Home » Eclipse Projects » eRCP » Question regarding build process
Question regarding build process [message #1011] Thu, 21 May 2009 08:28 Go to next message
Originally posted by: w.roeckelein.begis.com
is org.eclipse.ercp.swt.wm6pro used to build both of "Windows Mobile 5/6 Professional" and "Windows Mobile 5/6 Standard"?
What platform SDKs do you use for the release builds?
WM5 Pocket PC / WM5 Smartphone or WM6 Professional / WM6 Standard?
Has anyone already tried WM 6.1?
Wolfgang
Re: Question regarding build process [message #1301 is a reply to message #1011] Mon, 29 June 2009 14:23 Go to previous message
I believe that the wm6pro project is just a fragment template. It's not
really involved in the build of eSWT.
The built binaries are just copied into the template and then it is
exported. For wm6std, we just do a rename of the plugin and copy the wm6std
binaries into it.
We use the WM6 Pro and Std SDKs for both WM5 and 6. eRCP works just fine on
WM 6.1. We did see a couple minor issues on WM 6.5. I remember one was
around how WM caches shortcut icons.
"Wolfgang R
Re: Question regarding build process [message #563190 is a reply to message #1011] Mon, 29 June 2009 14:23 Go to previous message
binaries into it.
"Wolfgang R
Previous Topic:Re: Java vm running eRCP
Next Topic:Auto update eRCP eUpdates?
Current Time: Fri Jul 18 00:19:47 EDT 2025
Powered by FUDForum. Page generated in 0.03808 seconds
