| a problem launching Eclipse 3.0 unit tests under Eclipse 2.1.1 [message #133971] |
Mon, 22 September 2003 14:32 |
Originally posted by: dstalnov.yahoo.com
I'm trying to execute Eclipse 3.0 (build 20030917) workbench unit tests
under Eclipse 2.1.1 but getting the following error in console view:
java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/junit/runner/RemoteTestRunner
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find Class(Delegating
URLClassLoader.java:922)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParents
Self(PluginClassLoader.java:163)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf
(DelegatingURLClassLoader.java:490)
I exported all Eclipse 3.0 plugins into Eclipse 2.1.1 workspace and ran
JUnit Plug-in test launcher from Run -> Run ... menu. In the launcher
configuration dialog I selected org.eclipse.jdt.ui.tests.refactoring project
and org.eclipse.jdt.ui.tests.refactoring.InlineMethodTests test class. I
have org.eclipse.pde.junit_2.1.5 plugin installed in Eclipse 2.1.1.
Is it possible to do what I want? What am I doing wrong?
Thank you in advance,
Dmitry
FUDForum. Page generated in 0.02814 seconds
