Home » Eclipse Projects » Remote Application Platform (RAP) » cleanup after non-normal exit (Refresh or close browser instead of return from createUI())
cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #132789] Wed, 13 May 2009 18:42 Go to next message
We have a complicated RAP application, single-sourced SWT/RWT starting
from our original SWT application, running in Tomcat 6.0.18, RAP 1.2 M7,
the basic structure of which I have sketched below.
public int createUI()
UICallBack.activate(getClass().getName());
RWT.getSessionStore().addSessionStoreListener(new
SessionStoreListener() {
public void beforeDestroy(SessionStoreEvent event) {
if not already disposed {
...dispose shells, close db connection, etc....
UICallBack.deactivate(getClass().getName());
...open shells, db connection, etc....
...read and dispatch loop...
RWT.getRequest().getSession().setMaxInactiveInterval(1);
return 0;
Running the app and exiting by returning from createUI() works fine.
The problem I am trying to solve is how to clean up after a non-normal
exit, caused by navigating to a new web page, hitting F5 (refresh),
closing the browser, etc.
From reading the newsgroup and bugzilla, I have learned the following:
1) Implement a SessionStoreListener to do your cleanup. It will get
called before the session is destroyed, including:
a) when a new session is created after F5 (refresh) or re-addressing
the application start page
b) when the session is destroyed after a timeout (e.g. after the
browser is closed)
2) Upon normal exit, set the session timeout to 1 second so that the
session is destroyed quickly and will not have to wait for timeout:
When I exit my application normally, and createUI returns, I have no
problems, but when I exit through the abnormal path (F5, close browser,
session timeout, etc.), I can see a memory leak in Tomcat.
Suspects:
1) Disposing of SWT shells, etc. As far as i can tell I am doing this
correctly, calling the same code in the SessionStoreListener which is
getting called when I exit through the normal path.
2) Disposing of Images. I have seen some discussion in the newsgroup
suggesting that special work may need to be done to dispose of Images.
Again, as far as I can see, I am calling the same cleanup code in the
SessionStoreListener that I call when exiting through the normal path.
As it seems to me that, from my end, I am doing the same cleanup in the
SessionStoreListener as I do in the normal app exit path, I would like
to ask for some clarification as to what is going on the RAP side. Is
there something more I need to call on the RAP side from the
SessionStoreListener, to destroy the current thread, etc? Does the
normal exit path do any cleanup after returning from createUI that it
would not in the case of an abnormal exit through F5 (Refresh) or
session timeout? I don't see anything obvious in the examples in the
RAP source code, such as:
RWTDemo
RWTLifeCycle2_Test$EventProcessingOnSessionRestartEntryPoint
Some relevant postings and bugs:
Disposing:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247704
https://bugs.eclipse.org/bugs/show_bug.cgi?id=253763
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg03996.html
Images:
news://news.eclipse.org:119/497F6B5E.8808.0090.0@kabe-farben .ch
news://news.eclipse.org:119/gl9eoc$uoo$1@build.eclipse.org
news://news.eclipse.org:119/e1ad67dfb09b1ae8721919cda6c56e27 $1@www.eclipse.org
Any ideas are appreciated.
Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #132828 is a reply to message #132789] Thu, 14 May 2009 07:31 Go to previous messageGo to next message
Ryan,
your observations and findings are right and your code should just
run fine.
We just recently fixed two bugs ([1] and [2]) that you most likely
run into. The changes are in CVS HEAD and will go into the RC1 build.
Ideally there wouldn't be two paths and session invalidation code
would always be executed under the same conditions. But we aren't
there yet (see [1] and depedant bugs).
Images in RAP differ from their SWT counterparts in that they are
only made of a string to identify them and their width and height.
In addition they don't have session scope but are held in an
application-scoped map. The links related to images you provided
were about custom ways to deal with images. Naturally, you need free
these resources that you allocated.
HTH
Rüdiger
[1] 275332: Possible memory leak after session invalidate
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275332
[2] 262220: Invalid Thread Access
https://bugs.eclipse.org/bugs/show_bug.cgi?id=262220
[3] 219789: Finalize Display#readAndDispatch
https://bugs.eclipse.org/bugs/show_bug.cgi?id=219789
Ryan Donnelly wrote:
> starting from our original SWT application, running in Tomcat 6.0.18,
> RAP 1.2 M7, the basic structure of which I have sketched below.
> return 0;
> Running the app and exiting by returning from createUI() works fine. The
> problem I am trying to solve is how to clean up after a non-normal exit,
> caused by navigating to a new web page, hitting F5 (refresh), closing
> the browser, etc.
