr2f1u/ByE62lVdohrE+4Uwbh6eUCmeYQeSG0DAbFUiN7UA7S9Ae+a2 Z87YyMYu+Jaj
Wt5H09A4RitsKQbZpav1cv37AnyjXJpUaq5fHVtC/OO7cErSO1U824YuhcCc iluV181TbCUT
TdamV24qnE3gHA7AVnSPpqLnMDkDXoEsNFB4ooJnzt9inhz0832lDuW1THu0 Xb3czs0x53Xl
dNzafYF86ZzT9wqkp1PfRGgmxXtTIOGxRb3jaXOjdf1KzBmWClkLelDl912f 4VHbYTbMqK9j
DKOoJfMGSTLwoMej/1BLBwh7wIM5kgIAAH8IAABQSwMEFAAIAAgAUIJ7OgAA AAAAAAAAAAAA
AD8AAABFTUYtQ29tcGFyZS1leGFtcGxlcy9zcmMvZWFjaG9uY2UvaW1wbC9F YWNob25jZVBh
Y2thZ2VJbXBsLmphdmHVWVtz0zoQfk5n+h9UYIaEyQU4lwcKHEzqgmfSpCd2 Gc5TRrGVRAfH
zlhKS2D638/qYlu+JC2QFs4LxNLuai/frnbV3pMnhwfoCXrpx6tNQucL/lp9 94oLcvGREzwS
P3qHByvsf8Jzggj2F3Hkky5drsLjw4PDA/gRJzzfsPWPU+zzONkcb6c4VzLr KCJO+cYUHyfz
LvFDumKkS5Yz+B0nQGdxntDpmhtCtlD2Q8zYjVQVlbbQjcmMJARUvVlH4ahM sJN6rZfG4ajT
QVMyp1FnzUjSCWIfdToqJlaEBDNZkohjTuMIxTPEFwQt44CE6OX0tZb6sjd9 3c3FkSioCnsz
JxFJMCdBGtH1NKQ+8oVfUCkkQk1EPnOQBHvmYqZQhQd9PTxoSLMau+xqbNey UVKzIfVsrBJ6
CQtIhRD4BDb0xysUrUPl0fzsfkKAniEM/osYx6DjLs+1UQJ6Mg4BDdAV5Qsl 5eubkEafbgBK
dyxZkw2qrFyj6UaeqVNHSU3z6GLsoEscrklXu2T1ehhz8kJywBEJ8Tm6wiAh Rr60x5SFKEOX
FMslJrDhKykzlXNoSfgiDlITHtKIciT+abau2+hqQf0FwiGL0YokszhZMsUt KCgO6ZcC2PSR
bfAEOIqvk4jJdcNpKYkWM0NxROAAUDvYAIyAjHV/EBaMkNuGwuDYVnIekqE7 gRAYpA+Vf25G
YTVTmi2J/QZbgz+bWnQblQphlzhD17OGfbsFeG1cFzF7B/migIGmcRwSkQrM AQshWq8AJiEj
9UmTJwP8xFGQg4KosBdzBwF8YJlqBMn0UnxiA0cbFANTwtB6BYhSyAMsBmQl SksXIVcWFMWt
VqGqUpG8CVgABrAZBZ0hlXwcAprn8rQU4CATVovcPIUjA3+CFgQFseADZYAV fhAwHk72DDkB
uIzUZ4Gwg0bgjxr5ARVpGm7aQAGrCehCtDaijihVs/yhnJFwluf7aFYgUN6G ulo4TfiiLYzM
T5VeVFIW+JKgKOZoQzhYSyIzK1X5oUlea5RXZzRhXBcVhRp5dM4pnUPyAwUT SIoMLAhcIH4V
A8jIir3Q0Sccd1SFjaf/gmeYQgEoX6wlSqTWII0SxEcrAx/GSW3EqKzgUcb/ mNWdtYRqmYh7
GWqmkgSxZbL040jCMPe9E13GvlHmcihcUVBXuBTPZqIGCwxnavMF5tLpWlNd 4qTnDZX3Uezq
SpTymE6/fgw4gXs4q1lZFVNabCOrKRiqE9D1onytq7qoKhyU9mZaR1r6NkDN EkerUpG7aeXr
zglPd8tsXW1wSxWmRq+HRlOOAWeAIX0Fmjg17tVGXfsCAS+b8qqiq6BsNW+p cKpg1lUAdOpO
/qvaDNwg8AWKyFX91ZK6wyjfPFmT3EmqcGdVRCZGgDlO80KQVX3R3YKlXK6T ISnL1Ez2Fpk7
wJfLPcPJJ0NL6G9oFFBf2AA3g4+jx6KUIX+Bo7kEad1Js4SQLyQTq5FYJbzj m1Ylju5FRWRl
b5pmi9bKbFjvR59sKsp1mrhw9YUk2ynp2Mx5Wqa+Eq4uAM4HMhyeAg7WCYF4 io3m07vuZHbY
c7YOOd2vOc/uyZxseKyEJ9up2JPtfIM9z3+iPTI8+zXnt59oTn9BwwAW92LI 7z8xbawgoKLt
weF+c+ePXyA4z/cSnT/vyZLidCjNKS5VrClutwSH/u3ohqR5T6NlPlP2dWuw c6hUTy/104Ex
FpSGsnSonK8xjEOB6BT0vJP25mL8g/ac5s08oFbOUHLG+dE2fGvsLmMaoC0N lNkoa+eknfKx
6uNyl9U2cvJBTr5eBXp+m2mACrrS65dSQn027aHneP9ICDT0Rp7kJmMbKdLJ xHWG7wb2xPK8
sfP2wrO/ifnsYuA5W3jz0r/z4LF9ao/t9E3ktszq4O/j7b93BifA9k2WWicn jueMhtbgO81N
T73zK7mSoI4xs29J0lg8wegHxp1vgNkTRZ7LOmcP0wcAlbi/as7uGFDKA672 WSl3i94s5q8x
MBmjKSN8iJdi1rPONGbEEjtPyIx+liPgOSDZ+WjswUzYrE7Duj7wzYrIxybw NklYtu2KJ6B4
LV7sZV3dQgYNAJIPlYKAyedlVXBqBz+jFqVV6BhhEBGvhJshfGrTPAj8BBJ0 TSqlg/zq+urr
gfp80EZHjjux3rre2Op76ssZevb41OrbbQRf7+yhPbY8+2SSztGT/sByXeUz eVyewjtmnjaS
b8bpFKn7AKASWw9YkRz0En9caKOnbfSsrLvQEdQdug6kuPr8MBpYnjNQGvff W8N3tvVWfIrN
i6Fre576FuadyP8uhs7fF5rixB47H2y1PhrDl31yg3nlEWi3dcsCtWlcZ6/W HX2PeXn93DES
teVDXdeYs1MjdOgy2r2Grj86Ox+5jqd2x7Y7GnywIWlHHx3brY3uj9ldHp12 mL0skO43pvdt
dj5i7TDY10T7M7Vo6dHeTa1L3NohbHf24irLndWnvWWwMZjdIqbP/wdBLV7F cBvG68QneSM4
1ivm9a3avWvU69U88B4e/AdQSwcINzd4T2UHAACSIQAAUEsDBBQACAAIAFCC ezoAAAAAAAAA
AAAAAAA2AAAARU1GLUNvbXBhcmUtZXhhbXBsZXMvc3JjL2VhY2hvbmNlL2lt cGwvRW50aXR5
SW1wbC5qYXZh3VpbU9s6EH4OM/wHwek0Tic4M3mEQEnBbT2TQoeEnjlPjGNv ErWOnfpCy3T4
70e2ZFuS5ZCrmekTRJfV6tO3q92VO+/eHR6gd6hn+4unAE9n0QX93REb0sY3 pvMm+adzeLCw
7B/WFBBY9sz3bNDxfOGeHR4cHpB//CAqOgz2z1c640wxwotw9MRP/m49Wnoc YVe/8l0X7Aj7
Ht/vB1MdbBcvQtBhPtFtfz73Pd3zIzx50m+SP9i22Ky151zNLLzKcqmCxgCH 0bLBYPsB2eOV
a4VhtTZ0lOlFEHiWa9yOv5Ndvyw2QV03eOVNeg4rzKJrmNK5qWfQrV5bkTV6 WsC9h3/GkO18
hYl0qSvfiwiyc/CitefeQei7j9ibrj4zBzM/oU5G9qOTEzSGKfZO4hCCE8e3 0ckJJX7fQwk8
kGiZAor8CYpmgOa+Ay7yU21Qswfzi974glK31xlf9DqkpakX8sFzytJ7C/p3 RAROCLX9X2RL
aAJWFAcQIiuAYnVwTumc2KWTEOq5+OLPpYu9H6LhMRNKzvKfKURDItSFfhQF eBxHgBJlaRvK
G1N9n3sdInE94V9iN8Ki7LRpB6KpjncwgQDIEF7vvHE7vUXZVO/tRV/NsOsQ EanQ7MfG0vqO
gxPiWa6IctG+A6gzLbuCzl1ZXq+Tka/XWRQXweUUPAgsQtHsOojHLraRnTg5 VKyE4HdE7IA0
Fc6mIHg2Ev05PGikttlgpuHAxCJngx4tN4bMAJtsWwqGa60lHG8iK2vQ6RKV 9t+oNt6k6zIE
UC/P+jlY0t9+4BBq0V8EpcYi8CMCAzgoTJyLjSY4Oc4hkUPcwNC8+TQwHvqj 0Z354X5kPBjX
xsf+/WCEzpEXu9RNi0DZ5IiJtL8XJwZNKHm082qwNkBJdGkMJKVT4zBCLrlW dgWUrMHaOKWX
XI+idYHmgriNeZN7RpE3ksNsoiBr2C1vuOXXx4N6llAUtCk3ZCCUFweHw+65 sRUWKTcoIowb
2yCSXRYMC/G+ayK7iPL2BEihwJZQ2EyQAoQXbyDFLc0Aqb6n9+BhlWrs5Dbq X1+bI/P2pj/Y
6Y30V+HGoLIUEdv5cgC3sLuuZHjd+i2vuzPT60pAbKyiqIjqMkiCTwJdEmw2 wngBgdYiizee
96bA5e0jBAF2QFQmrQQgGKY2l/7ItAqApIEekiom+gCTRNZyQ5Loj8zRf/tV mkXyjNnKEJLX
VQrMatHt0cfEZZU1Yzp78EvqYSqzft915AT5XLWPRjnoLItOB+IJ0oAvwtzB zxgTM9BaiZ00
GrTzSSPzUalao0UzHLYR36wPjVG7xAN6/A8PcujbVmypLe+otWeys7MR41BV bP0nQ0wMUtE5
vVLYgIbci1LsFBWobDF2/Hqag7YRBbUKwi/EBZsFgik2CTg5r0sRdA3Q0ZBV GX3noEkBLTqi
qKG3b+VYVwcz/Br4v58ICRmmUnmxoE0h7xxp0qhWOYZuZLYhzKP6t4CW6oCu XV6CYl21GcV4
pvzLVraBnd0Zw9vBN+NFW7szPhp3xs0Vb2u5hm0Z+hbb47PMKgWUddFqbIXY /lTJrVdUUHTn
hWZM8dznyoxg/UoSqzhbpmxZ9Cu6800oVpM7z4I2VTosunMOXYU7l7BHytp+ tho7/3X8eQ5h
hT+v2fBk7LjEOUcti4NlvIp2Hin5BWUjrK4+m4NrAlMZJC4frjPCVKeEvFtS JFi1uiaVhkW0
qegtRZyqov551b4a6oRSvdRruCxVatuu2GZbtcvXcl98Dl2ywW6VEXb3aIXd ajPs1pieUrxK
r+AITI+MCsnFM/cfQY4NkR/NIDA8p42wF2XvmOZ1WyFpHk7DLPv+hSN7hrR8 fA64FcKLiJ3S
YI+BpWnCO2/v/UVLcLUtPY18mP6Fvqk6Z6uv2l1n2e4q6wqBYVKP0CWwi0kc sPn8WonBjhtI
