Home » Language IDEs » C / C++ IDE (CDT) » CDT and Refactoring Support
CDT and Refactoring Support [message #134125] Sun, 09 January 2005 15:23 Go to next message
Originally posted by: kdale.cs.virginia.edu
It looks like CDT supports simple refactoring (renaming) as of 2.0, based
on the docs that I've looked at, but the option doesn't appear when I try
to use it via the refactoring context menu. Instead I get "<no
refactoring available>". BTW, I'm using Eclipse 3.0.1 and CDT 2.1.0. Any
ideas?
Re: CDT and Refactoring Support [message #134174 is a reply to message #134125] Mon, 10 January 2005 08:50 Go to previous messageGo to next message
Originally posted by: cnelson.nycap.rr.com
> based on the docs that I've looked at, but the option doesn't appear
> when I try to use it via the refactoring context menu. Instead I get
> "<no refactoring available>". BTW, I'm using Eclipse 3.0.1 and CDT
> 2.1.0. Any ideas?
I'm having the same problem but I have no idea why. I'm using Eclipse
3.0.0 with "C/C++ Development Tools" add-in version 2.0.2 on RedHat
Linux. What're you using?
Chris
Re: CDT and Refactoring Support [message #134186 is a reply to message #134125] Mon, 10 January 2005 09:43 Go to previous messageGo to next message
The feature is significantly limited.
Different contributors are looking into upgrading this funcitonality for our
next release.
JC
"Kevin Dale" <kdale@cs.virginia.edu> wrote in message
news:crs3rq$72r$1@www.eclipse.org...
> ideas?
Re: CDT and Refactoring Support [message #134225 is a reply to message #134186] Mon, 10 January 2005 10:45 Go to previous messageGo to next message
BTW, I'm on WinXP. Based on help docs, it looks like I _should_ be able
to right-click a class name in a C++ project header file and do a
refactor-rename from there. Should I be able to do this, or is this not
available yet either? Also, what is the approximate next release date?
- Kevin
> next release.
> JC
>> ideas?
Re: CDT and Refactoring Support [message #134889 is a reply to message #134225] Fri, 14 January 2005 10:32 Go to previous message
Try doing it from the outline view context menu instead of from the editor.
-Andrew
news:cru7v0$8br$1@www.eclipse.org...
> - Kevin
our
> > next release.
> > JC
based
try
Any
> >> ideas?
Previous Topic:Automatic conversion from 2.0.2 project files to 2.1.0
Next Topic:problem with debugging
Current Time: Sun Jul 27 12:46:10 EDT 2025
Powered by FUDForum. Page generated in 0.05676 seconds