> browser is closed)
> Suspects:
> this correctly, calling the same code in the SessionStoreListener which
> is getting called when I exit through the normal path.
> newsgroup suggesting that special work may need to be done to dispose of
> Images. Again, as far as I can see, I am calling the same cleanup code
> in the SessionStoreListener that I call when exiting through the normal
> path.
> the SessionStoreListener as I do in the normal app exit path, I would
> like to ask for some clarification as to what is going on the RAP side.
> Is there something more I need to call on the RAP side from the
> RWTDemo
> Disposing:
> Images:
> Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #132898 is a reply to message #132828] Thu, 14 May 2009 14:28 Go to previous messageGo to next message
Rüdiger,
Thanks for the information. Unfortunately, I rebuilt my app with the
latest RAP CVS and still have the problem. Are you expecting to have
this and its blocking issues fixed for the 1.2 Galileo release?
I will look into the image resource management. As I say, I think I am
calling the same code in both exit paths, so I don't think that is this
problem in this case, but it could certainly represent a different
memory leak.
Ryan
Rüdiger Herrmann wrote:
> Ryan,
> your observations and findings are right and your code should just run
> fine.
> We just recently fixed two bugs ([1] and [2]) that you most likely run
> Ideally there wouldn't be two paths and session invalidation code would
> always be executed under the same conditions. But we aren't there yet
> Images in RAP differ from their SWT counterparts in that they are only
> application-scoped map. The links related to images you provided were
> about custom ways to deal with images. Naturally, you need free these
> HTH
> Rüdiger
>> UICallBack.deactivate(getClass().getName()); }
>> return 0; }
>> re-addressing the application start page
>> browser is closed)
>> browser, session timeout, etc.), I can see a memory leak in Tomcat.
>> Suspects:
>> which is getting called when I exit through the normal path.
>> of Images. Again, as far as I can see, I am calling the same cleanup
>> code in the SessionStoreListener that I call when exiting through the
>> normal path.
>> in the SessionStoreListener as I do in the normal app exit path, I
>> would like to ask for some clarification as to what is going on the
>> RAP side. Is there something more I need to call on the RAP side from
>> the SessionStoreListener, to destroy the current thread, etc? Does
>> the normal exit path do any cleanup after returning from createUI that
>> it would not in the case of an abnormal exit through F5 (Refresh) or
>> RWTDemo
>> Disposing:
>> Images:
>> Thanks,
>> Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #132954 is a reply to message #132789] Fri, 15 May 2009 02:50 Go to previous messageGo to next message
Hi Ryan,
Although this is not your question, I don't think that this line works:
getClass() would be sth different than during activation as it is called
from within an anonymous class.
Stefan.
> return 0;
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #133048 is a reply to message #132898] Fri, 15 May 2009 07:26 Go to previous messageGo to next message
Ryan,
we will not be able to resolve the "Finalize
Display#readAndDispatch" issue in 1.2. But note that this bug is
mostly about streamlining the internal session-termination handling.
Nonetheless shouldn't there any memory leaks if you execute the same
code in both paths.
Could you come up with a mini-plug-in or a snippet that causes the
memory leak? Preferably open a bugzilla to attach it.
Rüdiger
> Rüdiger,
> the latest RAP CVS and still have the problem. Are you expecting to
> have this and its blocking issues fixed for the 1.2 Galileo release?
> am calling the same code in both exit paths, so I don't think that is
> this problem in this case, but it could certainly represent a different
> memory leak.
> Ryan
>> Ryan,
>> fine.
>> HTH
>> Rüdiger
>>> Hi,
>>> return 0; }
>>> non-normal exit, caused by navigating to a new web page, hitting F5
>>> (refresh), closing the browser, etc.
>>> browser is closed)
>>> Suspects:
>>> normal path.
>>> from the SessionStoreListener, to destroy the current thread, etc?
>>> Does the normal exit path do any cleanup after returning from
>>> createUI that it would not in the case of an abnormal exit through F5
>>> (Refresh) or session timeout? I don't see anything obvious in the
>>> examples in the RAP source code, such as:
>>> RWTDemo
>>> Disposing:
>>> Images:
>>> Thanks,
>>> Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #133061 is a reply to message #132954] Fri, 15 May 2009 09:48 Go to previous messageGo to next message
Stefan,
You're right, that was an oversight. I've fixed it to:
final String httpSessionId = RWT.getSessionStore().getId();
UICallBack.activate(httpSessionId);
final String httpSessionId = event.getSessionStore().getId();
UICallBack.deactivate(httpSessionId);
return 0;
I have retested and this has not fixed the memory leak, but thank you
for catching that.