AKlJJz32fRcsDwU07C8akpf4JFfb6tDlXFc8BVV5YoUzlbK/kkw5Z11BpBzE nRY5CwOmhWSl
uTDqTFChMlZfeW+yHtLe1hOpNjzBylaQorozShKVocDmViqaZJXVJaTmCJ0T OSfwns1tGC8W
ZNHwXyvwyImH2nHs2TOwf4Bz3FLbYxqYwLBsjcxQyW31Lakj78P2FJU3Fgy1 8mUFPm9skQpT
JJcrWEFuMKoRJNzou66mFZ+O9d7nHyKwYtHmmlYYuiJ/zQoiW4Iir6Sw4QpQ +BFLQWHxy+aa
Sh5CcA1l5bi+/aq1xOVUBPVbE1l2RKIHqsaiuwMwUtfGfNpQ9GnCrFojB+qp 7r1Q9lU1uabK
70Rq81H7dC1JslKXW9mHN9ijKS99ft2vXVfYJDWCgui122IWmYMZlkKHPUbp S75rY68X70sf
eGXvGqfoqHK6Dj9jyw01+aVr2wxAenrinliOxC4dh8Z8ET1tkyGoC+/ZotsG /FLZtbSV4rVo
na2oE4K8ZMmvkjWuJf/lVOGFj1NyWqkKaRy1lorJ6KUqX22ekhQ1JRVMXQkn VY0gHL6uF2FF
zcin//CVNP7JUdC6GEy/92CV0Q/xhPAvybiSb61okY3v0eTZFBU6XrcWC7IP 7RjJHuAUHasG
Kv2EJKstWX+FKHFQhSQFcSrEVVJMHNZsNbPmFFvWK4BLufCMOp3iq5fDg/8B UEsHCJiSLUS8
BwAA5zMAAFBLAwQUAAgACABQgns6AAAAAAAAAAAAAAAAUAAAAEVNRi1Db21w YXJlLWV4YW1w
bGVzL3NyYy9lYWNob25jZS9wcmVzZW50YXRpb24vRWFjaG9uY2VBY3Rpb25C YXJDb250cmli
dXRvci5qYXZh3Vr/b9s2Fv/ZBfo/cMEwKJ2t3P26NFm9JhsMZG3X5HY4DEMg S0ysVhZ1pJQs
N/h/3yP5KFEkbcttnOEKrIslvffIR37eV/LoxYvnz8gL8jJl1QPPbxf1qX4+ 6r9QL7+eZV/L
H0fPn1VJ+jG5pYQm6YKVKY0rTgUt66TOWXn8/NnzZ/myYry2CdhdnlEen+Ob 8yyv3xXNbd6j
/5DcJXFT50U85Tx5uMhFfRz4+JoVBU3dwRi/jWla5JWgMV3exClbLlkZN3l8 l9N7GHv2q/r7
DueyiZfC9OKMLZO8jOVU8/L2TD0dD2KZ9XgGDwhTTZRaoGFZc1ZMjZIDuThN avp6kRfZJ3Fe
5vMCZr0jb09XzftDwpUG+bypGR8s6YIl2XsqWMNTuuMkfk2KPAMVphth8eEm ATAiy6YRAoSt
QvB7VtPlAMbZ4CFmnyLd5vk5KcEi1yx1n+1nWjbSsmg5nH4H8VeMFbD/wzl2 k39Jq4Qna1HV
p23mgXXdwKcdhYhnl7RzMDtQv14k5S3Nhqyuz2y5iQFcNW/SuuE022mq7kzP 78BtD2HUrnPd
6oEdKpfH+LuEr5EHNPLjrMzr8z9SWrV2eoRR6GqRCwL/1QtK9AaSecJJ2jkS cgP/5GcTRciS
ZbQgVA0d69j11WRC5hQCy6QRlE8ylpLJ5LT7RsvM//LqVu4X+I/MhLgGXGFK 0iIRoh0u5Nye
PxvRP2C3MyDb5giBFhamoEtYdEHWwob8CYRqVUZmWT5SWsHKcAi8hN20S3RH O91Hm5Qfrdd+
5Kg/UvqPIGLXMDuaEWtncdDeVg+Za9pwDjoTYTQmbUKwz4l7ptVNoBeTHQUQ fKyipUYjEFeU
1zkVRNrDXuescUPEgt13w0rrww8nQD4q6T3Rz5GfUMWzN5dX0zevz+NbWoOf AEhGB9f/ml1f
ejKvAYnNdQ5+8eDwUMFuNHr19o5yDmujntAO7lieEd6UkaEa1fzB/BzBOO/A fUeHsZy2FBwd
OKYv103EOPrD5YLS+uDwWPOv9J80qdMFiTwnQaj51Q4+2qR1wW6jjqU3hvr/ asOec3oDqeyC
6n3Xzs8FsbY4kuu3+klLsoz7z1eQSX3cOSddPQW2UEk98ufD6r0tbjCi5pAm 0KQEh39eJvOC
Zh20OIXAVnq+huSlqBOYE+yHn8rr3d0FwbCB0Q5jdODT7w06TkgUuaSu2EO5 ZpomMohU46OM
r05I2RRFN8QI4YFb1TGthsH5Pi8KFTkhEhFW0nV43FZArEAIoF5UrMxgw0nN VE1HMipSnlct
8lvYtSHad/nzB/VBYuNJ3H9XJb5E5J+S1FVQhFYPkxAJZbLUmSkAA3S/X+Sg vHqfWoml0klI
n90UGehBkizDpbBWFH2M2KuJW8m0rWw/x35cuPSqxi8TMD0VnwYyOOTfBBoc fQtsNC0Ez7L1
m22w7LLePUxdu/RNablx86KBhCOanp3NrmZv31xeX0wvr64vr/5zca5dauG1 HMChyzjo9yLQ
Cd/1Og1I3W8/IGVqN3GQsNfY0XSrUDqSQT3RlrpC4QLzDviUK0hI25JLXUMk lZXS46+zHUjt
MNpuLr1iWO5HTt2vZtU94m70X8agSiQXpVU0OjAdw4mgtSymBKQRxzuytiuE vGsXGBdQGacs
NRP9MykzItiSgivauAFjLS8B/0nBfybaBYhmPpFiNA+bfwAj05bSmv3fs1PS mKOerS+737a5
xB6XTagdwagnCHS2SBDqFsEu6aRNynQ+eXA4Ju32SrGzMywerFFjcEFQW0xv ahjvoMPA2Jmd
Zuy/C8HJBeB2DnTVOzA4QN2FZQLY0GyS8egIilRJRb2sQ4VPwwYRHdL/JQMn Fms+5aiCicLn
baM1hV5NENJT79wPFKZO+1sXntlGrU3gHKy3H+seQ3OU+tm6+7OztP+RQXSS 4bepZPQBZ5Im
4C/Iuc7ZyAI8giB0WdUPRPukkt1bC+DjzW4OqxpDAbDXM+4qKGK7GiloOmdN fcVko2Gbp5Hs
9thag2lRRDVvqKl3iC50yMooDVP8qWDzBCOoiALG7fj7fy9o6XfMSKqabmIM nyAeADjock65
9uH6mwoEHPwz6M1lklwvAFXSzydP0sla59TBM02tAjOyG3SVrDZtX+4SKwK1 ul7te6K4O3Rd
gsaQu2KUlDgIa41gkvWs119zS1uPIFZmSdf1QiO5O3q+KzNIpSa7RS7R3ztO WoBBrCeWQpUl
g61Gql73uoemCvd1AFRuVUCxSptNPtIegDTYMkJlL16uNhqzSU1UumAWObzK vemCfbr9BOFM
DqNK4CzAlz32m6bOcOjYsB2xJuHa3BsbeKCywpQL3mbKyW8VFVRyJWRt+d+G 8gcppK1AZZiB
GlQngNrvCj1gvUggiQNH21ZqaBV6beAZEz3JqvZPFb9mB8H1QFksC+LiYW/l EPoGZ6eDC6Cx
hvAATL5XNgiT12ECi1OVvxaWTMfY16QNDvgyWrGqKYDSxNIw3zjQnHEMf228 HjikzzkOFvjt
sLg8v0ikBJygXKCkAldY8VxarPyqQHSE6LHaHqJbO6vP8P2pZFIqn3Wktu/y iHGqQXKVmLc7
bs30RO+4Y7jHntvu9T8DZ4zkm29kuzPw5bCVcRiL/H/gQ6WL/qfZkrfaPNBK TgYIgan+mHNR
n2u3EbU+tHfMRvSNCy0xeOsi3IztkXayw5uBtzqA7Y3/PdI6jTUCj42Y4DZt FiQFjHGJXAj+
hFZv+kEKe+1qHRMDeMxZMp7cOwHES/UR7DAt41K89q+IAgtiBQTscwRMyJPa /xwFV8iRvJuf
+XQv09u6MBump1ZuurNT+jyXFJijzxqeZSgam72RqewnHw2onohs7qJVgxm+ TFlGTy2vJ6+S
wRvTKlHglKc7mGe3zg37hoI+RcMz1OjdYAN9F5zZeA05W9zw0CBJaxzqqM3c cWsJLJdsDeMi
Sa57hA61IyPf2VNrUz+znKaX4OnnnYFZVji2RHpZnn1Op7vijwo151jhCwab 4xq/QLj1NNw3
4IyjxXZsRdP8JoeN0HDBwxmEii7q11YRGy8ArrA2mCdC5v+6x7BNFC49VCB4 3AasuWbV80Pl
zPw60CKqoXDRLSMsMJYAWNk7cpT1zppQvP1+doajIPxnN5uI5BGX/izBYUxN DvtAZAdOyArv
QVdH+7QnVea4wTR0F9Kcw41tE/yemNtarpWMiW7ikb72iGxzWUCaU8g+zN0K vEfynZHau23Q
l+yf+i9DPcE+0xgFO3dnrOZGJ0baYIjartNHI89+dEMGMkzOlkNMKCmK/w8L 2jsq/brzEXC5
HYDe5eHffscK/sSMJUsO+UWYHpYCbV5CHAWifxzDn5d4NlXQ8rZewJtvv22R CQXIBWMf9Yl2
4FatMGT6rzehvk3JFyd6tN/y3xGa95CRUMdEJKFVkAYG7mwnMEIUhThcQlUO zkrYWvkUWabS
6n4G4QkbcmEgY3N4KW+wdYf2cX9VPA/gqBcW3WnouBip3xqWoIq9o+lRD1Ax WpIw7sK6iGQA
pL2Cp8Cmi0mD4jM8TZoKz2B1JJM99qqiCX/Cg9IdTy90b91l8k4ZN5+Rdj2b xzw/3Xjw5vqn
/sDbiuP151Yygw+etO5Hu7WHa8P0W19af4KG4W634oXiR51VtYm4lao5J7nd XYM9Y74fsbzj
tC24337errQZE+fYusknzun4WkkW6XjtNWgDrcBVVnniZa6Uhj5bF04Pj1X6 M3AuAWEdwiud
b/UXcwhSaCkarnxhAm4PUggVatDH63t56p4s+EiZaMEkKKdgK+r2iqY2hw/7 dpctdMzdXR0T
pkXxvp3V21IHS3NIjCWb7Ei1K7D6C1BLBwj1vz69OwsAAHg4AABQSwMEFAAI AAgAUIJ7OgAA
AAAAAAAAAAAAAEIAAABFTUYtQ29tcGFyZS1leGFtcGxlcy9zcmMvZWFjaG9u Y2UvcHJlc2Vu
dGF0aW9uL0VhY2hvbmNlRWRpdG9yLmphdmHtPWtz3MaRn5kq/wdYd3UCEwqS 7+rugxQqoUnK
3rL4OJKyKnV1xQIXw12Y2MUeBkuKcfjfr3uePQ9gsTSXiV1JXCIWmEdPz0y/ prvn9e9//9Xv
kt8nfxzXi/umnEzb9/L3a/eFePmvo+Jf8eH1V79b5OObfMISlo+n9XzMskXD OJu3eVvW83df
