Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Save a emfdiff result of comparaison using SVN
Save a emfdiff result of comparaison using SVN [message #134231] Tue, 24 March 2009 05:37 Go to next message
Originally posted by: cbda.free.fr
Hi everyone,
When I am doing a comparison between a local file and the latest version
from SVN Repository, I can not save the result as an emfdiff file. I am on
Eclipse 3.4.1 with EMF Compare 0.8.1. Is it there a way to save this
result?
Thanks in advance,
Caroline
Re: Save a emfdiff result of comparaison using SVN [message #134244 is a reply to message #134231] Tue, 24 March 2009 06:15 Go to previous messageGo to next message
Just to precise: the icon “save as emfdiff” is present but it is disable
when the comparison is made with files from repository while it works fine
with local files.
Re: Save a emfdiff result of comparaison using SVN [message #134284 is a reply to message #134244] Wed, 25 March 2009 09:49 Go to previous messageGo to next message
--------------050701090105030201060001
Hi Caroline,
The "emfdiff" export is disabled for all comparisons involving remote
models as the saved model would fail loading these : no direct URL to
them, or at least I don't know of a way to save references to these
models with revision/repository information that EMF would know of.
If you do wish to generate comparison reports, custom actions can be
added to the export menu of EMF Compare through the extension point
org.eclipse.emf.compare.ui.export (there should be a tutorial on this in
the eclipse help).
Laurent Goubet
Obeo
Caroline Bourdeu d'Aguerre a
Re: Save a emfdiff result of comparaison using SVN [message #134465 is a reply to message #134284] Thu, 26 March 2009 05:41 Go to previous message
Ok I'll try to do this.
Thank you for your answer.
Caroline
Re: Save a emfdiff result of comparaison using SVN [message #620747 is a reply to message #134231] Tue, 24 March 2009 06:15 Go to previous message
with local files.
Re: Save a emfdiff result of comparaison using SVN [message #620750 is a reply to message #134244] Wed, 25 March 2009 09:49 Go to previous message
Hi Caroline,
the eclipse help).
Laurent Goubet
Obeo
Re: Save a emfdiff result of comparaison using SVN [message #620764 is a reply to message #134284] Thu, 26 March 2009 05:41 Go to previous message
Caroline
Previous Topic:New Agent Modeling Proposal
Next Topic:[EMF Compare] Reference change detection bug in 3.5M6?
Current Time: Sat Nov 29 08:30:40 EST 2025
Powered by FUDForum. Page generated in 0.04440 seconds