-Ryan
Stefan Roeck wrote:
> Hi Ryan,
> Stefan.
>> return 0; }
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #133074 is a reply to message #133048] Fri, 15 May 2009 09:50 Go to previous messageGo to next message
Rüdiger,
Thank you, I will re-examine my code with this in mind and post a bug
or message depending upon my conclusions.
-Ryan
> Ryan,
> we will not be able to resolve the "Finalize Display#readAndDispatch"
> issue in 1.2. But note that this bug is mostly about streamlining the
> code in both paths.
> Cheers,
> Rüdiger
>> Rüdiger,
>> I am calling the same code in both exit paths, so I don't think that
>> is this problem in this case, but it could certainly represent a
>> different memory leak.
>> Thanks,
>> Ryan
>>> Ryan,
>>> run fine.
>>> HTH
>>> Rüdiger
>>>> Hi,
>>>> 6.0.18, RAP 1.2 M7, the basic structure of which I have sketched below.
>>>> return 0; }
>>>> browser is closed)
>>>> Suspects:
>>>> doing this correctly, calling the same code in the
>>>> SessionStoreListener which is getting called when I exit through the
>>>> normal path.
>>>> dispose of Images. Again, as far as I can see, I am calling the same
>>>> cleanup code in the SessionStoreListener that I call when exiting
>>>> F5 (Refresh) or session timeout? I don't see anything obvious in
>>>> the examples in the RAP source code, such as:
>>>> RWTDemo
>>>> Disposing:
>>>> Images:
>>>> Thanks,
>>>> Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #133111 is a reply to message #133074] Fri, 15 May 2009 16:27 Go to previous messageGo to next message
Rüdiger,
I am noticing an equinox error, showing up in Tomcat's
localhost.XXX.log, same as in the following resolved bug:
#216094 Frequently java.lang.IllegalStateException: The session store is
about to be unbound
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216094
When exiting through the normal path (createUI returns), when my 1s
timeout expires and the SessionStoreListener is entered:
May 15, 2009 5:02:14 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet equinoxbridgeservlet threw exception
java.lang.IllegalStateException: The session store is about to be unbound.
org.eclipse.rwt.internal.service.SessionStoreImpl.checkAbout Unbound(SessionStoreImpl.java:251)
org.eclipse.rwt.internal.service.SessionStoreImpl.removeSess ionStoreListener(SessionStoreImpl.java:125)
org.eclipse.rwt.internal.lifecycle.UICallBackManager.blockCa llBackRequest(UICallBackManager.java:214)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. service(UICallBackServiceHandler.java:418)
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:99)
at org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
org.eclipse.rap.ui.internal.servlet.RequestHandler.service(R equestHandler.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.servletbridge.BridgeServlet.service(Brid geServlet.java:120)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:286)
org.apache.coyote.http11.Http11AprProcessor.process(Http11Ap rProcessor.java:857)
org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionH andler.process(Http11AprProtocol.java:565)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoin t.java:1509)
at java.lang.Thread.run(Unknown Source)
and, when exiting through the abnormal path, in this case F5 (so the
session is re-opened), I assume also when the SessionStoreListener is
entered, I get either the above error or the similar:
May 15, 2009 5:14:55 PM org.apache.catalina.core.StandardWrapperValve invoke
java.lang.IllegalStateException: The session store has been unbound.
org.eclipse.rwt.internal.service.SessionStoreImpl.checkBound (SessionStoreImpl.java:244)
org.eclipse.rwt.internal.service.SessionStoreImpl.removeSess ionStoreListener(SessionStoreImpl.java:126)
Does this reveal a problem?
Ryan
> Rüdiger,
> bug or message depending upon my conclusions.
> -Ryan
>> Ryan,
>> code in both paths.
>> Cheers,
>> Rüdiger
>>> Rüdiger,
>>> think I am calling the same code in both exit paths, so I don't think
>>> that is this problem in this case, but it could certainly represent a
>>> Thanks,
>>> Ryan
>>>> Ryan,
>>>> run fine.
>>>> HTH
>>>> Rüdiger
>>>>> Hi,
>>>>> below.