/Q7/X84WddMmP+W3eVbW2ejk8MuYLVQB/+N8sWzP24bls3d+3WVbVtle0+T3 H0vevot83K+r
io0jLXtfeezz4S3AfXL1ExSJff4+59OjfBH7NGpZk7d1E/v2sZzfsKKnctdY ZHHzoW4mGRtX
5YKzbFw3LAM818tmzHg2+lBW7N2gkkd5c8OaYWXP1ON6pfen+XzCBC4fUxGx webrgnjAqjZ/
RJUfS14689ZTU1fkp9VyUs7752Y5b8sZgxXXsMhi7yw/Os3b6aByTT0B0PhR PV81AFXleFlV
Ya1ovZ+uc9jIudgpsGTYfNk/K2H5o3wORGFQ8XMgFUsOu4StUemirqtv82Z4 jfWAOmeLXG/o
ntJFmVf1hEPjnEPLB+JnX/O6gjcPpmJP1duS3bGGIw1bzuafGRLkg7xr0bt1 RucsoIpDSssd
WQyZ/LAyjPG2LIbWapvluF02rFgLVITsR/E8pLQ/rh4a5VV8HHS22nAYL/Kr in3M7+vlIMhE
8TVab9gapU3JaFl+12bnny/6Po+XvK1n2T5A+aGuiv62inmRHRwfxAHTBS6a fM6v+xtiOK24
UeZtU1d7Rb5ou8YbFtdrorP4pMkX03IMe7gu+0tWYhYz4M2VmdDOwndlMWEC DPgOPKmD6dKi
SNJWlxIrZGAxSVsGFIZlNKyUaTFaellmoz2xnYCW83iLWOawQCopJMNVhU7z ZmWZ8070Yhls
oZ/iYanPdXNzxebjaW+H+HEEJJ6KAF1lNW84z2/ZHu9nCVAcSGs2+q5uayPR dZUEViZWIRuC
RlH4aFm15SlwNAenXVWQXHCQNeaAshaWeQWsXGwnlKblz87uBtRFONarP4o2 0N/EoqkXrGlL
lBBP5fP9+ZSxdkD3pK5T9ZHV+uBls2sY7WwGMgr+yYEkfpvzcrwvf4AsNb6J dxupqSqtW/5R
nYhKZFutqj6v2/L6PlPU+wPIZXVzv7JTVesY/5TjvG/HkVowI3ITfc+qRdem d8tL1niaz4fM
FJRnYiPhPAOZna3eVm5tyZCzkerVClYr66IeKRYI0JPJvOZtOV49PKy0bvlP Z6M+eJhQRQ59
5bqj2I95VRZ94rctq9WzrF9Z7alwznpnQdaS9gFFV3pFCr8OPn6Cp94+YD1k RT3Ly7m34nGl
lPPJgfjW0yFp4BFVRk6dIetL1F6ogh7Mo5bNQLlmk7xTMQ2bkHIPK4ZueLf2 GbsWcvktw871
AIK2BrYWLJFf0CjsXqVTOjg2Uo8QO8ur5arFrtoas6pStMQFBIUtSVaGNIOi tAOPpCwHwIZW
L27Sxsd6nFdEJh9QRfeUT2xPKyt2rDS1H/s1zQHtfMyvWPWIVj7N70AbWAAW Y1rvynYkgYAf
n0bD+E+k4iDSolhIdvgF0FWwolfcIIZcNcxD9WbYNuiujxD3287MbuEZCth8 AeroUV0ATz9Z
oIXVmpRfK3P1xbTkCfyXzxP2JZ8tKpbU10me6D6TWV2wKlF7Rlq0v371Krli AMarJWfNq6Ie
J69evbffAEfhlz9PUHLJW1Zow/fyqirHybjKOU/oEOvmq99tMYFqnkREafha IqAz1DuTOO3d
SUJDCryjpjj46coD8MLqA8nP0I1A0pbG0g1jC560DQhiiKN2ygRaoO9E8gF4 lbeITBh8kbS1
KptXVTIWFhMuXk4VUjPZdic6t7rxueUhdEtgdAtWTAtjhs57uKAG2jC4YKDw HwJZz1mSy3aS
a9mQHNl13SRyceLYhTCuEbLxgcX5nIaTbqf4oJSqkyhdJ1nA0tokvBFdSsPg q1chwHlyUy0L
ADDbKIiBBdmDMGZhXge/L3miJPANjsKa5jzoiRUuDrLSI+8TjuR84ysiYB4G AJedxIGViJSU
hk/zor6T77mmdomgQ8FEZLopnJIGPzSsEgwhmS15C6OEGk0DbVT3ScGuoYrc 6C12DmTrDvjJ
M82fGUvP1M1vAWNy6E0NBBbojxoXKMtAbsuq8DGh+akowaf1naoB+wy3WgsA PNMAZb/do0Pg
eIIQSrDErIsZ4M8EYUsN3b3wVcBOQ/j27HtoragZn7+EBbtcCJGlHKOEssGR 2HMNAcdATKMJ
NzYU+WEMIhLsEsEBxYIRI7wr2+nmx0OOKSQ0a68dBHMsjMn877SQPgMI0pzN Y3BHpKtcaKR6
ES3yOdvRe/qqrjdKjax9KhkvG7tbjcVqMPSa+shR7CR303I8TWb5PS4mBjiB oaGkpWqpsyM9
TmRGIFw1Ud66eaaqGSpFQWz4lZCpJZ8Q42NAnvXEoSAjcLFZIabj0NVyk/A0 dtU0ouSOiP/5
z4Dvm8cc+T5wyaqB4CskocgstADozmhVGxSXtcfOHzthfN+JIp7sJnOgHsZl qKeRdHvgvrCS
ClGiYIULmno3ratnWieqX/t7N4mcU2eHR6cXfwmGxhJqccAl3jC+AC5QIqtA uWncsFzohnda
EU+0XQx2P9bliXL1UoDinj+UywskZmXq5mIPbhIjzkBm9Iec/NDAEp9qTQNw 8HdTJumXJlVX
bFzPmCYEm5xfevyIgpb9sQsFt3BETpl0W6j6W1vKHnFbl4WohybGW+wldQ8r k4WusVVeJ+kC
po23+XzMYDm7yp4pJwqmqfd1sZ1NWLsvaSuK/QDK7m5EO7TtbEGFmOkz3c64 /HKrDCWpa1HJ
kN6oaRP/46ZnSdXTmNKEFUTpB/lX/WEVZ0kwdkev8YfufuwYeaAHPeXAZTNA tIqK6alNVw8Q
wIo1aADraFA29BBdWN829XIybS/qi3rRvbZev05Gkzmeg/Q0tV+hLeQXNnLA 8tVLfVBLJwvY
UWs28uDREuMlKBnnNL9F6gHkpGGz+hZ2OC/RLFnlIHwruJFMPw8P1cC919BY aH1OaYoG1LJz
hNJI+I8yQgXNk46Qw1Px7CMRvT5mHEf5AmU1DtueCXZWmFNdEFd4PS4RDKlc 5Ya9b5ZZLwy8
O4k9ZH5ver+o7VuEX47WcaKOtxCMXnl0ceTmQk1RxjIUS4DwF8pBADXOZVUI 3XhRINybRAAo
fhUDTVx2pYSkkQVmF4TNpa+iKWOxscvLyl3jEcKLcVsWonvB0AcDKld1Xmx2 gN4huQbQDlF/
2E20PONVMRLNn09AC2vKggXEWvp5KBE+pe4e8pP64Qg69AOyb1lLdEekAL20 LIfksD1AIwzq
fwD5GETt0UGq62TiLGibcP1xDozYfD47PD/5dLZ/eHk5Or/8eLJ3cHjwdlXJ w7Ozk7PzlcU+
750dj46/O39r+97SxazcvpsYWLe70WGEjS27uyjl2E3yeV7d/5XptrSonzZm X86XVUUaQvzb
FrC7c9Swy/YesP/1LtnG2ckPBH9bWx1kIVssW9KdbZt0+mCehDw0oFHJFE27 blvOYDq2rwM6
jrJEmUqMd8qqSj4elHxR5TDyLOf38/HhFza2lbZS3BFny/kczWSp0+DWVkI3 QbOc+9+3uugK
nVUs9kB+JQ9RpF2BAnhjPuj3EUHTbJQlSL+ZuzWd3ejLlrFNbuiIGCLIxhd5 Azgz6zZpxW8z
7it0bjo3xdTXd8O7WM4HdvKJFPS7CcXAUKU0arQ6S92olSAeU2Mogffaapbx elEd020LpOZI
AFAinKsNHt3YG+BK+O+uLCR2Br4wS7Vt7s3akqfssdCdhJ6lRwuYHWLxQ3y/ zDjwedc9XEaY
SFGyiZ5W9hzU5voSu2xVTpmWO24RKWlsIigpEfQaX1IMSOp1cb9Q6q5pJPsw +njoUCKn/g8g
m3g1RLfAvo5Ofjw8SP72N1szgf+trrn//d7xd1Dz3/7NFv5Q5RMu2YlX+mjv 7IfDs3OXVsa4
I1kKzsA/nY0yYQ9jp1Xewm6e6U/wxQ70A0ZY5e0UENXW56Dizyfp9o4Q6ODP dQ7E0iHDiCXT
O4AtmKZL0NdCpM8M/BWT5UURY24O2d8i5oOvXc0j4I9+h/6yH9ghebaPlOM2 DCStuZaMg+9q
iUd3DdppPKgcpqma9iF/RDdnHrZj3fgzEmOv6um6BCErTvFu1V9JAGJFLFWR iycfY/xBqioS
8iBmWb3OooPISn44W6Cg5lqz1hZtegSbFWJNgDZcV3vQZy/gznqTy7nkB2Xj DUV8dcYjDXog
zNe8xyYX29BUrCLPRMB66MR8uEr/ETAf29Ee5kPAQ8zH8Dvx7J7bK22Vsr0u E+jgCSB/QDBF
1c6J0k2YfrI9hx6M2ej4/GLveP8wq+pJaquE9lNfMvxewM+Jacw7SEKZpn3J qYVGBoxsUGAU
8+9jVg7/9WsgMeN6BhqXNDkAIyySel7dJ6A1t9IW+hqbE2u6U4C6qM+g4gnU A1VL8mnC8JJu
ycurCBuT5eYMByoKAK+BzUxBMb1PlAOpNN3Jc2o8uwGs4PIvEL1FycVzphuQ fzmqpYq2iyVr
fqglrXav2LoBTQp2KxaTKBVUZ7+eX8NWa8l2/sVkRy4zqoUFYFlsiQXv72f3 s8fvnY8PCgNU
PgiaC5AQlJAAIg1xO1O9SISFNOVdvDUHwh7oEe6H+D68w3XS1klRKy8TZcW2 FjTYoc9jxya7
sEtoWYF2lIgJnwPROokvQbpIQ7bYRfb7tSP6wrIBtUb9mjQuDKpeV0s+tYpL t3lULH/ZMqrV
Vmc3kvTbgGs5dkBj5i75R2ENpfzVfFzO0VRquQtVRm0pUYZkFZGn7ZdHe6c+ w9GshuQ+iTEa
TVvi9ik84wT08R/YfVwIH2YtW22+s5BZ9hq1AGl5BsHu8dkGXMNEg/Dh+SxY 4B3a2+nH4Bl2
VhrRu8u4dCFJKGX4JKpwal/njoEdyQR+LOeoC8qXBePjprxixm2TL9gYLaoF sU5unHh0jtZS
jxWmSy9a0DH8yqlCadIrpZZG6thxd9Tb5MXh0YdLdHzPG3apojT4C/P5jXlC ecD+gG5kvGDy
P/+b/LzCMmNEPEEUCPzClZb8ftt10pTd5tVS0C1KLbzqg03XZM5RCfaaiZtC y3krTk11qMgE
bRJKMtivl3Mc5qvkm3dmx3mF3+8mb5ABQBUlQLgFtj13BzcU1cAuvB28b51N Cv8FO7A0tMQ/
