Home » Archived » BIRT » Locale date formatting in Dynamic Text
Locale date formatting in Dynamic Text [message #133666] Tue, 21 February 2006 14:32 Go to next message
Originally posted by: dave.gross.logiclibrary.com
What is the correct way to get a date formatted in the current locale if it
is used in an HTML/Dynamic Text item where there may be other text
interspersed? For example:
<b>Date:</b> <value-of>row["MYDATE"]</value-of>
I want the date column to be formatted as mm/dd/yy for US and dd/mm/yy for
FR, for example.
If I separate the text and the date data into different grid elements, I can
easily take the MYDATE column and use Format DateTime on the Property Editor
which is locale sensitive. But sometimes layout can be difficult to
control, so I would like to do it within a Dynamic Text item if possible.
I didn't see any standard functions that helped with date formatting using
locale.
-- Dave
Re: Locale date formatting in Dynamic Text [message #133867 is a reply to message #133666] Wed, 22 February 2006 01:28 Go to previous messageGo to next message
> FR, for example.
You could try something like that (which I use to display the current
date according to the reports Locale):
<value-of> java.text.DateFormat.getDateInstance(java.text.DateFormat.SH ORT,reportContext.getLocale()).format(new
java.util.Date())</value-of>
Re: Locale date formatting in Dynamic Text [message #134216 is a reply to message #133867] Wed, 22 February 2006 09:59 Go to previous message
Thanks, Jurgen.
Previous Topic:Table visibility in PDF
Next Topic:Exporting chart images cretaed for a report to have a cached version of it
Current Time: Thu Oct 30 01:23:00 EDT 2025
Powered by FUDForum. Page generated in 0.03250 seconds
