Problem showing 2 views [message #133500] |
Mon, 12 January 2004 09:42 |
Originally posted by: angeles_sorano.yahoo.com.ar
I have the following problems:
Depending the execution of an action (a run action from a PopupMenu) I
want to show, throws 2 views (textViewer), some information from 2
different files. But when I want to show the second view I have this
error inside the view
"An error has occurred when creating this view" and the .log is the
following:
!SESSION Jan 12, 2004 10:33:35.950
java.version=1.4.0_01
Command-line arguments: -pdelaunch -dev bin -feature org.eclipse.platform
-data C:\eclipse\runtime-workspace -os win32 -ws win32 -arch x86 -nl en_US
-configuration
file:C:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/C__eclipse_runtime-workspace/platform.cfg
-install file:C:/eclipse/
!ENTRY org.eclipse.ui.workbench 4 2 Jan 12, 2004 10:33:35.990
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
com.ibm.liniotest.views.LiniotestOutView.createPartControl(L iniotestOutView.java:116)
at org.eclipse.ui.internal.PartPane$4.run(PartPane.java:141)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:137)
at org.eclipse.ui.internal.ViewPane.createChildControl(ViewPane .java:211)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :186)
at org.eclipse.ui.internal.ViewPane.createControl(ViewPane.java :190)
org.eclipse.ui.internal.PartTabFolder.createPartTab(PartTabF older.java:252)
org.eclipse.ui.internal.PartTabFolder.createControl(PartTabF older.java:224)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:192)
org.eclipse.ui.internal.PerspectivePresentation.activate(Per spectivePresentation.java:96)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:725)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1799)
org.eclipse.ui.internal.WorkbenchWindow$7.run(WorkbenchWindo w.java:1496)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1483)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1363)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1263)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 223)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1141 )
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:1093)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:870)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
In this line (LiniotestOutView.java:116) I make reference to the file who
is actual selected.
Some advices?
Maria de los Angeles Sorano
mailto: soranom@ar.ibm.com
FUDForum. Page generated in 0.03028 seconds