0vZv3CKEXOT1GvFSMELJ+n0Fw9W7nryRunZQ0jCIoMZKvERrOG5K1JkpZhSF hSWQ84c/uOjZ
CeHfsYtCxP8TJY3LBXbBvrTpynakoNq0x/mMuW2snKwt9Oy9yK+452SiOWOQ K+FpFTGzaShW
s2nOJcr5CtnGUgWnfgH8qWUDm/hlG8KRQBwgpGlSAxE5C/NkkJXq7vpoDqSC qMh9Lny780Sm
ulCepfyG474dK9kUXQ51tJk9mQeNbZw3Gz661jbyqMQskSPteGKQTtKnrF6w +X8D+0CkKDIa
M9Uo7iYMTtJA/OLy0+gSs3Pori4rjEZ9ES2Kx7xO4RdyVT1EDp/kqkB0eyGQ T40/aUFydVWN
L3EmqDZ8CZsbkFX+lTmyYdo5AqAqHCSaWKTitXIp3/DQXOGqcwDGULIvcI7B qH7goVjr9yWr
CljtLZuZaB5O7CduFKDiOfGIwTT+OjsQYugC0XEGOOBANczW1dqV243Q7dy2 qVm5O+hXU7RB
za2OIV6ruSEB/7JBd2ZkGILQPNF6Nb6RE3NXVpVyKqGe7ejTrUpLPxr2hY2X ykNIzVmQfkXX
kD/kHAaFUgLaXlGoaBxxGIsOW6xVq5vj+eQYT1JVq2gXvL6Wi7IW0rGIWrhi cd90FcIgNJbr
erykq43CiWiOZWoRNChVyzD4aq3Fjh2ZNqxPh+VxBsmw6R0NCzq3L/VbbHiF TTvptmkn/Tbt
JLkuG6b9eSV4KUkelZ2enZxeHozOpLZJK8JcXeBWrhWeZZiMNxuZW4P+UigU 03omZlW/2U3Q
u9pibdsciZ+ro1eBkCO/omP9ToT4GzYePVl0rZ0XtfKiDmoLM70aopw4z8Cf ODZ36XUcRIgq
EFA5+Tr4mqmZb+pKHHrgtAu34G0f5LBqIw2/aRdE5DmxpwDqpXwREgiP1yj3 SKHPwxp2yAfZ
To7wpw/nu00iqUvndpxdsyNqh+6O30oJ5X3azfbhvylrmOGQlK4AlRChgPA4 xtigsn16num6
23gcNLL1UOmVJnsqMmSRkqpUr7TghxLrgK7niucilCe6v8jh8Z/eY0CjNoTJ sUsq6RaCIdEY
nzHNcCxW7lF+A4NewpyLY6P6Jr/3zmScJuhepB9C270mr0hE5QOxAEVobw/d jZJOlINMpKCK
0fPiDd2jscw2p5+EjYYGgsTInVMgc0yNOJSIudFBWdbWwssGMKO8OTqNovLD Goe0qcZt5zmF
WNxS7+Ax8pTj1/9bwn4BDeaexvvFU4s84LZgjYj/c+mGTMiSA/KvqV+ViPjD fYU5vcfJjLXT
uhAZM1Q/PVTuQfaA9BLbVAHU2GIkJjGSNElxIRk687A55cWh3cpUEgj4yonD zz/iT9jTg6e9
34CIcdabAinReWf6S0l9RQDcD3EfyAHMmgMoqIfAm/bmQdF7WGqR3jd6Irux oTiuo2pc1iiN
C0X5HqbqrZQCNeDqpcrssJtI3iZtaPAmVaUl1VDLK9WlFZ3+UxIeMJ0fXiRv nfccVmTFWqBc
svr2tqVa/xiY2kcTOID2T0xFMGVNT/zp8aQKK8b4914NFtboABXMFNLNE1gt sO37uRJSkkjh
1jyS07QguwKiOSjZXdQRVYISGdrMP6DenoZuH2F7tGeDvEiobNANzIn61q1Y zEDM5FLOFDYT
TPrgJ4dQ+SC07qFlOswCoZNA0OQPO6gulhhgx6V1Ykf2p3Mxqer1fPOiuosh JUrKYVnz3khA
i7ZV1EiAjsjEVkTSDkRRpwlRpCtZgSZjNNqUKKVGjxNnzUI118Xk3+52lYwq HPy78h/4wjrO
+E+YWElGcIjTcFDK0To2n5CkEMb8oURPrkTmUFJ3Ee5CkUZT8wfFDl2Tkec1 EC2dxfy4HMnd
dSmAsZ+39cJPdgHrtir0QjSjWq18uJqH9H3qnIKuGdyOgIhnkgGMOMMxGG/j wKn8K3lRPAFI
ZyAHza5QvW6d/l386A3xjoxFGTuliseJ+n6VY7xj7eqHsv5LUs7pzlkRXt9G TOj0L0HfIWfG
OrwAV+poCuM9upmbuzFUyp6e1Ck0EFrvqDV+kpwVh0qC9H9pQR2cLw3B18MG dQ9WFadmbUDF
HSjCgA88lWCN1ipNfaG58OfwsJOD2JcDwJSaH+om9S/rcCk3uT5GjxxfKTMf +Zq++JfTevFp
8UKuFVJW+IEIc4O+XCZ9Aa9KIZWqczynPNde7XtV9XnK5nh6Ok+t/cFrm+YG TW3WCAEmInmX
Ap4FOFBEwjHGyhYiH4SrAlbChmUpa/PQM0wbJ11L22ZP6lwFiTm9QQthMS9M BliMfDo4PsgO
0FC/f3L6l+Rv9jcGwtDfH0fHPwj4dJZiUEZa9ahDqMinnxMnpTEOeqR8ZtDH iOIDUI5ZjM+l
SSN1INyxfcjhBlmP6SDdJuvFsCb78ze7vgg7Ce2uw2wsdyMad4R1WIaao4cj yQ0gTaqhFeol
t0Xw9Moh3ZKyv0RT32K5AZOzc/YkfSHwWFjTt09nIwMcPu8mNnUyTjDGcMW9 YyJOEglRomIh
ZOajddcAHoeOpsp3XkeYTkUWlQgqHXZGWh7ue5uS0VKDpRB5lA8IGZqWB+gY 2bun6p7oLUpa
eHxUued28ihHmmEuso/wkZWu8f1Y0sYwjO5BdtCVHCG2Tc+UeJFTrCmvU81M QedGEQr5713e
zIWoLjiw8UrV8H9l7LKur6pdBCmgN5/fb29sv5J10IXtYIftJN2OS47rNOL+ UGCDBlKhP7xT
5LPCUizayveEvfJ+r+UOK/I4rO8R6/kJ7VvqJgZ3OZNOSC92EjoqpGjb292e tHajG5FYGWO2
iRe9LaYPTj0MZDPWTFhqrrjIVJQQcXu08ybIkGuXugouJvEDTCwInu5C/LB+ VRPg4f9h2xu0
YwNz6Nel9uLp1UFcNi7yxSi947rJZwyTECBXF37AMO/3AHECUqUQDTFXztNv duc0OGDUeIhv
YluMwYMT367rpp7R6DghQ1iji8Pv7Wk+RosZZUWo78IwJdORluJMEc9LQYus EVeSfuatTpKL
fUl7pjXtfB0eC62KgAlpCvERk1YxrTlZrdckvXUEAaWyR82RjoWH2C4j4WU7 KyIs3VQZ1mqj
E6kK2M1ZtrqqDl0X5BO1zWASXTkYLWUzlpqSO8n554vs6NPHixHx3SCJd6EK +WWbUJ1jw6Si
thrTSoGpp3N0Kp/F/6H/5p6J9HL8hqSdPVLGwhC1H7vp+zyj05adQ6KQoYbl OkNZRyQvtTg6
DtkBb5PmiJb/LloVVTj/MC50WfFLeGdwnYBh686tKpG23e+RljvalSL6MF/r SPXVZ/9rRbnh
z/SN7xlAZgKzxpStin3qh9jys67LfVJ/QJiRAzcW9B+ej8r2ouYOrx3jm66s 9SCRsi8ok6sQ
A3dleQYCN4bAVN/xmafV9KGIdnMOLYlxAqkOsf5JHf9JHTupI72XYB3SSOuJ fKzLtj78sgDt
6CMolFX6H2+6SsYo6CC/hw5y57f/i2loDwmgfT3L/pfHvv2b37nYhO5/ch/D r3vn281Irnmw
Wz/cDr/qjYnF7RUWuCntoPs3pa31ZKJK2Owm95ft6Vl2F+L1kXvLMNXf0N4i 3PC3vLdaKgUM
Zni21pPuLbfZJ9pbveIw6fGxkrBt4lm2KcL42G1qLvhhza9c/KUb1d4H9Nve qeQOJNyq9mf3
XpU1L2TQhvTAp/cniTUvnfDfkaIf8/t6iakExJ9di2X5IXUgkjtVvJcVgq/f sxw2KGaWw56o
lmsbgKFyvwSBSN6bpDz91A8Cl3yTiuak6nN8cnxoOLYAS0aoYbmDvM1VSBr+ /MzKybQVL/9j
J/nmzRvX1rxFOxXKOO5Pb1OekDLexgzqg9Ze/jXvHyho19ebG+a/x4Zpu+wa 5Lkp4Q/Rrds1
QLrwBNfACqfmEnttTkFbKpq5X+QvdpIXVy8eIhvgabmO2+4mRTrS1fMwC+zv F3ELItr9hljG
b1+28wUqcvvcUEFPkSViaIo2ZwUnIsVZrmDI0IeyqjQD8Yv2sAjdWA+HgCI9 DMJ8FZJaSDc3
T99jpT6XRTtN//0/30THEdL/VaPYJPkOyyjo37xZsdQeR+e7W3pyPcPrYaO0 P9bps6kMpM8e
frB2dtiuMPq+GPrEzfZjbKMm4yo51sY/wKQO5xg3oNzGaYIFkXhB5BItJIiG j73kyMFU/Rwm
xB7bot/5TF5pk89FHAJWkEXxXy+TgJCoBOJjWQ3EB//mkS0djzNZ5k3hZh30 2Yqb+UA0J7Yg
K1LVeiwVvjpSxuZpdl/VnZPpegpdOXmTbDkKlpuCx8a2r7smOpZEz4pYeemE E2/v+y2MyGm8
iDjQE6pdlmbLqi1fiTdq1eBdXSpURCwmxJCK/RbBXbhykrxVN622bT3bfNZO M0nWGclL3fbH
3eQbE9FINj5I8i+Uu7CuRpavcz0f9PChrgobULKVpuSlJ0YITpJffS80h/Qb PRuntaBW4t/d
SNqNc1i7Zuq8z1x9FrUzIFXy4T75Q/JflhZF/VPoPIe7d/hkywuClYTLn3ma bQ6zzml+3znL
axyHbnAdoORxcPhh79PHi42uiFcrV4RWXfS1VvKa1eDm5A37JLkTjCuPZKYw TNlJTkEK2QLv
bHLo8ApM339NJfl1ypG4laD+WoEopbw/2/X6KhgwuBlK4eqKYxNwgoEZNtp/ A9hGf3bg/tw4
W75YzsdTNr5hxYttfzr8WFHNmvdFDPwNuyc7D35loKIBE0xH+yHO3Ou4lP6I O5hcEgob6096
xbvV4ctbNwzV+iXSjk+DpDTRfpFK+CVJEtp429/VbS3z+sUbRYLoNeEOVkcH aywi/nrXDt4U
wbmM8AHNHrcFazjJKOVd4r25hHKRGe2cKLMiIjvPC6sUJpPwLnItfMhL590I NrHyju4j8Ohs
C5FPP68WFh0TgLV+qLB0mwl1aZM86tKqjBb9YpffSkpOTCW9pXujAL3Ld1XQ nsrMF1iYSNBn
tKen1AQ7e3gS57PO1oe6oFmE2SQ96HK7qBfLBRd3goU4iymfXbcbU2ViPbe1 yOUiIsPZuc3P
