Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] How to start
| [EMF Compare] How to start [message #133754] |
Sat, 28 February 2009 17:32  |
I'm sorry for this simple question.
I didn't found anywhere in the web how to start
develop applications using EMF Compare.
Can someone suggest me a resource?
I need a kind of "EMF Compare user guide"
I checked out plugins as described here:
http://wiki.eclipse.org/Setting_up_a_development_environment _for_EMF_Compare
but got some unresolved symbols, including:
org.eclipse.emf.ecore.*
org.eclipse.emf.common.notify.Adapter;
org.eclipse.emf.common.notify.Notifier;
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl;
I'm using eclipse 3.4.1
I think that if i'm not going to develop
EMF Compare, but use it, I don't need this sources.
I need binaries and a kind of documentation, isn't it?
But I can't find neither binaries nor sufficient documentation.
Are EMF Compare binaries automatically included in EMF or
should I download them explicitly somewhere?
Thanks in advance,
Oleg
| Re: [EMF Compare] How to start [message #133920 is a reply to message #133766] |
Mon, 09 March 2009 06:27   |
Hi Laurent
Sorry for delayed response.
Thanks, your information is very helpful, probably it makes sense to put
it on wiki...
As far as I understood this approach works for Eclipse 3.4
Do you know if it is possible to install EMF compare in Eclipse 3.3?
I want to use EMF compare to make things in another project
http://www.eclipse.org/bpel which uses Eclipse 3.3.
Oleg
laurent Goubet wrote:
> Hi Oleg,
> Indeed that wiki page you're pointing to is only for developping patches
> or applications needing EMF Compare sources. You need not retrieve any
> of these in your workspace if you only intent on comparing models
> without patching the comparison engines.
> The unresolved dependencies you had when downloading the source code
> points us to a possible answer as to why you cannot compare models
> though. You have to have installed EMF prior to installing EMF Compare.
> You can use the Ganymede update site for both of these : in your Eclipse
> select help => Software Updates. In the newly opened dialog open the tab
> "Available Software". In this tab should be a section "Ganymede"; expand
> it (this could take quite some time) and expand the category "Models and
> Model Development". In this category, select both "EMF" and "EMF Compare
> (Incubation)" then click on "Install..." and you're all set.
> You can then compare models following the information on
> http://wiki.eclipse.org/Installing_and_Using_EMF_Compare .
> Cheers,
> Laurent Goubet
> Obeo
> Oleg Vazhnev a écrit :
>> Hi
>> Thanks in advance,
>> Oleg
| Re: [EMF Compare] How to start [message #133932 is a reply to message #133920] |
Mon, 09 March 2009 09:07   |
--------------050901030804040604010505
Hi Oleg,
Indeed I assumed you were using Eclispe 3.4, though the approch is the
same on 3.3, only the UI changes :
Select Help => Software Updates => Check for updates.
On the new dialog, tick 'search for new features'.
On the next screen, either use the Europa update site to install EMF
Compare (should be in models and model development) or add the emft
interim update site :
http://download.eclipse.org/modeling/emft/updates/interim/ .
If you wish for a more direct approach, you can either use one of the
archived update sites from
http://www.eclipse.org/modeling/emft/downloads/ or download the zip you
want to install (SDK, runtime, 0.8 or 0.9, ...) and unzip it in your
eclipse directory.
There should be information about the update managers on the eclipse
wiki ... don't really know where though :).
Laurent Goubet
Obeo
Oleg Vazhnev a
| Re: [EMF Compare] How to start [message #133998 is a reply to message #133932] |
Wed, 11 March 2009 19:11   |
Hi Laurent
Thank you very much!
I just learned how to use my another project in Eclipse 3.4 :)
So I hope i can do everything in 3.4 now...
But this information is very useful, i think it would be nice
to have it published somewhere...
I've added .bpel to "EMF Compare" group in 'Content Types" and
I'm able to compare .bpel files now.
But i can't open .bpel files in general editor after that :)
I got this error trying to open file:
"Unsupported content type in editor. To associate file extensions
with a supported content type, please see Content Types Preference
Page" + very long stack trace
Probably this is known situation?
Probably I should configure something else?
Otherwise it could be bpel plugin problem, i can investigate it
myself then.
Oleg
> Hi Oleg,
> eclipse directory.
> Cheers,
> Laurent Goubet
> Obeo
>> Hi Laurent
>> put it on wiki...
>> Thanks,
>> Oleg
>>> Hi Oleg,
>>> patches or applications needing EMF Compare sources. You need not
>>> retrieve any of these in your workspace if you only intent on
>>> comparing models without patching the comparison engines.
