Home » Eclipse Projects » Remote Application Platform (RAP) » Exception at dispose shell
Exception at dispose shell [message #134169] Wed, 27 May 2009 03:59 Go to next message
I get an java.lang.StackOverflowError when I close my shell. I have the
following code snippet for this close event.
mainShell.addShellListener(new ShellAdapter() {
public void shellClosed(ShellEvent e) {
resultList = null;
mainShell.dispose();
public void shellDeactivated(ShellEvent e) {
resultList = null;
The error is in methode shellClosed at line mainShell.dispose().
Where is the error in my code?
kristin
Re: Exception at dispose shell [message #134196 is a reply to message #134169] Wed, 27 May 2009 05:13 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
Hi Kristin,
just a wild guess: the dispose() method calls the shellClosed() method of the listener, thus you end up in an endless loop.
maybe you could use a simple boolean variable isClosed to avout calling the dispose() method for a second time...
HTH,
ben
Kristin Polenz schrieb:
> Hello,
> resultList = null;
> resultList = null;
> The error is in methode shellClosed at line mainShell.dispose(). Where
> kristin
Re: Exception at dispose shell [message #134209 is a reply to message #134169] Wed, 27 May 2009 05:19 Go to previous message
Hi Kristin,
The StackOverflowError might be related to this bug:
229309: StackOverflow when widget disposes of its parent while itself in
dispose
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229309
Anyway, there is no use in disposing of the shell on shellClose. Closing
a shell automatically disposes it. So you can safely remove this call.
Regards, Ralf
> resultList = null;
> resultList = null;
> kristin
Previous Topic:could i build a wiki using RAP?
Next Topic:reference to undefined property this.__registry[$0]
Current Time: Sun Nov 23 08:33:47 EST 2025
Powered by FUDForum. Page generated in 0.03410 seconds