09S1js7X4pn1vHLSmyVJF6aexduOqD4rdx2GsZsLmDGwKh3R4L6Zfd5JRheg Bn6bN/pj6/yE
7+dt3i452rZ0Ee6/8fdx2L/Tpd9F2F58bYaQ7IZ13w1HEyf3VQOK7LNK1oWP /tDcOqScBnnS
fQn2FAjad1V9lVeyBE/lbRdhK25G3xjBlzGZEXptzaIYkyWom01JhTyO1yof JBOe4FJKUzH/
NgPcnUqwZRhEKHr0UNOvrOFlSDR+om38jNpQAEAFnAEeU1U2DTxX95mtq58e EX3vGSz0zTtd
QivrC7fvMA3p0OMAgRE7wTDxRKcIBDkPhKzNCSeBLNch4FnRJMyK6EkmkQIS aSLaU0garAi7
cOinnS7/8GNlajpxh+Cf3tvV0ZEPWh3yZNFGbOV3K+rKrCaUgg8DfA2qNJQs PQ1d8nLAhbkq
OVkgOsztF4k/7iYKOuzaQwXL8VJszGqJaiKQkrucJtvQvF5L+EgiZZoPEkmD gsAmbqQik91P
biztDFZsb7IdkffQ5o5wbs6hKDDGllFEaNFrbNQyEclv9w0QT30bKSZ1jVa2 8GalaiAldh+/
IUxSf4wmJCuqAU/4TqXNuC4b3prOE2a1eCJUKnXaaxlFBL+vuejISJY66c1L P7WmFPh38O3c
LKGy9TI88nxGK+VcmfDc1B0GzOjE0VNNJJl+5ILZ7vYmVDlcQsrwbXBfqipl aZBTXMTneugx
Je+mJbDeITM1oFWN9AgtJOlRSICYDMC/K4sJawP14VERLw6M266k5V7yTCAS kXgroFk5ozLD
goi5xx3qI9yisb8Vo5N1zVgst5YOzOmqM+hOA21xC1Jm0iScMrX0g4i35ljq PmkZV/lqg4TC
Gw/A1Kdb9p6wnwkjSdMgXfn2iuu7UJ08z2/ZMWPiQq0u1vMIPOGlbk48KOy8 54tSLWocljDy
TdCEeVTP5aGE+9sGsGJxeaBp748TEvsUPwD7XuYVhqZKQZtkD5OpfzHds6RL O4mhYlDzZKEz
n9DE0F5JRclIeZHVwFzTfHJ6MTo5vjzf+/Hw8uT4418uRx8u1U3KO8mQUpdH h0cnZ3+5/PbT
hw+HZ5pLwKgPFBFAQzMKFpiWFkRynbwEr2DMlzJ7GJe6VFXD1GPuW1wCwtxf tuqWBJhnnXFM
NnnF5uMpQdVnfZX6EZa8NzlSSIdSckZcdRVOKTONxE4LUCaYU7qc39Y3wFrv kNUJCch0AwPg
Hg/r0anV7QHhapo5q2jLLiSasYFrUos7IOH3oCnOAnqrd7aUCtyD5M7r8ta7 1c+9qy6VPfl5
FZTUFiRfKPkp6muYkYLeYIcymQtFyfWln/Gb7pzbcLa2xHJqyxnaQWYLcpW3 8G7S75008aYE
7peUbBpayLkw0G0K2ZXp0c1U711E2XULtk1Tb5/C9CyR63k2e9EfgUYvI8fP oOMmQEUNhtzc
6OTGkbnTlipxWr1Q2Y4ECxBHvZrWOjYXdRsX3UbyJp7otTvbGXos4GZQCWl2 7CamNiF9j6xM
poemhryh19zq3h/FInFVjPhBPTdnqWvdRNGZv8dfIEg8TFaDO5Tz75paJziQ VyrNX7pJ+ta8
7+mhf6IN0en1C+lLoQekVmiZNjsDpgi9YkCAF5p+aHKIKZ2U8cemsTF7VjdO TjglmEuuOAzW
H9dzoNrivh433YSf10qcUos89njhEzI5KQXztmH5LEueXiEObqeiJDSg5moN 6LLwelm1HXtP
CMznAnAF/6A0T4CvfY0uvK9YHFeQthx6KROhEN1W9uNnojRwEn6lUCruQw7v II5dp0o2wAho
YsNMaSXZym46bYvVXX5P0jgCKEZwkSbged3qNIkomco0bZu4k6xXZkfJYI/v VVV9h7K2I7tr
/MXHx2tztdpz5GXrF6r3jBON/CXJt5B2zQ8p7tLvcfJu5F5dTNzHplbN6DRv p8kC/9l1mlfL
G5aEvqEMzbRYzlufI7xyTcpdu0ZQ5opQYhYpLWMqaamu1V7BeqJFsgVEM/4G MCiBDaO21GmV
t3i9rO4Pt5JQfrBdqIujSjF3ufIp0mdiMjsg9kwz2mHNbX8XbTCvtutVQ4eX LJtyR6t7Aji1
EMWzwsjjTgVRpUc0QQ9qSSizAHrPHovrvVLaly5jbrQkH7FNesvlKhVQqRwT x9gsF6l/DCdl
R5l4S07/sFqZPGKgvaKTylfmkOAYl4VfQECv9FhfbY2Qig0ZcyfGkyUdyb+J vMNSTbhlS/aO
TiFw3y9wVymHmMMf86os0GCaHe2d/QA6qNlByiMdpn6vlQZ83Ky2IfOWNgKL 5XLv4uJs9O2n
i8MduSUV+xFXJdPGgntl1FqGXuymVavP1DJS9aG+9Uz9HcJpVZ1UbBjnvFvk RlMtBXB1XO0V
vwMhgOIzpmXF/KEqIdz2CnPYwEtFHyFhdhiQVG7SYinmm2Mm7OXi+ZgXXgKp pXRkRInM17KC
nnHFtWyk0hOSJmzUsfOaYyMbjiTKmLCtTMQnNK05b16QH7LCCjYHDegSUnMx TTXR14Aht7zM
zn56cn6hrEsbJkZd82mPIgccHunVHDUm0xNN3x+PBH9MnOgJybT8qtGlr/UX Hrs76SeROlye
yvBsFCyFzd2dJLDY5z3W6eVgkoObTRIvJy0oFV2evzoErUj9/wQ4kj1sHE2o +xLvU6tEQOcN
5pR0Dvc243xhj35dd5Pgmi4g0frrBtEhr2sdgot9eClzTQpjh1B63btn7UUf Gz5dd84Few7T
PTQm5ABWGc6EXXn1Ak7eBo5HZvFquqrLZoGLkkycH3FTUv4YFmxCgHlMjHZd VJ7taqEQkB6k
D3EsxLsgY3ePoDE9uPgi6iAslY9VfoRvk2HayTsb/xDC6vFP5x6coc4WW12X Zw7ytGhrXG02
G+ZdKcRW20rGRZSLlaPHObDvN2/JSb4/LHkNgkgA7EfrHtdSfj5XZ8sviIH9 ClSFG0+qlr19
Q3pTCo24ZCN2myxefH0ArU+E/4jnICRUJ/QqIOOzvia+w8FaIzsXuoM3uh0B 56oxFuw6B5L3
SJQeYWhY0O8IVi/WM3aQcEZXgEUUGsfXoRc2E7HX6xdQ1fWNuMI+RwsrTqfy rVoIoRo4hXzI
Fia8ekMH3IsGUxiYSzzV4rIYVi9sfI3ion16m62tw0oG4yAY9g46Zouz4IQv r3hbtssNyRCD
EaHP1RP+zSNxshOkXuffxINgB4si6l7UEb3tRQghU1YtcO1UNkpH3c6jfP3G 1OncnnPgIESx
zYob2MPeVb1sL2q8x6bT6V7b/1JnhBjRaFVuyYLiHpvbmd8TbfxZOL6TJDwG ZdIJveuHs7Kh
4Wh5loFTf1xPZnAG1u1u69V6Fqi9G2htsJx64wHvMtq/j80CcyWIUzEJ2eoj 969WG3Sk+riW
TSeaYUAZmGRzvTYmrOpiMzMDI8LkytVyq5MBCvdQmoCox6/bq2otvw+259Ah /+sVHvvOAJy2
VocER6JIoq1Jp3bnU8dNMfoU3b92UzkB4EUHGJcLndrTdFyXm4yi18eYYRhu xzEm/Pf/UEsH
CCHAUB5jKAAAm9gAAFBLAwQUAAgACABQgns6AAAAAAAAAAAAAAAARwAAAEVN Ri1Db21wYXJl
LWV4YW1wbGVzL3NyYy9lYWNob25jZS9wcmVzZW50YXRpb24vRWFjaG9uY2VN b2RlbFdpemFy
ZC5qYXZh1Rtrb9w28vMGyH9gjKLQpo7c9mNd5+ra63YBv2C7TYHrwdBK3DUT rbQVJTtO6/9+
M3xTouRHs76eE9grcUjODOc93K3Xr1++IK/J92m5uq3Y4qp+K5+3/Bfi5RfT 7Av8sPXyxSpJ
PyQLSmiSXpVFSuNVRTkt6qRmZbH98gX+Y8tVWdXkfXKdxE3N8ni3qpLbQ8br 7b5BHhrZK/Oc
pmrhgdHg5J8TfnWUrEJDfZj0gB8xzlmxOKO8bKqUTj6mdNWH1HldAehF+YEW 7BOtth12lNUi
pmnOVpzGdDmP03K5LAsgA/+c5s2CFQ8AF7v8cjYdAqVpWdF4spcn3GHNEBSb s2FkJXClWBBr
Xty3emfCOa0fsQ1A5e7UKTw/gPCT2XsQjPsBPy5Z/NvRoUNM/4SM1XHDQNrL a5bRKp58rGmR
0Wy6BG04owsQqeq2bwWPKh5P90pQGFYIlj8A/IDlPZzuQJZ59tBVT6tSsekB wMMH3oLWwHxY
quWspqjZkgp0FrAEPyoLVpe9wvh+noBgZCzJywWPj2AC8H9fPA5PuWb0hlZA Cqhok9ZNRbNz
as3LwMwb9impsvid+BNmQADwFPDqW5ff1PH5u4uhYXoNRhUILDM2F6aT9opL B3yCD0OL58lt
2dTxTxXL9pM66V/WATwUH4dWvWHZggISYNFmZf+aDtiq5KzukSkX9DCZ0V7F B62cHtOboeNB
kHdl9WFGi/RqYJ1EupMYYTl4Oir5ebKiVTIkJzBVS6REA/BBpd2rqJg3JAto VJKqjhF+kqHo
T4tV06OWGngKxtBI70VSLXyzapzzRH04AMpKYZ/6IE6lXw9AWJOn3iCWjmbf r9unSd3L9bZy
0o7H74d+hCZ7EnDqEToAVvUfgwV7x4qsvOkFxFWmYNLcsAH/bakA7OKKcQL/ E8LR3VEirQiZ
lxVJhfwUCxgs6A1ZlhnNyRwEJZax2qs3b8gMfE/xpuG0epOVKXnz5q0dAw/V HflhgaYkqWmm
Q7pmlrOUpBgIEH3IR7iXFGZCha/jRD0KNJdob4hVPPLnyxcjQdNIEEUJb1bI D6rmc9QsSxW8
RkJ4LCf0kjLqp2XUImYkqBkpcjiGpClsUiQ5QQP6vYzN3pKD6eHkcvLbxeT4 fHpyfE52YNLI
iSbjplii3rNkllOcGckQNU64eOrqARig84vd471JDIoot4k2Ln+ZXrqgZYUq XiRLOjH82BjH
fJWzOtr4/Xf+ehN/bYzHYyEilpu7yLZlUiPTcsCAlHOHu8hGh8WbMMRqRF0w O2OwQXL7PGyW
pJODk7Oj3YuLyf5lkNWfl38VBfpSupvnLhM3Cf5vM1LoWgprUtC3grACsIfV kZ81SKzUL5Xh
