Home » Eclipse Projects » Equinox » Bundle dependencies
Bundle dependencies [message #132819] Thu, 11 June 2009 11:06 Go to next message
How can I query bundle dependencies?
Is there any bundle that allows me to inquiry bundle dependencies? That
would be great!
Thanks in advance.
Kind regards.
Maurizio
Re: Bundle dependencies [message #132904 is a reply to message #132819] Fri, 12 June 2009 08:33 Go to previous messageGo to next message
Maurizio wrote:
> would be great!
Depends on where, and in what form those bundles are. Do you mean the
installed bundles, a bundle in an update site or p2 repository, a bundle
in source form (perhaps in source code repo), or a binary bundle
floating around on disk or internet somewhere...
For installed bundles, you can use p2 (provisional) API to get
information from the profile (what is currently installed) and then get
the required and provided capabilities (i.e. dependencies) for the
installable unit that represents the bundle. You can do the same for
bundles in a p2 repository (i.e. for things not installed).
If you are interested in a bundle in source form, on just referenced via
a URL then you could use Buckminster, as Buckminster has a variety of
adapters for different types of meta data (e.g. eclipse artifacts in
source and binary form, and maven artifacts). Using Buckminster's API
you can find a ComponentSpecification (CSPEC) that represents the
bundle, and its API can give you a list of dependencies.
Hope that gives you some starting points...
- henrik
Re: Bundle dependencies [message #133037 is a reply to message #132904] Mon, 15 June 2009 02:48 Go to previous messageGo to next message
Dear Henrik,
Thanks very much for your reply.
I'm not requiring bundles in source format. Only installed bundles, at
this moment.
I understand that there are API to inquiry their dependencies, but I was
wondering if I could access their manifest, where the "Require-Bundle"
should be explicit mentioned and so I can download or install any other
bundle that is required.
To make an example, I started downloading a tutorial for using Server-Side
Equinox from javaworld website: com.javaworld.sample.osgi.web.declarative.
The manifest indicated explicitly "Require-Bundle:
org.eclipse.equinox.http.registry", and so I downloaded such bundle before
starting my example. The point is that such bundle seems to require
"org.eclipse.equinox.registry", and I didn't know that until I started my
declarative bundle.
In this case, having the possibility to access the manifest for the bundle
that I downloaded (org.eclipse.equinox.http.registry) whould have done the
job that I was looking for.
Does all this make sense?
Am I following an incorrect approach?
Thanks.
Kind regards.
Maurizio
Re: Bundle dependencies [message #133062 is a reply to message #133037] Mon, 15 June 2009 07:19 Go to previous message
Maurizio wrote:
> Dear Henrik,
> this moment.
> Server-Side Equinox from javaworld website:
> com.javaworld.sample.osgi.web.declarative. The manifest indicated
> explicitly "Require-Bundle: org.eclipse.equinox.http.registry", and so I
> downloaded such bundle before starting my example. The point is that
> such bundle seems to require "org.eclipse.equinox.registry", and I
> didn't know that until I started my declarative bundle.
> bundle that I downloaded (org.eclipse.equinox.http.registry) whould have
> done the job that I was looking for.
I think you should take a closer look at p2. It sounds like you really
want to install everything that is required - and this is exactly what
p2 does for you. It takes everything you have installed into account, as
well as everything in known repositories, solves dependencies and
requirements and executes the installation.
Looking at "required bundle" is not enough, you must also handle package
imports, and in some cases you may also need to search for fragments in
order to find a working configuration. Filters and constraints in
installed features and plugins must also be taken into account. If you
try this on your own, you will find that it quickly snowballs on you and
eventually you will end up reimplementing the capabilities in p2.
If all you want to do is view the list of required bundles for things in
your workspace/IDE, then the Buckminster component view is one way of
displaying them. The Buckminster view works in earlier Eclipse versions
as well. (I am sure there are other ways of finding the dependencies,
but the Buckminster component view is what I usually use for a quick look).
- henrik
Previous Topic:access zip file entry
Next Topic:what to expect from p2 sat solver?
Current Time: Wed Nov 12 23:09:13 EST 2025
Powered by FUDForum. Page generated in 0.03262 seconds