>>> Eclipse select help => Software Updates. In the newly opened dialog
>>> open the tab "Available Software". In this tab should be a section
>>> "Ganymede"; expand it (this could take quite some time) and expand
>>> the category "Models and Model Development". In this category, select
>>> both "EMF" and "EMF Compare (Incubation)" then click on "Install..."
>>> and you're all set.
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Hi
>>>> Thanks in advance,
>>>> Oleg
| Re: [EMF Compare] How to start [message #134006 is a reply to message #134004] |
Sat, 14 March 2009 18:20   |
Hi Laurent
I've created https://bugs.eclipse.org/bugs/show_bug.cgi?id=268650 with
stack trace attached.
It's nice that you have time to look at this problem, thanks.
It is not trivial to reproduce a bug - bpel plugin should be installed
before. Just in case instructions are here:
http://www.eclipse.org/bpel/install.php (but there are no update site
for 3.4 yet, so you have to checkout/compile it).
Oleg
> Hi Oleg,
> Glad to see you've got through the installation issues :). As for the
> "cannot open editor issue" ... nope, never observed that with EMF
> Compare :(. Could you open a bug on the Eclipse bugzilla with the stack
> trace attached so we can try and have a look at what exactly happens?
> Laurent Goubet
> Obeo
>> Hi Laurent
>> myself then.
>> Thanks,
>> Oleg
>>> Hi Oleg,
>>> the same on 3.3, only the UI changes :
>>> you want to install (SDK, runtime, 0.8 or 0.9, ...) and unzip it in
>>> your eclipse directory.
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent
>>>> put it on wiki...
>>>> Thanks,
>>>> Oleg
>>>>> Hi Oleg,
>>>>> code points us to a possible answer as to why you cannot compare
>>>>> models though. You have to have installed EMF prior to installing
>>>>> EMF Compare.
>>>>> select both "EMF" and "EMF Compare (Incubation)" then click on
>>>>> Cheers,
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi
>>>>>> Thanks in advance,
>>>>>> Oleg
| Re: [EMF Compare] How to start [message #134009 is a reply to message #134006] |
Sun, 15 March 2009 06:53  |
--------------050808030605020204040806
Hi Oleg,
Thanks, I'll try and have a look into this. Looking at the stack trace I
believe the actual issue lies into the BPEL plugin. I'll look into this
from my end and cc them to the bug to see if they have already
encoutered this.
Laurent Goubet
Obeo
Oleg Vazhnev a
| Re: [EMF Compare] How to start [message #620699 is a reply to message #133754] |
Mon, 02 March 2009 03:07  |
--------------060804040301020904020407
Hi Oleg,
Laurent Goubet
Obeo
Oleg Vazhnev a
| Re: [EMF Compare] How to start [message #620711 is a reply to message #133766] |
Hi Laurent
it on wiki...
Oleg
> Hi Oleg,
> Cheers,
> Laurent Goubet
> Obeo
>> Hi
>> Thanks in advance,
>> Oleg
| Re: [EMF Compare] How to start [message #620712 is a reply to message #133920] |
Hi Oleg,
eclipse directory.
Laurent Goubet
Obeo
Oleg Vazhnev a
| Re: [EMF Compare] How to start [message #620721 is a reply to message #133932] |
Hi Laurent
myself then.
Oleg
> Hi Oleg,
> eclipse directory.
> Cheers,
> Laurent Goubet
> Obeo
>> Hi Laurent
>> put it on wiki...
>> Thanks,
>> Oleg
>>> Hi Oleg,
>>> and you're all set.
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Hi
>>>> Thanks in advance,
>>>> Oleg
| Re: [EMF Compare] How to start [message #620722 is a reply to message #133998] |
Thu, 12 March 2009 04:45  |
--------------080308070401050805000508
Hi Oleg,
Laurent Goubet
Obeo
Oleg Vazhnev a
| Re: [EMF Compare] How to start [message #620723 is a reply to message #134004] |
Hi Laurent
Oleg
> Hi Oleg,
> Laurent Goubet
> Obeo
>> Hi Laurent
>> myself then.
>> Thanks,
>> Oleg
>>> Hi Oleg,
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent
>>>> put it on wiki...
>>>> Thanks,
>>>> Oleg
>>>>> Hi Oleg,
>>>>> EMF Compare.
>>>>> Cheers,
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi
>>>>>> Thanks in advance,
>>>>>> Oleg
| Re: [EMF Compare] How to start [message #620724 is a reply to message #134006] |
Hi Oleg,
encoutered this.
Laurent Goubet
Obeo
Oleg Vazhnev a
Current Time: Sun Nov 23 15:26:54 EST 2025
Powered by FUDForum. Page generated in 0.12554 seconds