rIFjVVmDiMGRtYyusbX6eacNEVPNoadQNJfW/zkoUo7GUKSfd9o04km3JkXB 44L/SImQ8lT5
Uzij5zkgxwoGXDoa5aCbD5PAwAtAlEBKkZ78T4mZSlRkouSRxPpGWoSdgQdY zmglKOPa/ZKs
ERZArQJ7ibdoiFblqsmlN8MpGZ0nTQ5c0KnQOjkQivkt0kOU3WgvH6ZsrUib CMNi0UJ1Tyo+
Iop2kWu1r29X4nUC/AWrMKPG5yYSuirLWsnhOknw3K4nWceIbkhX3jfg3yrM zzOtNdL5rYfb
0oldlywT+EUhpm/eIz9jEfuMakA/tvKy452aGraKsuPJ32jEaS0DyQtW5/Qx MYbU6Mscc6QN
ETuI1falgqHqihrFPuVpxVZgaKNg7cJbvzNjGB0BHm3MmzzfgvB1lhRbYC71 JBXRjO7aegYM
Lf7B0mtDQiPDSGtHjCMlAGxOoq6Qk50dUgBjFNAoBCGie1Mk1btF8ixHaD0j p05HqPP5u6Bj
tQCAnd5ZIOjO1dEC8F3OMJAj+ax2AgTV/mPqlQtHetVX8n3M+O4MhAn8ubNt iOY4yTKFCyKM
7yIlu/BzJ//KP/K3G59zCHwDnN4kbi3VE1CsNSRwziDKahexaiVEMGyZ2uIq fCF1M7G1+uwT
J0igSuaEA9fS1ntCg+IQ9fr3OCTbmlsaHdQ89XGnHePFEld1qnKeYrCdFmDs fmk8LUnmNcr3
Na1uwV6iu+WEr2iKuGefn98/nMBOFcuodQWzsswpWJ0VrdDvHAC/+JXmOZhJ JdRbW36coJJy
MSKVViREonQrpUV82kELcqQfdcArlnPZcMOQegzoS1168hbvq09ZcJlpjUYo rH3QkdVQlxH4
YwVRuEb6kaYNHG27SEtW/rOj8pZVI0mf0R9dJwYHWDsA5qNT7zew+FlayVY3 wLJQbfMTQCIf
fzmbtpIgc0Kt/RASB/HvDs5TgnwK0SqKgN4RRiJzkqgtB2DVsbQVjeO6VB55 vEkgVKBtrLrE
o1HHkKAfL72vnbPj8kNhqaEiRUJ7590s85IPyQyVgtRS5jAGF+XjEBpB1Q+Z pW0zBT2CA/7K
d4Dix7R4hHGW2wMf0SvYmc6Sdz5V58k19VDXZ214pUgTaSO/5TVdBqk7Slbf y802ifz7FpRI
uBklcKqP2IZy6VUT4lVTR04/KT45vZieHF9OjvdO9qfHP232J1fCShcp6CfK kLO04RMHiiO1
kR2/0x/SpIaYMzJFRlBZ9cll+1AYl5eLyE7q7iAMWu4qdUv546wsaNSdqZ25 Fkx14iLpgyOv
miKaJzmnm0T9MUbMNY8y7pbBIpyKOFdz2GArhTA0VQXCQLA+7NnLdrHWhubq 2QnW8Sh2IdC4
pq1JmjS/jiyyd3e+BLarIJCJ5KRT8CrMJFFgFSrWSgnDrnmp56JSOaBO7BZo BphDVzvarKUW
4+dOHoLsDOQ31tbpI8V5VzQHVUcM92VhEZWW3xbpBFyEOvBI2OmmKLAI6TiZ EXHTLTx3VzZJ
FIUIsSSPVfZ0BuFBkkctQqzcES145E69vLNiBM5P+FUqCoqkLDyJ8oTG8WDi VEAsC1mHdOls
tW0crm1qNDzRkrA66VKslKmaHHqAjxGTppkxFJJgZQI6/YaAKfDappKwqoKt A0KsTnyTPCIj
PTGcEsvq1HTTYoIzFBLW3KlgUVgB/+DUCHpWG7zfb/Iea+46CNx1o1W3oAf2 Tqq/cj6q/7uu
KkVvgyZUmvR7NiEIwSNJF+57iosrQ2pKE7Ea7CdmiJoOOYoeTdDDSIlUVwE5 Pc0eWIwZ8Qa8
SKTncN9MKLmyxGO/al5BwiPC7xQcHZfRGYQRnIKDmdtoAgvuJTgaWXxYA3e8 YNxG4jozuU5y
lmF8KpRHVxXAOwiSY3/YqLxioukTKcMvbAvaGaBMJXyxejRdFuPTRf3ALiDD OvLXX+RVq88T
q6out+BOOUCh8oFiW6A9k7NPSNVb8g35F9m4fLd7dnwZ6PuQ73oHN7QngPxC 2B9taB5mwQCt
TcEaFb3++z/kz4GO1p2N1rr2S8c+bful3ofsjS+X69E7mZX6mag6HYVS6wYP ssdkkdJnnUGU
HhlZidygzvFZyQpcQdYSsPFDbKuwqzdXtKKmJohm1iYuMgURBQKh3OuoD9xn ePvbKL75Ddnb
z320TtlyOSv9VOOA0TzbbgtXe52no9TCwCv7U5XW8M7+a+aA3jhM/D/D3fUK kO/0Qk6tx5Ot
B3URsUuNQzWvyjwy17cAR8y6NI72fWo+SV9jRiI5Y5Ocv7uIj0+OJ+Nt7Rzs TTMi756pufa9
8UbqblrRLPfKvFmKhP0bfwz8aM3Am5+D3UJuAsC3CsIgB1lFrVaWs2wFRd+P Ixn+sojgO4MG
jpmNdnO2KPBqDEBryBhcxqELvKiSGUatnP/q4Idcsg5CQl6VFfuEZvXehQPk CCxxmVYWJC7T
2b6rfJTEic+RWUse0OHk4EIt8afezJ2LO16AvXtMz0qogJT6jfFTGP4YzrSR HWZP13Ba8Z2V
beb8eHK2Pznz2bMOKlqC87OZGBCdLgX3Uy16TMrmlKb8D1FWT8fL9pS6m2ER b4EbojDZxcZt
RrfbZXI2blhT0OmmAF3HKPOboc2k7Y6+9lLhMFL+XdpIBcplZeRPqoL2G09Q DG/qU/Tit6ND
XQZct150cO0VEAf4/1IfPOQfpwp6qlQEfTSu/PuLi66metNato2FJ7adVe6V VSAD4wT0qTkF
l9pK+7Y1kHbX5pyeKW4wwZhPCTGUqA4VCkOLWMNbN/gQNzJvhT45l9wJtWnl gziie8rPF4wO
pu0q3Qq3XnXjhHz5ZUv6nPzaE5yFsjjj5zlkv1DhHBYcxa+MMyz/GvLlsxfJ xg6cHrfF7taM
p/iLkCNIAZ3KVrlN9t6xEgdl2vDIl5sRhVTdrO5P6Vs47I5Dq989Y0SvDFyP 5EkKFUyuHGGY
+VLgtgPGs3hgBAHnasIFnDOO6R9NkvNIbOwUjpS2IEyXb2YUNOY5UyPLSNvA 87W7R0fDSLq3
oiTjZaeY2nsQshiCXFhXvmqMlyVOHo96RgRESKcIdVoliuZHxDwb5CuzIHzc uMSHjW5rI+r7
HiZZVtZK3FfzR9hADU4j8MzOMXzFzLH0TnnXFFLaN8pGzsjwTTJXPc13VAlv PZuWoPv2iVHs
3lXJIEDDYLa9T3yV8KOyouIFmkIy7lhWeU+sPbEA/RFPHbceUjveX27sL/qr 6mLoisG6ujyh
20jCmwILMGgw0uDeJ8FaELY3ZGe8xrujmyQpQnc+RPPCWA3Z5AxcYFfH/8De zMa7K0AE8N7o
NFkCa4uU6LH3WwOY+JddezbS11fRGf/N7TK71D2bmjL33/6Si2oK/5hwMIZo F2M0lO12CSwF
SYRESclJFEBN+2cQnQuw1SggCyUzznUsc0egJBlE0NWSFShj+lpFxrDphd/m 0C5JiJT85qMj
VKIXZRZzgthXttDK+GS5qm9tGOBc3TJ3XmKvH6/6MbraP5HfQXMvUseQ3qhL nsJGuFcn2tPc
+xPaoxj7E0CG6JolLMZq/Lqec3FLXygyKxksz+zdrcju00LGaa+154lwAXyT jGzNCpgKT9zU
p7NbaKFTQYIbdBpyRetlwa4pJw0SZ85aH4KhMYSlx035HXRsCw6Cqa+fWyLE JZ9aXYpTAuZ9
O8TFok//uk2oECNsh8q5Lgf7HyUfKGlWQH9TsD8aeTFEhLHYiOrgoKIh9VUW YTBQXbUGO1/j
+jxWYLt/304XNNBalbaitcjSnQ2TeonRFmhwV724iDMYqpkoyuPdHnMy4/aJ jOM5K7IjcZk2
8vAxKfA2+eor5twWegTW7HGY3w3Ll7HvPp7BNK6V+j3MyfZ3hIyr/VZJQv9t wrW42cHtnuhs
1T5q6UtZLA65W+3bepEIfcNE23DhpuZVuTSd5bW1ivtb6zo9DchV5064JAR+ /RdQSwcIImJ4
LI8PAACmRwAAUEsDBBQACAAIAFCCezoAAAAAAAAAAAAAAABCAAAARU1GLUNv bXBhcmUtZXhh
bXBsZXMvc3JjL2VhY2hvbmNlL3Byb3ZpZGVyL0VhY2hvbmNlRWRpdFBsdWdp bi5qYXZh1VVt
a9swEP4sQ/7DDfqhC9j+ActCR/EgbOtGl34a+2DLF0fUlowkZxuj/31nyS/Y TUqglDIwtiWd
7p7n0d0pXi4XASxhxVX9R4tib9d+HE8n3OTFJr9of+JFUKf8Pi0QMOV7JTlG tVYHkaN+twgW
gahqpS0oXUTIS1EbjLDaRVxVlZJR8uXjt7IphDzDthFR4mfvNudvsqKMbtGo RnP8rHhqlccV
d2y3e2GAHrtH4CitTkswQhYlWiVhp7RbSTpugLkgD1C7+JHX500YQoY0DhuD OswVhzBcj2so
88crVwVK1KnFvJexyUrBYSckIeBlaswQNaGgnjHgb0vuaKkXDv4uAubIMPL6 CbEG4sDvQe0c
8oFL5C1OomWn4bIZXuYAsw6xsakdgB+BvLn5vv1wc53Ae5D464jF5Vs6EfZ6 NLQ40ETPY1PV
JVaUCTSiDKjHTBvxXWtsd7TAhKR9bda/lLzH9HKHzkxTo25/2GUr7CzL4cdP b8YenL4PUwq3
aBstzVTcgU0ve1dwY74/i6N2MU+EjE4KcfX1gFpTRxlFmXMtsNNmttBL1UUe DrNVg/2nckzL
bpaugxBnM99S+JTbhopXTH3NSK+ytXe9irP1S3cT3wBn5IbmN70GPFFPaKxO A+lUzafxPgX4
EeIOco95CrNX3tfn0NwIYUxpVmGVob9UOqoTjGTkPv68qGVaup9aD+7cXA3T 6x9QSwcIslp2
OBgCAACrBwAAUEsDBBQACAAIAFCCezoAAAAAAAAAAAAAAABSAAAARU1GLUNv bXBhcmUtZXhh
bXBsZXMvc3JjL2VhY2hvbmNlL3Byb3ZpZGVyL0VhY2hvbmNlSXRlbVByb3Zp ZGVyQWRhcHRl
ckZhY3RvcnkuamF2Yc1Y227bOBB9tgH/A4PtgxKslfdNmqZIHSBAd1tsg32n pbHNmiYFkk7X
