Home » Eclipse Projects » GEF » Connections in GEF with EMF: ClassCastException
Connections in GEF with EMF: ClassCastException [message #132633] Tue, 18 May 2004 05:28 Go to next message
Originally posted by: dev.philippschill.de
Hi!
I implemented a model with EMF.
No I want to paint the model with gef.
There are Actions which have as children one or more Forwards.
You can navigate from the Actions to the Forwards an vice-versa.
I implemented for each "node" an AbstractGraphicalEditPart and a
AbstractGraphicalConnection.
In the ActionEditPart I implemented the method:
protected List getModelSourceConnections() {
return getAction().getForwards();
and in the ForwardEditPart the method:
protected List getModelTargetConnections() {
List l=new LinkedList();
l.add(getForward().getAction());
return l;
as described in the ibm redbook...
Now i get each time a ClassCastException when the second method is called.
Where is the problem
phil
Re: Connections in GEF with EMF: ClassCastException [message #132711 is a reply to message #132633] Tue, 18 May 2004 10:46 Go to previous messageGo to next message
Got a stack trace?
"Philipp Schill" <dev@philippschill.de> wrote in message
news:c8cklt$l9e$1@eclipse.org...
> Hi!
> return l;
> phil
Re: Connections in GEF with EMF: ClassCastException [message #132750 is a reply to message #132711] Tue, 18 May 2004 11:54 Go to previous message
!SESSION Mai 18, 2004 17:52:02.250
java.version=1.4.2_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.core.runtime 4 2 Mai 18, 2004 17:52:02.250
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.ClassCastException
org.eclipse.gef.editparts.AbstractGraphicalEditPart.createOr FindConnection(AbstractGraphicalEditPart.java:285)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshT argetConnections(AbstractGraphicalEditPart.java:640)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:540)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:221)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:196)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:184)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:742)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:694)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:538)
org.eclipse.gef.editparts.ScalableRootEditPart.setContents(S calableRootEditPart.java:349)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:557)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:566)
de.strutsbox.strutsplugin.visualizer.VisualizerEditor.initia lizeGraphicalViewer(VisualizerEditor.java:41)
org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalView er(GraphicalEditor.java:114)
org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:124)
at org.eclipse.ui.internal.PartPane$1.run(PartPane.java:94)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:610)
at org.eclipse.core.runtime.Platform.run(Platform.java:521)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:90)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :154)
at org.eclipse.ui.internal.EditorWorkbook.showPart(EditorWorkbo ok.java:470)
at org.eclipse.ui.internal.EditorWorkbook.add(EditorWorkbook.ja va:292)
at org.eclipse.ui.internal.EditorArea.addEditor(EditorArea.java :56)
org.eclipse.ui.internal.EditorPresentation.openEditor(Editor Presentation.java:225)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.ja va:550)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:539)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:635)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:438)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:426)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2129)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2072)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2059)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2054)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:265)
org.eclipse.ui.internal.ide.EditorAreaDropAdapter.openNonExt ernalEditor(EditorAreaDropAdapter.java:135)
org.eclipse.ui.internal.ide.EditorAreaDropAdapter.asyncDrop( EditorAreaDropAdapter.java:109)
org.eclipse.ui.internal.ide.EditorAreaDropAdapter.access$0(E ditorAreaDropAdapter.java:78)
org.eclipse.ui.internal.ide.EditorAreaDropAdapter$1.run(Edit orAreaDropAdapter.java:72)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2555)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2260)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1562)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1536)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:257)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Pratik Shah schrieb:
> Got a stack trace?
>>Hi!
>> return l;
>>phil
Previous Topic:How to change labelText in Logic ??
Next Topic:Rare bug under eclipse 2.1
Current Time: Sat Jul 12 07:43:20 EDT 2025
Powered by FUDForum. Page generated in 1.26546 seconds