>>>>> return 0; }
>>>>> fine. The problem I am trying to solve is how to clean up after a
>>>>> following:
>>>>> get called before the session is destroyed, including:
>>>>> the browser is closed)
>>>>> the session is destroyed quickly and will not have to wait for
>>>>> timeout:
>>>>> no problems, but when I exit through the abnormal path (F5, close
>>>>> Suspects:
>>>>> the normal path.
>>>>> same cleanup code in the SessionStoreListener that I call when
>>>>> cleanup in the SessionStoreListener as I do in the normal app exit
>>>>> path, I would like to ask for some clarification as to what is
>>>>> going on the RAP side. Is there something more I need to call on
>>>>> the RAP side from the SessionStoreListener, to destroy the current
>>>>> thread, etc? Does the normal exit path do any cleanup after
>>>>> returning from createUI that it would not in the case of an
>>>>> abnormal exit through F5 (Refresh) or session timeout? I don't see
>>>>> anything obvious in the examples in the RAP source code, such as:
>>>>> RWTDemo
>>>>> Disposing:
>>>>> Images:
>>>>> Thanks,
>>>>> Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #133219 is a reply to message #133111] Mon, 18 May 2009 07:30 Go to previous messageGo to next message
Ryan,
these exceptions shouldn't happen and likely prevent proper clean
up. Would you mind filing a bugzilla? I think the one you mentioned
dates back to "pre-readAndDispatch" times - a different code base
and thus presumably a different error source.
Rüdiger
> Rüdiger,
> about to be unbound
> invoke
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> invoke
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ryan
>> Rüdiger,
>> -Ryan
>>> Ryan,
>>> code in both paths.
>>> Cheers,
>>> Rüdiger
>>>> Rüdiger,
>>>> with the latest RAP CVS and still have the problem. Are you
>>>> expecting to have this and its blocking issues fixed for the 1.2
>>>> Galileo release?
>>>> think that is this problem in this case, but it could certainly
>>>> represent a different memory leak.
>>>> Thanks,
>>>> Ryan
>>>>> Ryan,
>>>>> run fine.
>>>>> free these resources that you allocated.
>>>>> HTH
>>>>> Rüdiger
>>>>>> Hi,
>>>>>> below.
>>>>>> return 0; }
>>>>>> F5 (refresh), closing the browser, etc.
>>>>>> following:
>>>>>> timeout:
>>>>>> Suspects:
>>>>>> the normal path.
>>>>>> see anything obvious in the examples in the RAP source code, such as:
>>>>>> RWTDemo
>>>>>> Disposing:
>>>>>> Images:
>>>>>> Thanks,
>>>>>> Ryan
Re: cleanup after non-normal exit (Refresh or close browser instead of return from createUI()) [message #133561 is a reply to message #133219] Tue, 19 May 2009 11:38 Go to previous message
Filed as:
#276930 Exception when SessionStoreListener is called:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=276930.
> Ryan,
> these exceptions shouldn't happen and likely prevent proper clean up.
> Would you mind filing a bugzilla? I think the one you mentioned dates
> back to "pre-readAndDispatch" times - a different code base and thus
> Cheers,
> Rüdiger
>> Rüdiger,
>> 1s timeout expires and the SessionStoreListener is entered:
>> invoke
>> exception
>> unbound.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> invoke
>> exception
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Ryan
>>> Rüdiger,
>>> -Ryan
>>>> Ryan,
>>>> code in both paths.
>>>> Cheers,
>>>> Rüdiger
>>>>> Rüdiger,
>>>>> Galileo release?
>>>>> Thanks,
>>>>> Ryan
>>>>>> Ryan,
>>>>>> run fine.
>>>>>> HTH
>>>>>> Rüdiger
>>>>>>> Hi,
>>>>>>> below.
>>>>>>> return 0; }
>>>>>>> following:
>>>>>>> timeout:
>>>>>>> Suspects:
>>>>>>> the normal path.
>>>>>>> exit path, I would like to ask for some clarification as to what
>>>>>>> is going on the RAP side. Is there something more I need to call
>>>>>>> on the RAP side from the SessionStoreListener, to destroy the
>>>>>>> current thread, etc? Does the normal exit path do any cleanup
>>>>>>> after returning from createUI that it would not in the case of an
>>>>>>> as:
>>>>>>> RWTDemo
>>>>>>> Disposing:
>>>>>>> Images:
>>>>>>> Thanks,
>>>>>>> Ryan
Previous Topic:Problems with trees
Next Topic:org is not defined
Current Time: Mon Jul 21 21:35:11 EDT 2025
Powered by FUDForum. Page generated in 0.05317 seconds