aPPvO7zoTtV2UAcLGLZFzQxnDs9cpMuLi8mYXJDrTBY7xZYrc+OvL9sLbvHN Q/7G/rmcjAua
rekSCNBsJUUGaaHkE8tBXU3GkzHbFFKZ+ubWMJ7OwtX7nBYG1D3NjFS7pvxX +kS97Hul6O4j
0+YqcvNOcg6ZYVI0laVappBxVmhIYbNIM7nZSJEKadhil4ZNrw4U/8v+sIyG TY7QaSPQ1YCc
mQqq9G5FxRIaeodpSZTSQOe8D+UxBvKXaT+8zOuHD0zjrtbrg1VmeMnE8oPc UCYeDGw+1yQ7
zIJV+kjnwF+kiUoFKLP7IrcqO9xtB83Ow5RbEoM4YuMvRm0zs1WQWxfupEB1 c7T7jwogrj8Z
X4acf1wxTfBjVkAWngT4nxq7tkV+ECNJsOhkGJpSKAiaCIDcC+ht4fz5h8E3 UDoNloFQzy5N
ljZ8alB8bu2j8XKzTIonxJfM/rwvxYloZJ62W0qSUc613ev7LWdiTX5bMAUt kElv5TniCOW6
9nfmsbMBujMmegVggv9oCjwUG6kR64WLvzakAMXxOycUC8CSbLbcsIJbiLSh WOOCneuz6ZTM
YcnEFAFV01xmZDq9qe+ByPt3bivEymK7nXOWkYxTrUlZRpv50M5kAv/imee1 aOc2MojDBlmh
yWAt+Z108hwX6gwm3yfjkaPRqOTRGqDAQ1LYF0q8lJSmOtcWwXLgsMQA3ak6 SnTEUm95EL/R
MICjDoIjB+EIz9lg08Aji5c/UuB5ChNpTp1AG8lRAVky86jK+XzKIDt7kax9 +RYz+BtpyyTn
sXA754qp6M42pJHFYVfgOWYryNY+xcssZTqgeC/VIwqR7sJJAaiHhOtP86/4 76b2+dG57DGo
Jo1SLA4DlirtCjNSVVRpfoIAfKrvT/Lk3CXhqB1USvM8Ge6bqSshNsC44k97 zz7lgZazT63X
og9RaHfmhsbzfgpb+kpRlXOfzQupHLcDeavJdSYMM7vnVmE/GWf9Zs0DQyvd pSg7FbhqitSs
CqkNaCicXx/E7Sfs5Ar9qzkc+Bqc8zuHtZK8bEGSfoTkLabmlvMgNIpJuNzt 45XYZuKp45kw
UoB8FnEco2zxCnpPB8N6YDC5dGugOVk5GGzTOFyZv9HJeG0Iscc6W4kxeecj +CMqlQ6YH8JO
4wTlgMtCj/0/gPckWW49+xwJMDliGAigWp/TOKRDM0QXq9Pm3VxKDrZJddpt 4huca9htgnSq
bHk8iZf88cMKYF3uGXT3h7hQDUdulEcTc40puHVDX+OBgxkNHOcKv7qGnatc jXH7VWuV2zOp
xiRRDb8/ww599Hq1eFWGXvXkg5PemXAh3U8sAFt840daFt6mPVd0m8GWhisS eItnzkTVL7Hf
3tnmfP3uxjEpSZLq2mkiqx6CbBI2Oq8cKEGm1dubkSvs3epuK9kQD3FmwC/C w3P4acsMblY+
8Cfx9wCeU93VEHB7Sk+b1uJqw01sI5/g9eL2+/3C0DsGj4u+9XhZPo60N3jG WSlv3o6V7lM8
oDRA6720SJqvHVtvQuIg9Q20dPyk6LIy2q/O2mNWdADYv4VPyOgxuPcFloU4 Z4TBm+EEVr5U
UuXg2nszlJKTAh8c2zOFVvD076WVhYqC+PUfUEsHCITZV7ToBAAATBcAAFBL AwQUAAgACABQ
gns6AAAAAAAAAAAAAAAAQgAAAEVNRi1Db21wYXJlLWV4YW1wbGVzL3NyYy9l YWNob25jZS9w
cm92aWRlci9FbnRpdHlJdGVtUHJvdmlkZXIuamF2Yd1abW/bNhD+7AD5D1xW YHKbyFs+7EPT
pPUctxPguIHjFBiGwaAl2uYqix5FJTPa/PcdX/QuxUqTOF2QwJbEuyPv7rnj 8eTOy5e7O+gl
euOy1ZrT+UKc6PtO/oF6+MLxXsiLzu7OCruf8Zwggt0FC1xirzi7oh7hR7s7 8o8uV4yLdLhv
Lt5jVzC+PqqnONeSqygCQcX6KCP+b3yF7UhQ3+4x3yeuoCw4qhgd0FBk+Rif 28T16SokNlnO
bJctlyywAybobG13PbwShJeWejvXUH5RF5s1bOJS6xqRkEXcJQMGfIzfxkZc xsEEF4JHrog4
9t8TDN/kVh6PisQxYCKgCgme+qSphnkBTh9uaTA/ZUtMA0eQ5Xnq9GYSJNMA T4n/TZzAtCJc
rE9J6HK60ha7O/uFsnlj1tjkxJNCeiwQJBB3Xv+YE3If/vupn/GV8X1T1k+U XBNeAnfH5I3x
goYI/sWCIAqzoJgRYT0PmjG4Rl/e+TT4XIzlG8Smf0PY2jrn/HBwgKZkToOD KCT8wGMuOjg4
ScdI4JVH3s1JQDgWxItTUzT1qYtcH4ch0vNk9d/daZF/wQVeiCrMAqNgFp8s wUch3LTqQb+v
hm9Fhyapcb0eLEVE+jiPV/QFBpTZW7HdXRaEavoQ4QBRuMFgWzTjbAkmn+no hiEP7lSWouBQ
zV9r61a9sVsFa7eUuVvG3mVLW/k0EyPC3LaVQq0wAh2twhBArHUjYVZQmBOw dKDRtjLWQV4S
DqECmxzU8jwNgodX+d3HK8I56JiqL7eYNzVZ6gTNiSg/Dq2PCv0mCIxB6AxZ tFJMiI6PURD5
vqHUtrNrZBuhKlqBFnveBcAYcr8QnE4jQcpMGR7NcRb5gt6FQU8xIjPCidzL G05xF4auJwOS
BdhvurAb+aGhg2osWwc4mA8+qrCWQE2rjJLFoJnemB8h0DgToBTA+opRDzXy aCXCqm1gg0Bl
ZMvloAKpxrKiaFmWVVtOtAvBLAE6Ykzkqaz2vhYlY6NQB+XGIMGCltbe5NKZ 6BwzCfNqT4zF
9+rYylpMYkcCkPb2URPheSqxXmXmK9SuUG+CotgP7f5w7Iz/mEwunOGHQX/S HY9Hzm+X437M
CNmbxNczYKi+qfaE/aE/7I+c3uRTd3DZnzhn3Q+JXJklstft2pTaAOEqRJ8G 4BsT0LPE9zKn
9cPCu0b2vdB9djkYO/9TcJv0nexA20/ft21+zxLeYV7tx0jfZeEPkb5H/ff9 UX/Y24zw7EAR
rg+cl58EuRurtmcJ3GVO60fIyw8MW52XvzPUpvX705QUzc4PzxK/uKz6w4L4 tgnuheTu6akz
dj4Ou4PvscwIV8SVzZUQLdg1EgwlLaS47/UjWLW3oL4H0X2jOjLABgD2JLVH vAjSNw4QXsnI
4RSnIaH7Z4GezUir7NjJvjIItgHfPX15s9+IYUSW7IrEPEhBteFcZ1lGGiTa 6kCIR7bSf0lf
ALx5i+IGX7ldrloxsSfMs/o+jFsgrG3AlCTmuhZFMTJjWBsx3/vdGZxC4n4Q IYflVkhRYAW6
H8tlSVIuOyjxj7nP+2YfmVu1eOOGTgf1FsT9rLYXmVgQm6nrOC49TW5kqPAz NkgbiUm8QUCC
QjLsjGyZ1II5skJCYoBnYqyNKEiUm56aw9btNiM+j49Yo1gVrcOmXqdOmPac zrYSR8a+sGZn
CYiqDA2jHQQ/9/Fa08VKVe1KdiJtbwbR0wHaX37taMX26tNqttvryxY5EhDY T9jj1fuiVHEM
C6k0jSHRyz1GlqW1bBsiaYlC087SkWlsahh1mkFfv+oHtk+CuVhYbTnyM3qr EkL1Hq83VvR6
M8krtAd/r/QMdT5YAMZ9SHxL5sG6gsxroBBN18jFvi/1jRN/tPJk4k92OhlM 6hEEnaR2F8bC
SfZR0SglyS1DisLoSr1yyk22j64X1F3IWFuBt2FBIDmedEY5US+o1j1Y7pxs acdRBWWQndfK
vibLrd+gI28eK0dhGvXhNRWgaG5MosYkD+fUIMpWsG/HO5GLIWcVd4O67uPr zSyFlk4DjqoS
TbO1Sg6yAnKNym8WrbzLiyYYmldYUOaa2k7Vfm2zQZoQOtq81HhTbKBVsn8+ niqqftUKVami
tmy9keTBVkRP/YGsSSln9rNzzPGSQBFxE5rD21QGpcy3ccRq6WKBYReGmnVK dOxCJo4C+eJX
yHmT97pbKSNUKLq6AhySaxVg2XdhmeJQJ+0TFJTJkuIil9G16W8RXikp//at gqR4alTjifXN
abFxeVc8SJnDok2c4cW4C2d/W8+ic4fVbm9tZYfftLS71gONEJ5qs9WTSVo1 ZFaQKyCuQUoC
PlOH5ivd/dz55gSFxNwYkGZp40L6OBZ1VKQw18f6ziBhyphPIJ7/ibAPWQYd p6eOROLx5pN6
7HeoXe4n4NCsS57DzJrizc7USkl1YzCpapyMjScSHod7yRkeErXW/M+/0BdV xUEhpByRsUpb
lbBmwemgeaBHEz7luTa6KR+u0sq/4HPj7MTLxr2pQyvQP0oPK9zU1sjXxbWp huWPcLK/vvkp
TCi3UxoXav7KY0Du8BDjQP685tyPYFl2nBASC8DHf1BLBwgZsObLmAcAAKAo AABQSwMEFAAI
AAgAUIJ7OgAAAAAAAAAAAAAAAEIAAABFTUYtQ29tcGFyZS1leGFtcGxlcy9z cmMvZWFjaG9u
Y2UvdXRpbC9FYWNob25jZUFkYXB0ZXJGYWN0b3J5LmphdmG1Vk1v4jAQPQeJ /+CVKjVFIvwA
KGqFqMSlXW059GqSCXib2JFtyqKK/77jL0hSoEhtL+A445k3782MM+j1uh3S I6NUVFvJlis9
ds+D5obdvJplV2Yx6HYqmr7SJRCg6UrwFJK1ZsWw2+l2WFkJqQ8vevVdIZcJ pAWrFCRQ5kkq
ylLwhAvN8m1yn9FKgxxeaP5o/pi1v/AEGhUhygNNtZDbGW6dcwCpkJBMnxZ/ IdXWcBAo+9Xv
kwUsGe+vFch+JlLS7zv65isgo8XYhyI+1miwGJNcSKLxdSkyKBJrPdOkkuKN ZaAI5YT6U6hJ
BuNUAtXw8vJiJMFnUoJeicz6MSSTtKBKEZG3vVp8wLOP6O4U1JSb+sVvJ6mz WAIHiXGzoPd6
UbDUxwonmkwS+KcxnCIfCSbv3U5keYs8OSm6gMzBJb6YEvf6JK/R6aSiFubI go6QVY2yYSCl
qUb8rVxdfP9gxT2gnFjerSCM43E8FUgOAuUuwx/A7dg+znN8Y+mMWE7iOn5y e0v4uij866j5
rp16ArPH5/n942Q6NNY7/Nk1CfgDei25IpsVFhyYomUqpExwSasKQdJFAfua 1ttqT5KwHXMJ
