Home » Modeling » GMF (Graphical Modeling Framework) » connections disappear on reopen
connections disappear on reopen [message #133517] Thu, 07 June 2007 03:37 Go to next message
Originally posted by: hansboerstra.hotmail.com
Just ran the mindmap tutorial Part 2 using Eclipse 3.3.0 with Build id:
I20070601-1539 and GMF 2.0RC2 and everything looks fine untill I save and
reopen the diagram. The RelationShip connections are all gone from the
diagram and the diagram editor immediately gets dirty. The edges element was
there in the XMI after the first save, but if I reopen and save again it is
gone.
Below are my simple domain and diagram files. Does anybody else see this
behaviour too with RC2 when opening the diagram?
Hans
<mindmap:map xmlns:mindmap="http://www.example.org/mindmap">
<rootTopics name="T1"/>
<rootTopics name="T2"/>
<relations label="depends" source="#//@map/@rootTopics.0"
target="#//@map/@rootTopics.1" type="DEPENDENCY"/>
</mindmap:map>
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation"
xmi:id="_yC374BTCEdyokddwUH6mnw" type="Mindmap"
name="default2.mindmap_diagram" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_zU6ykBTCEdyokddwUH6mnw"
type="1001">
<children xmi:type="notation:Node" xmi:id="_zU6ykxTCEdyokddwUH6mnw"
type="4002"/>
<children xmi:type="notation:Node" xmi:id="_zU6ylBTCEdyokddwUH6mnw"
type="5001">
<styles xmi:type="notation:DrawerStyle"
xmi:id="_zU6ylRTCEdyokddwUH6mnw"/>
<styles xmi:type="notation:SortingStyle"
xmi:id="_zU6ylhTCEdyokddwUH6mnw"/>
<styles xmi:type="notation:FilteringStyle"
xmi:id="_zU6ylxTCEdyokddwUH6mnw"/>
</children>
<styles xmi:type="notation:ShapeStyle"
xmi:id="_zU6ykRTCEdyokddwUH6mnw"/>
<element xmi:type="mindmap:Topic"
href="default2.mindmap#//@map/@rootTopics.0"/>
<layoutConstraint xmi:type="notation:Bounds"
xmi:id="_zU6ykhTCEdyokddwUH6mnw" x="280" y="127"/>
</children>
<children xmi:type="notation:Node" xmi:id="_0fnEEBTCEdyokddwUH6mnw"
type="1001">
<children xmi:type="notation:Node" xmi:id="_0fnEExTCEdyokddwUH6mnw"
type="4002"/>
<children xmi:type="notation:Node" xmi:id="_0fnEFBTCEdyokddwUH6mnw"
type="5001">
xmi:id="_0fnEFRTCEdyokddwUH6mnw"/>
xmi:id="_0fnEFhTCEdyokddwUH6mnw"/>
xmi:id="_0fnEFxTCEdyokddwUH6mnw"/>
</children>
xmi:id="_0fnEERTCEdyokddwUH6mnw"/>
href="default2.mindmap#//@map/@rootTopics.1"/>
xmi:id="_0fnEEhTCEdyokddwUH6mnw" x="470" y="181"/>
</children>
<styles xmi:type="notation:DiagramStyle"
xmi:id="_yC374RTCEdyokddwUH6mnw"/>
<element xmi:type="mindmap:Map" href="default2.mindmap#//@map"/>
<edges xmi:type="notation:Edge" xmi:id="_2mxk4BTCEdyokddwUH6mnw"
type="3004" source="_zU6ykBTCEdyokddwUH6mnw"
target="_0fnEEBTCEdyokddwUH6mnw">
<children xmi:type="notation:Node" xmi:id="_2mxk5BTCEdyokddwUH6mnw"
type="4005">
<layoutConstraint xmi:type="notation:Location"
xmi:id="_2mxk5RTCEdyokddwUH6mnw" y="40"/>
</children>
<styles xmi:type="notation:ConnectorStyle"
xmi:id="_2mxk4RTCEdyokddwUH6mnw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_2mxk4hTCEdyokddwUH6mnw"/>
<element xmi:type="mindmap:Relationship"
href="default2.mindmap#//@map/@relations.0"/>
<bendpoints xmi:type="notation:RelativeBendpoints"
xmi:id="_2mxk4xTCEdyokddwUH6mnw" points="[17, 5, -170, -60]$[189, 45,
2, -20]"/>
<sourceAnchor xmi:type="notation:IdentityAnchor"
xmi:id="_2nQGABTCEdyokddwUH6mnw" id="(0.575,0.225)"/>
</edges>
</notation:Diagram>
Re: connections disappear on reopen [message #133530 is a reply to message #133517] Thu, 07 June 2007 03:55 Go to previous message
That was quick! The problem was fixed in the GMF 2.0RC2 build of 20070605
while I previously used the on at 20070601.
Sorry for not staying on the bleeding edge ;-)
Hans
"Hans Boerstra" <hansboerstra@hotmail.com> wrote in message
news:f48cjv$56v$1@build.eclipse.org...
> was there in the XMI after the first save, but if I reopen and save again
> it is gone.
> Hans
> </mindmap:map>
> type="1001">
> type="4002"/>
> type="5001">
> </children>
> </children>
> type="1001">
> type="4002"/>
> type="5001">
> </children>
> </children>
> type="4005">
> </children>
> 2, -20]"/>
> </edges>
> </notation:Diagram>
Previous Topic:Copy element from one to another diagram problems ...
Next Topic:Creation of generator model failed
Current Time: Thu Nov 06 03:18:59 EST 2025
Powered by FUDForum. Page generated in 0.07857 seconds
