servlet creation failure [message #133611] |
Thu, 18 August 2005 16:07  |
Originally posted by: tonymq.aol.com
When I attempt to create a new servlet in a Dynamic Web Project, the
servlet.java file is not being created. Here is the error:
*** ERROR ***: Thu Aug 18 15:45:01 EDT 2005
org.eclipse.wst.common.frameworks.internal.enablement.nonui. WFTWrappedException
org.eclipse.emf.codegen.jet.JETException[0]:
org.eclipse.core.internal.resources.ResourceException: The project
description file (.project) for .JETEmitters is missing. This file
contains important information about the project. The project will not
function properly until this file is restored.
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:568)
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:767)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:674)
org.eclipse.core.internal.resources.Project.open(Project.jav a:805)
org.eclipse.core.internal.resources.Project.open(Project.jav a:839)
org.eclipse.jst.j2ee.internal.project.WTPJETEmitter.initiali ze(WTPJETEmitter.java:184)
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:592)
org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.generateTemplateSource(NewServletClassOperation.ja va:287)
org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.generateUsingTemplates(NewServletClassOperation.ja va:194)
org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.execute(NewServletClassOperation.java:138)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.doRun(WTPOperation.java:336)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration$1.run(WTPOperation.java:248)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1739)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.run(WTPOperation.java:266)
org.eclipse.jst.j2ee.internal.web.operations.AddServletOpera tion.createServletClass(AddServletOperation.java:122)
org.eclipse.jst.j2ee.internal.web.operations.AddServletOpera tion.execute(AddServletOperation.java:99)
org.eclipse.wst.common.frameworks.internal.ui.RunnableWithPr ogressWrapper.run(RunnableWithProgressWrapper.java:65)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.common.frameworks.internal.ui.WTPWizard.perf ormFinish(WTPWizard.java:241)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: servlet creation failure [message #133700 is a reply to message #133637] |
Thu, 18 August 2005 22:02  |
I have additional information about this. To reiterate the issue, when I
use the Create Servlet wizard, web.xml is updated, but no SERVLET.java
file is generated. At the same time, eclipse generates an ERROR message
(relevant portion pasted below).
It seems that for some reason my
$WORKSPACE/.metadata/.plugins/org.eclipse.core.resources/.pr ojects/.JETEmitters
project (generated by eclipse) has become invalid. I'm not sure of
exactly what is invalid about it, but when I create a new workspace, the
Create Servlet wizard behaves as expected (SERVLET.java is created).
When I renamed $WORKSPACE/.../.JETEmitters, a new
$WORKSPACE/.../.JETEmitters was generated, but creating new servlets still
does not work correctly. I think I can work around this by copying all my
projects to the new workspace and importing them.
Here is the relevant portion of the stacktrace:
*** ERROR ***: Thu Aug 18 21:52:45 EDT 2005
FUDForum. Page generated in 0.24432 seconds