N3Pj2LQmlMCNToIT6YO7HtByDaH8Wd29wQHMw/NyXqtQUNjMFmhdQXes1S2f KeTQfAsTR9S+
e3oDKbH7D8ovhCjA4FZe9Ach5+gyfvL47V+tEHxeWAJ12UMpePyGxr3a9WOB HgTsJ13rZByH
fR85gYkZBfFNsgQ99eGwMlsADtG8o5wWyu62is3MBLVhGueZXlFN0AUsbf9p YUk8OwzVT46O
0DjPFt7IN+PY5ek2ya1JkcPmlHHo2YbWUVA7XBMpVTDlmult7P6aOu9JdCw4 E382vrFUO67P
R8kgp+tCTzBYUPV8HGdzLNDu9Mzcz0jfEL6RqcR68eJ9VbSKSloS57I+E7Bi bPTQcaH665P7
U1SX9eleOZt4oCh8mHhsnlYPo1Y2SSbc4tBe/sS+Q46yS0yl1VNBvg+Dzd3R 1+93BeOvtWve
VdQIyrFbjga43F1fPKF93Zya1ObqIUq49t2YG55jcMUKHJFLjh9RtrzV0Hlk Gsc0BsrXhdHL
W1BrY+asGdk4apmb2huGvlNqOo3iSq+8M0x8u6Hbyye4OVkjL2jd/B6y7Hx2 NzeVb/ViQ3BD
zJGJd1pNAzKQbdL8ToW+TNWlhLSGxmlGdmQwOP6h0+38B1BLBwhnl3KLlQMA AJ4MAABQSwME
FAAIAAgAUIJ7OgAAAAAAAAAAAAAAADoAAABFTUYtQ29tcGFyZS1leGFtcGxl cy9zcmMvZWFj
aG9uY2UvdXRpbC9FYWNob25jZVN3aXRjaC5qYXZh7VZLb9s4ED7LgP/DFFsg chDLe44f7SLr
g4FFdrHRIXukpbHFRiIFkWpgFP3vO3zIkm3ZSV9ADz0Ypsh5fvMNOZPr6+EA rmGWyHJX8W2m
F+57crhhN9+u0rdmMRkOSpY8sS0CsiSTIsGo1jyfDgfDAS9KWen24Lq7+4F9 ZFY0+osr3T2R
1TbCJOelwgiLDa1lhdHyLmdKTV+S+nv9ARNnbtIk9GY8hjVuuRjXCqtxKhMY j11ycYYwWy8e
nrlOstlkvYCNrEDTbiFTzK8UcJFhxTWjBCDjWLEqyXaRVV5pUHVpolFWJWF5 Dp/e51w8wW+p
dEZDH9II9jvSbXy2RrQkFx/lE1oTBH6Ki4QpfHx8NMjTFxSoM5nayAyWkBgk QG7aOG+sKaVZ
pbnYArnJ7CFLdM3yQwXn3SowkUJZyQQxNWp1aQV6M7bytaB6AQMhxVjUlGyF qs41cEUrXVcC
UxfJc8YpTu5g8ULevbIYRG1lUKSndXmvsMOopV/846jmJLYoKDaNacPDep3z xOfaaPjCxgv4
NBwElhGBL3tCIpg6/KBsLAeXCBOcjzk4CimwMQWEria0yQ8VR1N4R6k49/7D srYN8q5CsqWo
SlQS5epxDOL3DtdheIheOLLgBXwDYTdcmM/BsMAfB4dnx5lGuLp/iP+4v1tO jTSR3/wO8qX2
Uf0dcIH6npRSoOegcgSFDkGnwDXsOOapYSTTfvtb8XP+bCgbXil90hdNU8B6 R0H1ZmbujOil
esRwfJsYp/uLxcLvg9kLtgIR2qszHN10taa/CvCaAuz7t1sDi6cF065u4GxV TM/s5agQUmjG
yQn1FHVPt2OaLuqro9PeorYLvqFLefVnTz1tVwWYK/TGzNM6c+oLwIe6xCre lXSnzOHA7rI9
Cp0lH4ddBh3NiKtlUeodJfDOHQYpbhiBfUe4hl0AbpvzJpWuGXIa/n4mg1+0 /CpacqEdDp4g
F2jp3g8Iu+INAU0gJ5f38j5exf/depFgSdjqHeVv/+YQuo1R68iRKIiblOdg 7Dqx0Ol5otke
aaSaF2WvdYZcXtUj7atp92wLNJy8haadLpjpody/njGH4wsBjFVJFs2w1I5S wE7e6KsZFguX
7GxCy6vXUCrOaGCi6TbHggCiaUGKPXUNKlMn5rZMCKeD2DOnNQVZcEF8OTMq nGFtySpWNCkZ
TZomqUt7R44uxb8nPnbsa0fnizP+6ORRHL38jnZI6Dksex7RBu0fwgoX689B ixtY16bYxoPL
iy4EbVGi4HfPbPdTEqcHwi9izivmrc590dyiLzLlM0wmh6PzcPA/UEsHCBqK REzVAwAAVg8A
AFBLAQIUABQACAAIAFCCezpjc8zAzgAAAHYBAAAfAAAAAAAAAAAAAAAAAAAA AABFTUYtQ29t
cGFyZS1leGFtcGxlcy8uY2xhc3NwYXRoUEsBAhQAFAAIAAgAUIJ7OpPAPUDw AAAAqQIAAB0A
AAAAAAAAAAAAAAAAGwEAAEVNRi1Db21wYXJlLWV4YW1wbGVzLy5wcm9qZWN0 UEsBAhQAFAAI
AAgAUIJ7Out1ks+WAAAADQEAACUAAAAAAAAAAAAAAAAAVgIAAEVNRi1Db21w YXJlLWV4YW1w
bGVzL2J1aWxkLnByb3BlcnRpZXNQSwECFAAUAAgACABQgns6OalskNcDAABx CgAAJgAAAAAA
AAAAAAAAAAA/AwAARU1GLUNvbXBhcmUtZXhhbXBsZXMvcGx1Z2luLnByb3Bl cnRpZXNQSwEC
FAAUAAgACABQgns6GNQP21wCAACFCAAAHwAAAAAAAAAAAAAAAABqBwAARU1G LUNvbXBhcmUt
ZXhhbXBsZXMvcGx1Z2luLnhtbFBLAQIUABQACAAIAFCCezoebttSRQEAAMYC AAApAAAAAAAA
AAAAAAAAABMKAABFTUYtQ29tcGFyZS1leGFtcGxlcy9NRVRBLUlORi9NQU5J RkVTVC5NRlBL
AQIUABQACAAIAFCCezpyl/0UCQIAABEHAAAwAAAAAAAAAAAAAAAAAK8LAABF TUYtQ29tcGFy
ZS1leGFtcGxlcy9lYWNoLW9uY2UvZWFjaG9uY2UuZ2VubW9kZWxQSwECFAAU AAgACABQgns6
x6WXQnoBAABdBQAALgAAAAAAAAAAAAAAAAAWDgAARU1GLUNvbXBhcmUtZXhh bXBsZXMvZWFj
aC1vbmNlL21ldGFtb2RlbC5lY29yZVBLAQIUABQACAAIAFCCezrdtzP2zgAA AN8AAABJAAAA
AAAAAAAAAAAAAOwPAABFTUYtQ29tcGFyZS1leGFtcGxlcy9pY29ucy9mdWxs L2N0b29sMTYv
Q3JlYXRlRW50aXR5X2NoaWxkcmVuMl9FbnRpdHkuZ2lmUEsBAhQAFAAIAAgA UIJ7Ot23M/bO
AAAA3wAAAEgAAAAAAAAAAAAAAAAAMREAAEVNRi1Db21wYXJlLWV4YW1wbGVz L2ljb25zL2Z1
bGwvY3Rvb2wxNi9DcmVhdGVFbnRpdHlfY2hpbGRyZW5fRW50aXR5LmdpZlBL AQIUABQACAAI
AFCCezrGV0CXDwEAAFoBAAA7AAAAAAAAAAAAAAAAAHUSAABFTUYtQ29tcGFy ZS1leGFtcGxl
cy9pY29ucy9mdWxsL29iajE2L0VhY2hvbmNlTW9kZWxGaWxlLmdpZlBLAQIU ABQACAAIAFCC
ezobi+zndwAAAIEAAAAwAAAAAAAAAAAAAAAAAO0TAABFTUYtQ29tcGFyZS1l eGFtcGxlcy9p
Y29ucy9mdWxsL29iajE2L0VudGl0eS5naWZQSwECFAAUAAgACABQgns6OEKx bC8JAACeCQAA
NgAAAAAAAAAAAAAAAADCFAAARU1GLUNvbXBhcmUtZXhhbXBsZXMvaWNvbnMv ZnVsbC93aXpi
YW4vTmV3RWFjaG9uY2UuZ2lmUEsBAhQAFAAIAAgAUIJ7Omd2xSKKAQAALQQA ADYAAA
| Re: [EMF Compare] Reference change detection bug in 3.5M6? [message #134553 is a reply to message #134540] |
Mon, 30 March 2009 08:29  |
Thanks Laurent!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270439
Best regards
Patrick
On 30-03-2009 13:19, laurent Goubet wrote:
> Hi Patrick,
> Thanks for the test models, this is indeed a regression with my adding
> the detection of inter-model references. This should be fixed in the
> next build as I could locate and fix the culprit, however coud you raise
> a bug for this issue for the record?
> Regards
> Laurent Goubet
> Obeo
> Patrick Könemann a écrit :
>> Dear developers,
>> and references.
>> to
>> correctly detected!
>> So what is wrong?!
>> Best regards
>> Patrick
| Re: [EMF Compare] Reference change detection bug in 3.5M6? [message #620769 is a reply to message #134508] |
Mon, 30 March 2009 07:19  |
--------------070501080500020601040608
Hi Patrick,
Laurent Goubet
Obeo
Patrick K
| Re: [EMF Compare] Reference change detection bug in 3.5M6? [message #620770 is a reply to message #134540] |
Thanks Laurent!
Best regards
Patrick
> Hi Patrick,
> Regards
> Laurent Goubet
> Obeo
>> Dear developers,
>> and references.
>> to
>> correctly detected!
>> So what is wrong?!
>> Best regards
>> Patrick
FUDForum. Page generated in 0.04116 seconds
