Home » Archived » BIRT » XML DataSource 2 or more DataSets possible?
XML DataSource 2 or more DataSets possible? [message #132649] Mon, 20 February 2006 04:04
Originally posted by: uwe.brylla.arcsolutions.de
Hi.
I have a xml-sourcefile like this:
<imanXML:body >
<imanXML:contents>
<imanXML:item xid="i253" item_id="Test-100000_000_0" type="Item"
name="Test-100000_000_0">
<imanXML:attr_desc>Sttest-100000_000_0desc</imanXML:attr_desc >
<imanXML:form xid="f254" type="Master" name="Sttest-100000_000_0"
relation="IMAN_master_form">
<imanXML:attr name="HSTK" type="string">D2396</imanXML:attr>
<imanXML:attr name="Sachnr" type="string">Sttest-100000.000.0</
imanXML:attr>
<imanXML:attr name="DokArt" type="string" />
</imanXML:form>
<imanXML:item_revision xid="ir255" rev_id="001" type="Revision"
name="Test-100000_000_0" item_id="Test-100000_000_0">
<imanXML:attr_desc>Test-100000_000_0</imanXML:attr_desc>
<imanXML:form xid="f256" type="Revision Master" name="Sttest-
100000_000_0/001" relation="IMAN_master_form_rev">
<imanXML:attr name="Benenn1"
type="string">Pinocchio</imanXML:attr>
<imanXML:attr name="Benenn2" type="string">Peppino</imanXML:attr>
<imanXML:attr name="CADKenn" type="string" />
<imanXML:attr name="EntwStufe" type="string" />
<imanXML:attr name="Ers_Durch"
type="string">E100000_000_1</imanXML:
attr>
<imanXML:attr name="Ers_Fuer" type="string">E100000_000_2</imanXML:
attr>
<imanXML:attr name="Gewicht" type="string" />
<imanXML:attr name="GroessAb" type="string" />
</imanXML:item_revision >
</imanXML:contents>
<imanXML:bom>
<imanXML:bom_line xid="bl263" item_id="Test-100000_000_0" rev_id="001"
view="view" precise="n" children="y">
<imanXML:bom_attr name="bl_sequence_no" type="string" />
<imanXML:bom_attr name="bl_abs_xform_matrix" type="string">1 0 0 0
0 1
0 0 0 0 1 0 0 0 0 1</imanXML:bom_attr>
<imanXML:bom_attr name="bl_quantity" type="string" />
<imanXML:bom_attr name="bl_variant_condition" type="string" />
<imanXML:bom_line xid="bl264" item_id="Sttest-100000_001_0"
rev_id="001"
quantity="1" precise="n" children="n">
<imanXML:bom_attr name="bl_sequence_no" type="string">001</imanXML:
bom_attr>
-171.
42843610484 0 1 0 -105.8177888 1</imanXML:bom_attr>
type="string">1</imanXML:bom_attr>
</imanXML:bom_line>
</imanXML:bom>
</imanXML:body >
for my reportdesign in birt i have to build two datasets (one for
imanXML:content and one for imanXML:bom) because only with this way i can
read the bom_lines sequentiell.
But in a table i can set only one dataset. so in the report is showing
only kind of data (content or bom) to the same time. I need both!
Is it possible to set more than one datasets to a table or grid or...?
Previous Topic:Dynamic parameter - List Box - RCP Designer
Next Topic:Pagination please help
Current Time: Sun Nov 09 01:31:04 EST 2025
Powered by FUDForum. Page generated in 0.03607 seconds
